This patch removes all occurrences of unnecessary cast on the
argument to kfree, all over in rtl8712.
There is no need of the cast on the argument to kfree.
Greped to find occurrences.
Signed-off-by: Tapasweni Pathak <tapaswenipathak@gmail.com>
This patch delete explicit comparison to false and NULL in files of
rtl8712.
This patch fixes checkpatch.pl warning in files of rtl8712
WARNING : line over 80 characters
list_insert_tail is just an inline wrapper around list_add_tail. This
patch removes the wrapper and directly uses list_add_tail.
Signed-off-by: James A Shackleford <shack@linux.com>
_init_listhead is just an inline wrapper around INIT_LIST_HEAD. This
patch removes the wrapper and directly uses INIT_LIST_HEAD instead.
As suggested by Andy Shevchenko on driverdev-devel, replace
v = ... sizeof(struct type_of_v) -> sizeof(*v)
Based on a cocci patch along the lines of
type T;
expression E;
identifier V;
T *V;
- V = kmalloc(sizeof(T), E);
+ V = kmalloc(sizeof(*V), E);
type T;
expression E;
identifier V;
T *V;
- V = kzalloc(sizeof(T), E);
+ V = kzalloc(sizeof(*V), E);
Signed-off-by: Vitaly Osipov <vitaly.osipov@gmail.com>
This patch removes all usage of _malloc() and the function itself. Most
uses are straightforward replacements by kmalloc(..., GFP_ATOMIC),
because this was the definition of _malloc(). In a few places it
was possible to use kzalloc() or memdup_user.
A further improvement would be to replace GFP_ATOMIC with GFP_KERNEL
where possible.
Verified by compilation only.
Initial replacement done by running a Coccinelle script along the lines
of:
type T;
expression E;
identifier V;
- V = (T) _malloc(E);
+ V = kmalloc(E, GFP_ATOMIC);
expression E, E1;
- E1 = _malloc(E);
+ E1 = kmalloc(E, GFP_ATOMIC);
I am preparing to convert this driver from semaphore to mutex locking,
The first step has been to eliminate a number of semaphores that were
initialized but never used, and one whose only use was a single "up"
after initialization. A total of 9 semaphores were removed in this process.
One other change was to remove some inline semaphore routines that were
unused.
In addition, several cases had the following structure:
down()
if () {
up()
The locking overhead was reduced by moving the up/down inside the if
block.
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com>
This code is for a completely new version of the Realtek 8192 USB devices
such as the D-Link DWA-130. The Realtek code, which was originally for
Linux, Windows XP and Windows CE, has been stripped of all code not needed
for Linux. In addition, only one additional configuration variable, which
enables AP mode, remains.
Signed-off-by: Florian Schilhabel <florian.c.schilhabel@googlemail.com>
Tested-by: Frederic Leroy <fredo@starox.org>
