path: root/drivers/telephony
2010-05-10pcmcia: dev_node removal (write-only drivers)Dominik Brodowski
dev_node_t was only used to transport some minor/major numbers from the PCMCIA device drivers to deprecated userspace helpers. However, only a few drivers made use of it, and the userspace helpers are deprecated anyways. Therefore, get rid of dev_node_t . As a first step, remove any usage of dev_node_t from drivers which only wrote to this typedef/struct, but did not make use of it. CC: linux-bluetooth@vger.kernel.org CC: Harald Welte <laforge@gnumonks.org> CC: linux-mtd@lists.infradead.org CC: linux-wireless@vger.kernel.org CC: netdev@vger.kernel.org CC: linux-serial@vger.kernel.org CC: alsa-devel@alsa-project.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-12-07Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: kernel/irq/chip.c
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-11-09pcmcia: use dynamic debug infrastructure, deprecate CS_CHECK (misc drivers)Dominik Brodowski
Convert PCMCIA drivers to use the dynamic debug infrastructure, instead of requiring manual settings of PCMCIA_DEBUG. Also, remove all usages of the CS_CHECK macro and replace them with proper Linux style calling and return value checking. The extra error reporting may be dropped, as the PCMCIA core already complains about any (non-driver-author) errors. CC: linux-mtd@lists.infradead.org CC: linux-usb@vger.kernel.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-11telephony: trivial: fix up email addressAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-01saner FASYNC handling on file closeAl Viro
As it is, all instances of ->release() for files that have ->fasync() need to remember to evict file from fasync lists; forgetting that creates a hole and we actually have a bunch that *does* forget. So let's keep our lives simple - let __fput() check FASYNC in file->f_flags and call ->fasync() there if it's been set. And lose that crap in ->release() instances - leaving it there is still valid, but we don't have to bother anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20phonedev: remove BKLRichard Holden
The phone_device array is covered by the phone_lock mutex in all cases and request_module no longer needs the BKL so we can remove the only remaining instance of the BKL from phonedev. Signed-off-by: Richard Holden <aciddeath@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16telephony: remove CVS keywordsAdrian Bunk
Remove CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-23pcmcia: pcmcia_config_loop() improvement by passing vccDominik Brodowski
By passing the current Vcc setting to the pcmcia_config_loop callback function, we can remove pcmcia_get_configuration_info() calls from many drivers. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-08-23pcmcia: pcmcia_config_loop() default CIS entry handlingDominik Brodowski
Many drivers use the default CIS entry within their pcmcia_config_loop() callback function. Therefore, factor the default CIS entry handling out. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-08-23pcmcia: pcmcia_config_loop() ConfigIndex unificationDominik Brodowski
Almost all drivers set p_dev->conf.ConfigIndex to cfg->index in the pcmcia_config_loop() callback function. Therefore, factor it out. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-08-23pcmcia: use pcmcia_loop_config in misc pcmcia driversDominik Brodowski
Use the config loop helper in misc pcmcia drivers. CC: Harald Welte <laforge@gnumonks.org> CC: <linux-parport@lists.infradead.org> CC: Russell King <rmk+kernel@arm.linux.org.uk> CC: Ed Okerson <eokerson@quicknet.net> CC: linux-serial@vger.kernel.org CC: boti@rocketmail.com CC: linux-usb@vger.kernel.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-07-25ixj: push BKL into driver and wrap ioctlsAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Cc: Nishanth Aravamudan <nacc@us.ibm.com> Cc: Domen Puncer <domen@coderock.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-20phonedev: cdev lock_kernel() pushdownJonathan Corbet
phone_open() looks OK, but I don't trust the subsidiary drivers (and ixj in particular). Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2007-11-05telephony: phonedev panics if unregistering device not registered [Bug 9266]Matti Linnanvuori
Remove panic from phonedev. See http://bugzilla.kernel.org/show_bug.cgi?id=9266 for details (phonedev panics if unregistering device not registered). Signed-off-by: Matti Linnanvuori <mattilinnanvuori@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-12kconfig: syntax cleanup - drop support for "depends/requires/def_boolean"Adrian Bunk
Remove the following redundant and never or rarely used kconfig syntax: - "def_boolean" (same as "def_bool") - "requires" (same as "depends on") - "depends" (same as "depends on") This patch contains the code changes and Kconfig updates. The shipped files are in next patch to let actual codechange stand out. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Cc: Bryan Wu <bryan.wu@analog.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-19some kmalloc/memset ->kzalloc (tree wide)Yoann Padioleau
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc). Here is a short excerpt of the semantic patch performing this transformation: @@ type T2; expression x; identifier f,fld; expression E; expression E1,E2; expression e1,e2,e3,y; statement S; @@ x = - kmalloc + kzalloc (E1,E2) ... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\) - memset((T2)x,0,E1); @@ expression E1,E2,E3; @@ - kzalloc(E1 * E2,E3) + kcalloc(E1,E2,E3) [akpm@linux-foundation.org: get kcalloc args the right way around] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <bryan.wu@analog.com> Acked-by: Jiri Slaby <jirislaby@gmail.com> Cc: Dave Airlie <airlied@linux.ie> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Jiri Kosina <jkosina@suse.cz> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Pierre Ossman <drzeus-list@drzeus.cx> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Greg KH <greg@kroah.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17drivers/telephony/ixj: cleanup and fix gcc warningJeff Garzik
1) Fix gcc uninit'd var warnings by adding 'default' switch stmt labels in two cases. It was lightning-strikes unlikely that a problem would ever arise, but not impossible. 2) Tighten the scope of 'blankword' in two cases. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-17mark a bunch of ISA|EISA|PCI drivers as suchAl Viro
2007-07-16Use menuconfig objects II - TelephonyJan Engelhardt
Change Kconfig objects from "menu, config" into "menuconfig" so that the user can disable the whole feature without having to enter the menu first. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-10[S390] Kconfig: menus with depends on HAS_IOMEM.Martin Schwidefsky
Add "depends on HAS_IOMEM" to a number of menus to make them disappear for s390 which does not have I/O memory. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-05-08replace pci_find_device in drivers/telephony/ixj.cSurya
Cleaning up of pci_find_device in drivers/telephony/ixj.c. Signed-off-by: Surya Prabhakar <surya.prabhakar@wipro.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct file_operations const 6Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] drivers/telephony/ixj: Convert to generic booleanRichard Knutsson
Convert: BOOL -> bool FALSE -> false TRUE -> true Change a variable ('mContinue') to boolean from char, since it is used as boolean. Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] struct path: convert ixjJosef Sipek
2006-12-04[PATCH] pcmcia: conf.ConfigBase and conf.Present consolidationDominik Brodowski
struct pcmcia_device *p_dev->conf.ConfigBase and .Present are set in almost all PCMICA driver right at the beginning, using the same calls but slightly different implementations. Unfiy this in the PCMCIA core. Includes a small bugfix ("drivers/net/pcmcia/xirc2ps_cs.c: remove unused label") from and Signed-off-by Adrian Bunk <bunk@stusta.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-12-04[PATCH] pcmcia: remove prod_id indirectionDominik Brodowski
As we read out the product information strings (VERS_1) from the PCMCIA device in the PCMCIA core, and device drivers can access those reliably in struct pcmcia_device's fields prod_id[], remove additional product information string detection logic from PCMCIA device drivers. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-11-08[PATCH] drivers/telephony/ixj: fix an array overrunAdrian Bunk
The Coverity checker noted that in drivers/telephony/ixj.c:ixj_build_filter_cadence(), filter_en[4] or filter_en[5] could be written to. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-18[ixj] Add pci dev table for module auto loading.Ben Collins
Signed-off-by: Ben Collins <bcollins@ubuntu.com>
2006-06-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/devfs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/devfs-2.6: (22 commits) [PATCH] devfs: Remove it from the feature_removal.txt file [PATCH] devfs: Last little devfs cleanups throughout the kernel tree. [PATCH] devfs: Rename TTY_DRIVER_NO_DEVFS to TTY_DRIVER_DYNAMIC_DEV [PATCH] devfs: Remove the tty_driver devfs_name field as it's no longer needed [PATCH] devfs: Remove the line_driver devfs_name field as it's no longer needed [PATCH] devfs: Remove the videodevice devfs_name field as it's no longer needed [PATCH] devfs: Remove the gendisk devfs_name field as it's no longer needed [PATCH] devfs: Remove the miscdevice devfs_name field as it's no longer needed [PATCH] devfs: Remove the devfs_fs_kernel.h file from the tree [PATCH] devfs: Remove devfs_remove() function from the kernel tree [PATCH] devfs: Remove devfs_mk_cdev() function from the kernel tree [PATCH] devfs: Remove devfs_mk_bdev() function from the kernel tree [PATCH] devfs: Remove devfs_mk_symlink() function from the kernel tree [PATCH] devfs: Remove devfs_mk_dir() function from the kernel tree [PATCH] devfs: Remove devfs_*_tape() functions from the kernel tree [PATCH] devfs: Remove devfs support from the sound subsystem [PATCH] devfs: Remove devfs support from the ide subsystem. [PATCH] devfs: Remove devfs support from the serial subsystem [PATCH] devfs: Remove devfs from the init code [PATCH] devfs: Remove devfs from the partition code ...
2006-06-26[PATCH] devfs: Remove the devfs_fs_kernel.h file from the treeGreg Kroah-Hartman
Also fixes up all files that #include it. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove devfs_remove() function from the kernel treeGreg Kroah-Hartman
Removes the devfs_remove() function and all callers of it. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove devfs_mk_cdev() function from the kernel treeGreg Kroah-Hartman
Removes the devfs_mk_cdev() function and all callers of it. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26ixj: make ixj_set_tone_off() staticMatthew Martin
Signed-off-by: Matthew Martin <lihnucks@gmail.com> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-31[PATCH] pcmcia: use bitfield instead of p_state and stateDominik Brodowski
Instead of the two status values struct pcmcia_device->p_state and state, use descriptive bitfields. Most value-checking in drivers was invalid, as the core now only calls the ->remove() (a.k.a. detach) function in case the attachement _and_ configuration was successful. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: remove unused p_dev->state flagsDominik Brodowski
Remove the unused DEV_RELEASE_PENDING flag, and move the DEV_SUSPEND flag into the p_dev structure, and make use of it at the core level. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: add return value to _config() functionsDominik Brodowski
Most of the driver initialization isn't done in the .probe function, but in the internal _config() functions. Make them return a value, so that .probe can properly report whether the probing of the device succeeded or not. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: remove dev_link_t and client_handle_t indirectionDominik Brodowski
dev_link_t * and client_handle_t both mean struct pcmcai_device * by now. Therefore, remove all such indirections. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: embed dev_link_t into struct pcmcia_deviceDominik Brodowski
Embed dev_link_t into struct pcmcia_device(), as they basically address the same entity. The actual contents of dev_link_t will be cleaned up step by step. This patch includes a bugfix from and signed-off-by Andrew Morton. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: remove unneeded Vcc pseudo settingDominik Brodowski
As we do not allow setting Vcc in the pcmcia core, and Vpp1 and Vpp2 can only be set to the same value, a lot of code can be streamlined. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: default suspend and resume handlingDominik Brodowski
In all but one case, the suspend and resume functions of PCMCIA drivers contain mostly of calls to pcmcia_release_configuration() and pcmcia_request_configuration(). Therefore, move this code out of the drivers and into the core. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: convert remaining users of pcmcia_release_io and _irqDominik Brodowski
Convert the remaining drivers which use pcmcia_release_io or pcmcia_release_irq, and remove the EXPORT of these symbols. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-28[PATCH] mark f_ops const in the inodeArjan van de Ven
Mark the f_ops members of inodes as const, as well as fix the ripple-through this causes by places that copy this f_ops and then "do stuff" with it. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] sem2mutex: misc static one-file mutexesIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Dave Jones <davej@codemonkey.org.uk> Cc: Paul Mackerras <paulus@samba.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Jens Axboe <axboe@suse.de> Cc: Neil Brown <neilb@cse.unsw.edu.au> Acked-by: Alasdair G Kergon <agk@redhat.com> Cc: Greg KH <greg@kroah.com> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-03[PATCH] ixj: fix writing silence checkAlexey Dobriyan
j->write_buffer_rp is a pointer. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] pcmcia: unify attach, EVENT_CARD_INSERTION handlers into one probe ↵Dominik Brodowski
callback Unify the EVENT_CARD_INSERTION and "attach" callbacks to one unified probe() callback. As all in-kernel drivers are changed to this new callback, there will be no temporary backwards-compatibility. Inside a probe() function, each driver _must_ set struct pcmcia_device *p_dev->instance and instance->handle correctly. With these patches, the basic driver interface for 16-bit PCMCIA drivers now has the classic four callbacks known also from other buses: int (*probe) (struct pcmcia_device *dev); void (*remove) (struct pcmcia_device *dev); int (*suspend) (struct pcmcia_device *dev); int (*resume) (struct pcmcia_device *dev); Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-01-06[PATCH] pcmcia: remove dev_list from driversDominik Brodowski
The linked list of devices managed by each PCMCIA driver is, in very most cases, unused. Therefore, remove it from many drivers. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-01-06[PATCH] pcmcia: unify detach, REMOVAL_EVENT handlers into one remove callbackDominik Brodowski
Unify the "detach" and REMOVAL_EVENT handlers to one "remove" function. Old functionality is preserved, for the moment. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
