Pull trivial tree from Jiri Kosina:
"Usual trivial tree updates. Nothing outstanding -- mostly printk()
and comment fixes and unused identifier removals"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial:
goldfish: goldfish_tty_probe() is not using 'i' any more
powerpc: Fix comment in smu.h
qla2xxx: Fix printks in ql_log message
lib: correct link to the original source for div64_u64
si2168, tda10071, m88ds3103: Fix firmware wording
usb: storage: Fix printk in isd200_log_config()
qla2xxx: Fix printk in qla25xx_setup_mode
init/main: fix reset_device comment
ipwireless: missing assignment
goldfish: remove unreachable line of code
coredump: Fix do_coredump() comment
stacktrace.h: remove duplicate declaration task_struct
smpboot.h: Remove unused function prototype
treewide: Fix typo in printk messages
mod_devicetable: fix comment for match_flags
The only place where 'i' has been used was a dead code that
got removed by 2a2483685a9de ("goldfish: remove unreachable line
of code"). Remove the last reference to the variable as well.
Fixes: 2a2483685a9de ("goldfish: remove unreachable line of code")
Signed-off-by: Alan Cox <alan@linux.intel.com>
The goldfish_ttys[] array has "goldfish_tty_line_count" number of
elements. It's allocated in goldfish_tty_create_driver(). This test
should be >= instead of >.
Acked-by: Alan Cox <alan@linux.intel.com>
drivers/tty/goldfish.c:160:46: warning: Using plain integer as NULL pointer
drivers/tty/goldfish.c:320:22: warning: Using plain integer as NULL pointer
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Mostly spacing changes, also making the operations structure const
Use the helper we now have available.
Signed-off-by: Jun Tian <jun.j.tian@intel.com>
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
Sorry forgot to merge this in the original submission. Resync
with the tty tree changes moving the buffers into the tty_port
This provides a console driver for the Goldfish virtual platform. The original
is from Arve with changes from Jun Nakajima and Tom Keel. This has been then
been ported to the current kernel and to the tty port mechanism by Alan Cox.
In the process it gained proper POSIX semantics and vhangup works. The default
name is not ttyS as this belongs to the 8250 driver. Instead ttyGFx is now used.
In the normal usage case the first port serves as a kernel logging console and
the second one carries various other data streams for the emulation.
Signed-off-by: Arve Hjønnevåg <arve@google.com>
[Cleaned up to handle x86]
Signed-off-by: Sheng Yang <sheng@linux.intel.com>
Signed-off-by: Yunhong Jiang <yunhong.jiang@intel.com>
Signed-off-by: Xiaohui Xin <xiaohui.xin@intel.com>
Signed-off-by: Jun Nakajima <jun.nakajima@intel.com>
Signed-off-by: Bruce Beare <bruce.j.beare@intel.com>
[Moved to 3.7 and chunks rewritten to use tty_port layer]
