path: root/drivers/tty/n_tracesink.c
2011-05-13n_tracerouter and n_tracesink ldisc additions.J Freyensee
The n_tracerouter and n_tracesink line discpline drivers use the Linux tty line discpline framework to route trace data coming from a tty port (say UART for example) to the trace sink line discipline driver and to another tty port(say USB). Those these two line discipline drivers can be used together, independently from pti.c, they are part of the original implementation solution of the MIPI P1149.7, compact JTAG, PTI solution for Intel mobile platforms starting with the Medfield platform. Signed-off-by: J Freyensee <james_p_freyensee@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
