path: root/drivers/target/Makefile
2011-07-26iscsi-target: Add iSCSI fabric support for target v4.1Nicholas Bellinger
The Linux-iSCSI.org target module is a full featured in-kernel software implementation of iSCSI target mode (RFC-3720) for the current WIP mainline target v4.1 infrastructure code for the v3.1 kernel. More information can be found here: http://linux-iscsi.org/wiki/ISCSI This includes support for: * RFC-3720 defined request / response state machines and support for all defined iSCSI operation codes from Section 10.2.1.2 using libiscsi include/scsi/iscsi_proto.h PDU definitions * Target v4.1 compatible control plane using the generic layout in target_core_fabric_configfs.c and fabric dependent attributes within /sys/kernel/config/target/iscsi/ subdirectories. * Target v4.1 compatible iSCSI statistics based on RFC-4544 (iSCSI MIBS) * Support for IPv6 and IPv4 network portals in M:N mapping to TPGs * iSCSI Error Recovery Hierarchy support * Per iSCSI connection RX/TX thread pair scheduling affinity * crc32c + crc32c_intel SSEv4 instruction offload support using libcrypto * CHAP Authentication support using libcrypto * Conversion to use internal SGl allocation with iscsit_alloc_buffs() -> transport_generic_map_mem_to_cmd() (nab: Fix iscsi_proto.h struct scsi_lun usage from linux-next in commit: iscsi: Use struct scsi_lun in iscsi structs instead of u8[8]) (nab: Fix 32-bit compile warnings) Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Andy Grover <agrover@redhat.com> Acked-by: Roland Dreier <roland@kernel.org> Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org>
2011-05-17[SCSI] tcm_fc: Adding FC_FC4 provider (tcm_fc) for FCoE target (TCM - target ↵Kiran Patil
core) support This is a comprehensive patch for FC-FC4 provider. tcm_fc is a FC-FC4 provider which glues target core (TCM) with Fiber channel library (libfc). tcm_fc uses existing FC4 provider hooks from Fiber channel library. This Fiber channel library is used by FCoE (transport - FC over Ethernet) protocol driver as well. Combination of modules such as Fiber channel library, tcm_fc, TCM target core, and FCoE protocol driver enables functional FCoE target. This patch includes initial commit for tcm_fc plus additional enhancement, bug fixes. This tcm_fc module essentially contains 3 entry points such as "prli", "prlo", "recv". When process login request (ELS_PRLI) request is received, Fiber channel library (libfc) module calls passive providers (FC-FC4, tcm_fc) (if any registered) "prli" function. Likewise when LOGO request is received, "prlo" function of passive provider is invoked by libfc. For all other request (e.g. any read/write, task management, LUN inquiry commands), "recv" function of passiver provider is invoked by libfc. Those passive providers "prli, prlo, recv" functions interact with TCM target core for requested operation. This module was primarily developed by "Joe Eykholt" and there were significant contributions from the people listed under signed-off. Signed-off-by: Joe Eykholt <jeykholt@cisco.com> Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Yi Zou <yi.zou@intel.com> Signed-off-by: Kiran Patil <kiran.patil@intel.com> Acked-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <jbottomley@parallels.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-03-23[SCSI] tcm_loop: Add multi-fabric Linux/SCSI LLD fabric moduleNicholas Bellinger
This patch adds the TCM_Loop Linux/SCSI LLD fabric module for accessing TCM device backstores as locally accessable SCSI LUNs in virtual SAS, FC, and iSCSI Target ports using the generic fabric TransportID and Target Port WWN naming handlers from TCM's target_core_fabric_lib.c The TCM_Loop module uses the generic fabric configfs infratructure provided by target_core_fabric_configfs.c and adds a module dependent attribute for the creation/release of the virtual I_T Nexus connected the TCM_Loop Target and Initiator Ports. TCM_Loop can also be used with scsi-generic and BSG drivers so that STGT userspace fabric modules, QEMU-KVM and other hypervisor SCSI passthrough support can access TCM device backstore and control CDB emulation. For more information please see: http://linux-iscsi.org/wiki/Tcm_loop [jejb: fixed up checkpatch stuff] Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-03-23[SCSI] target: add initial statisticsNicholas Bellinger
This patch adds a target_core_mib.c statistics conversion for backend context struct se_subsystem_dev + struct se_device config_group based statistics in target_core_device.c using CONFIGFS_EATTR() based struct config_item_types from target_core_stat.c code. The conversion from backend /proc/scsi_target/mib/ context output to configfs default groups+attributes include scsi_dev, scsi_lu, and scsi_tgt_dev output from within individual: /sys/kernel/config/target/core/$HBA/DEV/ The legacy procfs output now appear as individual configfs attributes under: *) $HBA/$DEV/statistics/scsi_dev: |-- indx |-- inst |-- ports `-- role *) $HBA/$DEV/statistics/scsi_lu: |-- creation_time |-- dev |-- dev_type |-- full_stat |-- hs_num_cmds |-- indx |-- inst |-- lu_name |-- lun |-- num_cmds |-- prod |-- read_mbytes |-- resets |-- rev |-- state_bit |-- status |-- vend `-- write_mbytes *) $HBA/$DEV/statistics/scsi_tgt_dev: |-- indx |-- inst |-- non_access_lus |-- num_lus |-- resets `-- status The conversion from backend /proc/scsi_target/mib/ context output to configfs default groups+attributes include scsi_port, scsi_tgt_port and scsi_transport output from within individual: /sys/kernel/config/target/fabric/$WWN/tpgt_$TPGT/lun/lun_$LUN_ID/statistics/ The legacy procfs output now appear as individual configfs attributes under: *) fabric/$WWN/tpgt_$TPGT/lun/lun_$LUN_ID/statistics/scsi_port |-- busy_count |-- dev |-- indx |-- inst `-- role *) fabric/$WWN/tpgt_$TPGT/lun/lun_$LUN_ID/statistics/scsi_tgt_port |-- dev |-- hs_in_cmds |-- in_cmds |-- indx |-- inst |-- name |-- port_index |-- read_mbytes `-- write_mbytes *) fabric/$WWN/tpgt_$TPGT/lun/lun_$LUN_ID/statistics/scsi_transport |-- dev_name |-- device |-- indx `-- inst The conversion from backend /proc/scsi_target/mib/ context output to configfs default groups+attributes include scsi_att_intr_port and scsi_auth_intr output from within individual: /sys/kernel/config/target/fabric/$WWN/tpgt_$TPGT/acls/$INITIATOR_WWN/lun_$LUN_ID/statistics/ The legacy procfs output now appear as individual configfs attributes under: *) acls/$INITIATOR_WWN/lun_$LUN_ID/statistics/scsi_att_intr_port |-- dev |-- indx |-- inst |-- port |-- port_auth_indx `-- port_ident *) acls/$INITIATOR_WWN/lun_$LUN_ID/statistics/scsi_auth_intr |-- att_count |-- creation_time |-- dev |-- dev_or_port |-- hs_num_cmds |-- indx |-- inst |-- intr_name |-- map_indx |-- num_cmds |-- port |-- read_mbytes |-- row_status `-- write_mbytes Also, this includes adding struct target_fabric_configfs_template-> tfc_wwn_fabric_stats_cit and ->tfc_tpg_nacl_stat_cit respectively for use during target_core_fabric_configfs.c:target_fabric_setup_cits() Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-03-23[SCSI] target: remove EXTRA_CFLAGSChristoph Hellwig
Add the current directory is superflous in general, and no includes in drivers/scsi are needed either. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-02-12[SCSI] target: Remove procfs based target_core_mib.c codeNicholas Bellinger
This patch removes the legacy procfs based target_core_mib.c code, and moves the necessary scsi_index_tables functions and defines into target_core_transport.c and target_core_base.h code to allow existing fabric independent statistics to function. This includes the removal of a handful of 'atomic_t mib_ref_count' counters used in struct se_node_acl, se_session and se_hba to prevent removal while using seq_list procfs walking logic. [jejb: fix up compile failures] Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-01-14[SCSI] target: Add LIO target core v4.0.0-rc6Nicholas Bellinger
LIO target is a full featured in-kernel target framework with the following feature set: High-performance, non-blocking, multithreaded architecture with SIMD support. Advanced SCSI feature set: * Persistent Reservations (PRs) * Asymmetric Logical Unit Assignment (ALUA) * Protocol and intra-nexus multiplexing, load-balancing and failover (MC/S) * Full Error Recovery (ERL=0,1,2) * Active/active task migration and session continuation (ERL=2) * Thin LUN provisioning (UNMAP and WRITE_SAMExx) Multiprotocol target plugins Storage media independence: * Virtualization of all storage media; transparent mapping of IO to LUNs * No hard limits on number of LUNs per Target; maximum LUN size ~750 TB * Backstores: SATA, SAS, SCSI, BluRay, DVD, FLASH, USB, ramdisk, etc. Standards compliance: * Full compliance with IETF (RFC 3720) * Full implementation of SPC-4 PRs and ALUA Significant code cleanups done by Christoph Hellwig. [jejb: fix up for new block bdev exclusive interface. Minor fixes from Randy Dunlap and Dan Carpenter.] Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
