Call request/release busfreq HIGH each time a SMC
is called.
This ensure that OPTEE is running in HIGH frequency mode
until no more SMC running
Signed-off-by: Cedric Neveux <cedric.neveux@nxp.com>
Acked-by: Peng Fan <peng.fan@nxp.com>
Modification of the L2 Cache operations to use
a TEE/Linux Shared mutex
Adds support for asynchronous supplicant requests, meaning that the
supplicant can process several requests in parallel or block in a
request for some time.
Acked-by: Etienne Carriere <etienne.carriere@linaro.org>
Tested-by: Etienne Carriere <etienne.carriere@linaro.org> (b2260 pager=y/n)
Signed-off-by: Jens Wiklander <jens.wiklander@linaro.org>
(cherry picked from commit c0b5b087a78777155603b0eb68dd9f9ab971330c)
Adds TEE_IOCTL_PARAM_ATTR_META with can be used to indicate meta
parameters when communicating with user space. These meta parameters can
be used by supplicant support multiple parallel requests at a time.
Reviewed-by: Etienne Carriere <etienne.carriere@linaro.org>
Modified from: From: https://github.com/linaro-swg/linux.git
drivers/tee/tee_core.c
(cherry picked from commit 66d81fcf145fdc55322c0a11764c76a43d90ecad)
(cherry picked from commit 747f68059436ac55c330ebffc5176b79006aafcf)
Adds a kernel internal TEE client interface to be used by other drivers.
(cherry picked from commit 860c46087c99c24073cc722b12c0017bb0ce0a79)
This change allows userland to create a tee_shm object that refers
to a dmabuf reference.
Userland provides a dmabuf file descriptor as buffer reference.
The created tee_shm object exported as a brand new dmabuf reference
used to provide a clean fd to userland. Userland shall closed this new
fd to release the tee_shm object resources. The initial dmabuf resources
are tracked independently through original dmabuf file descriptor.
Once the buffer is registered and until it is released, TEE driver
keeps a refcount on the registered dmabuf structure.
This change only support dmabuf references that relates to physically
contiguous memory buffers.
New tee_shm flag to identify tee_shm objects built from a registered
dmabuf: TEE_SHM_EXT_DMA_BUF. Such tee_shm structures are flagged both
TEE_SHM_DMA_BUF and TEE_SHM_EXT_DMA_BUF.
Signed-off-by: Etienne Carriere <etienne.carriere@linaro.org>
Reviewed-by: Jens Wiklander <jens.wiklander@linaro.org>
(cherry picked from commit 41e21e5c405530590dc2dd10b2a8dbe64589840f)
[ Upstream commit ab9d3db5b320a052452b9cd035599ee3c84bbee9 ]
This change prevents userland from referencing TEE shared memory
outside the area initially allocated by its owner. Prior this change an
application could not reference or access memory it did not own but
it could reference memory not explicitly allocated by owner but still
allocated to the owner due to the memory allocation granule.
Reported-by: Alexandre Jutras <alexandre.jutras@nxp.com>
commit bb765d1c331f62b59049d35607ed2e365802bef9 upstream.
Bump the file's refcount before moving the reference into the fd table,
not afterwards. The old code could drop the file's refcount to zero for a
short moment before calling get_file() via get_dma_buf().
This code can only be triggered on ARM systems that use Linaro's OP-TEE.
Fixes: 967c9cca2cc5 ("tee: generic TEE subsystem")
Signed-off-by: Jann Horn <jannh@google.com>
commit f044113113dd95ba73916bde10e804d3cdfa2662 upstream.
The first node supplied to of_find_matching_node() has its reference
counter decreased as part of call to that function. In optee_driver_init()
after calling of_find_matching_node() it's invalid to call of_node_put() on
the supplied node again.
So remove the invalid call to of_node_put().
Reported-by: Alex Shi <alex.shi@linaro.org>
Cc: <andi@linux-stable.l.notmuch.email>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
In the latest changes of optee_os, the interrupts' names are
changed to "native" and "foreign" interrupts.
Signed-off-by: David Wang <david.wang@arm.com>
Signed-off-by: Jerome Forissier <jerome.forissier@linaro.org>
Mirrors the TEE_DESC_PRIVILEGED bit of struct tee_desc:flags into struct
tee_ioctl_version_data:gen_caps as TEE_GEN_CAP_PRIVILEGED in
tee_ioctl_version()
Reviewed-by: Jerome Forissier <jerome.forissier@linaro.org>
Prior to this patch RPC sleep was uninterruptible since msleep() is
uninterruptible. Change to use msleep_interruptible() instead.
Signed-off-by: Tiger Yu <tigeryu99@hotmail.com>
Reviewed-by: Joakim Bech <joakim.bech@linaro.org>
Add const to tee_desc structures as they are only passed as an argument
to the function tee_device_alloc. This argument is of type const, so
declare these structures as const too.
Add const to tee_driver_ops structures as they are only stored in the
ops field of a tee_desc structure. This field is of type const, so
declare these structure types as const.
Signed-off-by: Bhumika Goyal <bhumirks@gmail.com>
dma_buf_ops are not supposed to change at runtime. All functions
working with dma_buf_ops provided by <linux/dma-buf.h> work with
const dma_buf_ops. So mark the non-const structs as const.
File size before:
2026 112 0 2138 85a drivers/tee/tee_shm.o
File size After adding 'const':
2138 0 0 2138 85a drivers/tee/tee_shm.o
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
Fixes the static checker warning in optee_release().
error: uninitialized symbol 'parg'.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
We've received a few fixes branches with -rc1 as base, but our contents was
still at pre-rc1. Merge it in expliticly to make 'git merge --log' clear on
hat was actually merged.
For the moment, the tee subsystem only makes sense in combination with
the op-tee driver that depends on ARM_SMCCC, so let's hide the subsystem
from users that can't select that.
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Pull TEE driver infrastructure and OP-TEE drivers from Arnd Bergmann:
"This introduces a generic TEE framework in the kernel, to handle
trusted environemtns (security coprocessor or software implementations
such as OP-TEE/TrustZone). I'm sending it separately from the other
arm-soc driver changes to give it a little more visibility, once the
subsystem is merged, we will likely keep this in the arm₋soc drivers
branch or have the maintainers submit pull requests directly,
depending on the patch volume.
I have reviewed earlier versions in the past, and have reviewed the
latest version in person during Linaro Connect BUD17.
Here is my overall assessment of the subsystem:
- There is clearly demand for this, both for the generic
infrastructure and the specific OP-TEE implementation.
- The code has gone through a large number of reviews, and the review
comments have all been addressed, but the reviews were not coming
up with serious issues any more and nobody volunteered to vouch for
the quality.
- The user space ioctl interface is sufficient to work with the
OP-TEE driver, and it should in principle work with other TEE
implementations that follow the GlobalPlatform[1] standards, but it
might need to be extended in minor ways depending on specific
requirements of future TEE implementations
- The main downside of the API to me is how the user space is tied to
the TEE implementation in hardware or firmware, but uses a generic
way to communicate with it. This seems to be an inherent problem
with what it is trying to do, and I could not come up with any
better solution than what is implemented here.
For a detailed history of the patch series, see
https://lkml.org/lkml/2017/3/10/1277"
* tag 'armsoc-tee' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
arm64: dt: hikey: Add optee node
Documentation: tee subsystem and op-tee driver
tee: add OP-TEE driver
dt/bindings: add bindings for optee
Adds a OP-TEE driver which also can be compiled as a loadable module.
* Targets ARM and ARM64
* Supports using reserved memory from OP-TEE as shared memory
* Probes OP-TEE version using SMCs
* Accepts requests on privileged and unprivileged device
* Uses OPTEE message protocol version 2 to communicate with secure world
Acked-by: Andreas Dannenberg <dannenberg@ti.com>
Tested-by: Jerome Forissier <jerome.forissier@linaro.org> (HiKey)
Tested-by: Volodymyr Babchuk <vlad.babchuk@gmail.com> (RCAR H3)
Tested-by: Scott Branden <scott.branden@broadcom.com>
Reviewed-by: Javier González <javier@javigon.com>
Initial patch for generic TEE subsystem.
This subsystem provides:
* Registration/un-registration of TEE drivers.
* Shared memory between normal world and secure world.
* Ioctl interface for interaction with user space.
* Sysfs implementation_id of TEE driver
A TEE (Trusted Execution Environment) driver is a driver that interfaces
with a trusted OS running in some secure environment, for example,
TrustZone on ARM cpus, or a separate secure co-processor etc.
The TEE subsystem can serve a TEE driver for a Global Platform compliant
TEE, but it's not limited to only Global Platform TEEs.
This patch builds on other similar implementations trying to solve
the same problem:
* "optee_linuxdriver" by among others
Jean-michel DELORME<jean-michel.delorme@st.com> and
Emmanuel MICHEL <emmanuel.michel@st.com>
* "Generic TrustZone Driver" by Javier González <javier@javigon.com>
