path: root/drivers/tty/n_gsm.c
2011-07-25Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (26 commits) amba pl011: workaround for uart registers lockup n_gsm: fix the wrong FCS handling pch_uart: add missing comment about OKI ML7223 pch_uart: Add MSI support tty: fix "IRQ45: nobody cared" PTI feature to allow user to name and mark masterchannel request. 0 for o PTI Makefile bug. tty: serial: samsung.c remove legacy PM code. SERIAL: SC26xx: Fix link error. serial: mrst_max3110: initialize waitqueue earlier mrst_max3110: Change max missing message priority. tty: s5pv210: Add delay loop on fifo reset function for UART tty/serial: Fix XSCALE serial ports, e.g. ce4100 serial: bfin_5xx: fix off-by-one with resource size drivers/tty: use printk_ratelimited() instead of printk_ratelimit() tty: n_gsm: Added refcount usage to gsm_mux and gsm_dlci structs tty: n_gsm: Add raw-ip support tty: n_gsm: expose gsmtty device nodes at ldisc open time pch_phub: Fix register miss-setting issue serial: 8250, increase PASS_LIMIT ...
2011-07-08n_gsm: fix the wrong FCS handlingDu, Alek
FCS could be GSM0_SOF, so will break state machine... [This byte isn't quoted in any way so a SOF here doesn't imply an error occurred.] Signed-off-by: Alek Du <alek.du@intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Cc: stable <stable@kernel.org> [3.0] [Trivial but best backported once its in 3.1rc I think] Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-01tty: n_gsm: Added refcount usage to gsm_mux and gsm_dlci structsRuss Gorby
The gsm_mux is created/destroyed when ldisc is opened/closed but clients of the MUX channel devices (gsmttyN) may access this structure as long as the TTYs are open. For the open, the ldisc open is guaranteed to preceed the TTY open, but the close has no such guaranteed ordering. As a result, the gsm_mux can be freed in the ldisc close before being accessed by one of the TTY clients. This can happen if the ldisc is removed while there are open, active MUX channels. A similar situation exists for DLCI-0, it is basically a resource shared by MUX and DLCI , and should not be freed while they can be accessed To avoid this, gsm_mux and dlcis now have a reference counter ldisc open takes a reference on the mux and all the dlcis gsmtty_open takes a reference on the mux, dlci0 and its specific dlci. Dropping the last reference initiates the actual free. Signed-off-by: Russ Gorby <russ.gorby@intel.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-01tty: n_gsm: Add raw-ip supportRuss Gorby
This patch adds the ability to open a network data connection over a mux virtual tty channel. This is for modems that support data connections with raw IP frames instead of PPP. On high speed data connections this eliminates a significant amount of PPP overhead. To use this interface, the application must first tell the modem to open a network connection on a virtual tty. Once that has been accomplished, the app will issue an IOCTL on that virtual tty to create the network interface. The IOCTL will return the index of the interface created. The two IOCTL commands are: ioctl( fd, GSMIOC_ENABLE_NET ); ioctl( fd, GSMIOC_DISABLE_NET ); Signed-off-by: Russ Gorby <russ.gorby@intel.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-01tty: n_gsm: expose gsmtty device nodes at ldisc open timeRuss Gorby
The n_gsm driver being an ldisc, does not provide a convenient method e.g. udev to create the tty device nodes automatically when the ldisc is opened. The TTY device nodes are now created via calls to tty_register_device from the ldisc open. Signed-off-by: Russ Gorby <russ.gorby@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-16tty: n_gsm: improper skb_pull() use was leaking framed dataRuss Gorby
gsm_dlci_data_output_framed() was doing: memcpy(dp, skb_pull(dlci->skb, len), len); The problem is skb_pull() returns the post-increment data ptr so the first chunk of dlci->skb->data is leaked. Signed-off-by: Russ Gorby <russ.gorby@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-16tty: n_gsm: Fixed logic to decode break signal from modem statusRuss Gorby
The modem status can be one or 2 octets and contains the V.24 signals and in the 2 octet case also the break signal. We were improperly decoding the break signal from the modem in the 2 octet case. Signed-off-by: Russ Gorby <russ.gorby@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-04Revert "tty: make receive_buf() return the amout of bytes received"Linus Torvalds
This reverts commit b1c43f82c5aa265442f82dba31ce985ebb7aa71c. It was broken in so many ways, and results in random odd pty issues. It re-introduced the buggy schedule_work() in flush_to_ldisc() that can cause endless work-loops (see commit a5660b41af6a: "tty: fix endless work loop when the buffer fills up"). It also used an "unsigned int" return value fo the ->receive_buf() function, but then made multiple functions return a negative error code, and didn't actually check for the error in the caller. And it didn't actually work at all. BenH bisected down odd tty behavior to it: "It looks like the patch is causing some major malfunctions of the X server for me, possibly related to PTYs. For example, cat'ing a large file in a gnome terminal hangs the kernel for -minutes- in a loop of what looks like flush_to_ldisc/workqueue code, (some ftrace data in the quoted bits further down). ... Some more data: It -looks- like what happens is that the flush_to_ldisc work queue entry constantly re-queues itself (because the PTY is full ?) and the workqueue thread will basically loop forver calling it without ever scheduling, thus starving the consumer process that could have emptied the PTY." which is pretty much exactly the problem we fixed in a5660b41af6a. Milton Miller pointed out the 'unsigned int' issue. Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Reported-by: Milton Miller <miltonm@bga.com> Cc: Stefan Bigler <stefan.bigler@keymile.com> Cc: Toby Gray <toby.gray@realvnc.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-23Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (48 commits) serial: 8250_pci: add support for Cronyx Omega PCI multiserial board. tty/serial: Fix break handling for PORT_TEGRA tty/serial: Add explicit PORT_TEGRA type n_tracerouter and n_tracesink ldisc additions. Intel PTI implementaiton of MIPI 1149.7. Kernel documentation for the PTI feature. export kernel call get_task_comm(). tty: Remove to support serial for S5P6442 pch_phub: Support new device ML7223 8250_pci: Add support for the Digi/IBM PCIe 2-port Adapter ASoC: Update cx20442 for TTY API change pch_uart: Support new device ML7223 IOH parport: Use request_muxed_region for IT87 probe and lock tty/serial: add support for Xilinx PS UART n_gsm: Use print_hex_dump_bytes drivers/tty/moxa.c: Put correct tty value TTY: tty_io, annotate locking functions TTY: serial_core, remove superfluous set_task_state TTY: serial_core, remove invalid test Char: moxa, fix locking in moxa_write ... Fix up trivial conflicts in drivers/bluetooth/hci_ldisc.c and drivers/tty/serial/Makefile. I did the hci_ldisc thing as an evil merge, cleaning things up.
2011-05-10treewide: fix a few typos in commentsJustin P. Mattock
- kenrel -> kernel - whetehr -> whether - ttt -> tt - sss -> ss Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-04-29n_gsm: Use print_hex_dump_bytesJoe Perches
Use the standard mechanism to print a hex buffer to eliminate empty printf warning. A couple % smaller text and data too. $ size drivers/tty/n_gsm.o* text data bss dec hex filename 23543 312 6376 30231 7617 drivers/tty/n_gsm.o.new 24051 408 6496 30955 78eb drivers/tty/n_gsm.o.old Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-22tty: make receive_buf() return the amout of bytes receivedFelipe Balbi
it makes it simpler to keep track of the amount of bytes received and simplifies how flush_to_ldisc counts the remaining bytes. It also fixes a bug of lost bytes on n_tty when flushing too many bytes via the USB serial gadget driver. Tested-by: Stefan Bigler <stefan.bigler@keymile.com> Tested-by: Toby Gray <toby.gray@realvnc.com> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19tty/n_gsm: fix bug in CRC calculation for gsm1 modeMikhail Kshevetskiy
Problem description: gsm_queue() calculate a CRC for arrived frames. As a last step of CRC calculation it call gsm->fcs = gsm_fcs_add(gsm->fcs, gsm->received_fcs); This work perfectly for the case of GSM0 mode as gsm->received_fcs contain the last piece of data required to generate final CRC. gsm->received_fcs is not used for GSM1 mode. Thus we put an additional byte to CRC calculation. As result we get a wrong CRC and reject incoming frame. Signed-off-by: Mikhail Kshevetskiy <mikhail.kshevetskiy@gmail.com> Acked-by: Alan Cox <alan@linux.intel.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-09n_gsm: fix UIH control byte : P bit should be 0Eric Bénard
* the GSM 07.10 specification says in 5.4.3.1 that 'both stations shall set the P bit to 0' thanks to Alan Cox for finding this explanation in the spec * without this fix, on Telit & Sim.com modems, opening a new DLC randomly fails. Not setting PF bit of the control byte gives a reliable behaviour on these modems. Signed-off-by: Eric Bénard <eric@eukrea.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-24Merge 2.6.38-rc6 into tty-nextGreg Kroah-Hartman
This was to resolve a merge issue with drivers/char/Makefile and drivers/tty/serial/68328serial.c Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17tty: now phase out the ioctl file pointer for goodAlan Cox
Only oddities here are a couple of drivers that bogusly called the ldisc helpers instead of returning -ENOIOCTLCMD. Fix the bug and the rest goes away. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17tiocmset: kill the file pointer argumentAlan Cox
Doing tiocmget was such fun we should do tiocmset as well for the same reasons Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17tiocmget: kill off the passing of the struct fileAlan Cox
We don't actually need this and it causes problems for internal use of this functionality. Currently there is a single use of the FILE * pointer. That is the serial core which uses it to check tty_hung_up_p. However if that is true then IO_ERROR is also already set so the check may be removed. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-03n_gsm: copy mtu over when configuring via ioctl interfaceKen Mills
This field is settable but did not get copied. Signed-off-by: Ken Mills <ken.k.mills@intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Cc: stable@kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-07Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (36 commits) serial: apbuart: Fixup apbuart_console_init() TTY: Add tty ioctl to figure device node of the system console. tty: add 'active' sysfs attribute to tty0 and console device drivers: serial: apbuart: Handle OF failures gracefully Serial: Avoid unbalanced IRQ wake disable during resume tty: fix typos/errors in tty_driver.h comments pch_uart : fix warnings for 64bit compile 8250: fix uninitialized FIFOs ip2: fix compiler warning on ip2main_pci_tbl specialix: fix compiler warning on specialix_pci_tbl rocket: fix compiler warning on rocket_pci_ids 8250: add a UPIO_DWAPB32 for 32 bit accesses 8250: use container_of() instead of casting serial: omap-serial: Add support for kernel debugger serial: fix pch_uart kconfig & build drivers: char: hvc: add arm JTAG DCC console support RS485 documentation: add 16C950 UART description serial: ifx6x60: fix memory leak serial: ifx6x60: free IRQ on error Serial: EG20T: add PCH_UART driver ... Fixed up conflicts in drivers/serial/apbuart.c with evil merge that makes the code look fairly sane (unlike either side).
2010-12-16n_gsm: gsm_data_alloc buffer allocation could fail and it is not being checkedKen Mills
gsm_data_alloc buffer allocation could fail and it is not being checked. Add check for allocated buffer and return if the buffer allocation fails. Signed-off-by: Ken Mills <ken.k.mills@intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Cc: stable@kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-16n_gsm: Fix message length handling when building headerKen Mills
Fix message length handling when building header When the message length is greater than 127, the length field in the header is built incorrectly. According to the spec, when the length is less than 128 the length field is a single byte formatted as: bbbbbbb1. When it is greater than 127 then the field is two bytes of the format: bbbbbbb0 bbbbbbbb. Signed-off-by: Ken Mills <ken.k.mills@intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Cc: stable@kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-11n_gsm: clean up printksAlan Cox
[Original From Ken Mills but I redid it using pr_ helpers instead] Also fix up coding style, there are two warnings left but that is where the CodingStyle tools blow up because they cannot handle if (blah) { foo } else switch (x) { case 1: } Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-11n_gsm: Fix support for legacy encodingAlan Cox
The mux supports several encoding schemes. Encoding 0 is a "not recommended" mode still sometimes used. This has now been tested with hardware that supports this mode, and found wanting. Fix the FCS handling in this mode and correct the state machine. Signed-off-by: Ken Mills <ken.k.mills@intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-11n_gsm: Fix length handlingKen Mills
If the mux is configured with a large mru/mtu the existing code gets the byte ordering wrong for the header. Signed-off-by: Ken Mills <ken.k.mills@intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-11n_gsm: Copy n2 over when configuring via ioctl interfaceKen Mills
The n2 field is settable but didn't get propogated Signed-off-by: Ken Mills <ken.k.mills@intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-05TTY: create drivers/tty and move the tty core files thereGreg Kroah-Hartman
The tty code should be in its own subdirectory and not in the char driver with all of the cruft that is currently there. Based on work done by Arnd Bergmann <arnd@arndb.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
