path: root/drivers/staging/pohmelfs/Kconfig
2012-02-08staging: pohmelfs: remove drivers/staging/pohmelfsstaging-3.3-rc3Evgeniy Polyakov
New pohmelfs is coming, and it is time to remove deadly old design https://lkml.org/lkml/2012/2/8/293 Signed-off-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-10-17staging: drop unused Kconfig symbolsPaul Bolle
Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-04-03Staging: pohmelfs: fix kconfig dependenciesRandy Dunlap
pohmelfs wants to use CONNECTOR, so it selects CONNECTOR, but when CONFIG_NET is not enabled, connector.c will not build, since select does not follow the dependency chain. Selecting NET is not a good idea, since that would build lots of code that someone seemingly didn't want to build/store and kconfig shouldn't do that behind someone's back. pohmelfs should depend on NET since it uses network interfaces. pohmelfs also uses CRYTPO and selects 2 cipher symbols, but it should also select the top-level CRYPTO symbol since kconfig dependency chains are not followed. (found by inspection) This allows the POHMELFS_CRYPTO option to depend only on POHMELFS and makes the kconfig menu align properly. Also fix minor typos & line lengths in kconfig help text. Drop CONFIG_* in kconfig symbols in Kconfig file. connector.c:(.text+0x46003): undefined reference to `kfree_skb' connector.c:(.text+0x460a6): undefined reference to `kfree_skb' connector.c:(.text+0x4612b): undefined reference to `kfree_skb' (.text+0x4624f): undefined reference to `netlink_has_listeners' (.text+0x4629b): undefined reference to `__alloc_skb' (.text+0x462ea): undefined reference to `kfree_skb' (.text+0x46308): undefined reference to `skb_put' (.text+0x46385): undefined reference to `netlink_broadcast' (.text+0x7b574): undefined reference to `sock_release' (.text+0x7b8dd): undefined reference to `sock_create' (.text+0x7b984): undefined reference to `kernel_connect' (.text+0x7ba4c): undefined reference to `sock_release' net.c:(.text+0x7bda4): undefined reference to `kernel_recvmsg' (.text+0x7ef42): undefined reference to `kernel_sendmsg' (.text+0x7f057): undefined reference to `kernel_sendpage' (.text+0x7f1e8): undefined reference to `kernel_sendmsg' connector.c:(.devinit.text+0x5b): undefined reference to `init_net' connector.c:(.devinit.text+0x60): undefined reference to `netlink_kernel_create' connector.c:(.devinit.text+0xc9): undefined reference to `netlink_kernel_release' connector.c:(.devexit.text+0x2c): undefined reference to `netlink_kernel_release' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-04-03Staging: pohmelfs should depend on CRYPTOAlexander Beregalov
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Cc: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-04-03Staging: pohmelfs: select crypto modules from the config.Evgeniy Polyakov
Signed-off-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-04-03Staging: pohmelfs: kconfig/makefile and vfs changes.Evgeniy Polyakov
This patch adds Kconfig and Makefile entries and exports to VFS functions to be used by POHMELFS. Signed-off-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
