path: root/drivers/staging/rt2860/common/cmm_sync.c
2011-04-08staging: rt2860sta and rt2870sta: Remove drivers replaced in net/wirelessLarry Finger
The staging driver rt2860sta is replaced by mainline driver rt2800pci, and rt2870sta is replaced by rt2800usb. As a result, the staging drivers are deleted. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> ---
2009-12-11Staging: rt28x0: remove typedefs (part three)Bartlomiej Zolnierkiewicz
Remove misc typedefs. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11Staging: rt28x0: remove typedefs (part one)Bartlomiej Zolnierkiewicz
Remove typedefs from rtmp_type.h. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11Staging: rt28x0: fix comments in common/*.c filesBartlomiej Zolnierkiewicz
2009-12-11Staging: rt28x0: run common/*.c files through LindentBartlomiej Zolnierkiewicz
2009-12-11Staging: rt2860: add RT3090 chipset supportBartlomiej Zolnierkiewicz
Add support for RT3090 chipset (based on 2009_0612_RT3090_Linux_STA_V2.1.0.0_DPO). Tested with RT2860. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11Staging: rt28x0: updates from vendor's V2.1.0.0 driversBartlomiej Zolnierkiewicz
Port changes from: * 2009_0420_RT2860_Linux_STA_V2.1.0.0 * 2009_0302_RT2870_Linux_STA_v2.1.0.0 * 2009_0525_RT3070_Linux_STA_v2.1.1.0 to in-kernel drivers. From the RT2860 driver release note: [2.1.0.0] 1. New generation schema for multiple OS porting 2. Fixed Ad-hoc ping failed in noisy environment. (Probe Response has too many retry packet then cause "not enough space in MgmtRing") 3. Fixed WPA(2)PSK issue when group cipher of AP is WEP40 or WEP104. 4. Modified iwpriv ra0 get_site_survey: In scan list result: Security shows "NONE" when AP is OPEN/NONE, shows "WEP" when AP is OPEN/WEP or SHARED/WEP, shows "WPAPSK(WPA2PSK)/TKIP(AES)" when AP is WPAPSK(WPA2PSK)/TKIP(AES) shows "WPA(WPA2)/TKIP(AES)" when AP is WPA(WPA2)/TKIP(AES) 5. Support kthread. 6. Add New A band channel list region 15 contains the whole channels in the A band region 4 and the new CE channel 167,169,171,173 7. Add New IEEE802.11r functionality. 8. Fixed WPA2-Enterprise failed when AP reboot or turn off then turn on. 9. Fixed STA cannot connect to 11B only AP when the setting of is PHY_11GN. From the RT2870 driver release note: [V2.1.0.0] 1. New generation schema for multiple OS porting. 2. Fixed Ad-hoc ping failed in noisy environment. (Probe Response has too many retry packet then cause "not enough space in MgmtRing"). 3. Fixed WPS failed with D-Link DIR-628 in 5GHz. 4. Change FastRoaming in DAT file to AutoRoaming. 5. Support kthread. 6. Add New A band channel list region 15 contains the whole channels in the A band region and the new CE channel 167,169,171,173. 7. New IEEE802.11r functionality. From the RT3070 driver release note: Version V2.1.1.0 1. Linux kernel 2.6.29 support. 2. Fix eFuse write from BIN file bug. Version 2.1.0.0 1. New generation schema for multiple OS porting 2. Fixed Ad-hoc ping failed in noisy environment. 3. Modified iwpriv ra0 get_site_survey: 4. Change FastRoaming in DAT file to AutoRoaming. 5. Support kthread. 6. New IEEE802.11r functionality. Tested with RT2860 and RT3070 chipsets. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-19Staging: rt2860: prepare for rt28[67]0/common/*.[ch] mergeBartlomiej Zolnierkiewicz
2009-06-19Staging: rt2860: remove dead CONFIG_AP_SUPPORT codeBartlomiej Zolnierkiewicz
Then remove no longer needed IF_DEV_CONFIG_OPMODE_ON_[AP,STA]() macros. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-19Staging: rt2860: remove DOT11_N_SUPPORT ifdefsBartlomiej Zolnierkiewicz
2009-06-19Staging: rt2860: remove CONFIG_STA_SUPPORT ifdefsBartlomiej Zolnierkiewicz
2009-06-19Staging: rt2860: remove dead RT_BIG_ENDIAN codeBartlomiej Zolnierkiewicz
2009-06-19Staging: rt2860: remove dead DOT11N_DRAFT3 codeBartlomiej Zolnierkiewicz
2009-06-19Staging: rt2860: remove dead CARRIER_DETECTION_SUPPORT codeBartlomiej Zolnierkiewicz
2009-06-19Staging: rt2860: remove dead RALINK_ATE codeBartlomiej Zolnierkiewicz
2009-04-03Staging: rt2860: Ported v1.7.1.1 changes into v1.8.0.0, becoming v1.8.1.1Adam McDaniel
Staging: rt2860: Ported v1.7.1.1 changes into v1.8.0.0, becoming v1.8.1.1 When RaLink released rt2860 v1.7.0.0, it lacked proper support for both WEP and WPA/WPA2 encryption. Either was possible, but the module had to be compiled to support only one or the other, never both. Since the EeePC was the most common device with this hardware (and these users were complaining to RaLink that WPA/WPA2 encryption didn't work) RaLink released a fix as an "eeepc-specific" version of this driver, v1.7.1.1 Unfortunately, when v1.8.0.0 was released, this WPA/WPA2 fix was never included. What complicates things further is that RaLink has no interest in continuing work on this Linux driver for their hardware. This commit ports the changes introduced in v1.7.1.1 into the v1.8.0.0 release, upgrading the kernel's module to v1.8.1.1 Signed-off-by: Adam McDaniel <adam@array.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-06Staging: add rt2860 wireless driverGreg Kroah-Hartman
This is the Ralink RT2860 driver from the company that does horrible things like reading a config file from /etc. However, the driver that is currently under development from the wireless development community is not working at all yet, so distros and users are using this version instead (quite common hardware on a lot of netbook machines). So here is this driver, for now, until the wireless developers get a "clean" version into the main tree, or until this version is cleaned up sufficiently to move out of the staging tree. Ported to the Linux build system and cleaned up a bit already by me. Cc: Linux wireless <linux-wireless@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
