del_timer_sync() is not to be called in the interrupt context unless
the timer is irqsafe. but most of the functions where commits
6501c8e7d86cca5f and 382d020f4459cd77 touched were called in interrupt
context. And as a result the WARN_ON was getting triggered. Changed
to del_timer() in places which were called from interrupt.
Fixes: 382d020f4459cd77 ("Staging: rtl8712: Eliminate use of _cancel_timer"
Fixes: 6501c8e7d86cca5f ("Staging: rtl8712: Eliminate use of _cancel_timer_ex")
Fixes: https://bugzilla.kernel.org/show_bug.cgi?id=97711
Reported-by: Arek Rusniak <arek.rusi@gmail.com>
Tested-by: Arek Rusniak <arek.rusi@gmail.com>
Signed-off-by: Sudip Mukherjee <sudip@vectorindia.org>
Use timer API function del_timer_sync instead of driver
specific function _cancel_timer_ex as besides deactivating
a timer, it ensures that the timer is stopped on all
CPUs before the driver exists. Also, definition of function
_cancel_timer_ex is removed as it is no longer needed after
this change.
This is done using Coccinelle and semantic patch used for
this is as follows:
@@ expression x; @@
- _cancel_timer_ex (&x);
+ del_timer_sync (&x);
Signed-off-by: Vaishali Thakkar <vthakkar1994@gmail.com>
This patch introduces the use of API function setup_timer
instead of driver specific function _init_timer as it is
the preferred and standard way to setup and set the timer.
To be compatible with the change, argument types of
referenced functions are changed. Also, definition of
function _init_timer is removed as it is no longer needed
after this change.
this is as follows:
@@ expression x, y; identifier a, b;@@
- _init_timer (&x, y, a, b);
+ setup_timer (&x, a, (unsigned long)b);
unused variables are removed. These variables were only assigned some
values and after that they were never being used. So they are safe to
be removed , and it has been build tested.
I left a call to r8712_read32(padapter, TCR) and
r8712_read8(padapter, SDIO_HCPWM) .
r8712_read32() and r8712_read8() is ultimately calling usb_read32()
and usb_read8() respectively. and they are again calling
r8712_usbctrl_vendorreq().
this r8712_usbctrl_vendorreq() is communicating through the usb bus
and is sending and receiving the control msg.
This patch fixes checkpatch.pl warning in hal_init.c file
WARNING : Missing a blank line after declarations
Signed-off-by: Tapasweni Pathak <tapaswenipathak@gmail.com>
The inline function _set_workitem() simply wraps schedule_work(). Removed.
Signed-off-by: James A Shackleford <shack@linux.com>
The inline function _init_workitem() is just a wrapper around INIT_WORK().
Oddly, this wrapper accepts 3 parameters while INIT_WORK() only accepts 2.
The third parameter is unused.
I am preparing to convert this driver from semaphore to mutex locking,
The first step has been to eliminate a number of semaphores that were
initialized but never used, and one whose only use was a single "up"
after initialization. A total of 9 semaphores were removed in this process.
One other change was to remove some inline semaphore routines that were
unused.
In addition, several cases had the following structure:
down()
if () {
up()
The locking overhead was reduced by moving the up/down inside the if
block.
The patch below removes an extra "l" in the word.
This code is for a completely new version of the Realtek 8192 USB devices
such as the D-Link DWA-130. The Realtek code, which was originally for
Linux, Windows XP and Windows CE, has been stripped of all code not needed
for Linux. In addition, only one additional configuration variable, which
enables AP mode, remains.
Signed-off-by: Florian Schilhabel <florian.c.schilhabel@googlemail.com>
Tested-by: Frederic Leroy <fredo@starox.org>
