path: root/drivers/tty/serial/altera_uart.c
2013-02-05tty: serial: altera_uart: Simplify altera_uart_init()Tobias Klauser
No need for two separate return statements, consolidate them. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-15TTY: switch tty_flip_buffer_pushJiri Slaby
Now, we start converting tty buffer functions to actually use tty_port. This will allow us to get rid of the need of tty in many call sites. Only tty_port will needed and hence no more tty_port_tty_get in those paths. Now, the one where most of tty_port_tty_get gets removed: tty_flip_buffer_push. IOW we also closed all the races in drivers not using tty_port_tty_get at all yet. Also we move tty_flip_buffer_push declaration from include/linux/tty.h to include/linux/tty_flip.h to all others while we are changing it anyway. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21tty: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@linux.intel.com> Acked-by: Tobias Klauser <tklauser@distanz.ch> Cc: Lucas Tavares <lucaskt@linux.vnet.ibm.com> Cc: Daniel Walker <dwalker@fifo99.com> Cc: Bryan Huntsman <bryanh@codeaurora.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Peter Korsgaard <jacmet@sunsite.dk> Cc: Tony Prisk <linux@prisktech.co.nz> Acked-by: David Brown <davidb@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21tty: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@linux.intel.com> Cc: Lucas Tavares <lucaskt@linux.vnet.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Peter Korsgaard <jacmet@sunsite.dk> Cc: Tony Prisk <linux@prisktech.co.nz> Acked-by: Tobias Klauser <tklauser@distanz.ch> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21tty: serial: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Alan Cox <alan@linux.intel.com> Cc: Lucas Tavares <lucaskt@linux.vnet.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Peter Korsgaard <jacmet@sunsite.dk> Cc: Tony Prisk <linux@prisktech.co.nz> Acked-by: Tobias Klauser <tklauser@distanz.ch> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-05tty: serial: altera_uart: Use platform_{get,set}_drvdataTobias Klauser
Use the wrapper functions, so we can directly pass a struct platfrom_device. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-09tty: serial: altera_uart: Check for NULL platform_data in probe.Yuriy Kozlov
Follow altera_jtag_uart. This fixes a crash if there is a mistake in the DTS. Signed-off-by: Yuriy Kozlov <ykozlov@ptcusa.com> Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-09tty: serial: altera_uart: Add CONSOLE_POLL supportTobias Klauser
This allows altera_uart to be used for KGDB debugging over serial line. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-09tty: serial: altera_uart: remove early_altera_uart_setupTobias Klauser
The function has no users inside the tree and the nios2 (out-of-mainline) port doesn't use it either (anymore). Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-10-27Merge branch 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6: of_mdio: Don't phy_scan_fixups() twice Devicetree: Expand on ARM Primecell binding documentation dt: Add empty of_match_node() macro dt: add empty dt helpers for non-dt build devicetree: fix build error on drivers/tty/serial/altera_jtaguart.c devicetree: Add ARM pl022 spi controller binding doc devicetree: Add ARM pl061 gpio controller binding doc of/irq: of_irq_find_parent: check for parent equal to child MAINTAINERS: update devicetree maintainers dt: add helper to read 64-bit integers tty: use of_match_ptr() for of_match_table entry OF: Add of_match_ptr() macro dt: add empty for_each_child_of_node, of_find_property devicetree: Document Qualcomm and Atmel prefixes serial/imx: add of_alias_get_id() reference back dt: add of_alias_scan and of_alias_get_id devicetree: Add a registry of vendor prefixes
2011-09-29tty: use of_match_ptr() for of_match_table entryBen Dooks
Use the new of_match_ptr() macro for the of_match_table pointer entry to avoid having to #dfine match NULL Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-09-22TTY: irq: Remove IRQF_DISABLEDYong Zhang
Since commit [e58aa3d2: genirq: Run irq handlers with interrupts disabled], We run all interrupt handlers with interrupts disabled and we even check and yell when an interrupt handler returns with interrupts enabled (see commit [b738a50a: genirq: Warn when handler enables interrupts]). So now this flag is a NOOP and can be removed. Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Acked-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19serial: altera_uart: Scan for a free port if platform device id is -1Tobias Klauser
Devices extracted from device tree all seem to have pdev->id set to -1. Up until now we mapped all devices with id -1 to the first device. This behaviour could lead to problems when using more than one Altera UART in a system. This patch changes the behaviour of the driver to scan for the next free id in case the id is -1. Because we cannot refer back to the assigned id in altera_uart_remove, the port instance needs to be stored in device drvdata. Reported-by: David Smoot <davidsmoot@gmail.com> Cc: Anton Vorontsov <cbouatmailru@gmail.com> Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-16Merge branch 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6: (21 commits) tty: serial: altera_jtaguart: Add device tree support tty: serial: altera_uart: Add devicetree support dt: eliminate of_platform_driver shim code dt: Eliminate of_platform_{,un}register_driver dt/serial: Eliminate users of of_platform_{,un}register_driver dt/usb: Eliminate users of of_platform_{,un}register_driver dt/video: Eliminate users of of_platform_{,un}register_driver dt/net: Eliminate users of of_platform_{,un}register_driver dt/sound: Eliminate users of of_platform_{,un}register_driver dt/spi: Eliminate users of of_platform_{,un}register_driver dt: uartlite: merge platform and of_platform driver bindings dt: xilinx_hwicap: merge platform and of_platform driver bindings ipmi: convert OF driver to platform driver leds/leds-gpio: merge platform_driver with of_platform_driver dt/sparc: Eliminate users of of_platform_{,un}register_driver dt/powerpc: Eliminate users of of_platform_{,un}register_driver dt/powerpc: move of_bus_type infrastructure to ibmebus drivercore/dt: add a match table pointer to struct device dt: Typo fix. altera_ps2: Add devicetree support ...
2011-03-01tty: serial: altera_uart: Add devicetree supportTobias Klauser
With the recent switch of the (currently still out-of-tree) Nios2 Linux port to devicetree we want to be able to retrieve the resources and properties from dts. The old method to retrieve resources and properties from platform data is still supported. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-02-17tty: serial: altera_uart: Use port->regshift to store bus shiftTobias Klauser
Use the regshift member of struct uart_port to store the address stride from platform data. This way we can save one dereference per call of altera_uart_readl and altera_uart_writel. This also allows us to use the driver without platform data, which is needed for device tree support in the Nios2 port. Acked-by: Anton Vorontsov <cbouatmailru@gmail.com> Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17tty: serial: altera_uart: Handle pdev->id == -1 in altera_uart_removeTobias Klauser
Commit 6b5756f176568a710d008d3b478128fafb6707f0 introduced the possibility for pdev->id being -1 but the change was not done equally in altera_uart_remove. This patch fixes this. Acked-by: Anton Vorontsov <cbouatmailru@gmail.com> Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-13tty: move drivers/serial/ to drivers/tty/serial/Greg Kroah-Hartman
The serial drivers are really just tty drivers, so move them to drivers/tty/ to make things a bit neater overall. This is part of the tty/serial driver movement proceedure as proposed by Arnd Bergmann and approved by everyone involved a number of months ago. Cc: Arnd Bergmann <arnd@arndb.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Rogier Wolff <R.E.Wolff@bitwizard.nl> Cc: Michael H. Warfield <mhw@wittsend.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
