Fixes occasional urb submitted while active.
Even thought the fMP_CONTROL_WRITES/fMP_CONTROL_READS flags
are cleared in the return context urb->hcpriv is not NULL.
check for hcpriv and return STATUS_FAILURE if not NULL.
Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com>
Remove sTimerTxData 10 second timer which triggers PSbSendNullPacket
every 40 seconds when bLinkPass == true.
Move the 40 second timer to the existing BSSvSecondCallBack
one second delayed workqueue and trigger every 40 seconds when
bLinkPass == true.
Replace with struct vnt_rcb
Replace with struct vnt_usb_send_context.
ASSERT is always defined as empty macro
because VIAWET_DEBUG is never defined.
Several sed -i '/^$/{ N /^\n$/ D }' drivers/staging/vt6656/*.[ch]
Signed-off-by: Andres More <more.andres@gmail.com>
Removed comments from coding template.
sed -i '/^\/\*---/d' drivers/staging/vt6656/*.[ch]
Reviewed-by: Dan Carpenter <dan.carpenter@oracle.com>
Checkpatch findings were not resolved, just direct replacement.
sed -i 's/\bTRUE\b/true/g' drivers/staging/vt6656/*.[ch]
sed -i 's/\bFALSE\b/false/g' drivers/staging/vt6656/*.[ch]
This error happens because PIPEnsControlOut and PIPEnsControlIn unlock the
spin lock for delay, letting in another thread.
The patch moves the current MP_SET_FLAG to before filling
of sUsbCtlRequest for pControlURB and clears it in event of failing.
Any thread calling either function while fMP_CONTROL_READS or fMP_CONTROL_WRITES
flags set will return STATUS_FAILURE.
Cc: stable@vger.kernel.org # 3.8
This patch cleans up function declarations, definitions and local variables
where appropriate replacing types defined in "ttype.h" with linux/types.h.
Eventually, when there is enough errors we run out of free TX urbs and
connection stalls.
These macros were reported by forgotten-macros tool
(https://github.com/marcosps/forgotten_macros).
Signed-off-by: Marcos Paulo de Souza <marcos.souza.org@gmail.com>
Removed custom macro used to test bits.
Removed int redefinition for function results.
Replaced NTSTATUS with int, as defined in a couple of places.
Removed an always defined macro, perhaps used to patch the driver
Removed code in .c files that was being skipped by the preprocessor
Cleared all checkpatch warnings but 'do not add new typedefs' ones.
Remoted empty OUT define in ttype.h and its usage across the code.
Warnings about the usage of externs in .c files were not resolved here.
Code cleanup, removed empty IN definition used to denote input parameters.
Remove gratuitous macros re-defining usb functions.
One result is to make kcompat.h now identical in both driver dirs
Signed-off-by: Jim Lieb <lieb@canonical.com>
Remove references to umem.h macros and refer directly to memcpy
functions. Delete the include file.
Remove cplusplus lines from include files
Remove needless ifdefs on includes to conform with C
conventions. Remove misc commented code/includes
Update TODO
Clean up unused typedefs and macros to remove Win32'isms and
misc non-linux constructs. Text edits to referencing
source for less frequently used macros.
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com>
Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Add pristine upstream vt6656 driver sources to drivers/staging/vt6656. These
files were copied from the driver directory in the upstream source archive,
available here:
http://www.viaarena.com/Driver/VT6656_Linux_src_v1.19_12_x86.zip
After copying, trailing whitespace was stripped. This is GPL-licensed code.
Signed-off-by: Forest Bond <forest@alittletooquiet.net>
