path: root/drivers/thunderbolt
2018-12-05thunderbolt: Export IOMMU based DMA protection support to userspaceMika Westerberg
Recent systems with Thunderbolt ports may support IOMMU natively. In practice this means that Thunderbolt connected devices are placed behind an IOMMU during the whole time it is connected (including during boot) making Thunderbolt security levels redundant. This is called Kernel DMA protection [1] by Microsoft. Some of these systems still have Thunderbolt security level set to "user" in order to support OS downgrade (the older version of the OS might not support IOMMU based DMA protection so connecting a device still relies on user approval). Export this information to userspace by introducing a new sysfs attribute (iommu_dma_protection). Based on it userspace tools can make more accurate decision whether or not authorize the connected device. In addition update Thunderbolt documentation regarding IOMMU based DMA protection. [1] https://docs.microsoft.com/en-us/windows/security/information-protection/kernel-dma-protection-for-thunderbolt Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Yehezkel Bernat <YehezkelShB@gmail.com>
2018-11-26thunderbolt: Prevent root port runtime suspend during NVM upgradeMika Westerberg
During NVM upgrade process the host router is hot-removed for a short while. During this time it is possible that the root port is moved into D3cold which would be fine if the root port could trigger PME on itself. However, many systems actually do not implement it so what happens is that the root port goes into D3cold and never wakes up unless userspace does PCI config space access, such as running 'lscpi'. For this reason we explicitly prevent the root port from runtime suspending during NVM upgrade. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-08Merge 4.19-rc7 into char-misc-nextGreg Kroah-Hartman
We want the fixes in here as well. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-02thunderbolt: Add Intel as copyright holderMika Westerberg
Intel has done pretty major changes to the driver and we continue to do so in the future as well. Add Intel as copyright holder of the files we have done changes. While there drop "Cactus Ridge" from the headers because this driver works also with other Thunderbolt controllers. No functional changes intended. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Yehezkel Bernat <yehezkelshb@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-02thunderbolt: Convert rest of the driver files to use SPDX identifierMika Westerberg
This gets rid of the licence boilerplate duplicated in each file. While there fix doubled space in domain.c author line. No functional changes intended. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Yehezkel Bernat <yehezkelshb@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-02thunderbolt: Print connected devicesMika Westerberg
The previous patch made the driver less verbose meanining that all the switch structures and ports are now logged as debug level. However, we have been missing similar output that USB for intance prints when a new USB device is connected and disconnected. This information is useful for end users as well as developers because it immediately shows the actual device that was connected. This patch adds printing of the actual connected devices to the driver. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Yehezkel Bernat <yehezkelshb@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-02thunderbolt: Make the driver less verboseMika Westerberg
Currently the driver logs quite a lot to the system message buffer even when doing normal operations. This information is not useful for ordinary users and might even annoy some. For this reason convert most of the logs at info level to happen at debug level instead. The nice output formatting is untouched. Logging can be easily re-enabled by passing "thunderbolt.dyndbg" in the kernel command line (or using the corresponding control file runtime). Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Yehezkel Bernat <yehezkelshb@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-02thunderbolt: Remove a meaningless NULL pointer check before dma_pool_destroyzhong jiang
dma_pool_destroy() already takes NULL pointer into account so there is no need to check that again in tb_ctl_free(). Signed-off-by: zhong jiang <zhongjiang@huawei.com> [mw: reword commit log a bit] Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-02thunderbolt: Initialize after IOMMUsMika Westerberg
If IOMMU is enabled and Thunderbolt driver is built into the kernel image, it will be probed before IOMMUs are attached to the PCI bus. Because of this DMA mappings the driver does will not go through IOMMU and start failing right after IOMMUs are enabled. For this reason move the Thunderbolt driver initialization happen at rootfs level. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-02thunderbolt: Do not handle ICM events after domain is stoppedMika Westerberg
If there is a long chain of devices connected when the driver is loaded ICM sends device connected event for each and those are put to tb->wq for later processing. Now if the driver gets unloaded in the middle, so that the work queue is not yet empty it gets flushed by tb_domain_stop(). However, by that time the root switch is already removed so the driver crashes when it tries to dereference it in ICM event handling callbacks. Fix this by checking whether the root switch is already removed. If it is we know that the domain is stopped and we should merely skip handling the event. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-25thunderbolt: Add support for runtime PMMika Westerberg
When Thunderbolt host controller is set to RTD3 mode (Runtime D3) it is present all the time. Because of this it is important to runtime suspend the controller whenever possible. In case of ICM we have following rules which all needs to be true before the host controller can be put to D3: - The controller firmware reports to support RTD3 - All the connected devices announce support for RTD3 - There is no active XDomain connection Implement this using standard Linux runtime PM APIs so that when all the children devices are runtime suspended, the Thunderbolt host controller PCI device is runtime suspended as well. The ICM firmware then starts powering down power domains towards RTD3 but it can prevent this if it detects that there is an active Display Port stream (this is not visible to the software, though). The Thunderbolt host controller will be runtime resumed either when there is a remote wake event (device is connected or disconnected), or when there is access from userspace that requires hardware access. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-25thunderbolt: Remove redundant variable 'approved'Colin Ian King
Variable 'approved' is being assigned but is never used hence it is redundant and can be removed. Cleans up clang warning: warning: variable 'approved' set but not used [-Wunused-but-set-variable] Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-25thunderbolt: Use correct ICM commands in system suspendMika Westerberg
The correct way to put the ICM into suspend state is to send it NHI_MAILBOX_DRV_UNLOADS mailbox command. NHI_MAILBOX_SAVE_DEVS is not needed on Intel Titan Ridge so we can skip it. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-25thunderbolt: No need to take tb->lock in domain suspend/completeMika Westerberg
If the connection manager implementation needs to touch the domain structures it ought to take the lock itself. Currently only ICM implements these hooks and it does not need the lock because we there will be no notifications before driver ready message is sent to it. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-25thunderbolt: Do not unnecessarily call ICM get routeMika Westerberg
This command is not really fast and can make resume time slower. We only need to get route again if the link was changed and during initial device connected message. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-25thunderbolt: Use 64-bit DMA mask if supported by the platformMika Westerberg
PCI defaults to 32-bit DMA mask but this device is capable of full 64-bit addressing, so make sure we first try 64-bit DMA mask before falling back to the default 32-bit. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-25thunderbolt: Fix small typo in variable nameNathan Ciobanu
Fixes small variable name typo and the associated checkpatch spelling warning. Signed-off-by: Nathan Ciobanu <nathan.d.ciobanu@linux.intel.com> Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-07thunderbolt: Notify userspace when boot_acl is changedMika Westerberg
The commit 9aaa3b8b4c56 ("thunderbolt: Add support for preboot ACL") introduced boot_acl attribute but missed the fact that now userspace needs to poll the attribute constantly to find out whether it has changed or not. Fix this by sending notification to the userspace whenever the boot_acl attribute is changed. Fixes: 9aaa3b8b4c56 ("thunderbolt: Add support for preboot ACL") Reported-and-tested-by: Christian Kellner <christian@kellner.me> Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Christian Kellner <christian@kellner.me> Acked-by: Yehezkel Bernat <yehezkelshb@gmail.com> Cc: stable@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-15thunderbolt: Handle NULL boot ACL entries properlyMika Westerberg
If the boot ACL entry is already NULL we should not fill in the upper two DWs with 0xfffffffff. Otherwise they are not shown as empty entries when the sysfs attribute is read. Fixes: 9aaa3b8b4c56 ("thunderbolt: Add support for preboot ACL") Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Yehezkel Bernat <yehezkelshb@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-14thunderbolt: Prevent crash when ICM firmware is not runningMika Westerberg
On Lenovo ThinkPad Yoga 370 (and possibly some other Lenovo models as well) the Thunderbolt host controller sometimes comes up in such way that the ICM firmware is not running properly. This is most likely an issue in BIOS/firmware but as side-effect driver crashes the kernel due to NULL pointer dereference: BUG: unable to handle kernel NULL pointer dereference at 0000000000000980 IP: pci_write_config_dword+0x5/0x20 Call Trace: pcie2cio_write+0x3b/0x70 [thunderbolt] icm_driver_ready+0x168/0x260 [thunderbolt] ? tb_ctl_start+0x50/0x70 [thunderbolt] tb_domain_add+0x73/0xf0 [thunderbolt] nhi_probe+0x182/0x300 [thunderbolt] local_pci_probe+0x42/0xa0 ? pci_match_device+0xd9/0x100 pci_device_probe+0x146/0x1b0 driver_probe_device+0x315/0x480 ... Instead of crashing update the driver to bail out gracefully if we encounter such situation. Fixes: f67cf491175a ("thunderbolt: Add support for Internal Connection Manager (ICM)") Reported-by: Jordan Glover <Golden_Miller83@protonmail.ch> Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Yehezkel Bernat <yehezkel.bernat@intel.com> Cc: stable@vger.kernel.org
2018-03-09thunderbolt: Add support for Intel Titan RidgeRadion Mirchevsky
Intel Titan Ridge is the next Thunderbolt 3 controller. The ICM firmware message format in Titan Ridge differs from Falcon Ridge and Alpine Ridge somewhat because it is using route strings addressing devices. In addition to that the DMA port of 4-channel (two port) controller is in different port number than the previous controllers. There are some other minor differences as well. This patch add support for Intel Titan Ridge and the new ICM firmware message format. Signed-off-by: Radion Mirchevsky <radion.mirchevsky@intel.com> Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2018-03-09thunderbolt: Introduce USB only (SL4) security levelMika Westerberg
This new security level works so that it creates one PCIe tunnel to the connected Thunderbolt dock, removing PCIe links downstream of the dock. This leaves only the internal USB controller visible. Display Port tunnels are created normally. While there make sure security sysfs attribute returns "unknown" for any future security level. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
2018-03-09thunderbolt: Add support for preboot ACLMika Westerberg
Preboot ACL is a mechanism that allows connecting Thunderbolt devices boot time in more secure way than the legacy Thunderbolt boot support. As with the legacy boot option, this also needs to be enabled from the BIOS before booting is allowed. Difference to the legacy mode is that the userspace software explicitly adds device UUIDs by sending a special message to the ICM firmware. Only the devices listed in the boot ACL are connected automatically during the boot. This works in both "user" and "secure" security levels. We implement this in Linux by exposing a new sysfs attribute (boot_acl) below each Thunderbolt domain. The userspace software can then update the full list as needed. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
2018-03-09thunderbolt: Add 'boot' attribute for devicesYehezkel Bernat
In various cases, Thunderbolt device can be connected by ICM on boot without waiting for approval from user. Most cases are related to OEM-specific BIOS configurations. This information is interesting for user-space as if the device isn't in SW ACL, it may create a friction in the user experience where the device is automatically authorized if it's connected on boot but requires an explicit user action if connected after OS is up. User-space can use this information to suggest adding the device to SW ACL for auto-authorization on later connections. Signed-off-by: Yehezkel Bernat <yehezkel.bernat@intel.com> Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
2018-03-09thunderbolt: Move driver ready handling to struct icmMika Westerberg
Intel Titan Ridge uses slightly different format for ICM driver ready response, so add a new ->driver_ready() callback to struct icm and move the existing handling to a separate function which we then use in Falcon Ridge and Alpine Ridge. No functional changes intended. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
2018-03-09thunderbolt: Add constant for approval timeoutMika Westerberg
We will be using this from Titan Ridge support code as well so make it constant. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
2018-03-09thunderbolt: Add tb_xdomain_find_by_route()Radion Mirchevsky
This is needed by the new ICM interface to find xdomains by route string instead of link and depth. While there update existing tb_xdomain_find_* functions to use tb_xdomain_get() instead of open-coding the same. Signed-off-by: Radion Mirchevsky <radion.mirchevsky@intel.com> Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
2018-03-09thunderbolt: Add tb_switch_find_by_route()Radion Mirchevsky
With the new ICM messaging there is need for find switch by route string instead of link and depth. Add new function that makes it possible. Signed-off-by: Radion Mirchevsky <radion.mirchevsky@intel.com> Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
2018-03-09thunderbolt: Add tb_switch_get()Mika Westerberg
Sometimes there is need for increasing reference count of a switch as well. This also follows what we have for xdomains. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
2018-03-09thunderbolt: Correct function name in kernel-doc commentRadion Mirchevsky
Use correct name in kernel-doc of tb_switch_find_by_uuid(). Signed-off-by: Radion Mirchevsky <radion.mirchevsky@intel.com> Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
2018-03-09thunderbolt: Factor common ICM add and update operations outMika Westerberg
The newer ICM will not use link and depth to address devices. Instead it uses route strings. In order to take advantage of the existing code factor out common operations so that we can use the same functions with the new ICM as well. No functional changes intended. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
2018-03-09thunderbolt: Handle rejected Thunderbolt devicesMika Westerberg
The ICM firmware rejects devices if the maximum topology limit is exceeded (more than 6 devices are connected). If that happens just log a message to the kernel message buffer and bail out. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
2018-03-09thunderbolt: Wait a bit longer for ICM to authenticate the active NVMMika Westerberg
Sometimes during cold boot ICM has not yet authenticated the active NVM image leading to timeout and failing the driver probe. Allow ICM to take some more time and increase the timeout to 3 seconds before we give up. While there fix icm_firmware_init() to return the real error code without overwriting it with -ENODEV. Fixes: f67cf491175a ("thunderbolt: Add support for Internal Connection Manager (ICM)") Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Cc: stable@vger.kernel.org
2018-03-09thunderbolt: Wait a bit longer for root switch config spaceMika Westerberg
In some case reading root switch config space takes longer than what we are currently waiting in the driver resulting timeout and failure. Increase number of retries to allow some more time for the root switch config space to become accesssible. Also log an error if the timeout is exceeded so we know why the driver probe failed. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
2018-03-09thunderbolt: Do not overwrite error code when domain adding failsMika Westerberg
If the Thunderbolt domain adding fails for some reason we currently always return -EIO instead of the real error code. To make debugging easier return the actual error code instead. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
2018-03-09thunderbolt: Handle connecting device in place of host properlyMika Westerberg
If the system is suspended and user disconnects cable to another host and connects it to a Thunderbolt device instead we get a warning from driver core about adding duplicate sysfs attribute and adding the new device fails. Handle this properly so that we first remove the existing XDomain connection before adding new devices. Fixes: d1ff70241a27 ("thunderbolt: Add support for XDomain discovery protocol") Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Cc: stable@vger.kernel.org
2018-03-09thunderbolt: Serialize PCIe tunnel creation with PCI rescanMika Westerberg
We need to make sure a new PCIe tunnel is not created in a middle of previous PCI rescan because otherwise the rescan code might find too much and fail to reconfigure devices properly. This is important when native PCIe hotplug is used. In BIOS assisted hotplug there should be no such issue. Fixes: f67cf491175a ("thunderbolt: Add support for Internal Connection Manager (ICM)") Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: stable@vger.kernel.org
2018-03-09thunderbolt: Resume control channel after hibernation image is createdMika Westerberg
The driver misses implementation of PM hook that undoes what ->freeze_noirq() does after the hibernation image is created. This means the control channel is not resumed properly and the Thunderbolt bus becomes useless in later stages of hibernation (when the image is stored or if the operation fails). Fix this by pointing ->thaw_noirq to driver nhi_resume_noirq(). This makes sure the control channel is resumed properly. Fixes: 23dd5bb49d98 ("thunderbolt: Add suspend/hibernate support") Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Cc: stable@vger.kernel.org
2017-12-16thunderbolt: Mask ring interrupt properly when polling startsMika Westerberg
When ring enters polling mode we are expected to mask the ring interrupt before the callback is called. However, the current code actually unmasks it probably because of a copy-paste mistake. Mask the interrupt properly from now on. Fixes: 4ffe722eefcb ("thunderbolt: Add polling mode for rings") Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Yehezkel Bernat <yehezkel.bernat@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-16Merge tag 'char-misc-4.15-rc1' of ↵Linus Torvalds
ssh://gitolite.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc updates from Greg KH: "Here is the big set of char/misc and other driver subsystem patches for 4.15-rc1. There are small changes all over here, hyperv driver updates, pcmcia driver updates, w1 driver updats, vme driver updates, nvmem driver updates, and lots of other little one-off driver updates as well. The shortlog has the full details. All of these have been in linux-next for quite a while with no reported issues" * tag 'char-misc-4.15-rc1' of ssh://gitolite.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (90 commits) VME: Return -EBUSY when DMA list in use w1: keep balance of mutex locks and refcnts MAINTAINERS: Update VME subsystem tree. nvmem: sunxi-sid: add support for A64/H5's SID controller nvmem: imx-ocotp: Update module description nvmem: imx-ocotp: Enable i.MX7D OTP write support nvmem: imx-ocotp: Add i.MX7D timing write clock setup support nvmem: imx-ocotp: Move i.MX6 write clock setup to dedicated function nvmem: imx-ocotp: Add support for banked OTP addressing nvmem: imx-ocotp: Pass parameters via a struct nvmem: imx-ocotp: Restrict OTP write to IMX6 processors nvmem: uniphier: add UniPhier eFuse driver dt-bindings: nvmem: add description for UniPhier eFuse nvmem: set nvmem->owner to nvmem->dev->driver->owner if unset nvmem: qfprom: fix different address space warnings of sparse nvmem: mtk-efuse: fix different address space warnings of sparse nvmem: mtk-efuse: use stack for nvmem_config instead of malloc'ing it nvmem: imx-iim: use stack for nvmem_config instead of malloc'ing it thunderbolt: tb: fix use after free in tb_activate_pcie_devices MAINTAINERS: Add git tree for Thunderbolt development ...
2017-11-06thunderbolt: tb: fix use after free in tb_activate_pcie_devicesGustavo A. R. Silva
Add a ̣̣continue statement in order to avoid using a previously free'd pointer tunnel in list_add. Addresses-Coverity-ID: 1415336 Fixes: 9d3cce0b6136 ("thunderbolt: Introduce thunderbolt bus and connection manager") Signed-off-by: Gustavo A. R. Silva <garsilva@embeddedor.com> Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Files removed in 'net-next' had their license header updated in 'net'. We take the remove from 'net-next'. Signed-off-by: David S. Miller <davem@davemloft.net>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27thunderbolt: Drop sequence number check from tb_xdomain_match()Mika Westerberg
Commit 9a03c3d398c1 ("thunderbolt: Fix a couple right shifting to zero bugs") revealed an issue that was previously hidden because we never actually compared received XDomain message sequence numbers properly. The idea with these sequence numbers is that the responding host uses the same sequence number that was in the request packet which we can then check at the requesting host. However, testing against macOS it looks like it does not follow this but instead uses some other logic. Windows driver on the other hand handles it the same way than Linux. In order to be able to talk to macOS again, fix this so that we drop the whole sequence number check. This effectively works exactly the same than it worked before the aforementioned commit. This also follows the logic the original P2P networking code used. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-10-19thunderbolt: Fix a couple right shifting to zero bugsDan Carpenter
The problematic code looks like this: res_seq = res_hdr->xd_hdr.length_sn & TB_XDOMAIN_SN_MASK; res_seq >>= TB_XDOMAIN_SN_SHIFT; TB_XDOMAIN_SN_SHIFT is 27, and right shifting a u8 27 bits is always going to result in zero. The fix is to declare these variables as u32. Fixes: d1ff70241a27 ("thunderbolt: Add support for XDomain discovery protocol") Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-10-09thunderbolt: Initialize Thunderbolt bus earlierMika Westerberg
The 0day kbuild robot reports following crash: BUG: unable to handle kernel NULL pointer dereference at 00000004 IP: tb_property_find+0xe/0x41 *pde = 00000000 Oops: 0000 [#1] CPU: 0 PID: 1 Comm: swapper Not tainted 4.14.0-rc1-00741-ge69b6c0 #412 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1 04/01/2014 task: 89c80000 task.stack: 89c7c000 EIP: tb_property_find+0xe/0x41 EFLAGS: 00210246 CPU: 0 EAX: 00000000 EBX: 7a368f47 ECX: 00000044 EDX: 7a368f47 ESI: 8851d340 EDI: 7a368f47 EBP: 89c7df0c ESP: 89c7defc DS: 007b ES: 007b FS: 0000 GS: 0000 SS: 0068 CR0: 80050033 CR2: 00000004 CR3: 027a2000 CR4: 00000690 Call Trace: tb_register_property_dir+0x49/0xb9 ? cdc_mbim_driver_init+0x1b/0x1b tbnet_init+0x77/0x9f ? cdc_mbim_driver_init+0x1b/0x1b do_one_initcall+0x7e/0x145 ? parse_args+0x10c/0x1b3 ? kernel_init_freeable+0xbe/0x159 kernel_init_freeable+0xd1/0x159 ? rest_init+0x110/0x110 kernel_init+0xd/0xd0 ret_from_fork+0x19/0x30 The reason is that both Thunderbolt bus and thunderbolt-net are build into the kernel image, and the latter is linked first because drivers/net comes before drivers/thunderbolt. Since both use module_init() thunderbolt-net ends up calling Thunderbolt bus functions too early triggering the above crash. Fix this by moving Thunderbolt bus initialization to happen earlier to make sure all the data structures are ready when Thunderbolt service drivers are initialized. To be on the safe side also add a check for properly initialized xdomain_property_dir to tb_register_property_dir(). Reported-by: kernel test robot <fengguang.wu@intel.com> Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-10-02thunderbolt: Allocate ring HopID automatically if requestedMika Westerberg
Thunderbolt services should not care which HopID (ring) they use for sending and receiving packets over the high-speed DMA path, so make tb_ring_alloc_rx() and tb_ring_alloc_tx() accept negative HopID. This means that the NHI will allocate next available HopID for the caller automatically. These HopIDs will be allocated from the range which is not reserved for the Thunderbolt protocol (8 .. hop_count - 1). The allocated HopID can be retrieved from ring->hop field after the ring has been allocated successfully if needed. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Michael Jamet <michael.jamet@intel.com> Reviewed-by: Yehezkel Bernat <yehezkel.bernat@intel.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-10-02thunderbolt: Add polling mode for ringsMika Westerberg
In order to support things like networking over Thunderbolt cable, there needs to be a way to switch the ring to a mode where it can be polled with the interrupt masked. We implement such mode so that the caller can allocate a ring by passing pointer to a function that is then called when an interrupt is triggered. Completed frames can be fetched using tb_ring_poll() and the interrupt can be re-enabled when the caller is finished with polling by using tb_ring_poll_complete(). Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Michael Jamet <michael.jamet@intel.com> Reviewed-by: Yehezkel Bernat <yehezkel.bernat@intel.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-10-02thunderbolt: Use spinlock in NHI serializationMika Westerberg
This is needed because ring polling functionality can be called from atomic contexts when networking and other high-speed traffic is transferred over a Thunderbolt cable. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Michael Jamet <michael.jamet@intel.com> Reviewed-by: Yehezkel Bernat <yehezkel.bernat@intel.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-10-02thunderbolt: Use spinlock in ring serializationMika Westerberg
This makes it possible to enqueue frames also from atomic context which is needed for example, when networking packets are sent over a Thunderbolt cable. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Michael Jamet <michael.jamet@intel.com> Reviewed-by: Yehezkel Bernat <yehezkel.bernat@intel.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
