The return value of the tx operation is commonly
misused by drivers, leading to errors. All drivers
will drop frames if they fail to TX the frame, and
they must also properly manage the queues (if they
didn't, mac80211 would already warn).
Removing the ability for drivers to return a BUSY
value also allows significant cleanups of the TX
TX handling code in mac80211.
Note that this also fixes a bug in ath9k_htc, the
old "return -1" there was wrong.
Tested-by: Sedat Dilek <sedat.dilek@googlemail.com> [ath5k]
Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> [rt2x00]
Acked-by: Larry Finger <Larry.Finger@lwfinger.net> [b43, rtl8187, rtlwifi]
Acked-by: Luciano Coelho <coelho@ti.com> [wl12xx]
This patch kills struct wb_usb which now only contains a pointer to struct
usb_device.
Cc: Pavel Machek <pavel@ucw.cz>
Signed-off-by: Pekka Enberg <penberg@kernel.org>
This patch removes two unused fields from struct wb_usb:
- DetectCount which is always zero
- IsUsb20 which is a write-only struct member
The wblinux_f.h header file doesn't contain anything that's actually used. Kill
it.
This patch merges mlmetxrx.c to mds.c because it's small and the functions are
only used in mto.c.
The Vendor2 macro is never defined so remove the ifdef'd block from
hal_init_hardware().
Use pr_debug() for debugging printk's and kill the FULL_DEBUG macro. It would
be even better to use dev_dbg() but unfortunately looking up struct device in
the current code structure makes things very ugly.
Please note that I dropped the DataDmp() calls from
RFSynthesizer_SwitchingChannel() because that function doesn't exist.
This patch kills the NullPacketCount member of struct hwdata. It's not used for
anything so it's safe to remove it.
Acked-by: Pavel Machek <pavel@ucw.cz>
The Mds_Destroy() function doesn't do anything so kill it.
This patch renames the wbhal_s.h header file to wbhal.h now that it contains
both structure and function definitions.
This patch merges HAL struct and function definitions into one header file.
The wbsoft_tx() function is a simple wrapper on top of MLMESendFrame() so
inline the latter to the former.
Cc: Lars Lindley <lindley@coyote.org>
Cc: Ruslan Pisarev <ruslan@rpisarev.org.ua>
This patch changes MLMESendFrame to return NETDEV_TX_BUSY if MLME frame is in
use so that wbsoft_tx() doesn't blindly return NETDEV_TX_OK in that case.
Cc: Sandro Bonazzola <sandro.bonazzola@gmail.com>
This patch removes unused spinlocks from "struct mlme_frame" and "struct
wbsoft_priv".
drivers/staging/Kconfig
drivers/staging/batman-adv/bat_sysfs.c
drivers/staging/batman-adv/device.c
drivers/staging/batman-adv/hard-interface.c
drivers/staging/cx25821/cx25821-audups11.c
pavel@suse.cz no longer works, replace it with working address.
Signed-off-by: Pavel Machek <pavel@ucw.cz>
drivers/staging/arlan/arlan-main.c
drivers/staging/comedi/drivers/cb_das16_cs.c
drivers/staging/cx25821/cx25821-alsa.c
drivers/staging/dt3155/dt3155_drv.c
drivers/staging/hv/hv.c
drivers/staging/netwave/netwave_cs.c
drivers/staging/wavelan/wavelan.c
drivers/staging/wavelan/wavelan_cs.c
drivers/staging/wlags49_h2/wl_cs.c
This required a bit of hand merging due to the conflicts
that happened in the later .34-rc releases, as well as
some staging driver changing coming in through other trees
(v4l and pcmcia).
I fixed the reported checkpatch.pl problems except for a bunch of
long lines and some printk:s.
I also removed versioning comments.
Signed-off-by: Lars Lindley <lindley@coyote.org>
Converts the list and the core manipulating with it to be the same as uc_list.
+uses two functions for adding/removing mc address (normal and "global"
variant) instead of a function parameter.
+removes dev_mcast.c completely.
+exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for
manipulation with lists on a sandbox (used in bonding and 80211 drivers)
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
The wireless core made a number of api changes that caused
the winbond driver to break. This patch fixes those errors by
making the needed changes to the driver.
The id_table field of the struct usb_device_id is constant in <linux/usb.h>
so it is worth to make the initialization data also constant.
The semantic match that finds this kind of pattern is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r@
disable decl_init,const_decl_init;
identifier I1, I2, x;
struct I1 {
const struct I2 *x;
@s@
identifier r.I1, y;
identifier r.x, E;
struct I1 y = {
.x = E,
@c@
identifier r.I2;
identifier s.E;
const struct I2 E[] = ... ;
@depends on !c@
identifier r.I2;
identifier s.E;
+ const
struct I2 E[] = ...;
// </smpl>
Signed-off-by: Németh Márton <nm127@freemail.hu>
Cc: Julia Lawall <julia@diku.dk>
Cc: cocci@diku.dk
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
This patch adds a prepare_multicast callback for the winbond driver
to properly receive mc_count in ->configure_filter.
This also fixes incompatible pointer assignment build errors because
->configure_filter had changed.
This is build tested only, but that's more than the original code received.
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
Commit f424afa17899408cbd267a4c4534ca6fc9d8f71c ("mac80211: remove
deprecated API") removed ->beacon_int from struct ieee80211_conf. Fix
breakage in w35und by setting beacon period in ->add_interface to
bss_conf.beacon_int.
Cc: Jiri Benc <jbenc@suse.cz>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Johannes Berg <johannes@sipsolutions.net>
There's no point in keeping around struct members that are only written
to but never read.
The commit 'mac80211: unify config_interface and bss_info_changed' from
Johannes Berg <johannes@sipsolutions.net> removed the config_interface structure
tag from struct ieee80211_ops. The BSSID detection functionality migrated to
ieee80211_ops.bss_info_changed.
Since wbsoft_config_interface() was largely empty, there wasn't much to do
other then to remove the function itself. There is currently no support
for BSSID change detection.
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
Impact: cleanup
This patch moves all the functions in wbhal.c that are used only in
wbusb.c to the latter file.
Impact: cleanup
No need to keep read-only data on the stack.
Impact: cleanup
The contact details in MODULE_AUTHOR do not reflect current state of
affairs so remove it.
Impact: cleanup
Use scripts/Lindent on the file and clean up the rest by hand.
Impact: cleanup
The hal_set_phy_type() is called in wb35_hw_init() only so inline the
function there. Also remove a redundant assignment of ->phy_type to
RF_WB_242_1.
Impact: cleanup
Remove some useless comments and clean up others.
Impact: cleanup
Now that hal_halt() is called from wb35_hw_halt() only where
->InitialResource is always set to 4, we can simplify
hal_init_hardware() and hal_halt().
Impact: fix, cleanup
If initialization in hal_init_hardware() fails, we call hal_halt() to
clean up and release resource. However, hal_halt() will attempt to
call del_timer_sync() on ->LEDTimer on "stage 3" although it's not
initialized at that point. Fix that up by simplifying error handling
logic in hal_init_hardware() with gotos.
Impact: cleanup
Use gotos to simplify the deep if-statement nesting in
Impact: cleanup
Change hal_init_hardware() to return an error code rather than a boolean
to simplify error handling in wb35_hw_init().
Impact: cleanup
The hal_init_hardware() and hal_halt() functions are only used in
wbusb.c so move them there.
Impact: cleanup
This patch replaces the switch-based error handling in wb35_hw_init()
with regular gotos.
We don't initialize hardware multicast filter in the driver nor do we know how
to do that. Therefore, remove some code that isn't actually used from
wbsoft_configure_filter().
Impact: fix module removal
This patch fixes an oops when the w35und module is removed from the
kernel and added back.
Reported-by: luoyi <luoyi.ly@gmail.com>
Tested-by: Sandro Bonazzola <sandro.bonazzola@gmail.com>
As this typedef is used everywhere in the driver, remove it in a separate
patch.
Acked-by: Pavel Machek <pavel@suse.cz>
This patch removes some typedefs from the driver code. I also removed some
unused structs I spotted while removing the typedefs.
The only remaining thing in common.h header file is the WBDEBUG() macro which
is unconditionally defined as printk(). Kill the macro and remove the header
file.
No need to keep function definitions separate from the rest so unify mto.h and
mto_f.h header files.
If successful, the usb_control_msg() function returns the number of
bytes transferred. Fix up wb35_probe() to only bail out if the function returns
a negative number. Also, fix up ieee80211_alloc_hw() error code to ENOMEM;
otherwise GCC complains that err might be undefined (and is right about that).
Reported-and-tested-by: Sandro Bonazzola <sandro.bonazzola@gmail.com>
Initialize few more fields in wireless device structure so that
wireless core actually accepts our registration.
Signed-off-by: Pavel Machek <pavel@suse.cz>
Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
the wireless config function has changed with commit
e8975581f63870be42ff4662b293d1b0c8c21350 so fix up the wbusb driver to
work properly with that change.
It's not actually used for anything, so remove it.
The function no longer has dependencies to wbusb.c so we can move it to
wb35rx.c and make it static now.
