unused variables are removed. These variables were only assigned some
values and after that they were never being used. So they are safe to
be removed , and it has been build tested.
I left a call to r8712_read32(padapter, TCR) and
r8712_read8(padapter, SDIO_HCPWM) .
r8712_read32() and r8712_read8() is ultimately calling usb_read32()
and usb_read8() respectively. and they are again calling
r8712_usbctrl_vendorreq().
this r8712_usbctrl_vendorreq() is communicating through the usb bus
and is sending and receiving the control msg.
Signed-off-by: Sudip Mukherjee <sudip@vectorindia.org>
Removed unnecessary else after return/break to solve
checkpatch.pl warning
Signed-off-by: Nitin Kuppelur <nitinkuppelur@gmail.com>
This patch remove variables that are initialized with a constant,
are never updated, and are only used as parameter of return.
Return the constant instead of using a variable.
Verified by compilation only.
The coccinelle script that find and fixes this issue is:
// <smpl>
type T;
constant C;
identifier ret;
- T ret = C;
... when != ret
- return ret;
+ return C;
// </smpl>
Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com>
These set off a static checker warning about "warn: add curly braces?",
but actually the code it correct, it's just the indenting which is
wrong.
In r8712_generate_ie(), HT check is no longer done.
Removed r8712_add_ht_addt_info().
Changes to defragmentation handling, and queue selection.
Get TSSI command.
Added an Ad-Hoc check to is_desired_network()
r8712_ind_disconnect() now checks for Linked state.
r8712_xmit_bh() now schedules an xmit tasklet.
Signed-off-by: Ali Bahar <ali@internetDog.org>
This code is for a completely new version of the Realtek 8192 USB devices
such as the D-Link DWA-130. The Realtek code, which was originally for
Linux, Windows XP and Windows CE, has been stripped of all code not needed
for Linux. In addition, only one additional configuration variable, which
enables AP mode, remains.
Signed-off-by: Florian Schilhabel <florian.c.schilhabel@googlemail.com>
Tested-by: Frederic Leroy <fredo@starox.org>
