Freeing netdev without free_netdev() leads to net, tx leaks.
I might lead to dereferencing freed pointer.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
struct net_device* dev;
-kfree(dev)
+free_netdev(dev)
Signed-off-by: Vasiliy Kulikov <segooon@gmail.com>
Acked-by: Denis Kirjanov <dkirjanov@kernel.org>
Remove explicit arch dependencies
Signed-off-by: Denis Kirjanov <dkirjanov@kernel.org>
Remove net_device_stats from the driver's private.
Reorder functions to kill their prototypes.
This patch makes error handling more readable due to 'goto err' pattern.
Signed-off-by: Kulikov Vasiliy <segooon@gmail.com>
Cc: Denis Kirjanov <kirjanov@gmail.com>
Remove defines of STATUS_XXX from header file.
Change defined STATUS_XXX return codes to standard -EYYY.
Converts the list and the core manipulating with it to be the same as uc_list.
+uses two functions for adding/removing mc address (normal and "global"
variant) instead of a function parameter.
+removes dev_mcast.c completely.
+exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for
manipulation with lists on a sandbox (used in bonding and 80211 drivers)
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
There were a number of patches that went into Linus's
tree already that conflicted with other changes in the
staging branch. This merge resolves those merge conflicts.
String constants that are continued on subsequent lines with \
are not good.
Use pci_set_consistent_dma_mask() in the case of 64-bit consistent allocations.
Signed-off-by: Denis Kirjanov <kirjanov@gmail.com>
Use compare_ether_addr.
Use PCI_DEVICE_TABLE: defines array as const and puts
it into the __devinitconst section.
Use dev->stats rather than adapter->stats.
No need to check pointer expicitly since it has been done in debugfs_remove()
No need type casting when using netdev_priv.
Check for valid hw address.
Convert to netdev_tx_t.
removed needless checks in arlan-main.c and slicoss.c
fixed bug in et131x_netdev.c to actually fill addresses in.
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss
anything). Used spatch and did small tweaks and conding style changes when
it was suitable.
Jirka
The definition of slic_netdev_ops has initializations of a local function
and eth_mac_addr for its ndo_set_mac_address field. This change uses only
the local function.
// <smpl>
@r@
identifier I, s, fld;
position p0,p;
expression E;
struct I s =@p0 { ... .fld@p = E, ...};
@s@
identifier I, s, r.fld;
position r.p0,p;
expression E;
@script:python@
p0 << r.p0;
fld << r.fld;
ps << s.p;
pr << r.p;
if int(ps[0].line)!=int(pr[0].line) or int(ps[0].column)!=int(pr[0].column):
cocci.print_main(fld,p0)
// </smpl>
These changes were a direct result of using a semantic patch
More information can be found at http://www.emn.fr/x-info/coccinelle/
Signed-off-by: Stoyan Gaydarov <sgayda2@uiuc.edu>
This patch is the result of an automatic spatch transformation to convert
all ndo_start_xmit() return values of 0 to NETDEV_TX_OK.
Some occurences are missed by the automatic conversion, those will be
handled in a seperate patch.
This fixes some build warnings in the slicoss driver.
The remove function uses __devexit, so the .remove assignment needs
__devexit_p() to fix a build error with hotplug disabled.
I looked, I gagged, I left
Revert commit 2bb347361e2c19799431f56488a3f64de40a3aa6
This commit has been reported to cause problems:
Mar 24 11:50:31 linuxdev kernel: BUG: sleeping function called from invalid context at mm/slub.c:1599 Mar 24 11:50:31 linuxdev kernel: in_atomic(): 1, irqs_disabled(): 0, pid: 3251, name: avahi-daemon
Cc: Lior Dotan <liodot@gmail.com>
Cc: Christopher Harrer <charrer@alacritech.com>
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com>
Replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64)
Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com>
Lots of spaces->tabs cleanups for slichw.h
It's much more sane and "Linux-like" now.
Move the ASSERT macro into slicoss.c as that's all that is currently
being used.
No one uses it, so drop it.
Use the dev_err() call instead, it is the standard and provides much
more information.
They aren't needed or used anymore.
It was always enabled, so just always use it.
Cleaned up the ioctl code a bit as well to make it more readable.
It's not being used for anything, so delete it and all instances of it.
It's quite wierd, and doesn't even do anything on x86_64, so just delete
it.
It was always enabled, so just enable it properly.
It was always enabled, so just enable it and take out the one place it
was being used.
It was always disabled, so just remove it and the 2 lines of
code it was protecting.
Also remove SLIC_POWER_MANAGEMENT which was also disabled, yet
was never used.
Added bonus is this fixes a compiler warning on 4.3.3
It was always enabled, so just turn on the code that was being always
enabled, and remove the #define.
Putting static function prototypes in a .h file doesn't make much sense.
Move the ones that we need into the .c file and delete the rest.
SLIC_GET_STATS_TIMER_ENABLED was never defined, so remove the code that
was bound by it.
As SLIC_DUMP_ENABLED was disabled, remove the code that it was keeping
from being built as it was not ever used. This removed a lot.
It was just duplicating the same #defines already in the .c file
and it wasn't even being #included in any file.
There are a number of "config" defines that do nothing, remove them.
