path: root/drivers/target/target_core_file.c
2011-07-22target: Follow up core updates from AGrover and HCH (round 4)Andy Grover
This patch contains the squashed version of forth round series cleanups from Andy and Christoph following the post heavy lifting in the preceeding: 'Eliminate usage of struct se_mem' and 'Make all control CDBs scatter-gather' changes. This also includes a conversion of target core and the v3.0 mainline fabric modules (loopback and tcm_fc) to use pr_debug and the CONFIG_DYNAMIC_DEBUG infrastructure! These have been squashed into this third and final round for v3.1. target: Remove ifdeffed code in t_g_process_write target: Remove direct ramdisk code target: Rename task_sg_num to task_sg_nents target: Remove custom debug macros for pr_debug. Use pr_err(). target: Remove custom debug macros in mainline fabrics target: Set WSNZ=1 in block limits VPD. Abort if WRITE_SAME sectors = 0 target: Remove transport do_se_mem_map callback target: Further simplify transport_free_pages target: Redo task allocation return value handling target: Remove extra parentheses target: change alloc_task call to take *cdb, not *cmd (nab: Fix bogus struct file assignments in fd_do_readv and fd_do_writev) Signed-off-by: Andy Grover <agrover@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2011-07-22target: Updates from AGrover and HCH (round 3)Andy Grover
This patch contains a squashed version of third round series cleanups, improvements ,and simplfications from Andy and Christoph ahead of the heavy lifting between round 3 -> 4 for the target core SGL conversion. This include cleanups to the main target I/O path and other miscellaneous updates. target: Replace custom sg<->buf functions with lib funcs target: Simplify sector limiting code target: get_cdb should never return NULL target: Simplify transport_memcpy_se_mem_read_contig target: Use assignment rather than increment for t_task_cdbs target: Don't pass dma_size to generic_get_mem target: Pass sg with type scatterlist in transport_map_sg_to_mem target: Move task_sg_num next to task_sg in struct se_task target: inline struct se_transport_task into struct se_cmd target: Change name & semantics of transport_get_sectors() target: Remove unused members of se_cmd target: Rename se_cmd.t_task_cdbs to t_task_list_num target: Fix some spelling target: Remove unused var from transport_generic_do_tmr target: map_sg_to_mem: return sg_count in return value target/pscsi: Use min_t for sector limits target/pscsi: Unused param for pscsi_get_bio() target: Rename get_cdb_count to allocate_tasks target: Make transport_generic_new_cmd() available for iscsi-target target: Remove fabric callback to allocate iovecs target: Fix transport_generic_new_cmd WRITE comment (hch: Use __GFP_ZERO usage for alloc_pages() usage) Signed-off-by: Andy Grover <agrover@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2011-07-22target: More core cleanups from AGrover (round 2)Andy Grover
This patch contains the squashed version of second round of target core cleanups and simplifications and Andy and Co. It also contains a handful of fixes to address bugs the original series and other minor cleanups. Here is the condensed shortlog: target: Remove unneeded casts to void* target: Rename get_lun_for_{cmd,tmr} to lookup_{cmd,tmr}_lun target: Make t_task a member of se_cmd, not a pointer target: Handle functions returning "-2" target: Use cmd->se_dev over cmd->se_lun->lun_se_dev target: Embed qr in struct se_cmd target: Replace embedded struct se_queue_req with a list_head target: Rename list_heads that are nodes in struct se_cmd to "*_node" target: Fold transport_device_setup_cmd() into lookup_{tmr,cmd}_lun() target: Make t_mem_list and t_mem_list_bidi members of t_task target: Add comment & cleanup transport_map_sg_to_mem() target: Remove unneeded checks in transport_free_pages() (Roland: Fix se_queue_req removal leftovers OOPs) (nab: Fix transport_lookup_tmr_lun failure case) (nab: Fix list_empty(&cmd->t_task.t_mem_bidi_list) inversion bugs) Signed-off-by: Andy Grover <agrover@redhat.com> Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2011-07-22target: Core cleanups from AGrover (round 1)Andy Grover
This patch contains the squashed version of a number of cleanups and minor fixes from Andy's initial series (round 1) for target core this past spring. The condensed log looks like: target: use errno values instead of returning -1 for everything target: Rename transport_calc_sg_num to transport_init_task_sg target: Fix leak in error path in transport_init_task_sg target/pscsi: Remove pscsi_get_sh() usage target: Make two runtime checks into WARN_ONs target: Remove hba queue depth and convert to spin_lock_irq usage target: dev->dev_status_queue_obj is unused target: Make struct se_queue_req.cmd type struct se_cmd * target: Remove __transport_get_qr_from_queue() target: Rename se_dev->g_se_dev_list to se_dev_node target: Remove struct se_global target: Simplify scsi mib index table code target: Make dev_queue_obj a member of se_device instead of a pointer target: remove extraneous returns at end of void functions target: Ensure transport_dump_vpd_ident_type returns null-terminated str target: Function pointers don't need to use '&' to be assigned target: Fix comment in __transport_execute_tasks() target: Misc style cleanups target: rename struct pr_reservation_template to pr_reservation target: Remove #defines that just perform indirection target: Inline transport_get_task_from_execute_queue() target: Minor header comment fixes Signed-off-by: Andy Grover <agrover@redhat.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2011-03-23[SCSI] target: Fix FILEIO fd_buffered_io= token typoNicholas Bellinger
This patch fixes a token typo for the TCM/FILEIO match_table_t used for toggling O_SYNC usage for individual struct file backend access. Reported-by: Christophe Fergeau <cfergeau@gmail.com> Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-03-23[SCSI] target: Convert backend ->create_virtdevice() call to return ERR_PTRNicholas Bellinger
This patch converts the target_core_store_dev_enable() -> struct se_subsystem_api->create_virtdevice() call to return proper ERR_PTR values back up to configfs logic during backend dependent struct se_device ENABLE exception conditions. Along with the change to target_core_configfs.c, this includes converting IBLOCK, FILEIO, pSCSI, and RAMDISK_* backend subsystem plugins to obtain upper level PTR_ERR return codes (where available), and return via ERR_PTR during a *_create_virtdev() failure. Reported-by: Fubo Chen <fubo.chen@gmail.com> Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-03-23[SCSI] target: Fix match_strdup() memory leaksJesper Juhl
match_strdup() dynamically allocates memory and it is the responsabillity of the caller to free that memory. The following three cases: drivers/target/target_core_file.c:fd_set_configfs_dev_params() drivers/target/target_core_iblock.c:iblock_set_configfs_dev_params() drivers/target/target_core_configfs.c:target_core_dev_pr_store_attr_res_aptpl_metadata() should be kfree()'ing the allocated memory once it is no longer needed. It also makes sure to return -ENOMEM if the memory allocation in match_strdup() should fail. For target_core_configfs.c, this patch adds kfree()'s around Opt_initiator_fabric, Opt_initiator_node, Opt_initiator_sid, Opt_sa_res_key, Opt_target_fabric, and Opt_target_node for the Persistent Reservations Activate Persistence across Target Power Loss (APTPL=1) token parsing. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-03-02drivers: remove extraneous includes of smp_lock.hArnd Bergmann
These were missed the last time I cleaned this up globally, because of code moving around or new code getting merged. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-01-14[SCSI] target: Add LIO target core v4.0.0-rc6Nicholas Bellinger
LIO target is a full featured in-kernel target framework with the following feature set: High-performance, non-blocking, multithreaded architecture with SIMD support. Advanced SCSI feature set: * Persistent Reservations (PRs) * Asymmetric Logical Unit Assignment (ALUA) * Protocol and intra-nexus multiplexing, load-balancing and failover (MC/S) * Full Error Recovery (ERL=0,1,2) * Active/active task migration and session continuation (ERL=2) * Thin LUN provisioning (UNMAP and WRITE_SAMExx) Multiprotocol target plugins Storage media independence: * Virtualization of all storage media; transparent mapping of IO to LUNs * No hard limits on number of LUNs per Target; maximum LUN size ~750 TB * Backstores: SATA, SAS, SCSI, BluRay, DVD, FLASH, USB, ramdisk, etc. Standards compliance: * Full compliance with IETF (RFC 3720) * Full implementation of SPC-4 PRs and ALUA Significant code cleanups done by Christoph Hellwig. [jejb: fix up for new block bdev exclusive interface. Minor fixes from Randy Dunlap and Dan Carpenter.] Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
