Fix build by moving enum list outside of
#ifdef CONFIG_IIO_RING_BUFFER.
drivers/staging/iio/accel/adis16201_core.c:413: error: 'ADIS16201_SCAN_SUPPLY' undeclared here (not in a function)
drivers/staging/iio/accel/adis16201_core.c:417: error: 'ADIS16201_SCAN_TEMP' undeclared here (not in a function)
drivers/staging/iio/accel/adis16203_core.c:374: error: 'ADIS16203_SCAN_SUPPLY' undeclared here (not in a function)
drivers/staging/iio/accel/adis16203_core.c:378: error: 'ADIS16203_SCAN_AUX_ADC' undeclared here (not in a function)
Acked-by: Jonathan Cameron <jic23@cam.ac.uk>
Cc: linux-iio@vger.kernel.org
struct iio_info introduced a bug where the second channel of a MAX518 can't be
used. This commit fixes the typo (using max518 instead of the max517 struct).
Signed-off-by: Roland Stigge <stigge@antcom.de>
! has higher precedence than !=. H_RDY is 8 and since neither 0 nor
1 are equal to 8 the original condition was always true.
Acked-by: Tomas Winkler <tomas.winkler@intel.com>
The data pointer should be freed in the error
cases of adis16400_trigger_handler().
Signed-off-by: Andre Bartke <andre.bartke@gmail.com>
The kernel panic happens when we try to complete a pending
scan request while going to suspend state. The cause for this
kernel panic is accessing a freed memory (ar->arWmin). This
is freed before ar6k_cfg80211_scanComplete_event() getting
called where it is dereferenced.
RIP: 0010:[<ffffffffa042e726>] [<ffffffffa042e726>] wlan_iterate_nodes+0x16/0xc0 [ath6kl]
RSP: 0018:ffff8800719fbce8 EFLAGS: 00010296
RAX: ffff880071bbcc00 RBX: ffff880037b22520 RCX: ffff880077413c80
RDX: ffff880037b221c0 RSI: ffffffffa041ef10 RDI: 0000000000000020
RBP: ffff8800719fbd18 R08: 0000000000000001 R09: 0000000000000001
R10: 0000000000000400 R11: 0000000000000000 R12: 0000000000000010
R13: ffff8800719fbdd8 R14: 00007fff83a84b60 R15: 0000000000000001
FS: 00007fdccb8a7700(0000) GS:ffff880077400000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000000000000148 CR3: 0000000070604000 CR4: 00000000000006f0
Process rmmod (pid: 1998, threadinfo ffff8800719fa000, task ffff880066712d80)
Stack:
0000000000000000 ffff880037b22520 0000000000000010 ffff8800719fbdd8
00007fff83a84b60 0000000000000001 ffff8800719fbd28 ffffffffa0429fe2
ffff8800719fbd58 ffffffffa041ee5f ffff8800719fbd58 ffff880037b22520
Call Trace:
[<ffffffffa0429fe2>] wmi_iterate_nodes+0x12/0x20 [ath6kl]
[<ffffffffa041ee5f>] ar6k_cfg80211_scanComplete_event+0x3f/0xf0 [ath6kl]
[<ffffffffa04245f1>] ar6000_close+0x61/0x100 [ath6kl]
[<ffffffff814d6736>] __dev_close_many+0x96/0x100
[<ffffffff814d688d>] dev_close_many+0x9d/0x120
[<ffffffff814d6a48>] rollback_registered_many+0xe8/0x290
[<ffffffff814d6d16>] unregister_netdevice_queue+0x96/0x100
[<ffffffff814d6ea0>] unregister_netdev+0x20/0x30
[<ffffffffa0420259>] ar6000_destroy+0x119/0x180 [ath6kl]
[<ffffffffa043182a>] ar6k_cleanup_module+0x2a/0x33 [ath6kl]
[<ffffffff81098fde>] sys_delete_module+0x19e/0x270
[<ffffffff815d7542>] system_call_fastpath+0x16/0x1b
Code: c3 0f 1f 40 00 48 89 df e8 68 ff ff ff eb df 66 0f 1f 44 00 00 55 48 89 e5 41 57 41 56 41 55 41 54 53 48 83 ec 08 0f 1f 44 00 00
8b af 28 01 00 00 4c 8d 7f 08 49 89 fc 48 89 f3 49 89 d6 41
RIP [<ffffffffa042e726>] wlan_iterate_nodes+0x16/0xc0 [ath6kl]
RSP <ffff8800719fbce8>
Signed-off-by: Vasanthakumar Thiagarajan <vasanth@atheros.com>
Many Linux distributions would enable vesafb in order to display
early stage boot splash. In this case, we will get garbled X
Window screen if running X fbdev on psbfb.
This is because fb0 is occupied by vesafb while psbfb is on fb1.
They tried to drive the same pieces of hardware at the same
time. With unmodified X start-up, it would try to use default
fb0 framebuffer device and unfortunately it is now broken
becaues fb1 supersedes it.
We should let psbfb takeover framebuffer control from vesafb
to get around this problem.
See also commit : 4410f3910947dcea8672280b3adecd53cec4e85e
Signed-off-by: Michael Chang <mchang@novell.com>
Cc: Alan Cox <alan@linux.intel.com>
Cc: stable <stable@kernel.org>
backlight
On the Fit-PC2 the VBT reports an invalid fixed panel mode for LVDS, this gets
in the way for SDVO. This patch makes VBT parsing skip the invalid mode. When
there is no LVDS output the backlight support crashes so the patch also checks
for this before enabling it.
Signed-off-by: Patrik Jakobsson <patrik.r.jakobsson@gmail.com>
Signed-off-by: Alan Cox <alan@linux.intel.com>
Implemented pre_reset and post_reset methods of the driver to prevent the
driver from being unbound upon a device reset. Because of this also the
asynchronous reset introduced to prevent a race condition is no longer necessary
(and sometimes causes problems, because it comes later then expected).
Signed-off-by: Arjan Mels <arjan.mels@gmx.net>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Takahiro Hirofuchi <hirofuchi@users.sourceforge.net>
Cc: Max Vozeler <max@vozeler.com>
Cc: usbip-devel <usbip-devel@lists.sourceforge.net>
Failure to set iio_poll_func private_data, causes zero pointer access
violations in all consumer trigger handlers.
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Looks like a typo.
Signed-off-by: Nicolas Kaiser <nikai@nikai.net>
Reviewed-by: Peter Huewe <peterhuewe@gmx.de>
Fix build errors when CONFIG_CFG80211 is not enabled:
drivers/built-in.o: In function `ar6k_cfg80211_deinit':
(.text+0x189b71): undefined reference to `cfg80211_scan_done'
(.text+0x189b86): undefined reference to `wiphy_unregister'
(.text+0x189b8d): undefined reference to `wiphy_free'
drivers/built-in.o: In function `ar6k_cfg80211_init':
(.text+0x18add7): undefined reference to `wiphy_new'
(.text+0x18ae48): undefined reference to `wiphy_register'
drivers/built-in.o: In function `ar6k_cfg80211_tkip_micerr_event':
(.text+0x18ae95): undefined reference to `cfg80211_michael_mic_failure'
drivers/built-in.o: In function `ar6k_cfg80211_scan_node':
(.text+0x18afb5): undefined reference to `__ieee80211_get_channel'
(.text+0x18afd2): undefined reference to `cfg80211_inform_bss_frame'
drivers/built-in.o: In function `ar6k_cfg80211_disconnect_event':
(.text+0x18b046): undefined reference to `cfg80211_ibss_joined'
(.text+0x18b176): undefined reference to `cfg80211_connect_result'
(.text+0x18b190): undefined reference to `cfg80211_disconnected'
drivers/built-in.o: In function `ar6k_cfg80211_connect_event':
(.text+0x18b291): undefined reference to `cfg80211_get_bss'
(.text+0x18b457): undefined reference to `cfg80211_put_bss'
(.text+0x18b4fa): undefined reference to `cfg80211_roamed'
Cc: Luis R. Rodriguez <mcgrof@gmail.com>
Cc: Joe Perches <joe@perches.com>
Cc: Naveen Singh <nsingh@atheros.com>
Signed-off-by: Peter Foley <pefoley2@verizon.net>
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Roland Vossen <rvossen@broadcom.com>
Fix olpc_dcon.c build by selecting the needed kconfig symbol
BACKLIGHT_CLASS_DEVICE.
olpc_dcon.c:(.text+0x11588b): undefined reference to `backlight_device_register'
Cc: Andres Salomon <dilinger@queued.net>
Cc: Chris Ball <cjb@laptop.org>
Cc: Jon Nettleton <jon.nettleton@gmail.com>
Part of the requirement to be in the staging tree is that the code must
build, so let's make it easier for people to build the code to
test/prove this out.
Based on a recommendation from Linus to implement this.
Staging drivers should be self-contained, without files in the include/
directories. So move the altera.h file back to the driver directory for
now, until it moves out of the staging tree.
Cc: Igor M. Liplianin <liplianin@netup.ru>
Cc: Mauro Carvalho Chehab <mchehab@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6
* 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6:
gfs2: Drop __TIME__ usage
isdn/diva: Drop __TIME__ usage
atm: Drop __TIME__ usage
dlm: Drop __TIME__ usage
wan/pc300: Drop __TIME__ usage
parport: Drop __TIME__ usage
hdlcdrv: Drop __TIME__ usage
baycom: Drop __TIME__ usage
pmcraid: Drop __DATE__ usage
edac: Drop __DATE__ usage
rio: Drop __DATE__ usage
scsi/wd33c93: Drop __TIME__ usage
scsi/in2000: Drop __TIME__ usage
aacraid: Drop __TIME__ usage
media/cx231xx: Drop __TIME__ usage
media/radio-maxiradio: Drop __TIME__ usage
nozomi: Drop __TIME__ usage
cyclades: Drop __TIME__ usage
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (89 commits)
bonding: documentation and code cleanup for resend_igmp
bonding: prevent deadlock on slave store with alb mode (v3)
net: hold rtnl again in dump callbacks
Add Fujitsu 1000base-SX PCI ID to tg3
bnx2x: protect sequence increment with mutex
sch_sfq: fix peek() implementation
isdn: netjet - blacklist Digium TDM400P
via-velocity: don't annotate MAC registers as packed
xen: netfront: hold RTNL when updating features.
sctp: fix memory leak of the ASCONF queue when free asoc
net: make dev_disable_lro use physical device if passed a vlan dev (v2)
net: move is_vlan_dev into public header file (v2)
bug.h: Fix build with CONFIG_PRINTK disabled.
wireless: fix fatal kernel-doc error + warning in mac80211.h
wireless: fix cfg80211.h new kernel-doc warnings
iwlagn: dbg_fixed_rate only used when CONFIG_MAC80211_DEBUGFS enabled
dst: catch uninitialized metrics
be2net: hash key for rss-config cmd not set
bridge: initialize fake_rtable metrics
net: fix __dst_destroy_metrics_generic()
Fix up trivial conflicts in drivers/staging/brcm80211/brcmfmac/wl_cfg80211.c
ssh://master.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
Change each shrinker's API by consolidating the existing parameters into
shrink_control struct. This will simplify any further features added w/o
touching each file of shrinker.
[akpm@linux-foundation.org: fix build]
[akpm@linux-foundation.org: fix warning]
[kosaki.motohiro@jp.fujitsu.com: fix up new shrinker API]
[akpm@linux-foundation.org: fix xfs warning]
[akpm@linux-foundation.org: update gfs2]
Signed-off-by: Ying Han <yinghan@google.com>
Cc: Minchan Kim <minchan.kim@gmail.com>
Acked-by: Pavel Emelyanov <xemul@openvz.org>
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
ssh://master.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6:
pcmcia: Make struct pcmcia_device_id const, sound drivers edition
staging: pcmcia: Convert pcmcia_device_id declarations to const
pcmcia: Make declaration and uses of struct pcmcia_device_id const
pcmcia/sa1100: put sa11x0_pcmcia_hw_init[] to .devinit.data
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (247 commits)
[media] gspca - sunplus: Fix some warnings and simplify code
[media] gspca: Fix some warnings tied to 'no debug'
[media] gspca: Unset debug by default
[media] gspca - cpia1: Remove a bad conditional compilation instruction
[media] gspca - main: Remove USB traces
[media] gspca - main: Version change to 2.13
[media] gspca - stk014 / t613: Accept the index 0 in querymenu
[media] gspca - kinect: Remove __devinitdata
[media] gspca - cpia1: Fix some warnings
[media] video/Kconfig: Fix mis-classified devices
[media] support for medion dvb stick 1660:1921
[media] tm6000: fix uninitialized field, change prink to dprintk
[media] cx231xx: Add support for Iconbit U100
[media] saa7134 add new TV cards
[media] Use a more consistent value for RC repeat period
[media] cx18: Move spinlock and vb_type initialisation into stream_init
[media] tm6000: remove tm6010 sif audio start and stop
[media] tm6000: remove unused exports
[media] tm6000: add pts logging
[media] tm6000: change from ioctl to unlocked_ioctl
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6
* 'staging-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: (970 commits)
staging: usbip: replace usbip_u{dbg,err,info} and printk with dev_ and pr_
staging:iio: Trivial kconfig reorganization and uniformity improvements.
staging:iio:documenation partial update.
staging:iio: use pollfunc allocation helpers in remaining drivers.
staging:iio:max1363 misc cleanups and use of for_each_bit_set to simplify event code spitting out.
staging:iio: implement an iio_info structure to take some of the constant elements out of iio_dev.
staging:iio:meter:ade7758: Use private data space from iio_allocate_device
staging:iio:accel:lis3l02dq make write_reg_8 take value not a pointer to value.
staging:iio: ring core cleanups + check if read_last available in lis3l02dq
staging:iio:core cleanup: squash tiny wrappers and use dev_set_name to handle creation of event interface name.
staging:iio: poll func allocation clean up.
staging:iio:ad7780 trivial unused header cleanup.
staging:iio:adc: AD7780: Use private data space from iio_allocate_device + trivial fixes
staging:iio:adc:AD7780: Convert to new channel registration method
staging:iio:adc: AD7606: Drop dev_data in favour of iio_priv()
staging:iio:adc: AD7606: Consitently use indio_dev
staging:iio: Rip out helper for software rings.
staging:iio:adc:AD7298: Use private data space from iio_allocate_device
staging:iio: rationalization of different buffer implementation hooks.
staging:iio:imu:adis16400 avoid allocating rx, tx, and state separately from iio_dev.
- drivers/staging/intel_sst/intelmid.c: patches applied in both branches
- drivers/staging/rt2860/common/cmm_data_{pci,usb}.c: removed vs spelling
- drivers/staging/usbip/vhci_sysfs.c: trivial header file inclusion
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (346 commits)
ASoC: core: Don't set "(null)" as a driver name
ALSA: hda - Use LPIB for ATI/AMD chipsets as default
Revert "ALSA: hda - Use position_fix=3 as default for AMD chipsets"
ASoC: Tegra: Fix compile when debugfs not enabled
ASoC: spdif-dit: Add missing MODULE_*
SOUND: OSS: Remove Au1550 driver.
ALSA: hda - add Intel Panther Point HDMI codec id
ALSA: emu10k1 - Add dB range to Bass and Treble for SB Live!
ALSA: hda - Remove PCM mixer elements from Virtual Master of realtek
ALSA: hda - Fix input-src parse in patch_analog.c
ASoC: davinci-mcasp: enable ping-pong SRAM buffers
ASoC: add iPAQ hx4700 machine driver
ASoC: Asahi Kasei AK4641 codec driver
ALSA: hda - Enable Realtek ALC269 codec input layer beep
ALSA: intel8x0m: enable AMD8111 modem
ALSA: HDA: Add jack detection for HDMI
ALSA: sound, core, pcm_lib: fix xrun_log
ASoC: Max98095: Move existing NULL check before pointer dereference.
ALSA: sound, core, pcm_lib: xrun_log: log also in_interrupt
ALSA: usb-audio - Add support for USB X-Fi S51 Pro
Signed-off-by: Stefan Ringel <stefan.ringel@arcor.de>
move from tm6000_set_reg to tm6000_set_reg_mask
change input control
vitual input enums
change to virtual inputs
add tm6010 audio mode setup
add radio capabilities
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits)
macvlan: fix panic if lowerdev in a bond
tg3: Add braces around 5906 workaround.
tg3: Fix NETIF_F_LOOPBACK error
macvlan: remove one synchronize_rcu() call
networking: NET_CLS_ROUTE4 depends on INET
irda: Fix error propagation in ircomm_lmp_connect_response()
irda: Kill set but unused variable 'bytes' in irlan_check_command_param()
irda: Kill set but unused variable 'clen' in ircomm_connect_indication()
rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport()
be2net: Kill set but unused variable 'req' in lancer_fw_download()
irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication()
atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined.
rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer().
rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler()
rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection()
rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window()
pkt_sched: Kill set but unused variable 'protocol' in tc_classify()
isdn: capi: Use pr_debug() instead of ifdefs.
tg3: Update version to 3.119
tg3: Apply rx_discards fix to 5719/5720
Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c
as per Davem.
Commit e66eed651fd1 ("list: remove prefetching from regular list
iterators") removed the include of prefetch.h from list.h, which
uncovered several cases that had apparently relied on that rather
obscure header file dependency.
So this fixes things up a bit, using
grep -L linux/prefetch.h $(git grep -l '[^a-z_]prefetchw*(' -- '*.[ch]')
grep -L 'prefetchw*(' $(git grep -l 'linux/prefetch.h' -- '*.[ch]')
to guide us in finding files that either need <linux/prefetch.h>
inclusion, or have it despite not needing it.
There are more of them around (mostly network drivers), but this gets
many core ones.
On some situations, it is desired to use eeprom data to detect
the board type. This patch adds a logic for it and fixes 2 detection
issues:
1) 10Moons UT-821 uses a generic Trident ID. Other boards
also share the same ID. So, better to use an alternative way for
it;
2) Sometimes, HVR-900H is loaded with the default Trident
ID. This seems to be some hardware bug or race condition.
The new logic will only be enabled if the device is detected as
having a generic ID.
add CARDLIST
In commit 8aff8ba95155df, most of the manipulations to vbuf inside
copy_streams were gated on if !dev->radio, but one place that touches
vbuf lays outside those gates -- a memcpy of vbuf isn't NULL. If we
initialize vbuf to NULL, that memcpy will never happen in the case where
we do have dev->radio, and otherwise, in the !dev->radio case, the code
behaves exactly like it did prior to 8aff8ba95155df.
While we're at it, also fix an incorrectly indented closing brace for
one of the sections touching vbuf that is conditional on !dev->radio.
Signed-off-by: Jarod Wilson <jarod@redhat.com>
This switches all of the usbip_u{dbg,err,info} and printk statements to
dev_<level>, if possible, or pr_<level> macros. And removes a few
unnecessary debug statements.
Signed-off-by: matt mooney <mfm@muteddisk.com>
Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk>
