This patch was generated by the following semantic patch:
// <smpl>
@@ expression E; @@
- if (E != NULL) { kfree(E); }
+ kfree(E);
@@ expression E; @@
- if (E != NULL) { kfree(E); E = NULL; }
+ kfree(E);
+ E = NULL;
// </smpl>
Signed-off-by: Ilia Mirkin <imirkin@alum.mit.edu>
This patch removes typedefs in p80211conv.h.
Signed-off-by: Edgardo Hames <ehames@gmail.com>
Removed typedef and other style issues.
This doesn't change the behavior. It just silences a sparse warning.
drivers/staging/wlan-ng/hfa384x_usb.c:2810:62: warning: dubious: !x | !y
The point of the bitwise OR is so that a logical OR could short circuit
the second call to test_and_set_bit().
This patch includes the feedback received from Richard Kennedy.
This is a patch in hfa834x_usb.c to fix typedef declarations and long lines.
Turns out that multiple people sent pretty much the same patch
for the same staging drivers. Commit these in two different
branches and merge them together to get a more complete coverage
of the cleanup and properly credit everyone for the work that they
did.
Signed-off-by: Andrew Elwell <Andrew.Elwell@gmail.com>
Basic fixups in the staging/wlan-ng directory.
(First kernel patch - thanks to FOSDEM talk)
Cleanups as suggested by checkpatch.pl utiltiy.
.o's from before and after cleanup have matching SHA1s.
Signed-off-by: Svenne Krap <svenne@krap.dk>
Trivial changes to code-paths.
A comment misspells "invocation"; this fixes it. No code changes.
Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com>
Signed-off-by: Moritz Muehlenhoff <jmm@debian.org>
scripts/checkpatch.pl error fixes. This is a TODO item.
This patch fixes most of the errors reported by checkpatch.pl in
wlan-ng directory of staging tree.
Signed-off-by: Mithlesh Thukral <mithlesh@linsyssoft.com>
Lindent script cleanups in wlan-ng driver in the staging tree.
This is a item in the TODO list.
Change uses of KERN_DEBUG over to pr_debug to match original driver
where messages are only needed during driver development.
Signed-off-by: Karl Relton <karllinuxtest.relton@ntlworld.com>
Remove unused #include <linux/version.h>'s.
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com>
fix ETIMEOUT -> ETIMEDOUT typos
Signed-off-by: Stoyan Gaydarov <stoyboyker@gmail.com>
Replace hfa384x2host_16(), hfa384x2host_32(), host2hfa384x_16()
and host2hfa384x_32() with standard byteorder macros.
Replace WLAN_LOG_INFO with printk() and remove it.
This patch removes the ieee2host16(), ieee2host32(), host2ieee16()
and host2ieee32() macros and replaces them with the generic ones.
Remove the ugly DBFENTER/DBFEXIT macros, which are only inserted to add "<---" and
"--->" at the function start/end at higher debug levels and which make the code
a lot less readable.
hfa384x_usbin_callback: check for hardware removed
copied from latest wlan-ng-devel version
Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk>
include the needed fixes from Karl Relton
see thread on linux-wlan-devel mailing list
"Possible cause of those pesky hfa384x_usbctlx_complete_sync errors"
Cc: Karl Relton <karllinuxtest.relton@ntlworld.com>
Signed-off-by: Solomon Peachy <pizza@shaftnet.org>
It's not needed at all anymore now that we are in the kernel tree.
wlan-ng needed to interact with userspace, and support very old kernels,
so it used to define its own types for integers to ensure consistency.
It's all rather irrelevant now.
The kernel provides us with the proper version of this file.
Also delete a large pile of code that existed to support <2.6 kernels.
This adds the wlan-ng prism2 USB driver to the drivers/staging tree.
The code was originally written by the linux-wlan-ng team, patched by
some Novell engineers to properly work on newer kernels, and then hacked
into place in order to get it to build properly in a single subdirectory
within the kernel tree by me.
It supports a wide range of older USB prism2 devices, and contains a
80211 stack to support this single driver.
Cc: Christian Zoz <zoz@suse.de>
Cc: Andreas Gruenbacher <agruen@suse.de>
Cc: linux-wireless <linux-wireless@vger.kernel.org>
Cc: John Linville <linville@tuxdriver.com>
Cc: Helmut Schaa <helmut.schaa@googlemail.com>
Cc: linux-wlan-ng <solomon@linux-wlan.com>
