Pull trivial tree from Jiri Kosina:
"Usual trivial tree updates. Nothing outstanding -- mostly printk()
and comment fixes and unused identifier removals"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial:
goldfish: goldfish_tty_probe() is not using 'i' any more
powerpc: Fix comment in smu.h
qla2xxx: Fix printks in ql_log message
lib: correct link to the original source for div64_u64
si2168, tda10071, m88ds3103: Fix firmware wording
usb: storage: Fix printk in isd200_log_config()
qla2xxx: Fix printk in qla25xx_setup_mode
init/main: fix reset_device comment
ipwireless: missing assignment
goldfish: remove unreachable line of code
coredump: Fix do_coredump() comment
stacktrace.h: remove duplicate declaration task_struct
smpboot.h: Remove unused function prototype
treewide: Fix typo in printk messages
mod_devicetable: fix comment for match_flags
We never report the error because we don't assign it to ret.
Signed-off-by: Alan Cox <alan@linux.intel.com>
Precedence of & and >> is not the same and is not left to right.
shift has higher precedence and should be done after the mask.
Add parentheses around the masks.
Acked-by: David Sterba <dsterba@suse.cz>
Reviewed-by: Jiri Kosina <jkosina@suse.cz>
tty->closing cannot be set on ipw_open() because the ipwireless tty
driver does not call any functions that set tty->closing.
CC: Jiri Kosina <jkosina@suse.cz>
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
The user-settable knob, low_latency, has been the source of
several BUG reports which stem from flush_to_ldisc() running
in interrupt context. Since 3.12, which added several sleeping
locks (termios_rwsem and buf->lock) to the input processing path,
the frequency of these BUG reports has increased.
Note that changes in 3.12 did not introduce this regression;
sleeping locks were first added to the input processing path
with the removal of the BKL from N_TTY in commit
a88a69c91256418c5907c2f1f8a0ec0a36f9e6cc,
'n_tty: Fix loss of echoed characters and remove bkl from n_tty'
and later in commit 38db89799bdf11625a831c5af33938dcb11908b6,
'tty: throttling race fix'. Since those changes, executing
flush_to_ldisc() in interrupt_context (ie, low_latency set), is unsafe.
However, since most devices do not validate if the low_latency
setting is appropriate for the context (process or interrupt) in
which they receive data, some reports are due to misconfiguration.
Further, serial dma devices for which dma fails, resort to
interrupt receiving as a backup without resetting low_latency.
Historically, low_latency was used to force wake-up the reading
process rather than wait for the next scheduler tick. The
effect was to trim multiple milliseconds of latency from
when the process would receive new data.
Recent tests [1] have shown that the reading process now receives
data with only 10's of microseconds latency without low_latency set.
Remove the low_latency rx steering from tty_flip_buffer_push();
however, leave the knob as an optional hint to drivers that can
tune their rx fifos and such like. Cleanup stale code comments
regarding low_latency.
[1] https://lkml.org/lkml/2014/2/20/434
"Yay.. thats an annoying historical pain in the butt gone."
-- Alan Cox
Reported-by: Beat Bolli <bbolli@ewanet.ch>
Reported-by: Pavel Roskin <proski@gnu.org>
Cc: Grant Edwards <grant.b.edwards@gmail.com>
Cc: Stanislaw Gruszka <sgruszka@redhat.com>
Cc: Hal Murray <murray+fedora@ip-64-139-1-69.sjc.megapath.net>
Cc: <stable@vger.kernel.org> # 3.12.x+
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
kfree on NULL pointer is a no-op.
Signed-off-by: Syam Sidhardhan <s.syam@samsung.com>
"Assorted tiny fixes queued in trivial tree"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (22 commits)
DocBook: update EXPORT_SYMBOL entry to point at export.h
Documentation: update top level 00-INDEX file with new additions
ARM: at91/ide: remove unsused at91-ide Kconfig entry
percpu_counter.h: comment code for better readability
x86, efi: fix comment typo in head_32.S
IB: cxgb3: delay freeing mem untill entirely done with it
net: mvneta: remove unneeded version.h include
time: x86: report_lost_ticks doesn't exist any more
pcmcia: avoid static analysis complaint about use-after-free
fs/jfs: Fix typo in comment : 'how may' -> 'how many'
of: add missing documentation for of_platform_populate()
btrfs: remove unnecessary cur_trans set before goto loop in join_transaction
sound: soc: Fix typo in sound/codecs
treewide: Fix typo in various drivers
btrfs: fix comment typos
Update ibmvscsi module name in Kconfig.
powerpc: fix typo (utilties -> utilities)
of: fix spelling mistake in comment
h8300: Fix home page URL in h8300/README
xtensa: Fix home page URL in Kconfig
drivers/devfreq/exynos4_bus.c
Sync with Linus' tree to be able to apply patches that are
against newer code (mvneta).
Now, we start converting tty buffer functions to actually use
tty_port. This will allow us to get rid of the need of tty in many
call sites. Only tty_port will needed and hence no more
tty_port_tty_get in those paths.
Now, the one where most of tty_port_tty_get gets removed:
tty_flip_buffer_push.
IOW we also closed all the races in drivers not using tty_port_tty_get
at all yet.
Also we move tty_flip_buffer_push declaration from include/linux/tty.h
to include/linux/tty_flip.h to all others while we are changing it
anyway.
One point is to have less places where we actually need tty pointer.
The other is that low_latency is bound to buffer processing and
buffers are now in tty_port. So it makes sense to move low_latency to
tty_port too.
tty_insert_flip_string this time.
Signed-off-by: Jorrit Schippers <jorrit@ncode.nl>
Pull trivial branch from Jiri Kosina:
"Usual stuff -- comment/printk typo fixes, documentation updates, dead
code elimination."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
HOWTO: fix double words typo
x86 mtrr: fix comment typo in mtrr_bp_init
propagate name change to comments in kernel source
doc: Update the name of profiling based on sysfs
treewide: Fix typos in various drivers
treewide: Fix typos in various Kconfig
wireless: mwifiex: Fix typo in wireless/mwifiex driver
messages: i2o: Fix typo in messages/i2o
scripts/kernel-doc: check that non-void fcts describe their return value
Kernel-doc: Convention: Use a "Return" section to describe return values
radeon: Fix typo and copy/paste error in comments
doc: Remove unnecessary declarations from Documentation/accounting/getdelays.c
various: Fix spelling of "asynchronous" in comments.
Fix misspellings of "whether" in comments.
eisa: Fix spelling of "asynchronous".
various: Fix spelling of "registered" in comments.
doc: fix quite a few typos within Documentation
target: iscsi: fix comment typos in target/iscsi drivers
treewide: fix typo of "suport" in various comments and Kconfig
treewide: fix typo of "suppport" in various comments
"Asynchronous" is misspelled in some comments. No code changes.
Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com>
After commit "TTY: move tty buffers to tty_port", the tty buffers are
not freed in some drivers. This is because tty_port_destructor is not
called whenever a tty_port is freed. This was an assumption I counted
with but was unfortunately untrue. So fix the drivers to fulfil this
assumption.
To be sure, the TTY buffers (and later some stuff) are gone along with
the tty_port, we have to call tty_port_destroy at tear-down places.
This is mostly where the structure containing a tty_port is freed.
This patch does exactly that -- put tty_port_destroy at those places.
Resolves-bug: https://bugzilla.kernel.org/show_bug.cgi?id=49851
Pull workqueue changes from Tejun Heo:
"This is workqueue updates for v3.7-rc1. A lot of activities this
round including considerable API and behavior cleanups.
* delayed_work combines a timer and a work item. The handling of the
timer part has always been a bit clunky leading to confusing
cancelation API with weird corner-case behaviors. delayed_work is
updated to use new IRQ safe timer and cancelation now works as
expected.
* Another deficiency of delayed_work was lack of the counterpart of
mod_timer() which led to cancel+queue combinations or open-coded
timer+work usages. mod_delayed_work[_on]() are added.
These two delayed_work changes make delayed_work provide interface
and behave like timer which is executed with process context.
* A work item could be executed concurrently on multiple CPUs, which
is rather unintuitive and made flush_work() behavior confusing and
half-broken under certain circumstances. This problem doesn't
exist for non-reentrant workqueues. While non-reentrancy check
isn't free, the overhead is incurred only when a work item bounces
across different CPUs and even in simulated pathological scenario
the overhead isn't too high.
All workqueues are made non-reentrant. This removes the
distinction between flush_[delayed_]work() and
flush_[delayed_]_work_sync(). The former is now as strong as the
latter and the specified work item is guaranteed to have finished
execution of any previous queueing on return.
* In addition to the various bug fixes, Lai redid and simplified CPU
hotplug handling significantly.
* Joonsoo introduced system_highpri_wq and used it during CPU
hotplug.
There are two merge commits - one to pull in IRQ safe timer from
tip/timers/core and the other to pull in CPU hotplug fixes from
wq/for-3.6-fixes as Lai's hotplug restructuring depended on them."
Fixed a number of trivial conflicts, but the more interesting conflicts
were silent ones where the deprecated interfaces had been used by new
code in the merge window, and thus didn't cause any real data conflicts.
Tejun pointed out a few of them, I fixed a couple more.
* 'for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (46 commits)
workqueue: remove spurious WARN_ON_ONCE(in_irq()) from try_to_grab_pending()
workqueue: use cwq_set_max_active() helper for workqueue_set_max_active()
workqueue: introduce cwq_set_max_active() helper for thaw_workqueues()
workqueue: remove @delayed from cwq_dec_nr_in_flight()
workqueue: fix possible stall on try_to_grab_pending() of a delayed work item
workqueue: use hotcpu_notifier() for workqueue_cpu_down_callback()
workqueue: use __cpuinit instead of __devinit for cpu callbacks
workqueue: rename manager_mutex to assoc_mutex
workqueue: WORKER_REBIND is no longer necessary for idle rebinding
workqueue: WORKER_REBIND is no longer necessary for busy rebinding
workqueue: reimplement idle worker rebinding
workqueue: deprecate __cancel_delayed_work()
workqueue: reimplement cancel_delayed_work() using try_to_grab_pending()
workqueue: use mod_delayed_work() instead of __cancel + queue
workqueue: use irqsafe timer for delayed_work
workqueue: clean up delayed_work initializers and add missing one
workqueue: make deferrable delayed_work initializer names consistent
workqueue: cosmetic whitespace updates for macro definitions
workqueue: deprecate system_nrt[_freezable]_wq
workqueue: deprecate flush[_delayed]_work_sync()
Otherwise we start trying to use a bogus channel - ungood.
flush[_delayed]_work_sync() are now spurious. Mark them deprecated
and convert all users to flush[_delayed]_work().
If you're cc'd and wondering what's going on: Now all workqueues are
non-reentrant and the regular flushes guarantee that the work item is
not pending or running on any CPU on return, so there's no reason to
use the sync flushes at all and they're going away.
This patch doesn't make any functional difference.
Cc: Ian Campbell <ian.campbell@citrix.com>
Cc: Mattia Dongili <malattia@linux.it>
Cc: Kent Yoder <key@linux.vnet.ibm.com>
Cc: David Airlie <airlied@linux.ie>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Karsten Keil <isdn@linux-pingi.de>
Cc: Bryan Wu <bryan.wu@canonical.com>
Cc: Alasdair Kergon <agk@redhat.com>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Cc: linux-wireless@vger.kernel.org
Cc: Anton Vorontsov <cbou@mail.ru>
Cc: Sangbeom Kim <sbkim73@samsung.com>
Cc: "James E.J. Bottomley" <James.Bottomley@HansenPartnership.com>
Cc: Eric Van Hensbergen <ericvh@gmail.com>
Cc: Takashi Iwai <tiwai@suse.de>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Petr Vandrovec <petr@vandrovec.name>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Avi Kivity <avi@redhat.com>
Currently we have no way to assign tty->port while performing tty
installation. There are two ways to provide the link tty_struct =>
tty_port. Either by calling tty_port_install from tty->ops->install or
tty_port_register_device called instead of tty_register_device when
the device is being set up after connected.
In this patch we modify most of the drivers to do the latter. When the
drivers use tty_register_device and we have tty_port already, we
switch to tty_port_register_device. So we have the tty_struct =>
tty_port link for free for those.
Acked-by: Alan Cox <alan@linux.intel.com>
It does not make the driver less racy though. Close and hangup should
be rewritten and tty refcounting used properly.
And use count from that.
There are two functions which only print a status. Let us do that
directly at places where they are called.
Do not touch internal workqueue. Call tty_vhangup instead.
Note that finished hangup does not necessarily mean that all processes
are dead. Especially when the tty is a console. The code assumes that
right now.
Pull networking merge from David Miller:
"1) Move ixgbe driver over to purely page based buffering on receive.
From Alexander Duyck.
2) Add receive packet steering support to e1000e, from Bruce Allan.
3) Convert TCP MD5 support over to RCU, from Eric Dumazet.
4) Reduce cpu usage in handling out-of-order TCP packets on modern
systems, also from Eric Dumazet.
5) Support the IP{,V6}_UNICAST_IF socket options, making the wine
folks happy, from Erich Hoover.
6) Support VLAN trunking from guests in hyperv driver, from Haiyang
Zhang.
7) Support byte-queue-limtis in r8169, from Igor Maravic.
8) Outline code intended for IP_RECVTOS in IP_PKTOPTIONS existed but
was never properly implemented, Jiri Benc fixed that.
9) 64-bit statistics support in r8169 and 8139too, from Junchang Wang.
10) Support kernel side dump filtering by ctmark in netfilter
ctnetlink, from Pablo Neira Ayuso.
11) Support byte-queue-limits in gianfar driver, from Paul Gortmaker.
12) Add new peek socket options to assist with socket migration, from
Pavel Emelyanov.
13) Add sch_plug packet scheduler whose queue is controlled by
userland daemons using explicit freeze and release commands. From
Shriram Rajagopalan.
14) Fix FCOE checksum offload handling on transmit, from Yi Zou."
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1846 commits)
Fix pppol2tp getsockname()
Remove printk from rds_sendmsg
ipv6: fix incorrent ipv6 ipsec packet fragment
cpsw: Hook up default ndo_change_mtu.
net: qmi_wwan: fix build error due to cdc-wdm dependecy
netdev: driver: ethernet: Add TI CPSW driver
netdev: driver: ethernet: add cpsw address lookup engine support
phy: add am79c874 PHY support
mlx4_core: fix race on comm channel
bonding: send igmp report for its master
fs_enet: Add MPC5125 FEC support and PHY interface selection
net: bpf_jit: fix BPF_S_LDX_B_MSH compilation
net: update the usage of CHECKSUM_UNNECESSARY
fcoe: use CHECKSUM_UNNECESSARY instead of CHECKSUM_PARTIAL on tx
net: do not do gso for CHECKSUM_UNNECESSARY in netif_needs_gso
ixgbe: Fix issues with SR-IOV loopback when flow control is disabled
net/hyperv: Fix the code handling tx busy
ixgbe: fix namespace issues when FCoE/DCB is not enabled
rtlwifi: Remove unused ETH_ADDR_LEN defines
igbvf: Use ETH_ALEN
Fix up fairly trivial conflicts in drivers/isdn/gigaset/interface.c and
drivers/net/usb/{Kconfig,qmi_wwan.c} as per David.
* do not test if tty->index is in bounds. It is always.
* tty->index is not a minor! Fix that.
>From now on, let's assume that the parameter of the function is tty
index with base being zero. This makes also the code more readable.
Factually, there is no real change as tty_driver->minor_start is zero,
so the tests are equivalent. But it did not make sense. And if this
had changed eventually, it would have caused troubles.
Acked-by: Jiri Kosina <jkosina@suse.cz>
Cc: David Sterba <dsterba@suse.cz>
All num, magic and owner are set by alloc_tty_driver. No need to
re-set them on each allocation site.
pti driver sets something different to what it passes to
alloc_tty_driver. It is not a bug, since we don't use the lines
parameter in any way. Anyway this is fixed, and now we do the right
thing.
Acked-by: Tilman Schmidt <tilman@imap.cc>
Since all that include/linux/if_ppp.h does is #include <linux/ppp-ioctl.h>,
this replaces the occurrences of #include <linux/if_ppp.h> with
#include <linux/ppp-ioctl.h>.
It also corrects an error in Documentation/networking/l2tp.txt, where
it referenced include/linux/if_ppp.h as the source of some definitions
that are actually now defined in include/linux/if_pppol2tp.h.
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6:
pcmcia: Make struct pcmcia_device_id const, sound drivers edition
staging: pcmcia: Convert pcmcia_device_id declarations to const
pcmcia: Make declaration and uses of struct pcmcia_device_id const
pcmcia/sa1100: put sa11x0_pcmcia_hw_init[] to .devinit.data
Saves about 50KB of data.
Old/new size of all objects:
563015 80096 130684 773795 bcea3 (TOTALS)
610916 32256 130632 773804 bceac (TOTALS)
Acked-by: Kurt Van Dijck <kurt.van.dijck@eia.be> (for drivers/net/can/softing/softing_cs.c)
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
remove invalid location line in each file header after location
moved from driver/char to driver/tty
Signed-off-by: Jovi Zhang <bookjovi@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6
* 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (76 commits)
pch_uart: reference clock on CM-iTC
pch_phub: add new device ML7213
n_gsm: fix UIH control byte : P bit should be 0
n_gsm: add a documentation
serial: msm_serial_hs: Add MSM high speed UART driver
tty_audit: fix tty_audit_add_data live lock on audit disabled
tty: move cd1865.h to drivers/staging/tty/
Staging: tty: fix build with epca.c driver
pcmcia: synclink_cs: fix prototype for mgslpc_ioctl()
Staging: generic_serial: fix double locking bug
nozomi: don't use flush_scheduled_work()
tty/serial: Relax the device_type restriction from of_serial
MAINTAINERS: Update HVC file patterns
tty: phase out of ioctl file pointer for tty3270 as well
tty: forgot to remove ipwireless from drivers/char/pcmcia/Makefile
pch_uart: Fix DMA channel miss-setting issue.
pch_uart: fix exclusive access issue
pch_uart: fix auto flow control miss-setting issue
pch_uart: fix uart clock setting issue
pch_uart : Use dev_xxx not pr_xxx
Fix up trivial conflicts in drivers/misc/pch_phub.c (same patch applied
twice, then changes to the same area in one branch)
As planned by Arnd Bergmann, this moves the ipwireless driver to the
drivers/tty/ directory as that's where it really belongs.
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Jiri Slaby <jslaby@suse.cz>
