based mechanism
Problem: Changed from wake_up_interruptible -> wake_up_process and
wait_event_interruptible-> schedule_timeout_interruptible broke the FCoE
target. Earlier approach of wake_up_interruptible was also looking at
'queue_cnt' which is not necessary, because it increment of 'queue_cnt'
with wake_up_inetrriptible / waker_up_process introduces race condition.
Fix: Instead of fixing the code which used wake_up_process and remove
'queue_cnt', using work_queue based approach is cleaner and acheives
same result. As well, work queue based approach has less programming
overhead and OS manages threads which processes work queues.
This patch is developed by Christoph Hellwig and reviwed+validated by
Kiran Patil.
Signed-off-by: Kiran Patil <kiran.patil@intel.com>
Problem: HW DDP context wasn;t invalidated in case of ABORTS, etc...
This leads to the problem where memory pages which are used for DDP
as user descriptor could get reused for some other purpose (such as to
satisfy new memory allocation request either by kernel or user mode threads)
and since HW DDP context was not invalidated, HW continue to write to
those pages, hence causing memory corruption.
Fix: Either on incoming ABORTS or due to exchange time out, allowed the
target to cleanup HW DDP context if it was setup for respective ft_cmd.
Added new function to perform this cleanup, furthur it can be enhanced
for other cleanup activity.
Additinal Notes: To avoid calling ddp_done from multiple places, composed
the functionality in helper function "ft_invl_hw_context" and it is being
called from multiple places. Cleaned up code in function "ft_recv_write_data"
w.r.t DDP.
With qla2xxx, acl_node_lock is taken inside qla2xxx's hardware_lock,
which is taken in hardirq context. This means acl_node_lock must become
an IRQ-disabling lock; in particular this fixes lockdep warnings along
the lines of
[ INFO: HARDIRQ-safe -> HARDIRQ-unsafe lock order detected ]
(&(&se_tpg->acl_node_lock)->rlock){+.....}, at: [<ffffffffa026f872>] transport_deregister_session+0x92/0x140 [target_core_mod]
and this task is already holding:
(&(&ha->hardware_lock)->rlock){-.-...}, at: [<ffffffffa017c5e7>] qla_tgt_stop_phase1+0x57/0x2c0 [qla2xxx]
which would create a new lock dependency:
(&(&ha->hardware_lock)->rlock){-.-...} -> (&(&se_tpg->acl_node_lock)->rlock){+.....}
but this new dependency connects a HARDIRQ-irq-safe lock:
to a HARDIRQ-irq-unsafe lock:
Signed-off-by: Roland Dreier <roland@purestorage.com>
There's no need for the #ifdef protection when building into the kernel,
and in fact we need the module_init() for the initialization function to
be called.
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending:
tcm_fc: Handle DDP/SW fc_frame_payload_get failures in ft_recv_write_data
target: Fix bug for transport_generic_wait_for_tasks with direct operation
target: iscsi_target depends on NET
target: Fix WRITE_SAME_16 lba assignment breakage
MAINTAINERS: Add target-devel list for drivers/target/
iscsi-target: Fix CONFIG_SMP=n and CONFIG_MODULES=n build failure
iscsi-target: Fix snprintf usage with MAX_PORTAL_LEN
iscsi-target: Fix uninitialized usage of cmd->pad_bytes
iscsi-target: strlen() doesn't count the terminator
iscsi-target: Fix NULL dereference on allocation failure
Problem: HW DDP context was not invalidated in case of ABORTS, etc...
for other cleanup activity. Fix ft_recv_write_data() to properly handle
fc_frame_payload_get to return pointer to payload if it exist. If there is
no payload which is most common case (+ve case in case if DDP is working
as expected, it will return NULL. Yes, scope of buf is limited to printk.
Invalidation of HW context (which is done inside ft_invl_hw_context() is
necessary in SUCCESS and FAILURE case of DDP. Hence invalidation is DONE
as long as there was DDP setup (whether it worked correctly or not,
NOTE: For some reason, if there is any error w.r.t DDP such as out of
order packet reception, HW simply post the full packet in rx queue.
Cc: Robert W Love <robert.w.love@intel.com>
Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
fs: Merge split strings
treewide: fix potentially dangerous trailing ';' in #defined values/expressions
uwb: Fix misspelling of neighbourhood in comment
net, netfilter: Remove redundant goto in ebt_ulog_packet
trivial: don't touch files that are removed in the staging tree
lib/vsprintf: replace link to Draft by final RFC number
doc: Kconfig: `to be' -> `be'
doc: Kconfig: Typo: square -> squared
doc: Konfig: Documentation/power/{pm => apm-acpi}.txt
drivers/net: static should be at beginning of declaration
drivers/media: static should be at beginning of declaration
drivers/i2c: static should be at beginning of declaration
XTENSA: static should be at beginning of declaration
SH: static should be at beginning of declaration
MIPS: static should be at beginning of declaration
ARM: static should be at beginning of declaration
rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check
Update my e-mail address
PCIe ASPM: forcedly -> forcibly
gma500: push through device driver tree
Fix up trivial conflicts:
- arch/arm/mach-ep93xx/dma-m2p.c (deleted)
- drivers/gpio/gpio-ep93xx.c (renamed and context nearby)
- drivers/net/r8169.c (just context changes)
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (77 commits)
[SCSI] fix crash in scsi_dispatch_cmd()
[SCSI] sr: check_events() ignore GET_EVENT when TUR says otherwise
[SCSI] bnx2i: Fixed kernel panic due to illegal usage of sc->request->cpu
[SCSI] bfa: Update the driver version to 3.0.2.1
[SCSI] bfa: Driver and BSG enhancements.
[SCSI] bfa: Added support to query PHY.
[SCSI] bfa: Added HBA diagnostics support.
[SCSI] bfa: Added support for flash configuration
[SCSI] bfa: Added support to obtain SFP info.
[SCSI] bfa: Added support for CEE info and stats query.
[SCSI] bfa: Extend BSG interface.
[SCSI] bfa: FCS bug fixes.
[SCSI] bfa: DMA memory allocation enhancement.
[SCSI] bfa: Brocade-1860 Fabric Adapter vHBA support.
[SCSI] bfa: Brocade-1860 Fabric Adapter PLL init fixes.
[SCSI] bfa: Added Fabric Assigned Address(FAA) support
[SCSI] bfa: IOC bug fixes.
[SCSI] bfa: Enable ASIC block configuration and query.
[SCSI] bnx2i: Updated copyright and bump version
[SCSI] bnx2i: Modified to skip CNIC registration if iSCSI is not supported
Fix up some trivial conflicts in:
- drivers/scsi/bnx2fc/{bnx2fc.h,bnx2fc_fcoe.c}:
Crazy broadcom version number conflicts
- drivers/target/tcm_fc/tfc_cmd.c
Just trivial cleanups done on adjacent lines
This patch contains the squashed version of forth round series cleanups
from Andy and Christoph following the post heavy lifting in the preceeding:
'Eliminate usage of struct se_mem' and 'Make all control CDBs scatter-gather'
changes. This also includes a conversion of target core and the v3.0
mainline fabric modules (loopback and tcm_fc) to use pr_debug and the
CONFIG_DYNAMIC_DEBUG infrastructure!
These have been squashed into this third and final round for v3.1.
target: Remove ifdeffed code in t_g_process_write
target: Remove direct ramdisk code
target: Rename task_sg_num to task_sg_nents
target: Remove custom debug macros for pr_debug. Use pr_err().
target: Remove custom debug macros in mainline fabrics
target: Set WSNZ=1 in block limits VPD. Abort if WRITE_SAME sectors = 0
target: Remove transport do_se_mem_map callback
target: Further simplify transport_free_pages
target: Redo task allocation return value handling
target: Remove extra parentheses
target: change alloc_task call to take *cdb, not *cmd
(nab: Fix bogus struct file assignments in fd_do_readv and fd_do_writev)
Signed-off-by: Andy Grover <agrover@redhat.com>
Both backstores and fabrics use arrays of struct scatterlist to describe
data buffers. However TCM used struct se_mems, basically a linked list
of scatterlist entries. We are able to simplify the code by eliminating
this intermediate data structure and just using struct scatterlist[]
throughout.
Also, moved attachment of task to cmd out of transport_generic_get_task
and into allocate_control_task and allocate_data_tasks. The reasoning
is that it's nonintuitive that get_task should automatically add it to
the cmd's task list -- it should just return an allocated, initialized
task. That's all it should do, based on the function's name, so either the
function shouldn't do it, or the name should change to encapsulate the
entire essence of what it does.
(nab: Fix compile warnings in tcm_fc, and make transport_kmap_first_data_page
honor sg->offset for SGLs from contigious memory with TCM_Loop, and
fix control se_cmd descriptor memory leak)
Previously, some control CDBs did not allocate memory in pages for their
data buffer, but just did a kmalloc. This patch makes all cdbs allocate
pages.
This has the benefit of streamlining some paths that had to behave
differently when we used two allocation methods. The downside is that
all accesses to the data buffer need to kmap it before use, and need to
handle data in page-sized chunks if more than a page is needed for a given
command's data buffer.
Finally, note that cdbs with no data buffers are handled a little
differently. Before, SCSI_NON_DATA_CDBs would not call get_mem at all
(they'd be in the final else in transport_allocate_resources) but now
these will make it into generic_get_mem, but just not allocate any
buffers.
This patch converts ft_queue_cmd() to use wake_up_process() and
ft_thread() to use schedule_timeout_interruptible(MAX_SCHEDULE_TIMEOUT)
instead of wait_event_interruptible(). This fixes a potential race with
the wait_event_interruptible() conditional with qobj->queue_cnt in
ft_thread().
This patch also drops the unnecessary set_user_nice(current, -20) in
ft_thread(), and drops extra () around two if (!(acl)) conditionals in
tfc_conf.c.
Reported-by: Christoph Hellwig <hch@infradead.org>
This patch removes the unnecessary EXTRA_CFLAGS includes, and drops the
unused -DTCM_FC_DEBUG define.
The release_cmd_to_pool and release_cmd_direct methods are always the same.
Merge them into a single release_cmd method, and clean up the fallout.
(nab: fix breakage in transport_generic_free_cmd() parameter build breakage
in drivers/target/tcm_fc/tfc_cmd.c)
This patch contains a squashed version of third round series cleanups,
improvements ,and simplfications from Andy and Christoph ahead of the
heavy lifting between round 3 -> 4 for the target core SGL conversion.
This include cleanups to the main target I/O path and other miscellaneous
updates.
target: Replace custom sg<->buf functions with lib funcs
target: Simplify sector limiting code
target: get_cdb should never return NULL
target: Simplify transport_memcpy_se_mem_read_contig
target: Use assignment rather than increment for t_task_cdbs
target: Don't pass dma_size to generic_get_mem
target: Pass sg with type scatterlist in transport_map_sg_to_mem
target: Move task_sg_num next to task_sg in struct se_task
target: inline struct se_transport_task into struct se_cmd
target: Change name & semantics of transport_get_sectors()
target: Remove unused members of se_cmd
target: Rename se_cmd.t_task_cdbs to t_task_list_num
target: Fix some spelling
target: Remove unused var from transport_generic_do_tmr
target: map_sg_to_mem: return sg_count in return value
target/pscsi: Use min_t for sector limits
target/pscsi: Unused param for pscsi_get_bio()
target: Rename get_cdb_count to allocate_tasks
target: Make transport_generic_new_cmd() available for iscsi-target
target: Remove fabric callback to allocate iovecs
target: Fix transport_generic_new_cmd WRITE comment
(hch: Use __GFP_ZERO usage for alloc_pages() usage)
This patch contains the squashed version of second round of target core
cleanups and simplifications and Andy and Co. It also contains a handful
of fixes to address bugs the original series and other minor cleanups.
Here is the condensed shortlog:
target: Remove unneeded casts to void*
target: Rename get_lun_for_{cmd,tmr} to lookup_{cmd,tmr}_lun
target: Make t_task a member of se_cmd, not a pointer
target: Handle functions returning "-2"
target: Use cmd->se_dev over cmd->se_lun->lun_se_dev
target: Embed qr in struct se_cmd
target: Replace embedded struct se_queue_req with a list_head
target: Rename list_heads that are nodes in struct se_cmd to "*_node"
target: Fold transport_device_setup_cmd() into lookup_{tmr,cmd}_lun()
target: Make t_mem_list and t_mem_list_bidi members of t_task
target: Add comment & cleanup transport_map_sg_to_mem()
target: Remove unneeded checks in transport_free_pages()
(Roland: Fix se_queue_req removal leftovers OOPs)
(nab: Fix transport_lookup_tmr_lun failure case)
(nab: Fix list_empty(&cmd->t_task.t_mem_bidi_list) inversion bugs)
This patch contains the squashed version of a number of cleanups and
minor fixes from Andy's initial series (round 1) for target core this
past spring. The condensed log looks like:
target: use errno values instead of returning -1 for everything
target: Rename transport_calc_sg_num to transport_init_task_sg
target: Fix leak in error path in transport_init_task_sg
target/pscsi: Remove pscsi_get_sh() usage
target: Make two runtime checks into WARN_ONs
target: Remove hba queue depth and convert to spin_lock_irq usage
target: dev->dev_status_queue_obj is unused
target: Make struct se_queue_req.cmd type struct se_cmd *
target: Remove __transport_get_qr_from_queue()
target: Rename se_dev->g_se_dev_list to se_dev_node
target: Remove struct se_global
target: Simplify scsi mib index table code
target: Make dev_queue_obj a member of se_device instead of a pointer
target: remove extraneous returns at end of void functions
target: Ensure transport_dump_vpd_ident_type returns null-terminated str
target: Function pointers don't need to use '&' to be assigned
target: Fix comment in __transport_execute_tasks()
target: Misc style cleanups
target: rename struct pr_reservation_template to pr_reservation
target: Remove #defines that just perform indirection
target: Inline transport_get_task_from_execute_queue()
target: Minor header comment fixes
This patch removes the now unnecessary 'unsigned char *cdb' function
parameter from transport_get_lun_for_cmd(). This also includes updating
lio-target, tcm_loop and tcm_fc usage of transport_get_lun_for_cmd().
Reported-by: Fubo Chen <fubo.chen@gmail.com>
Sync with Linus' tree to be able to apply pending patches that
are based on newer code already present upstream.
to be deleted.
Problem: After fixing the issue in TCM core w.r.t LUN Reset (Task
Management request) , ran into issue where during the completing of
this LUN Reset command, reference count of "ft_sess" drops to zero
which caused "sess" to be deleted.
Fix: As part of handling task management request (e.g. LUN Reset), TCM
core function "transport_generic_do_tmr" ends up calling ft_free_cmd
which in turn calls "ft_sess_put" (which drops session's reference
count by 1) and then frees ft_cmd. Then function
"transport_generic_do_tmr" calls "transport_cmd_check_stop" which in
turn also calls ft_free_cmd (which calls ft_sess_put - which drops
reference count of sess by 1, hence reference count of sess becomes
zero and session gets deleted). Fix is to just send response in case
of tmr from function "ft_queue_resp_code" and not delete "ft_cmd"
(means don't call ft_free_cmd). Earlier code was to send the response
code and also free ft_cmd. ft_free_cmd will be freed later after
sending response code as a result of "transport_cmd_check_stop" (which
calls ft_release_cmd -> ft_free_cmd) being called from
"transport_generic_do_tmr" after sening TMR response code.
Notes/Dependencies: This bug was found after fixing NULL pointer
access issue in TCM core (in LUN Reset codepath)
Signed-off-by: Robert Love <robert.w.love@intel.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
FCoE DDP in target mode
The fcoe driver can implement ddp_targ() similarly to ddp_setup() when fcoe
stack works with existing target frame, e.g., tcm, where the ddp_targ() would
eventually point to the underlying hardware driver's implementation of
ndo_fcoe_ddp_targ() through net_device_ops. This new API sets up DDP context
for target appropriately by setting required bits for DDP context.
Signed-off-by: Yi Zou <yi.zou@intel.com>
This patch fixes the following conversion specification warning for size_t
drivers/target/tcm_fc/tfc_io.c: In function ‘ft_queue_data_in’:
drivers/target/tcm_fc/tfc_io.c:209: warning: format ‘%x’ expects type ‘unsigned int’, but argument 5 has type ‘size_t’
Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
There is a typo here, it should be an unlock instead of a lock. The
original code will deadlock.
This patch fixes a bug in ft_send_tm() that was incorrectly calling
ft_get_lun_for_cmd() -> transport_get_lun_for_cmd(), instead of using
transport_get_lun_for_tmr() for the proper struct se_lun lookup
that was triggering an OOPs in the se_cmd->tmr_req failure path.
This patch fixes the issue by re-arranging the codepath where
transport_get_lun_for_tmr() is called after tmr request is allocated and
made it available as part of se_cmd.
It also drops the now unnecessary ft_get_lun_for_cmd() unpacking code, and
uses scsilun_to_int() directly ahead of transport_get_lun_for_cmd() and
transport_get_lun_for_tmr() usage.
Signed-off-by: Patil, Kiran <kiran.patil@intel.com>
transport_init_session() and core_tmr_alloc_req() never return NULL,
they only return ERR_PTRs on error.
v2: Fix patch to return PTR_ERR(tl_nexus->se_sess) from Ankit Jain's
feedback.
Signed-off-by: Ankit Jain <jankit@suse.de>
Many stupid corrections of duplicated includes based on the output of
scripts/checkincludes.pl.
Signed-off-by: Vitaliy Ivanov <vitalivanov@gmail.com>
This patch converts target core and follwing scsi-misc upstream fabric
modules to use include/scsi/scsi_tcq.h includes for SIMPLE, HEAD_OF_QUEUE
and ORDERED SCSI tasks instead of scsi/libsas.h with TASK_ATTR*
*) tcm_loop: Convert tcm_loop_allocate_core_cmd() + tcm_loop_device_reset() to
scsi_tcq.h
*) tcm_fc: Convert ft_send_cmd() from FCP_PTA_* to scsi_tcq.h
Signed-off-by: James Bottomley <jbottomley@parallels.com>
This patch converts transport_core_report_lun_response() to use
drivers/scsi/scsi_scan.c:int_to_scsilun instead of using the
struct target_core_fabric_ops->pack_lun() fabric provided API vector.
It also removes the tfo->pack_lun check from target_fabric_tf_ops_check()
and removes from struct target_core_fabric_ops->pack_lun() from
target_core_fabric_ops.h, and the following mainline scsi-misc fabric
modules:
*) tcm_loop: Drop tcm_loop_pack_lun() usage
*) tcm_fc: Drop ft_pack_lun() usage
Reported-by: Mike Christie <michaelc@cs.wisc.edu>
scsi_tcq.h
modules:
core) support
This is a comprehensive patch for FC-FC4 provider. tcm_fc is a FC-FC4
provider which glues target core (TCM) with Fiber channel library
(libfc). tcm_fc uses existing FC4 provider hooks from Fiber channel
library. This Fiber channel library is used by FCoE (transport - FC
over Ethernet) protocol driver as well.
Combination of modules such as Fiber channel library, tcm_fc, TCM
target core, and FCoE protocol driver enables functional FCoE target.
This patch includes initial commit for tcm_fc plus additional
enhancement, bug fixes.
This tcm_fc module essentially contains 3 entry points such as "prli",
"prlo", "recv". When process login request (ELS_PRLI) request is
received, Fiber channel library (libfc) module calls passive providers
(FC-FC4, tcm_fc) (if any registered) "prli" function. Likewise when
LOGO request is received, "prlo" function of passive provider is
invoked by libfc. For all other request (e.g. any read/write, task
management, LUN inquiry commands), "recv" function of passiver
provider is invoked by libfc. Those passive providers "prli, prlo,
recv" functions interact with TCM target core for requested operation.
This module was primarily developed by "Joe Eykholt" and there were
significant contributions from the people listed under signed-off.
Signed-off-by: Joe Eykholt <jeykholt@cisco.com>
Acked-by: Robert Love <robert.w.love@intel.com>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
