commit 7cbf3c7cd59288fb5e9f31815c74773549668d43 upstream.
The serqt_usb2 driver will not work properly with the ssu100 device
even though it claims to support it. The ssu100 is supported by the
ssu100 driver in mainline so there is no need to have it claimed by
serqt_usb2.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6
* 'staging-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: (961 commits)
staging: hv: fix memory leaks
staging: hv: Remove NULL check before kfree
Staging: hv: Get rid of vmbus_child_dev_add()
Staging: hv: Change the signature for vmbus_child_device_register()
Staging: hv: Get rid of vmbus_cleanup() function
Staging: hv: Get rid of vmbus_dev_rm() function
Staging: hv: Change the signature for vmbus_on_isr()
Staging: hv: Eliminate vmbus_event_dpc()
Staging: hv: Get rid of the function vmbus_msg_dpc()
Staging: hv: Change the signature for vmbus_cleanup()
Staging: hv: Simplify root device management
staging: rtl8192e: Don't copy dev pointer to skb
staging: rtl8192e: Pass priv to cmdpkt functions
staging: rtl8192e: Pass priv to firmware download functions
staging: rtl8192e: Pass priv to rtl8192_interrupt
staging: rtl8192e: Pass rtl8192_priv to dm functions
staging: rtl8192e: Pass ieee80211_device to callbacks
This patch was generated by the following semantic patch:
// <smpl>
@@ expression E; @@
- if (E != NULL) { kfree(E); }
+ kfree(E);
@@ expression E; @@
- if (E != NULL) { kfree(E); E = NULL; }
+ kfree(E);
+ E = NULL;
// </smpl>
Signed-off-by: Ilia Mirkin <imirkin@alum.mit.edu>
We don't use it so we can trim it from here as we try and stamp the file
object dependencies out of the serial code.
Signed-off-by: Alan Cox <alan@linux.intel.com>
Doing tiocmget was such fun we should do tiocmset as well for the same
reasons
We don't actually need this and it causes problems for internal use of
this functionality. Currently there is a single use of the FILE * pointer.
That is the serial core which uses it to check tty_hung_up_p. However if
that is true then IO_ERROR is also already set so the check may be removed.
This is a patch to the serqt_usb2.c files that fixed space error and
warning found by the checkpatch.pl tools.
Signed-off-by: Ruslan Pisarev <ruslan@rpisarev.org.ua>
Regardless of the condition, the branches executed the same code
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
The id_table field of the struct usb_device_id is constant in <linux/usb.h>
so it is worth to make the initialization data also constant.
The semantic match that finds this kind of pattern is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r@
disable decl_init,const_decl_init;
identifier I1, I2, x;
struct I1 {
const struct I2 *x;
@s@
identifier r.I1, y;
identifier r.x, E;
struct I1 y = {
.x = E,
@c@
identifier r.I2;
identifier s.E;
const struct I2 E[] = ... ;
@depends on !c@
identifier r.I2;
identifier s.E;
+ const
struct I2 E[] = ...;
// </smpl>
Signed-off-by: Németh Márton <nm127@freemail.hu>
Cc: Julia Lawall <julia@diku.dk>
Cc: cocci@diku.dk
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
The parameter list for qt_open() was from the old non usb-serial
driver.
a standard memory leak, as later allocations may fail even if prior
allocations did not. Then the prior allocations must be undone.
Signed-off-by: Oliver Neukum <oliver@neukum.org>
tty_port_tty_get() was called without a corresponding tty_kref_put()
in qt_read_bulk_callback() and qt_close().
The parameter list for qt_close() was from the old non usb-serial
driver.
Remove the replicated urban legends from the comments and fix a couple of
other silly calls
This is the serqt_usb driver rewritten to use usb-serial.
