commit 50b2b571c5f3df721fc81bf9a12c521dfbe019ba upstream.
The driver forgets to call pm_runtime_disable in remove.
Add the missed calls to fix it.
Signed-off-by: Chuhong Yuan <hslester96@gmail.com>
Cc: stable <stable@vger.kernel.org>
Link: https://lore.kernel.org/r/20191118024833.21587-1-hslester96@gmail.com
Make sure to deregister the SPI driver before releasing the tty driver
to avoid use-after-free in the SPI remove callback where the tty
devices are deregistered.
Fixes: 72d4724ea54c ("serial: ifx6x60: Add modem power off function in the platform reboot process")
Cc: stable <stable@vger.kernel.org> # 3.8
Cc: Jun Chen <jun.d.chen@intel.com>
Signed-off-by: Johan Hovold <johan@kernel.org>
When spi_setup() fails it doesn't free ifx_dev and we have a memory
leak. Fix this by freeing ifx_dev before the return.
Signed-off-by: Souptick joarder <jrdr.linux@gmail.com>
In ifx_spi_complete, 'more' is not initialized. It is set only if the
status is clear and only if the header is parsed OK. If any of those
is not true, 'more' can be used uninitialized in that function later.
gcc warns about a potential use of an uninitialized variable in this driver:
drivers/tty/serial/ifx6x60.c: In function 'ifx_spi_complete':
drivers/tty/serial/ifx6x60.c:713:6: warning: 'more' may be used uninitialized in this function [-Wmaybe-uninitialized]
if (more || ifx_dev->spi_more || queue_length > 0 ||
Unlike a lot of other such warnings, this one is correct and describes
an actual problem in the handling of the "IFX_SPI_HEADER_F" result code.
This appears to be a result from a restructuring of the driver that
dates back to before it was merged in the kernel, so it's impossible
to know where it went wrong. I also don't know what that result code
means, so I have no idea if setting 'more' to zero is the correct
solution, but at least it makes the behavior reproducible rather than
depending on whatever happens to be on the kernel stack.
This patch initializes the 'more' variable to zero in each of the
three code paths that could result in undefined behavior before,
which is more explicit than initializing it at the start of the
function.
An spi_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Andrew F. Davis <afd@ti.com>
Acked-by: Jonathan Cameron <jic23@kernel.org>
Signed-off-by: Mark Brown <broonie@kernel.org>
There's no need to cast the last parameter of {request,free}_irq() to
"void *", as any pointer type is accepted.
Remove the superfluous casts to fix this.
Casting spi_driver pointers to "void *" when calling
spi_{,un}register_driver() bypasses all type checking.
Casting the return value which is a void pointer is redundant.
The conversion from void pointer to any other pointer type is
guaranteed by the C programming language.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Acked-by: Vineet Gupta <vgupta@synopsys.com>
Use the wrapper function for retrieving the platform data instead of
accessing dev->platform_data directly.
The ifx6x60 driver implements both legacy suspend/resume callbacks and
dev_pm_ops. The SPI core is going to ignore legacy suspend/resume
callbacks if a driver implements dev_pm_ops. Since the legacy suspend/resume
callbacks are empty in this case it is safe to just remove them.
Cc: Bi Chao <chao.bi@intel.com>
Cc: Chen Jun <jun.d.chen@intel.com>
It allows for cleaning up on a considerable amount of places. They did
port_get, hangup, kref_put. Now the only thing needed is to call
tty_port_tty_hangup which does exactly that. And they can also decide
whether to consider CLOCAL or completely ignore that.
port_get, wakeup, kref_put. Now the only thing needed is to call
tty_port_tty_wakeup which does exactly that.
One exception is ifx6x60 where tty_wakeup was open-coded. We now call
tty_wakeup properly there.
This resolves a number of tty driver merge issues found in linux-next
There is no need to memset 0 to SPI frame memory before preparing
transfer frame bits, because SPI frame header are encoded with valid
data size, so don't need to worry about adopting dirty bits, more,
memset zero for each SPI frame may impact the spi throughput efficiency.
Signed-off-by: Chen Jun <jun.d.chen@intel.com>
Signed-off-by: channing <chao.bi@intel.com>
Now, we start converting tty buffer functions to actually use
tty_port. This will allow us to get rid of the need of tty in many
call sites. Only tty_port will needed and hence no more
tty_port_tty_get in those paths.
Now, the one where most of tty_port_tty_get gets removed:
tty_flip_buffer_push.
IOW we also closed all the races in drivers not using tty_port_tty_get
at all yet.
Also we move tty_flip_buffer_push declaration from include/linux/tty.h
to include/linux/tty_flip.h to all others while we are changing it
anyway.
One point is to have less places where we actually need tty pointer.
The other is that low_latency is bound to buffer processing and
buffers are now in tty_port. So it makes sense to move low_latency to
tty_port too.
tty_insert_flip_string this time.
As protocol driver, IFX SPI driver initiate to setup SPI master with default
SPI word size as 16 bit/word, however, SPI master may not adopt this default
value due to SPI controller's capability, it might choose an available value by
itself and set it to spi_device.bits_per_word. In order to keep align with
Controller, IFX driver should make use of this value during SPI transfer,
but the default one.
When shut down SPI port, it's possible that MRDY has been asserted and a SPI
timer was activated waiting for SRDY assert, in the case, it needs to delete
this timer.
This patch add modem power off function in the reboot process according registering
reboot callback to the reboot_notifier_list. Also realizing the spi shutdown function.
Signed-off-by: Bi Chao <chao.bi@intel.com>
Fix gcc warning of mixed data/code:
drivers/tty/serial/ifx6x60.c:516:2: warning: ISO C90 forbids mixed declarations and code
Cc: Russ Gorby <russ.gorby@intel.com>
Cc: Alan Cox <alan@linux.intel.com>
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Cc: Lucas Tavares <lucaskt@linux.vnet.ibm.com>
Cc: Peter Korsgaard <jacmet@sunsite.dk>
Cc: Tony Prisk <linux@prisktech.co.nz>
Acked-by: Tobias Klauser <tklauser@distanz.ch>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
After commit "TTY: move tty buffers to tty_port", the tty buffers are
not freed in some drivers. This is because tty_port_destructor is not
called whenever a tty_port is freed. This was an assumption I counted
with but was unfortunately untrue. So fix the drivers to fulfil this
assumption.
To be sure, the TTY buffers (and later some stuff) are gone along with
the tty_port, we have to call tty_port_destroy at tear-down places.
This is mostly where the structure containing a tty_port is freed.
This patch does exactly that -- put tty_port_destroy at those places.
empty
This patch check whether the fifo lenth is empty before writing new data to fifo.If condition
is true,ifx_spi_write need to trigger one mrdy_assert. If condition is false,the mrdy_assert
will be trigger by the next ifx_spi_io.
Acked-by: Alan Cox <alan@linux.intel.com>
This patch is to correct the bit mapping of "MORE" and "CTS" in SPI frame header.
Per SPI protocol, SPI header is encoded with length of 4 byte, which is defined
as below:
bit 0 ~ 11: current data size;
bit 12: "MORE" bit;
bit 13: reserve
bit 14 ~ 15: reserve
bit 16 ~ 27: next data size
bit 28: RI
bit 29: DCD
bit 30: CTS/RTS
bit 31: DSR/DTR
According to above SPI header structure, the bit mapping of "MORE" and "CTS" is
incorrect in function ifx_spi_decode_spi_header();
This patch is to implement following 2 places to avoid potential error when IFX6x60 port shutdown:
1) Clear Flag IFX_SPI_STATE_IO_AVAILABLE to disable data transfer when Modem port is shutdown;
2) Clear Flag IFX_SPI_STATE_IO_IN_PROGRESS and IFX_SPI_STATE_IO_READY when reopen port.
This is because last port shutdown may happen when SPI/DMA transfer is in progress, if the last
data transfer is not completed(for example due to modem reset), the Flag IFX_SPI_STATE_IO_IN_PROGRESS
will be set forever, so when IFX port is activated again, IFX_SPI_STATE_IO_IN_PROGRESS will prevent
transferring data forever. And if don't clear IFX_SPI_STATE_IO_READY, it may cause one more SPI frame
transferring in spit there is not data need to be transfer.
cc: liu chuansheng <chuansheng.liu@intel.com>
cc: Chen Jun <jun.d.chen@intel.com>
This patch make use of del_timer instead of del_timer_sync in the
interrupt context.
The spi_timer function don't use any resources that may release after
running del_timer,
so using the del_timer is also safe and enough in this context.
Tested-by: Chuansheng Liu <chuansheng.liu@intel.com>
This patch make use of mod_timer instead of add_timer in the mrdy_assert function.
Because the srdy interrupter can go high when we are running function mrdy_assert and mrdy_assert
can be called by multi-entry. In our medfield platform, spi stress test can encounter this
error logs triggered by the BUG_ON of add_timer function.This patch had been tested on
our medfield platform.
the scenario:
CPU0 CPU1
mrdy_assert
set_bit(IFX_SPI_STATE_TIMER_PENDING)
ifx_spi_handle_srdy
clear_bit(IFX_SPI_STATE_TIMER_PENDING)
mrdy_assert
add_timer
add_timer
Cc: liu chuansheng <chuansheng.liu@intel.com>
process
SPI protocol driver only provide one function (swap_buf()) to swap SPI
data into big endian format, which is only available when SPI
controller's word width is 16 bits. But word width could be configured
as 8/16/32 bits, different word width configure should be mapped to
different swap methods.This patch is to make SPI protocol driver choose
the right swap function corresponding to SPI word width configuration.
This picks up all of the different fixes in Linus's tree that we also need here.
Currently we have no way to assign tty->port while performing tty
installation. There are two ways to provide the link tty_struct =>
tty_port. Either by calling tty_port_install from tty->ops->install or
tty_port_register_device called instead of tty_register_device when
the device is being set up after connected.
In this patch we modify most of the drivers to do the latter. When the
drivers use tty_register_device and we have tty_port already, we
switch to tty_port_register_device. So we have the tty_struct =>
tty_port link for free for those.
[ 117.240866] BUG: unable to handle kernel paging request at 815b627c
[ 117.240866] IP: [<813fe94b>] spi_register_driver+0xb/0x50
[ 117.240866] Call Trace:
[ 117.240866] [<817de977>] ifx_spi_init+0xbe/0xf0
The root cause is, spi_register_driver() is trying to write into the
passed *const* struct spi_driver.
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
All num, magic and owner are set by alloc_tty_driver. No need to
re-set them on each allocation site.
pti driver sets something different to what it passes to
alloc_tty_driver. It is not a bug, since we don't use the lines
parameter in any way. Anyway this is fixed, and now we do the right
thing.
Acked-by: Tilman Schmidt <tilman@imap.cc>
In ancient times it was necessary to manually initialize the bus field of an
spi_driver to spi_bus_type. These days this is done in spi_driver_register(),
so we can drop the manual assignment.
The patch was generated using the following coccinelle semantic patch:
// <smpl>
identifier _driver;
struct spi_driver _driver = {
.driver = {
- .bus = &spi_bus_type,
// </smpl>
Remove linux/mm.h inclusion from netdevice.h -- it's unused (I've checked manually).
To prevent mm.h inclusion via other channels also extract "enum dma_data_direction"
definition into separate header. This tiny piece is what gluing netdevice.h with mm.h
via "netdevice.h => dmaengine.h => dma-mapping.h => scatterlist.h => mm.h".
Removal of mm.h from scatterlist.h was tried and was found not feasible
on most archs, so the link was cutoff earlier.
Hope people are OK with tiny include file.
Note, that mm_types.h is still dragged in, but it is a separate story.
Including linux/tty.h 3 times is a little over the top - once will do.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Doing tiocmget was such fun we should do tiocmset as well for the same
reasons
Signed-off-by: Alan Cox <alan@linux.intel.com>
We don't actually need this and it causes problems for internal use of
this functionality. Currently there is a single use of the FILE * pointer.
That is the serial core which uses it to check tty_hung_up_p. However if
that is true then IO_ERROR is also already set so the check may be removed.
renamed spi_driver variable to not be h/w specific
set driver name to use DRVNAME define
removed commented-out define
Signed-off-by: Russ Gorby <russ.gorby@intel.com>
The probe routine should call spi_setup() to configure
the SPI bus so it can properly communicate with the device.
E.g. the device operates in SPI mode 1.
Called spi_setup to configure SPI mode, max_speed_hz, and bpw
Platforms containing the 6260 can run up to 25Mhz.
For these platforms set max_speed_hz to 25Mhz.
driver should support 32bit SPI transfers. The boolean variable
only allowed 8/16.
Changed to support 8/16/32 for future enabling
of 32 bpw.
This driver is a SPI protocol driver and has no DMA ops
associated with the device so the call will fail. Furthermore,
the DMA allocation made here will be used by the SPI
controller driver (parent dev) so it makes sense to
pass that device instead.
The port ops must be set AFTER calling port init as that function
zeroes the structure
Some platform attributes (e.g. max_hz, use_dma) were being intuited
from the modem type. These things should be specified by the platform
data.
Added max_hz, use_dma to ifx_modem_platform_data definition,
replaced is_6160 w/ modem_type, and changed clients accordingly
The serial drivers are really just tty drivers, so move them to
drivers/tty/ to make things a bit neater overall.
This is part of the tty/serial driver movement proceedure as proposed by
Arnd Bergmann and approved by everyone involved a number of months ago.
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Rogier Wolff <R.E.Wolff@bitwizard.nl>
Cc: Michael H. Warfield <mhw@wittsend.com>
