path: root/drivers/thermal/spear_thermal.c
2013-05-28Merge branches 'misc', 'drv_cleanup', 'devm-cleanup' and 'ti-soc' of .git ↵Zhang Rui
into next
2013-05-28Thermal: spear: Remove redundant use of of_match_ptrSachin Kamat
'spear_thermal_id_table' is always compiled in and the driver is dependent on OF. Hence use of of_match_ptr is unnecessary. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Cc: Vincenzo Frascino <vincenzo.frascino@st.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Eduardo Valentin <eduardo.valentin@ti.com> Signed-off-by: Zhang Rui <rui.zhang@intel.com>
2013-05-28Thermal: don't check resource with devm_ioremap_resourceZhang Rui
devm_ioremap_resource does sanity checks on the given resource. No need to duplicate this in the driver. CC: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> CC: Vincenzo Frascino <vincenzo.frascino@st.com> Signed-off-by: Zhang Rui <rui.zhang@intel.com> Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
2013-05-20Thermal: spear_thermal: convert to devm_ioremap_resourceZhang Rui
Use the newly introduced devm_ioremap_resource(). devm_ioremap_resource() provides its own error messages; so all explicit error messages can be removed from the failure code paths. CC: Vincenzo Frascino <vincenzo.frascino@st.com> Signed-off-by: Zhang Rui <rui.zhang@intel.com>
2013-05-06Thermal: spear: Remove redundant platform_set_drvdata()Sachin Kamat
Commit 0998d06310 (device-core: Ensure drvdata = NULL when no driver is bound) removes the need to set driver data field to NULL. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Cc: Vincenzo Frascino <vincenzo.frascino@st.com> Acked-by: Eduardo Valentin <eduardo.valentin@ti.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Zhang Rui <rui.zhang@intel.com>
2013-01-04drivers/thermal/spear_thermal.c: use devm_clk_getJulia Lawall
devm_clk_get allocates a resource that is released when a driver detaches. This patch uses devm_clk_get for data that is allocated in the probe function of a platform device and is only released in the remove function. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Zhang Rui <rui.zhang@intel.com>
2012-11-05Thermal: Pass zone parameters as argument to tzd_registerDurgadoss R
This patch adds the thermal zone parameter as an argument to the tzd_register() function call; and updates other drivers using this function. Signed-off-by: Durgadoss R <durgadoss.r@intel.com> Signed-off-by: Zhang Rui <rui.zhang@intel.com>
2012-09-24Thermal: Remove tc1/tc2 in generic thermal layer.Zhang Rui
Remove tc1/tc2 in generic thermal layer. .get_trend() callback starts to take effect from this patch. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Reviewed-by: Rafael J. Wysocki <rjw@sisk.pl> Reviewed-by: Valentin, Eduardo <eduardo.valentin@ti.com>
2012-07-26Merge branches 'acpi_pad', 'acpica', 'apei-bugzilla-43282', 'battery', ↵Len Brown
'cpuidle-coupled', 'cpuidle-tweaks', 'intel_idle-ivb', 'ost', 'red-hat-bz-772730', 'thermal', 'thermal-spear' and 'turbostat-v2' into release
2012-07-24Thermal: Make Thermal trip points writeableDurgadoss R
Some of the thermal drivers using the Generic Thermal Framework require (all/some) trip points to be writeable. This patch makes the trip point temperatures writeable on a per-trip point basis, and modifies the required function call in thermal.c. This patch also updates the Documentation to reflect the new change. Signed-off-by: Durgadoss R <durgadoss.r@intel.com> Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-06-02drivers/thermal/spear_thermal.c: add Device Tree probing capabilityViresh Kumar
SPEAr platforms now support DT and so must convert all drivers to support DT. This patch adds DT probing support for SPEAr thermal sensor driver and updates its documentation too. Also, as SPEAr is the only user of this driver and is only available with DT, make this an only DT driver. So, platform_data is completely removed and passed via DT now. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Cc: Dan Carpenter <dan.carpenter@oracle.com> Reviewed-by: Vincenzo Frascino <vincenzo.frascino@st.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2012-03-22thermal: spear13xx: checking for NULL instead of IS_ERR()Dan Carpenter
thermal_zone_device_register() never returns NULL, on error it returns and ERR_PTR(). Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Reviewed-by: Viresh Kumar <viresh.kumar@st.com> Reviewed-by: Vincenzo Frascino <vincenzo.frascino@st.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2012-03-22thermal/spear_thermal: replace readl/writel with lighter _relaxed variantsViresh Kumar
readl/writel versions for ARM contain memory barrier instruction for synchronizing DMA buffers. These are not required at least on this module. So use lighter _relaxed variants. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2012-03-22thermal: add support for thermal sensor present on SPEAr13xx machinesVincenzo Frascino
ST's SPEAr13xx machines are based on CortexA9 ARM processors. These machines contain a thermal sensor for junction temperature monitoring. This patch adds support for this thermal sensor in existing thermal framework. [akpm@linux-foundation.org: little code cleanup] [akpm@linux-foundation.org: print the pointer correctly] [viresh.kumar@st.com: thermal/spear_thermal: add compilation dependency on PLAT_SPEAR] Signed-off-by: Vincenzo Frascino <vincenzo.frascino@st.com> Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
