commit 354e379684fcc70ab8d5450b4d57bd92b5294dfd upstream.
Function 'mtk_hsdma_start_transfer' uses 'tx_desc' pointer which can be
dereferenced before it is initializated. Initializate pointer before
avoiding the problem.
Fixes: 0853c7a53eb3 ("staging: mt7621-dma: ralink: add rt2880 dma engine")
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Sergio Paracuellos <sergio.paracuellos@gmail.com>
Cc: stable <stable@vger.kernel.org>
Fixes checkpatch check: PARENTHESIS_ALIGNMENT
Signed-off-by: Christian Lütke-Stetzkamp <christian@lkamp.de>
Reviewed-by: NeilBrown <neil@brown.name>
Fixes checkpatch warning: BRACES
Fixes checkpatch error: CODE_IDENT
Fixes checkpatch error: ASSIGN_IN_IF by adding an inner if in the else
path, this also avoids calling vchan_find_desc when not needed.
Fixes checkpatch error: OPEN_BRACE
Fixes checkpatch error: SPACING
Fixes checkpatch error: POINTER_LOCATION
Signed-off-by: John Crispin <blogic@openwrt.org>
Signed-off-by: NeilBrown <neil@brown.name>
