Support for this hardware is now included in a "real" driver in the
kernel, so it is safe to remove the staging driver now.
Cc: wwang <wei_wang@realsil.com.cn>
fixed below checkpatch warnings.
-WARNING: braces {} are not necessary for single statement blocks
-WARNING: braces {} are not necessary for any arm of this statement
Signed-off-by: Toshiaki Yamane <yamanetoshi@gmail.com>
This resolves the conflict in:
drivers/staging/vt6656/ioctl.c
This patch changes the space of the indent to the tab that warning
found by the checkpatch.pl tool.
Signed-off-by: Hitoshi NAKAMORI<hitoshi.nakamori@gmail.com>
rtsx_transport.c (rtsx_transfer_sglist_adma_partial):
pointer struct scatterlist *sg, which is mapped in dma_map_sg,
is used as an iterator in later transfer operation. It is corrupted and
passed to dma_unmap_sg, thus causing fatal unmap of some erroneous address.
Fix it by duplicating *sg_ptr for iterating.
Signed-off-by: wwang <wei_wang@realsil.com.cn>
Add static modifier before some functions and global variables.
Delete a function named rtsx_transfer_sglist which won't be called.
rts_pstor is used to support Realtek PCI-E card readers,
including rts5209, rts5208, Barossa.
