commit fc01d8c61ce02c034e67378cd3e645734bc18c8c upstream.
Fix __might_sleep warning[1] in tty/n_hdlc.c read due to copy_to_user
call while current is TASK_INTERRUPTIBLE. This is a false positive
since the code path does not depend on current state remaining
TASK_INTERRUPTIBLE. The loop breaks out and sets TASK_RUNNING after
calling copy_to_user.
This patch supresses the warning by setting TASK_RUNNING before calling
copy_to_user.
[1] https://syzkaller.appspot.com/bug?id=17d5de7f1fcab794cb8c40032f893f52de899324
Signed-off-by: Paul Fulghum <paulkf@microgate.com>
Reported-by: syzbot <syzbot+c244af085a0159d22879@syzkaller.appspotmail.com>
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: stable <stable@vger.kernel.org>
commit 82f2341c94d270421f383641b7cd670e474db56b upstream.
Currently N_HDLC line discipline uses a self-made singly linked list for
data buffers and has n_hdlc.tbuf pointer for buffer retransmitting after
an error.
The commit be10eb7589337e5defbe214dae038a53dd21add8
("tty: n_hdlc add buffer flushing") introduced racy access to n_hdlc.tbuf.
After tx error concurrent flush_tx_queue() and n_hdlc_send_frames() can put
one data buffer to tx_free_buf_list twice. That causes double free in
n_hdlc_release().
Let's use standard kernel linked list and get rid of n_hdlc.tbuf:
in case of tx error put current data buffer after the head of tx_buf_list.
Signed-off-by: Alexander Popov <alex.popov@linux.com>
OpenSSH expects the (non-blocking) read() of pty master to return
EAGAIN only if it has received all of the slave-side output after
it has received SIGCHLD. This used to work on pre-3.12 kernels.
This fix effectively forces non-blocking read() and poll() to
block for parallel i/o to complete for all ttys. It also unwinds
these changes:
1) f8747d4a466ab2cafe56112c51b3379f9fdb7a12
tty: Fix pty master read() after slave closes
2) 52bce7f8d4fc633c9a9d0646eef58ba6ae9a3b73
pty, n_tty: Simplify input processing on final close
3) 1a48632ffed61352a7810ce089dc5a8bcd505a60
pty: Fix input race when closing
Inspired by analysis and patch from Marc Aurele La France <tsi@tuyoix.net>
Reported-by: Volth <openssh@volth.com>
Reported-by: Marc Aurele La France <tsi@tuyoix.net>
BugLink: https://bugzilla.mindrot.org/show_bug.cgi?id=52
BugLink: https://bugzilla.mindrot.org/show_bug.cgi?id=2492
Signed-off-by: Brian Bloniarz <brian.bloniarz@gmail.com>
Reviewed-by: Peter Hurley <peter@hurleysoftware.com>
The class of 4 n_hdls buf locks is the same because a single function
n_hdlc_buf_list_init is used to init all the locks. But since
flush_tx_queue takes n_hdlc->tx_buf_list.spinlock and then calls
n_hdlc_buf_put which takes n_hdlc->tx_free_buf_list.spinlock, lockdep
emits a warning:
[ INFO: possible recursive locking detected ]
4.3.0-25.g91e30a7-default #1 Not tainted
a.out/1248 is trying to acquire lock:
(&(&list->spinlock)->rlock){......}, at: [<ffffffffa01fd020>] n_hdlc_buf_put+0x20/0x60 [n_hdlc]
but task is already holding lock:
(&(&list->spinlock)->rlock){......}, at: [<ffffffffa01fdc07>] n_hdlc_tty_ioctl+0x127/0x1d0 [n_hdlc]
Possible unsafe locking scenario:
CPU0
lock(&(&list->spinlock)->rlock);
*** DEADLOCK ***
May be due to missing lock nesting notation
2 locks held by a.out/1248:
#0: (&tty->ldisc_sem){++++++}, at: [<ffffffff814c9eb0>] tty_ldisc_ref_wait+0x20/0x50
#1: (&(&list->spinlock)->rlock){......}, at: [<ffffffffa01fdc07>] n_hdlc_tty_ioctl+0x127/0x1d0 [n_hdlc]
Call Trace:
[<ffffffff81738fd0>] _raw_spin_lock_irqsave+0x50/0x70
[<ffffffffa01fdc24>] n_hdlc_tty_ioctl+0x144/0x1d0 [n_hdlc]
[<ffffffff814c25c1>] tty_ioctl+0x3f1/0xe40
Fix it by initializing the spin_locks separately. This removes also
reduntand memset of a freshly kzallocated space.
A read() from a pty master may mistakenly indicate EOF (errno == -EIO)
after the pty slave has closed, even though input data remains to be read.
For example,
pty slave | input worker | pty master
| | n_tty_read()
pty_write() | | input avail? no
add data | | sleep
schedule worker --->| | .
|---> flush_to_ldisc() | .
pty_close() | fill read buffer | .
wait for worker | wakeup reader --->| .
| read buffer full? |---> input avail ? yes
|<--- yes - exit worker | copy 4096 bytes to user
TTY_OTHER_CLOSED <---| |<--- kick worker
**** New read() before worker starts ****
| | n_tty_read()
| | input avail? no
| | TTY_OTHER_CLOSED? yes
| | return -EIO
Several conditions are required to trigger this race:
1. the ldisc read buffer must become full so the input worker exits
2. the read() count parameter must be >= 4096 so the ldisc read buffer
is empty
3. the subsequent read() occurs before the kicked worker has processed
more input
However, the underlying cause of the race is that data is pipelined, while
tty state is not; ie., data already written by the pty slave end is not
yet visible to the pty master end, but state changes by the pty slave end
are visible to the pty master end immediately.
Pipeline the TTY_OTHER_CLOSED state through input worker to the reader.
1. Introduce TTY_OTHER_DONE which is set by the input worker when
TTY_OTHER_CLOSED is set and either the input buffers are flushed or
input processing has completed. Readers/polls are woken when
TTY_OTHER_DONE is set.
2. Reader/poll checks TTY_OTHER_DONE instead of TTY_OTHER_CLOSED.
3. A new input worker is started from pty_close() after setting
TTY_OTHER_CLOSED, which ensures the TTY_OTHER_DONE state will be
set if the last input worker is already finished (or just about to
exit).
Remove tty_flush_to_ldisc(); no in-tree callers.
Fixes: 52bce7f8d4fc ("pty, n_tty: Simplify input processing on final close")
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=96311
BugLink: http://bugs.launchpad.net/bugs/1429756
Cc: <stable@vger.kernel.org> # 3.19+
Reported-by: Andy Whitcroft <apw@canonical.com>
Reported-by: H.J. Lu <hjl.tools@gmail.com>
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
Signed-off-by: Fabian Frederick <fabf@skynet.be>
On initialization failure, an error message is already printed with
level KERN_ERR, no need to print another one with level KERN_INFO.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Cc: Jiri Slaby <jslaby@suse.cz>
Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
N_HDLC can spoil tty->flags because use not atomic operations on tty->flags.
I use n_hdlc line discipline and it happens.
Signed-off-by: Ilya Zykov <ilya@ilyx.ru>
Acked-by: Alan Cox <alan@linux.intel.com>
This reverts commit b1c43f82c5aa265442f82dba31ce985ebb7aa71c.
It was broken in so many ways, and results in random odd pty issues.
It re-introduced the buggy schedule_work() in flush_to_ldisc() that can
cause endless work-loops (see commit a5660b41af6a: "tty: fix endless
work loop when the buffer fills up").
It also used an "unsigned int" return value fo the ->receive_buf()
function, but then made multiple functions return a negative error code,
and didn't actually check for the error in the caller.
And it didn't actually work at all. BenH bisected down odd tty behavior
to it:
"It looks like the patch is causing some major malfunctions of the X
server for me, possibly related to PTYs. For example, cat'ing a
large file in a gnome terminal hangs the kernel for -minutes- in a
loop of what looks like flush_to_ldisc/workqueue code, (some ftrace
data in the quoted bits further down).
Some more data: It -looks- like what happens is that the
flush_to_ldisc work queue entry constantly re-queues itself (because
the PTY is full ?) and the workqueue thread will basically loop
forver calling it without ever scheduling, thus starving the consumer
process that could have emptied the PTY."
which is pretty much exactly the problem we fixed in a5660b41af6a.
Milton Miller pointed out the 'unsigned int' issue.
Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Reported-by: Milton Miller <miltonm@bga.com>
Cc: Stefan Bigler <stefan.bigler@keymile.com>
Cc: Toby Gray <toby.gray@realvnc.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
it makes it simpler to keep track of the amount of
bytes received and simplifies how flush_to_ldisc counts
the remaining bytes. It also fixes a bug of lost bytes
on n_tty when flushing too many bytes via the USB
serial gadget driver.
Tested-by: Stefan Bigler <stefan.bigler@keymile.com>
Tested-by: Toby Gray <toby.gray@realvnc.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
These were missed the last time I cleaned this up
globally, because of code moving around or new code
getting merged.
Fix locking in read and write code of n_hdlc line discipline.
2.6.36 replaced lock_kernel() with tty_lock(). The tty mutex is not
dropped automatically when the thread sleeps like the BKL. This results
in a blocked read or write holding the tty mutex and stalling operations
by other devices that use the tty mutex.
A review of n_hdlc read and write code shows:
1. neither BKL or tty mutex are required for correct operation
2. read can block while read data is available if data is posted
between availability check and call to interruptible_sleep_on()
3. write does not set process state to TASK_INTERRUPTIBLE
on each pass through the processing loop which can cause
unneeded scheduling of the thread
The unnecessary tty mutex references have been removed.
Read changed to use same code as n_tty read
for completing reads and blocking.
Write corrected to set process state to TASK_INTERRUPTIBLE on each pass
through processing loop.
The tty code should be in its own subdirectory and not in the char
driver with all of the cruft that is currently there.
Based on work done by Arnd Bergmann <arnd@arndb.de>
