With the previous patch, we fixed another bug where read_buf was freed
while we still was in n_tty_read. We currently check whether read_buf
is NULL at the start of the function. Add one more check after we wake
up from waiting for input.
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
This reverts commit b1c43f82c5aa265442f82dba31ce985ebb7aa71c.
It was broken in so many ways, and results in random odd pty issues.
It re-introduced the buggy schedule_work() in flush_to_ldisc() that can
cause endless work-loops (see commit a5660b41af6a: "tty: fix endless
work loop when the buffer fills up").
It also used an "unsigned int" return value fo the ->receive_buf()
function, but then made multiple functions return a negative error code,
and didn't actually check for the error in the caller.
And it didn't actually work at all. BenH bisected down odd tty behavior
to it:
"It looks like the patch is causing some major malfunctions of the X
server for me, possibly related to PTYs. For example, cat'ing a
large file in a gnome terminal hangs the kernel for -minutes- in a
loop of what looks like flush_to_ldisc/workqueue code, (some ftrace
data in the quoted bits further down).
Some more data: It -looks- like what happens is that the
flush_to_ldisc work queue entry constantly re-queues itself (because
the PTY is full ?) and the workqueue thread will basically loop
forver calling it without ever scheduling, thus starving the consumer
process that could have emptied the PTY."
which is pretty much exactly the problem we fixed in a5660b41af6a.
Milton Miller pointed out the 'unsigned int' issue.
Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Reported-by: Milton Miller <miltonm@bga.com>
Cc: Stefan Bigler <stefan.bigler@keymile.com>
Cc: Toby Gray <toby.gray@realvnc.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
it makes it simpler to keep track of the amount of
bytes received and simplifies how flush_to_ldisc counts
the remaining bytes. It also fixes a bug of lost bytes
on n_tty when flushing too many bytes via the USB
serial gadget driver.
Tested-by: Stefan Bigler <stefan.bigler@keymile.com>
Tested-by: Toby Gray <toby.gray@realvnc.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
Commit f23eb2b2b285 ('tty: stop using "delayed_work" in the tty layer')
ended up causing hung machines on UP with no preemption, because the
work routine to flip the buffer data to the ldisc would endlessly re-arm
itself if the destination buffer had filled up.
With the delayed work, that only caused a timer-driving polling of the
tty state every timer tick, but without the delay we just ended up with
basically a busy loop instead.
Stop the insane polling, and instead make the code that opens up the
receive room re-schedule the buffer flip work. That's what we should
have been doing anyway.
This same "poll for tty room" issue is almost certainly also the cause
of excessive kworker activity when idle reported by Dave Jones, who also
reported "flush_to_ldisc executing 2500 times a second" back in Nov 2010:
http://lkml.org/lkml/2010/11/30/592
which is that silly flushing done every timer tick. Wasting both power
and CPU for no good reason.
Reported-and-tested-by: Alexander Beregalov <a.beregalov@gmail.com>
Reported-and-tested-by: Sitsofe Wheeler <sitsofe@yahoo.com>
Cc: Greg KH <gregkh@suse.de>
Cc: Dave Jones <davej@redhat.com>
The tty code should be in its own subdirectory and not in the char
driver with all of the cruft that is currently there.
Based on work done by Arnd Bergmann <arnd@arndb.de>
Cc: Jiri Slaby <jslaby@suse.cz>
