path: root/drivers/target/target_core_pscsi.c
2011-05-24[SCSI] target: Convert TASK_ATTR to scsi_tcq.h definitionsNicholas Bellinger
This patch converts target core and follwing scsi-misc upstream fabric modules to use include/scsi/scsi_tcq.h includes for SIMPLE, HEAD_OF_QUEUE and ORDERED SCSI tasks instead of scsi/libsas.h with TASK_ATTR* *) tcm_loop: Convert tcm_loop_allocate_core_cmd() + tcm_loop_device_reset() to scsi_tcq.h *) tcm_fc: Convert ft_send_cmd() from FCP_PTA_* to scsi_tcq.h Reported-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: James Bottomley <jbottomley@parallels.com>
2011-03-23[SCSI] target: Minor sparse warning fixes and annotationsDan Carpenter
This patch addresses the majority of sparse warnings and adds proper locking annotations. It also fixes the dubious one-bit signed bitfield, for which the signed one-bit types can be 0 or -1 which can cause a problem if someone ever checks if (foo->lu_gp_assoc == 1). The current code is fine because everyone just checks zero vs non-zero. But Sparse complains about it so lets change it. The warnings look like this: include/target/target_core_base.h:228:26: error: dubious one-bit signed bitfield Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Fubo Chen <fubo.chen@gmail.com> Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-03-23[SCSI] target: Convert backend ->create_virtdevice() call to return ERR_PTRNicholas Bellinger
This patch converts the target_core_store_dev_enable() -> struct se_subsystem_api->create_virtdevice() call to return proper ERR_PTR values back up to configfs logic during backend dependent struct se_device ENABLE exception conditions. Along with the change to target_core_configfs.c, this includes converting IBLOCK, FILEIO, pSCSI, and RAMDISK_* backend subsystem plugins to obtain upper level PTR_ERR return codes (where available), and return via ERR_PTR during a *_create_virtdev() failure. Reported-by: Fubo Chen <fubo.chen@gmail.com> Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-03-23[SCSI] target: Fix memory leak on error path in pscsi_alloc_taskRoland Dreier
If allocation of pt->pscsi_cdb fails, we need to free the just-allocated pt or else it will be leaked. Signed-off-by: Roland Dreier <rolandd@cisco.com> Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-03-02drivers: remove extraneous includes of smp_lock.hArnd Bergmann
These were missed the last time I cleaned this up globally, because of code moving around or new code getting merged. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-02-12[SCSI] target: iblock/pscsi claim checking for NULL instead of IS_ERRDan Carpenter
blkdev_get_by_path() returns an ERR_PTR() or error and it doesn't return a NULL. It looks like this bug would be easy to trigger by mistake. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-01-14[SCSI] target: Add LIO target core v4.0.0-rc6Nicholas Bellinger
LIO target is a full featured in-kernel target framework with the following feature set: High-performance, non-blocking, multithreaded architecture with SIMD support. Advanced SCSI feature set: * Persistent Reservations (PRs) * Asymmetric Logical Unit Assignment (ALUA) * Protocol and intra-nexus multiplexing, load-balancing and failover (MC/S) * Full Error Recovery (ERL=0,1,2) * Active/active task migration and session continuation (ERL=2) * Thin LUN provisioning (UNMAP and WRITE_SAMExx) Multiprotocol target plugins Storage media independence: * Virtualization of all storage media; transparent mapping of IO to LUNs * No hard limits on number of LUNs per Target; maximum LUN size ~750 TB * Backstores: SATA, SAS, SCSI, BluRay, DVD, FLASH, USB, ramdisk, etc. Standards compliance: * Full compliance with IETF (RFC 3720) * Full implementation of SPC-4 PRs and ALUA Significant code cleanups done by Christoph Hellwig. [jejb: fix up for new block bdev exclusive interface. Minor fixes from Randy Dunlap and Dan Carpenter.] Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
