commit 9b5cd7f37e1e018432111333e2a67f78ba41edfe upstream.
SBC-3 says:
A TRANSFER LENGTH field set to zero specifies that 256 logical
blocks shall be written. Any other value specifies the number
of logical blocks that shall be written.
The old code was always just returning the value in the TRANSFER LENGTH
byte. Fix this to return 256 if the byte is 0.
Signed-off-by: Roland Dreier <roland@purestorage.com>
transport_generic_map_mem_to_cmd
commit fef58a6096770ed6ab49103a430cc755254a74d9 upstream.
This patch changes transport_generic_map_mem_to_cmd() to reject SCSI data
overflow and to send exception status with CHECK_CONDITION + TCM_INVALID_CDB_FIELD
for fabrics that are passing a pre-populated struct scatterlist (eg: tcm_loop
and iscsi-target) being mapped into se_cmd->t_data_sg and se_cmd->t_data_nents.
This addresses an OOPs where transport_allocate_data_tasks() would walk
the incorrect post OVERFLOW cmd->data_length value beyond the end of
the passed scatterlist.
Cc: Andy Grover <agrover@redhat.com>
commit c252f003470a99d319db4ebd12f4a9e4710a65db upstream.
This patch fixes a bug where transport_send_task_abort() could be called
during LUN_RESET to return SAM_STAT_TASK_ABORTED + tfo->queue_status(), when
SCF_SENT_CHECK_CONDITION -> tfo->queue_status() has already been sent from
within another context via transport_send_check_condition_and_sense().
Signed-off-by: Nicholas Bellinger <nab@risingtidesystems.com>
commit 77039d1eafbbc192df71ee84b157b8973766737d upstream.
This patch fixes a bug in LUN_RESET operation with transport_cmd_finish_abort()
where transport_remove_cmd_from_queue() was incorrectly being called, causing
descriptors with t_state == TRANSPORT_FREE_CMD_INTR to be incorrectly removed
from qobj->qobj_list during process context release. This change ensures the
descriptor is only removed via transport_remove_cmd_from_queue() when doing a
direct release via transport_generic_remove().
commit 79a7fef26431830e22e282053d050af790117db8 upstream.
This patch addresses a bug with the lio-core-2.6.git conversion of
transport_add_cmd_to_queue() to use a single embedded list_head, instead
of individual struct se_queue_req allocations allowing a single se_cmd to
be added to the queue mulitple times. This was changed in the following:
commit 2a9e4d5ca5d99f4c600578d6285d45142e7e5208
Author: Andy Grover <agrover@redhat.com>
Date: Tue Apr 26 17:45:51 2011 -0700
target: Embed qr in struct se_cmd
The problem is that some target code still assumes performing multiple
adds is allowed via transport_add_cmd_to_queue(), which ends up causing
list corruption in qobj->qobj_list code. This patch addresses this
by removing an existing struct se_cmd from the list before the add, and
removes an unnecessary list walk in transport_remove_cmd_from_queue()
It also changes cmd->t_transport_queue_active to use explict sets intead
of increment/decrement to prevent confusion during exception path handling.
When work is scheduled with schedule_work(), the work can end up
running on multiple CPUs at the same time -- this happens if
the work is already running on one CPU and schedule_work() is called
on another CPU. This leads to list corruption with target_qf_do_work(),
which is roughly doing:
spin_lock(...);
list_for_each_entry_safe(...) {
list_del(...);
spin_unlock(...);
// do stuff
spin_lock(...);
With multiple CPUs running this code, one CPU can end up deleting the
list entry that the other CPU is about to work on.
Fix this by splicing the list entries onto a local list and then
operating on that in the work function. This way, each invocation of
target_qf_do_work() operates on its own local list and so multiple
invocations don't corrupt each other's list. This also avoids dropping
and reacquiring the lock for each list entry.
At least the tcm_qla2xxx fabric driver calls into transport_deregister_session()
while holding an IRQ-disabled spinlock, so the inner locking needs to
use spin_lock_irqsave() instead of spin_lock_bh().
This fixes warnings seen with tcm_qla2xxx like:
WARNING: at kernel/softirq.c:159 local_bh_enable_ip+0x98/0xb0()
Call Trace:
[<ffffffff8104e65f>] warn_slowpath_common+0x7f/0xc0
[<ffffffff8104e6ba>] warn_slowpath_null+0x1a/0x20
[<ffffffff81055368>] local_bh_enable_ip+0x98/0xb0
[<ffffffff814d5284>] _raw_spin_unlock_bh+0x14/0x20
[<ffffffffa027b7f6>] transport_deregister_session+0x96/0x180 [target_core_mod]
[<ffffffffa00f7731>] tcm_qla2xxx_free_session+0xd1/0x170 [tcm_qla2xxx]
[<ffffffffa01b9173>] qla_tgt_sess_put+0xc3/0x140 [qla2xxx]
[<ffffffffa01bf40f>] qla_tgt_stop_phase1+0x8f/0x2c0 [qla2xxx]
[<ffffffffa00f735e>] tcm_qla2xxx_tpg_store_enable+0x6e/0xd0 [tcm_qla2xxx]
[<ffffffffa026ca29>] target_fabric_tpg_attr_store+0x39/0x40 [target_core_mod]
[<ffffffffa00a575d>] configfs_write_file+0xbd/0x120 [configfs]
[<ffffffff811464a6>] vfs_write+0xc6/0x180
[<ffffffff811467c1>] sys_write+0x51/0x90
[<ffffffff814dd382>] system_call_fastpath+0x16/0x1b
This patch fixes two bugs associated with transport_do_task_sg_chain()
operation where transport_allocate_data_tasks() was incorrectly setting
task_padded_sg for all tasks, and causing bogus task->task_sg_nents
assignments + OOPsen with fabrics depending upon this code. The first bit
here adds a task_sg_nents_padded check in transport_allocate_data_tasks()
to include an extra SGL vector when necessary for tasks that expect to
be linked using sg_chain().
The second change involves making transport_do_task_sg_chain() properly
account for the extra SGL vector when task->task_padded_sg is set for
the non trailing ->task_sg or single ->task_sg allocations. Note this
patch also removes the BUG_ON(!task->task_padded_sg) check within
transport_do_task_sg_chain() as we expect this to happen normally
with the updated logic in transport_allocate_data_tasks(), along with
being bogus for CONTROL_SG_IO_CDB type payloads.
So far this bugfix has been tested with tcm_qla2xxx and iblock backends
in (task_count > 1)( and (task_count == 1) operation.
Reported-by: Kiran Patil <kiran.patil@intel.com>
Cc: Kiran Patil <kiran.patil@intel.com>
This patch addresses recent breakage with multiple se_task (task_count > 1)
operation following backend dev->se_sub_dev->se_dev_attrib.max_sectors in new
transport_allocate_data_tasks() code. The initial bug here was a bogus
task->task_sg_nents assignment in transport_allocate_data_tasks() based on
the passed parameter, which now uses DIV_ROUND_UP(task_size, PAGE_SIZE) to
determine the proper number of per task SGL entries for the (task_count > 1)
case.
This also means we now need to enforce a PAGE_SIZE aligned max_sector count
value for this to work as expected without bringing back the pre v3.1
transport_map_mem_to_sg() logic to handle SGL offsets across multiple tasks.
So this patch adds se_dev_align_max_sectors() to round down max_sectors as
necessary to ensure this alignment via se_dev_set_default_attribs() and
se_dev_align_max_sectors() and keeps it simple for (task_count > 1)
operation.
So far this bugfix has been tested with (task_count > 1) operation
using iscsi-target and iblock backends.
Reported-by: Chris Boot <bootc@bootc.net>
This patch adds the missing transport_cmd_get_valid_sectors() check for
SCF_SCSI_DATA_SG_IO_CDB type payloads to ensure that a received LBA + range
does not exeed past the end of associated backend struct se_device.
This patch also fixes a bug in the failure path of transport_new_cmd_obj()
where this check can fail, so change to use a signed 'rc' and return '-EINVAL'
to signal proper transport_generic_request_failure() handling.
This patch fixes a SYNCHRONIZE_CACHE CDB handling bug with IBLOCK/FILEIO
backends where transport_cmd_get_valid_sectors() was incorrectly rejecting
a zero LBA + range CDB from being processed, and returning CHECK_CONDITION.
This includes changing transport_cmd_get_valid_sectors() to return '0' on
success and '-EINVAL' on failure (this makes more sense than sectors),
and to only check transport_cmd_get_valid_sectors() when a non zero LBA +
range SYNCHRONIZE_CACHE operation has been receieved for the non passthrough
case.
For all flavours of WRITE_SAME, we only expect to handle a single block
of data-out buffer payload, regardless of the number of logical blocks
presented in the CDB. This patch changes all flavours of WRITE_SAME in
transport_generic_cmd_sequencer() to pass '1' into transport_get_size()
instead of the extracted 'sectors' to properly handle the default usage
of sg_write_same without the --xferlen parameter.
Reported-by: Eric Seppanen <eric@purestorage.com>
This patch adds initial WRITE_SAME (10) w/ UNMAP=1 support following updates in
sbcr26 to allow UNMAP=1 for the non 16 + 32 byte CDB case. It also refactors
current pSCSI passthrough passthrough checks into target_check_write_same_discard()
ahead of UNMAP=0 w/ write payload support into target_core_iblock.c.
This includes the support for handling WRITE_SAME in transport_emulate_control_cdb(),
and converts target_emulate_write_same to accept num_blocks directly for
WRITE_SAME, WRITE_SAME_16 and WRITE_SAME_32.
Cc: Roland Dreier <roland@purestorage.com>
This patch fixes a bug for fabrics using tfo->new_cmd_map() that
are expect transport_generic_request_failure() to be calling
transport_send_check_condition_and_sense() for both READ and WRITE,
instead of only for READ exceptions.
This was originally observed with a failed WRITE_SAME_16 w/ unmap=0
using tcm_loop.
This patch changes transport_send_check_condition_and_sense() for
TCM_NON_EXISTENT_LUN emulation to use 0x25 (LOGICAL UNIT NOT SUPPORTED)
instead of the original 0x20 (INVALID COMMAND OPERATION CODE). This is
helpful to distinguish between TCM_UNSUPPORTED_SCSI_OPCODE ASC=0x20
exceptions.
Signed-off-by: Nicholas A. Bellinger <nab@risingtidesystems.com>
This patch fixes a bug in transport_handle_cdb_direct() usage with target_core
where transport_generic_wait_for_tasks() was bypassing active I/O + usage of
cmd->t_transport_stop_comp because cmd->t_transport_active=1 was not being set
before dispatching with transport_generic_new_cmd(). The fix follows existing
usage in transport_generic_handle_cdb*() -> transport_add_cmd_to_queue() and
set these directly, as well as handle transport_generic_new_cmd() exceptions
for QUEUE_FULL and CHECK_CONDITION instead of propigating up to RX context
fabric code.
The bug was manifesting itself with the following SLUB poison overwritten
warnings with iscsi-target v4.1 LUNs using the new process context direct
operation during session reinstatement with active I/O exception handling:
[885410.498267] =============================================================================
[885410.621622] BUG lio_cmd_cache: Poison overwritten
[885410.621791] -----------------------------------------------------------------------------
[885410.621792]
[885410.623420] INFO: 0xffff880000cf3750-0xffff880000cf378d. First byte 0x6a instead of 0x6b
[885410.626332] INFO: Allocated in iscsit_allocate_cmd+0x1c/0xd4 [iscsi_target_mod] age=345 cpu=1 pid=22554
[885411.855189] INFO: Freed in iscsit_release_cmd+0x208/0x217 [iscsi_target_mod] age=1410 cpu=1 pid=22554
[885411.856048] INFO: Slab 0xffffea000002d480 objects=22 used=0 fp=0xffff880000cf7300 flags=0x4080
[885411.856368] INFO: Object 0xffff880000cf33c0 @offset=13248 fp=0xffff880000cf6780
<SNIP>
[885411.955678] Pid: 22554, comm: iscsi_trx Not tainted 3.0.0-rc7+ #30
[885411.956040] Call Trace:
[885411.957029] [<ffffffff810e5cf9>] print_trailer+0x12e/0x137
[885412.752879] [<ffffffff810e61d9>] check_bytes_and_report+0xb9/0xfd
[885412.754933] [<ffffffff810e62d2>] check_object+0xb5/0x192
[885412.755099] [<ffffffff810e6445>] __free_slab+0x96/0x13a
[885412.757008] [<ffffffff810e652a>] discard_slab+0x41/0x43
[885412.758171] [<ffffffff810e7a4c>] __slab_free+0xf3/0xfe
[885412.761027] [<ffffffffa030a536>] ? iscsit_release_cmd+0x208/0x217 [iscsi_target_mod]
[885412.761354] [<ffffffff810e7e95>] kmem_cache_free+0x6f/0xac
[885412.761536] [<ffffffffa030a536>] iscsit_release_cmd+0x208/0x217 [iscsi_target_mod]
[885412.762056] [<ffffffffa020e467>] ? iblock_free_task+0x34/0x39 [target_core_iblock]
[885412.762368] [<ffffffffa0314131>] lio_release_cmd+0x10/0x12 [iscsi_target_mod]
[885412.764129] [<ffffffffa02c2254>] transport_release_cmd+0x2f/0x33 [target_core_mod]
[885412.805024] [<ffffffffa02c230e>] transport_generic_remove+0xb6/0xc3 [target_core_mod]
[885412.806424] [<ffffffff81035b5f>] ? try_to_wake_up+0x1bd/0x1bd
[885412.809033] [<ffffffffa02c241f>] transport_generic_free_cmd+0x75/0x7d [target_core_mod]
[885412.810066] [<ffffffffa02c2643>] transport_generic_wait_for_tasks+0x21c/0x22b [target_core_mod]
[885412.811056] [<ffffffff8139f0b1>] ? mutex_lock+0x11/0x32
[885412.813059] [<ffffffff8139f0b1>] ? mutex_lock+0x11/0x32
[885412.813200] [<ffffffffa030b81d>] iscsit_close_connection+0x1d5/0x63a [iscsi_target_mod]
[885412.813517] [<ffffffffa0300a82>] iscsit_take_action_for_connection_exit+0xdb/0xe0 [iscsi_target_mod]
[885412.813851] [<ffffffffa03111e9>] iscsi_target_rx_thread+0x11f6/0x1221 [iscsi_target_mod]
[885412.829024] [<ffffffff81033e8d>] ? pick_next_task_fair+0xbe/0x10e
[885412.831010] [<ffffffffa030fff3>] ? iscsit_handle_scsi_cmd+0x91d/0x91d [iscsi_target_mod]
[885412.833011] [<ffffffffa030fff3>] ? iscsit_handle_scsi_cmd+0x91d/0x91d [iscsi_target_mod]
[885412.835010] [<ffffffff8105388a>] kthread+0x7d/0x85
[885412.837022] [<ffffffff813a7124>] kernel_thread_helper+0x4/0x10
[885412.838008] [<ffffffff8105380d>] ? kthread_worker_fn+0x145/0x145
[885412.840047] [<ffffffff813a7120>] ? gs_change+0x13/0x13
[885412.842007] FIX lio_cmd_cache: Restoring 0xffff880000cf3750-0xffff880000cf378d=0x6
This patch fixes a bug in WRITE_SAME_16 LBA assignment where get_unaligned_be16()
is incorrectly being used instead of get_unaligned_be64() for a 64-bit LBA.
This was introduced with:
commit a1d8b49abd60ba5d09e7c968731abcb0f8f1cbf6
Date: Mon May 2 17:12:10 2011 -0700
target: Updates from AGrover and HCH (round 3)
(target: inline struct se_transport_task into struct se_cmd)
This patch adds the new macro usage of include/linux/kernel.h:DIV_ROUND_UP_SECTOR_T
for the new DIV_ROUND_UP_ULL() usage for 32-bit architectures with unsigned long long
sector_t division in transport_allocate_data_tasks() usage for target_core_mod v4.1
Reported-by: Andrew Morton <akpm@linux-foundation.org>
Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org>
This patch drops transport_asciihex_to_binaryhex() in favor of proper
hex2bin usage from include/linux/kernel.h:hex2bin()
This patch breaks up the ->map_task_SG() backend call into two seperate
->map_control_SG() and ->map_data_SG() in order to better address
IBLOCK and pSCSI. IBLOCK only allocates bios for ->map_data_SG(), and
pSCSI will allocate a struct request for both cases.
This patch fixes incorrect usage of ->map_task_SG() for all se_cmd descriptors
in transport_generic_new_cmd() by moving the call into it's proper location
directly inside of transport_allocate_data_tasks()
Reported-by: Christoph Hellwig <hch@lst.de>
This patch contains the squashed version of forth round series cleanups
from Andy and Christoph following the post heavy lifting in the preceeding:
'Eliminate usage of struct se_mem' and 'Make all control CDBs scatter-gather'
changes. This also includes a conversion of target core and the v3.0
mainline fabric modules (loopback and tcm_fc) to use pr_debug and the
CONFIG_DYNAMIC_DEBUG infrastructure!
These have been squashed into this third and final round for v3.1.
target: Remove ifdeffed code in t_g_process_write
target: Remove direct ramdisk code
target: Rename task_sg_num to task_sg_nents
target: Remove custom debug macros for pr_debug. Use pr_err().
target: Remove custom debug macros in mainline fabrics
target: Set WSNZ=1 in block limits VPD. Abort if WRITE_SAME sectors = 0
target: Remove transport do_se_mem_map callback
target: Further simplify transport_free_pages
target: Redo task allocation return value handling
target: Remove extra parentheses
target: change alloc_task call to take *cdb, not *cmd
(nab: Fix bogus struct file assignments in fd_do_readv and fd_do_writev)
Signed-off-by: Andy Grover <agrover@redhat.com>
Both backstores and fabrics use arrays of struct scatterlist to describe
data buffers. However TCM used struct se_mems, basically a linked list
of scatterlist entries. We are able to simplify the code by eliminating
this intermediate data structure and just using struct scatterlist[]
throughout.
Also, moved attachment of task to cmd out of transport_generic_get_task
and into allocate_control_task and allocate_data_tasks. The reasoning
is that it's nonintuitive that get_task should automatically add it to
the cmd's task list -- it should just return an allocated, initialized
task. That's all it should do, based on the function's name, so either the
function shouldn't do it, or the name should change to encapsulate the
entire essence of what it does.
(nab: Fix compile warnings in tcm_fc, and make transport_kmap_first_data_page
honor sg->offset for SGLs from contigious memory with TCM_Loop, and
fix control se_cmd descriptor memory leak)
Since sectors is not modified, it's more straightforward to do this.
Due to all cdbs' data buffers being referenced by scatterlists, buffers
of more than a page are not contiguous. Instead of handling this in all
control command handlers, we may be able to get away with just limiting
control cdb data buffers to one page. The only control CDBs we handle that
have potentially large data buffers are REPORT LUNS and UNMAP, so if we
didn't want to live with this limitation, they would need to be modified
to walk the pages in the data buffer's sgl.
Previously, some control CDBs did not allocate memory in pages for their
data buffer, but just did a kmalloc. This patch makes all cdbs allocate
pages.
This has the benefit of streamlining some paths that had to behave
differently when we used two allocation methods. The downside is that
all accesses to the data buffer need to kmap it before use, and need to
handle data in page-sized chunks if more than a page is needed for a given
command's data buffer.
Finally, note that cdbs with no data buffers are handled a little
differently. Before, SCSI_NON_DATA_CDBs would not call get_mem at all
(they'd be in the final else in transport_allocate_resources) but now
these will make it into generic_get_mem, but just not allocate any
buffers.
This patch adds SCF_EMULATE_QUEUE_FULL support using -EAGAIN failures
via transport_handle_queue_full() to signal queue full in completion
path TFO->queue_data_in() and TFO->queue_status() callbacks.
This is done using a new se_cmd->transport_qf_callback() to handle
the following queue full exception cases within target core:
*) TRANSPORT_COMPLETE_OK (for completion path queue full)
*) TRANSPORT_COMPLETE_QF_WP (for TRANSPORT_WRITE_PENDING queue full)
*) transport_send_check_condition_and_sense() failure paths in
transport_generic_request_failure() and transport_generic_complete_ok()
All logic is driven using se_device->qf_work_queue -> target_qf_do_work()
to to requeue outstanding se_cmd at the head of se_dev->queue_obj->qobj_list
for transport_processing_thread() execution.
Tested using tcm_qla2xxx with MAX_OUTSTANDING_COMMANDS=128 for FCP READ
to trigger the TRANSPORT_COMPLETE_OK queue full cases, and a simulated
TFO->write_pending() -EAGAIN failure to trigger TRANSPORT_COMPLETE_QF_WP.
Reported-by: Roland Dreier <roland@purestorage.com>
This patch adds a transport_handle_cdb_direct() optimization for mapping
and queueing tasks directly from within fabric processing context by calling
the newly exported transport_generic_new_cmd(). This currently expects to
be called from process context only, and will fail if called within interrupt
context.
This patch also leaves transport_generic_handle_cdb() unmodified for the
moment to function as expected with existing tcm_fc and ib_srpt fabrics,
and will be removed once these have been converted and tested with v4.1
code using transport_handle_cdb_direct().
Based on Andy's original patch here:
[PATCH 39/42] target: Call transport_new_cmd instead of adding to cmd queue
The release_cmd_to_pool and release_cmd_direct methods are always the same.
Merge them into a single release_cmd method, and clean up the fallout.
(nab: fix breakage in transport_generic_free_cmd() parameter build breakage
in drivers/target/tcm_fc/tfc_cmd.c)
This patch contains a squashed version to remove unused SCF_* flags:
target: remove the unused SCF_SE_DISABLE_ONLINE_CHECK flag
target: remove the unused SCF_CMD_PASSTHROUGH_NOALLOC flag
target: remove the unused SCF_EMULATE_SYNC_UNMAP flag
target: remove the unused SCF_EMULATE_SYNC_CACHE flag
This patch contains a squashed version of third round series cleanups,
improvements ,and simplfications from Andy and Christoph ahead of the
heavy lifting between round 3 -> 4 for the target core SGL conversion.
This include cleanups to the main target I/O path and other miscellaneous
updates.
target: Replace custom sg<->buf functions with lib funcs
target: Simplify sector limiting code
target: get_cdb should never return NULL
target: Simplify transport_memcpy_se_mem_read_contig
target: Use assignment rather than increment for t_task_cdbs
target: Don't pass dma_size to generic_get_mem
target: Pass sg with type scatterlist in transport_map_sg_to_mem
target: Move task_sg_num next to task_sg in struct se_task
target: Change name & semantics of transport_get_sectors()
target: Remove unused members of se_cmd
target: Rename se_cmd.t_task_cdbs to t_task_list_num
target: Fix some spelling
target: Remove unused var from transport_generic_do_tmr
target: map_sg_to_mem: return sg_count in return value
target/pscsi: Use min_t for sector limits
target/pscsi: Unused param for pscsi_get_bio()
target: Rename get_cdb_count to allocate_tasks
target: Make transport_generic_new_cmd() available for iscsi-target
target: Remove fabric callback to allocate iovecs
target: Fix transport_generic_new_cmd WRITE comment
(hch: Use __GFP_ZERO usage for alloc_pages() usage)
This patch fixes the handling of WRITE_SAME_[16,32] emulation where a
WRITE_SAME_* CDB with number of blocks=0 was being rejected by SCSI
expected data transfer length overflow checking in target core.
It changes both CDB cases in transport_generic_cmd_sequencer() to use
dev->se_sub_dev->se_dev_attrib.block_size to match what sg_write_same
is sending us with --num=0. It also fixes target_emulate_write_same()
to properly determine the num_blocks with --num=0 case to determine the
remaining range for dev->transport->do_discard().
Reported-by: Chris Greiveldinger <chris.greiveldinger@rnanetworks.com>
This patch fixes a bug in the assignment of cmd->t_task.t_task_lba with
WRITE_SAME_16 to correctly use get_unaligned_be64() for the 64-bit LBA.
This patch contains the squashed version of second round of target core
cleanups and simplifications and Andy and Co. It also contains a handful
of fixes to address bugs the original series and other minor cleanups.
Here is the condensed shortlog:
target: Remove unneeded casts to void*
target: Rename get_lun_for_{cmd,tmr} to lookup_{cmd,tmr}_lun
target: Make t_task a member of se_cmd, not a pointer
target: Handle functions returning "-2"
target: Use cmd->se_dev over cmd->se_lun->lun_se_dev
target: Replace embedded struct se_queue_req with a list_head
target: Rename list_heads that are nodes in struct se_cmd to "*_node"
target: Fold transport_device_setup_cmd() into lookup_{tmr,cmd}_lun()
target: Make t_mem_list and t_mem_list_bidi members of t_task
target: Add comment & cleanup transport_map_sg_to_mem()
target: Remove unneeded checks in transport_free_pages()
(Roland: Fix se_queue_req removal leftovers OOPs)
(nab: Fix transport_lookup_tmr_lun failure case)
(nab: Fix list_empty(&cmd->t_task.t_mem_bidi_list) inversion bugs)
The code in transport_add_device_to_core_hba() really intends to make sure
that neither inquiry_prod nor inquiry_rev is NULL.
This patch contains the squashed version of a number of cleanups and
minor fixes from Andy's initial series (round 1) for target core this
past spring. The condensed log looks like:
target: use errno values instead of returning -1 for everything
target: Rename transport_calc_sg_num to transport_init_task_sg
target: Fix leak in error path in transport_init_task_sg
target/pscsi: Remove pscsi_get_sh() usage
target: Make two runtime checks into WARN_ONs
target: Remove hba queue depth and convert to spin_lock_irq usage
target: dev->dev_status_queue_obj is unused
target: Make struct se_queue_req.cmd type struct se_cmd *
target: Remove __transport_get_qr_from_queue()
target: Rename se_dev->g_se_dev_list to se_dev_node
target: Remove struct se_global
target: Simplify scsi mib index table code
target: Make dev_queue_obj a member of se_device instead of a pointer
target: remove extraneous returns at end of void functions
target: Ensure transport_dump_vpd_ident_type returns null-terminated str
target: Function pointers don't need to use '&' to be assigned
target: Fix comment in __transport_execute_tasks()
target: Misc style cleanups
target: rename struct pr_reservation_template to pr_reservation
target: Remove #defines that just perform indirection
target: Inline transport_get_task_from_execute_queue()
target: Minor header comment fixes
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
irq state
This patch converts transport_deregister_session_configfs() to save/restore
spinlock IRQ state for struct se_node_acl->nacl_sess_lock access as tcm_qla2xxx
logic expects to call transport_deregister_session_configfs() code with
irq save already held for struct qla_hw_data.
This patch converts target core and follwing scsi-misc upstream fabric
modules to use include/scsi/scsi_tcq.h includes for SIMPLE, HEAD_OF_QUEUE
and ORDERED SCSI tasks instead of scsi/libsas.h with TASK_ATTR*
*) tcm_loop: Convert tcm_loop_allocate_core_cmd() + tcm_loop_device_reset() to
scsi_tcq.h
*) tcm_fc: Convert ft_send_cmd() from FCP_PTA_* to scsi_tcq.h
Reported-by: Christoph Hellwig <hch@infradead.org>
Signed-off-by: James Bottomley <jbottomley@parallels.com>
This patch fixes a bug where task->task_execute_queue=1 was not being
cleared once se_task had been removed from se_device->execute_task_list,
resulting in an OOPs in core_tmr_lun_reset() for the task->task_active=0
case where transport_remove_task_from_execute_queue() was incorrectly
being called.
This patch fixes two cases in transport_get_task_from_execute_queue()
and transport_remove_task_from_execute_queue() to properly clear
task->task_execute_queue=0 once list_del(&task->t_execute_list) has
been called.
It also adds an explict check in transport_remove_task_from_execute_queue()
to dump_stack + return if called with task->task_execute_queue=0.
Cc: stable@kernel.org
This patch addresses a bug in the target core release path for HW
operation where transport_free_dev_tasks() was incorrectly being called
from transport_lun_remove_cmd() while releasing a se_cmd reference and
calling struct target_core_fabric_ops->queue_data_in().
This would result in a OOPs with HW target mode when the release of
se_task->task_sg[] would happen before pci_unmap_sg() can be called in
HW target mode fabric module code. This patch addresses the issue by
moving transport_free_dev_tasks() from transport_lun_remove_cmd() into
transport_generic_free_cmd(), and adding TRANSPORT_FREE_CMD_INTR and
transport_generic_free_cmd_intr() to allow se_cmd descriptor release
to happen fromfrom within transport_processing_thread() process context
when release of se_cmd is not possible from HW interrupt context.
This patch fixes a bug in transport_do_task_sg_chain() used by HW target
mode modules with sg_chain() to provide a single sg_next() walkable memory
layout for use with pci_map_sg() and friends. This patch addresses an
issue with mapping multiple small block max_sector tasks across multiple
struct se_task->task_sg[] mappings for HW target mode operation.
This was causing OOPs with (cmd->t_task->t_tasks_no > 1) I/O traffic for
HW target drivers using transport_do_task_sg_chain(), and has been tested
so far with tcm_fc(openfcoe), tcm_qla2xxx, and ib_srpt fabrics with
t_tasks_no > 1 IBLOCK backends using a smaller max_sectors to trigger the
original issue.
Acked-by: Kiran Patil <kiran.patil@intel.com>
Fast-forwarded to current state of Linus' tree as there are patches to be
applied for files that didn't exist on the old branch.
This patch removes a bogus conditional+return check within the failure path
of transport_add_device_to_core_hba(). This breakage was introduced during
the v4 conversion to remove struct se_cmd passthrough ops for INQUIRY /
READ_CAPCITY during struct se_device creation and registration process.
Reported-by: Julia Lawall <julia@diku.dk>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
In drivers/target/target_core_transport.c::transport_generic_get_mem()
there are a few potential memory leaks in the error paths. This patch
makes sure that we free previously allocated memory when other allocations
fail. It also moves some work (INIT_LIST_HEAD() and assignment to
se_mem->se_len) below all the allocations so that if something fails we
don't do the work at all.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
This patch changes include/target/target_core_tmr.h code to use
target specific 'TMR_*' prefixed definitions for fabric independent
SCSI Task Management Request/Request naming in include/scsi/scsi.h
definitions for mainline target code.
This patch addresses the majority of sparse warnings and adds
proper locking annotations. It also fixes the dubious one-bit signed
bitfield, for which the signed one-bit types can be 0 or -1 which can
cause a problem if someone ever checks if (foo->lu_gp_assoc == 1).
The current code is fine because everyone just checks zero vs non-zero.
But Sparse complains about it so lets change it. The warnings look like
this:
include/target/target_core_base.h:228:26: error: dubious one-bit signed bitfield
Signed-off-by: Fubo Chen <fubo.chen@gmail.com>
* 'config' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
BKL: That's all, folks
fs/locks.c: Remove stale FIXME left over from BKL conversion
ipx: remove the BKL
appletalk: remove the BKL
x25: remove the BKL
ufs: remove the BKL
hpfs: remove the BKL
drivers: remove extraneous includes of smp_lock.h
tracing: don't trace the BKL
adfs: remove the big kernel lock
