With qla2xxx, acl_node_lock is taken inside qla2xxx's hardware_lock,
which is taken in hardirq context. This means acl_node_lock must become
an IRQ-disabling lock; in particular this fixes lockdep warnings along
the lines of
[ INFO: HARDIRQ-safe -> HARDIRQ-unsafe lock order detected ]
(&(&se_tpg->acl_node_lock)->rlock){+.....}, at: [<ffffffffa026f872>] transport_deregister_session+0x92/0x140 [target_core_mod]
and this task is already holding:
(&(&ha->hardware_lock)->rlock){-.-...}, at: [<ffffffffa017c5e7>] qla_tgt_stop_phase1+0x57/0x2c0 [qla2xxx]
which would create a new lock dependency:
(&(&ha->hardware_lock)->rlock){-.-...} -> (&(&se_tpg->acl_node_lock)->rlock){+.....}
but this new dependency connects a HARDIRQ-irq-safe lock:
to a HARDIRQ-irq-unsafe lock:
Signed-off-by: Roland Dreier <roland@purestorage.com>
This patch changes target_emulate_inquiry_std() to set the 'not connected'
(0x35) bit in standard INQUIRY response data when we are processing a
request to a virtual LUN=0 mapping from struct se_device *g_lun0_dev that
have been setup for us in transport_lookup_cmd_lun().
This addresses an issue where qla2xxx FC clients need to be able
to create demo-mode I_T FC Nexuses by default, but should not be
exposing the default set of TPG LUNs to all FC clients. This includes
adding an new optional target_core_fabric_ops->tpg_check_demo_mode_login_only()
caller to allow demo_mode nexuses to skip the old default of bulding
a demo-mode MappedLUNs list via core_tpg_add_node_to_devs().
(roland: Add missing tpg_check_demo_mode_login_only check in core_dev_add_lun)
Reported-by: Roland Dreier <roland@purestorage.com>
Cc: Andrew Vasquez <andrew.vasquez@qlogic.com>
Signed-off-by: Nicholas Bellinger <nab@risingtidesystems.com>
This patch contains the squashed version of forth round series cleanups
from Andy and Christoph following the post heavy lifting in the preceeding:
'Eliminate usage of struct se_mem' and 'Make all control CDBs scatter-gather'
changes. This also includes a conversion of target core and the v3.0
mainline fabric modules (loopback and tcm_fc) to use pr_debug and the
CONFIG_DYNAMIC_DEBUG infrastructure!
These have been squashed into this third and final round for v3.1.
target: Remove ifdeffed code in t_g_process_write
target: Remove direct ramdisk code
target: Rename task_sg_num to task_sg_nents
target: Remove custom debug macros for pr_debug. Use pr_err().
target: Remove custom debug macros in mainline fabrics
target: Set WSNZ=1 in block limits VPD. Abort if WRITE_SAME sectors = 0
target: Remove transport do_se_mem_map callback
target: Further simplify transport_free_pages
target: Redo task allocation return value handling
target: Remove extra parentheses
target: change alloc_task call to take *cdb, not *cmd
(nab: Fix bogus struct file assignments in fd_do_readv and fd_do_writev)
Signed-off-by: Andy Grover <agrover@redhat.com>
This patch contains the squashed version of a number of cleanups and
minor fixes from Andy's initial series (round 1) for target core this
past spring. The condensed log looks like:
target: use errno values instead of returning -1 for everything
target: Rename transport_calc_sg_num to transport_init_task_sg
target: Fix leak in error path in transport_init_task_sg
target/pscsi: Remove pscsi_get_sh() usage
target: Make two runtime checks into WARN_ONs
target: Remove hba queue depth and convert to spin_lock_irq usage
target: dev->dev_status_queue_obj is unused
target: Make struct se_queue_req.cmd type struct se_cmd *
target: Remove __transport_get_qr_from_queue()
target: Rename se_dev->g_se_dev_list to se_dev_node
target: Remove struct se_global
target: Simplify scsi mib index table code
target: Make dev_queue_obj a member of se_device instead of a pointer
target: remove extraneous returns at end of void functions
target: Ensure transport_dump_vpd_ident_type returns null-terminated str
target: Function pointers don't need to use '&' to be assigned
target: Fix comment in __transport_execute_tasks()
target: Misc style cleanups
target: rename struct pr_reservation_template to pr_reservation
target: Remove #defines that just perform indirection
target: Inline transport_get_task_from_execute_queue()
target: Minor header comment fixes
These were missed the last time I cleaned this up
globally, because of code moving around or new code
getting merged.
This patch removes the legacy procfs based target_core_mib.c code,
and moves the necessary scsi_index_tables functions and defines into
target_core_transport.c and target_core_base.h code to allow existing
fabric independent statistics to function.
This includes the removal of a handful of 'atomic_t mib_ref_count'
counters used in struct se_node_acl, se_session and se_hba to prevent
removal while using seq_list procfs walking logic.
[jejb: fix up compile failures]
Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
LIO target is a full featured in-kernel target framework with the
following feature set:
High-performance, non-blocking, multithreaded architecture with SIMD
support.
Advanced SCSI feature set:
* Persistent Reservations (PRs)
* Asymmetric Logical Unit Assignment (ALUA)
* Protocol and intra-nexus multiplexing, load-balancing and failover (MC/S)
* Full Error Recovery (ERL=0,1,2)
* Active/active task migration and session continuation (ERL=2)
* Thin LUN provisioning (UNMAP and WRITE_SAMExx)
Multiprotocol target plugins
Storage media independence:
* Virtualization of all storage media; transparent mapping of IO to LUNs
* No hard limits on number of LUNs per Target; maximum LUN size ~750 TB
* Backstores: SATA, SAS, SCSI, BluRay, DVD, FLASH, USB, ramdisk, etc.
Standards compliance:
* Full compliance with IETF (RFC 3720)
* Full implementation of SPC-4 PRs and ALUA
Significant code cleanups done by Christoph Hellwig.
[jejb: fix up for new block bdev exclusive interface. Minor fixes from
Randy Dunlap and Dan Carpenter.]
