[ Upstream commit a8da3c7873ea57acb8f9cea58c0af477522965aa ]
Function max310x_tx_empty() accesses the IRQSTS register, which is
cleared by IC when reading, so if there is an interrupt status, we
will lose it. This patch implement the transmitter check only by
the current FIFO level.
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
[ Upstream commit 35240ba26a932b279a513f66fa4cabfd7af55221 ]
Current calculator doesn't do it' job quite correct. First of all the
max310x baud-rates generator supports the divisor being less than 16.
In this case the x2/x4 modes can be used to double or quadruple
the reference frequency. But the current baud-rate setter function
just filters all these modes out by the first condition and setups
these modes only if there is a clocks-baud division remainder. The former
doesn't seem right at all, since enabling the x2/x4 modes causes the line
noise tolerance reduction and should be only used as a last resort to
enable a requested too high baud-rate.
Finally the fraction is supposed to be calculated from D = Fref/(c*baud)
formulae, but not from D % 16, which causes the precision loss. So to speak
the current baud-rate calculator code works well only if the baud perfectly
fits to the uart reference input frequency.
Lets fix the calculator by implementing the algo fully compliant with
the fractional baud-rate generator described in the datasheet:
D = Fref / (c*baud), where c={16,8,4} is the x1/x2/x4 rate mode
respectively, Fref - reference input frequency. The divisor fraction is
calculated from the same formulae, but making sure it is found with a
resolution of 0.0625 (four bits).
Signed-off-by: Serge Semin <fancer.lancer@gmail.com>
commit 5d24f455c182d5116dd5db8e1dc501115ecc9c2c upstream.
The datasheet states:
Bit 4: ClockEnSet the ClockEn bit high to enable an external clocking
(crystal or clock generator at XIN). Set the ClockEn bit to 0 to disable
clocking
Bit 1: CrystalEnSet the CrystalEn bit high to enable the crystal
oscillator. When using an external clock source at XIN, CrystalEn must
be set low.
The bit 4, MAX310X_CLKSRC_EXTCLK_BIT, should be set and was not.
This was required to make the MAX3107 with an external crystal on our
board able to send or receive data.
Signed-off-by: Joe Burmeister <joe.burmeister@devtank.co.uk>
Cc: stable <stable@vger.kernel.org>
commit 3a10e3dd52e80b9a97a3346020024d17b2c272d6 upstream.
of_match_device can return a NULL pointer when matching device is not
found. This patch avoids a scenario causing NULL pointer derefernce.
Signed-off-by: Aditya Pakki <pakki001@umn.edu>
New IC MAX14830 has 0xB4 silicon revision ID.
This patch adds support for such ICs.
When dev.of_node is not NULL, we also need to set IRQF_TRIGGER_FALLING
flag, otherwise it may cause uncertain interrupts.
Signed-off-by: Liu Xiang <liu.xiang6@zte.com.cn>
This patch makes assignment of port line automatically,
so now user allow to use several MAX310X chips.
Add uart_remove_one_port() for error path.
This patch moves UART registration at module_init initcall,
so this should helps to add multiple chip support in the future.
Use resource managed functions devm_gpiochip_add_data() to make
error & exit path a bit simpler.
RS485 IOCTLs uses spinlocks, so move regmap functions into a separate
work queue.
This makes the driver use the data pointer added to the gpio_chip
to store a pointer to the state container instead of relying on
container_of().
Cc: Jiri Slaby <jslaby@suse.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
The name .dev in a struct is normally reserved for a struct device
that is let us say a superclass to the thing described by the struct.
struct gpio_chip stands out by confusingly using a struct device *dev
to point to the parent device (such as a platform_device) that
represents the hardware. As we want to give gpio_chip:s real devices,
this is not working. We need to rename this member to parent.
This was done by two coccinelle scripts, I guess it is possible to
combine them into one, but I don't know such stuff. They look like
this:
struct gpio_chip *var;
-var->dev
+var->parent
and:
struct gpio_chip var;
-var.dev
+var.parent
and:
struct bgpio_chip *var;
-var->gc.dev
+var->gc.parent
Plus a few instances of bgpio that I couldn't figure out how
to teach Coccinelle to rewrite.
This patch hits all over the place, but I *strongly* prefer this
solution to any piecemal approaches that just exercise patch
mechanics all over the place. It mainly hits drivers/gpio and
drivers/pinctrl which is my own backyard anyway.
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Rafał Miłecki <zajec5@gmail.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
Cc: Alek Du <alek.du@intel.com>
Cc: Jaroslav Kysela <perex@perex.cz>
Cc: Takashi Iwai <tiwai@suse.com>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Acked-by: Lee Jones <lee.jones@linaro.org>
Acked-by: Jiri Kosina <jkosina@suse.cz>
Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Acked-by: Jacek Anaszewski <j.anaszewski@samsung.com>
An spi_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Andrew F. Davis <afd@ti.com>
Acked-by: Jonathan Cameron <jic23@kernel.org>
Signed-off-by: Mark Brown <broonie@kernel.org>
In order to unify all the rs485 ioctl handling
Use the implementation of TIOC[GS]RS485 ioctl handling on serial_core.
Reviewed-by: Alan Cox <alan@linux.intel.com>
Cc: Jiri Slaby <jslaby@suse.cz>
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com>
Commit e676253b19b2 ("serial/8250: Add support for RS485 IOCTLs") added
references to TIOC[SG]RS48 on 8250_core.c. This change triggered the
need to define them in all the arches that uses tty/serial.
This made #ifdef TIOC[SG]RS48 obsolete.
Cc: linux-serial@vger.kernel.org
register
This patch allows to read the REV_ID register in SPI mode and consequently
to properly detect the max3109. Indeed in SPI mode, this register is only
accessible by using indirect addressing.
Signed-off-by: Gregory Hermant <gregory.hermant@calao-systems.com>
this remove all reference to gpio_remove retval in all driver
except pinctrl and gpio. the same thing is done for gpio and
pinctrl in two different patches.
Signed-off-by: Abdoulaye Berthe <berthe.ab@gmail.com>
Acked-by: Michael Büsch <m@bues.ch>
Acked-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
If IGNBRK is set without either BRKINT or PARMRK set, some uart
drivers send a 0x00 byte for BREAK without the TTYBREAK flag to the
line discipline, when it should send either nothing or the TTYBREAK flag
set. This happens because the read_status_mask masks out the BI
condition, which uart_insert_char() then interprets as a normal 0x00 byte.
SUS v3 is clear regarding the meaning of IGNBRK; Section 11.2.2, General
Terminal Interface - Input Modes, states:
"If IGNBRK is set, a break condition detected on input shall be ignored;
that is, not put on the input queue and therefore not read by any
process."
Fix read_status_mask to include the BI bit if IGNBRK is set; the
lsr status retains the BI bit if a BREAK is recv'd, which is
subsequently ignored in uart_insert_char() when masked with the
ignore_status_mask.
Affected drivers:
8250 - all
serial_txx9
mfd
amba-pl010
amba-pl011
atmel_serial
bfin_uart
dz
ip22zilog
max310x
mxs-auart
netx-serial
pnx8xxx_uart
pxa
sb1250-duart
sccnxp
serial_ks8695
sirfsoc_uart
st-asc
vr41xx_siu
zs
sunzilog
fsl_lpuart
sunsab
ucc_uart
bcm63xx_uart
sunsu
efm32-uart
pmac_zilog
mpsc
msm_serial
m32r_sio
Unaffected drivers:
omap-serial
rp2
sa1100
imx
icom
Annotated for fixes:
altera_uart
mcf
Drivers without break detection:
21285
xilinx-uartps
altera_jtaguart
apbuart
arc-uart
clps711x
max3100
uartlite
msm_serial_hs
nwpserial
lantiq
vt8500_serial
Unknown:
samsung
mpc52xx_uart
bfin_sport_uart
cpm_uart/core
Fixes: Bugzilla #71651, '8250_core.c incorrectly handles IGNBRK flag'
Reported-by: Ivan <athlon_@mail.ru>
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
cris allmodconfig:
drivers/tty/serial/max310x.c: In function 'max310x_ioctl':
drivers/tty/serial/max310x.c:885:3: error: implicit declaration of function 'copy_from_user' [-Werror=implicit-function-declaration]
drivers/tty/serial/max310x.c:916:3: error: implicit declaration of function 'copy_to_user' [-Werror=implicit-function-declaration]
sparse warnings: (new ones prefixed by >>)
>> drivers/tty/serial/max310x.c:906:45: sparse: incorrect type in argument 2 (different address spaces)
drivers/tty/serial/max310x.c:906:45: expected void const [noderef] <asn:1>*from
drivers/tty/serial/max310x.c:906:45: got struct serial_rs485 *<noident>
>> drivers/tty/serial/max310x.c:938:35: sparse: incorrect type in argument 1 (different address spaces)
drivers/tty/serial/max310x.c:938:35: expected void [noderef] <asn:1>*to
drivers/tty/serial/max310x.c:938:35: got struct serial_rs485 *<noident>
Reported-by: kbuild test robot <fengguang.wu@intel.com>
This is a temporary solution to fix following issue:
config: make ARCH=alpha allyesconfig
All error/warnings:
>> drivers/tty/serial/max310x.c:905:7: error: 'TIOCSRS485' undeclared (first use in this function)
drivers/tty/serial/max310x.c:905:7: note: each undeclared identifier is reported only once for each function it appears in
>> drivers/tty/serial/max310x.c:906:3: error: implicit declaration of function 'copy_from_user' [-Werror=implicit-function-declaration]
>> drivers/tty/serial/max310x.c:929:7: error: 'TIOCGRS485' undeclared (first use in this function)
>> drivers/tty/serial/max310x.c:938:3: error: implicit declaration of function 'copy_to_user' [-Werror=implicit-function-declaration]
cc1: some warnings being treated as errors
This reverts commit e3c6ea9b1b81b87de96c01d5d37764009d546636 as it
didn't help anything, and caused more problems than expected.
Cc: Alexander Shiyan <shc_work@mail.ru>
config: x86_64-randconfig-x006 (attached as .config)
All warnings:
drivers/tty/serial/max310x.c: In function 'max310x_probe':
>> drivers/tty/serial/max310x.c:1240:1: warning: label 'out_uart' defined but not used [-Wunused-label]
All error/warnings:
This patch adds devicetree support for the MAX310X serial driver.
This patch removes some unused definitions from driver code and
sort #includes alphabetically.
This patch adds support for RS-485 (TIOCSRS485/TIOCGRS485) IOCTLs.
As a result this patch eliminate private driver header.
Always register GPIOs and use dynamic GPIO ID assignment.
This is no much worth if GPIOs is not used, but helps remove
private driver header and add DT support in the future.
Additionally, patch adds missing uart_unregister_driver()
call if probe() fails.
This patch removes "frequency" parameter from MAX310X platform_data
and uses CLK API for getting clock. Clock type (XTAL/OSC) is
determined by clk name.
Patch move all SPI-dependent stuff in one place. This include move
PM-function definitions out of CONFIG_SPI_MASTER and move regmap
initialization out of common probe into CONFIG_SPI_MASTER which
may help to add I2C support in the future for this driver.
This patch removes excess IRQ checks at driver probe().
IRQ validation is already provided by request_threaded_irq().
This patch replaces loopback mode support from platform data to
dynamic setup with TIOCMSET ioctl.
Serial core calls set_termios() after port startup, so there are
no reason to setup port twice.
These callbacks were previously used for the IC power initialization.
If this initialization will be needed in the future, it should be
implemented with the regulator API.
This patch provide more precisely setup of baud rate generator.
If the result of division has a remainder, we use the multiplier
for the base frequency. Additionally, we report result baud rate
back to serial core.
These aren't necessary after switch and while blocks.
This patch fixes wrong dev_pm_ops which caused by commit:
serial: max310x: Driver rework.
CC drivers/tty/serial/max310x.o
LD drivers/video/fb.o
CC drivers/w1/slaves/w1_ds2433.o
CC drivers/w1/slaves/w1_ds2760.o
CC drivers/xen/balloon.o
CC drivers/video/backlight/adp8870_bl.o
drivers/tty/serial/max310x.c:1292:8: warning: initialization from incompatible pointer type [enabled by default]
drivers/tty/serial/max310x.c:1292:8: warning: (near initialization for 'max310x_pm_ops.suspend') [enabled by default]
drivers/tty/serial/max310x.c:1292:8: warning: (near initialization for 'max310x_pm_ops.resume') [enabled by default]
drivers/tty/serial/max310x.c:1292:8: warning: (near initialization for 'max310x_pm_ops.freeze') [enabled by default]
drivers/tty/serial/max310x.c:1292:8: warning: (near initialization for 'max310x_pm_ops.thaw') [enabled by default]
drivers/tty/serial/max310x.c:1292:8: warning: (near initialization for 'max310x_pm_ops.poweroff') [enabled by default]
drivers/tty/serial/max310x.c:1292:8: warning: (near initialization for 'max310x_pm_ops.restore') [enabled by default]
This patch adds support for MAX14830 (advanced quad universal asynchronous
receiver-transmitter) into max310x driver.
This patch adds support for MAX3109 (advanced dual universal asynchronous
This patch rework max310x driver.
Major changes have been made:
- Prepare driver to support ICs with more than one UART.
- Prepare driver to support work with I2C-bus.
The patch changes almost every function and can not be divided into parts.
Use dev_pm_ops instead of the deprecated legacy suspend/resume for the
max310x driver.
Now, we start converting tty buffer functions to actually use
tty_port. This will allow us to get rid of the need of tty in many
call sites. Only tty_port will needed and hence no more
tty_port_tty_get in those paths.
Now, the one where most of tty_port_tty_get gets removed:
tty_flip_buffer_push.
IOW we also closed all the races in drivers not using tty_port_tty_get
at all yet.
Also we move tty_flip_buffer_push declaration from include/linux/tty.h
to include/linux/tty_flip.h to all others while we are changing it
anyway.
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Cc: Jiri Slaby <jirislaby@gmail.com>
Cc: Alan Cox <alan@linux.intel.com>
Acked-by: Tobias Klauser <tklauser@distanz.ch>
Cc: Lucas Tavares <lucaskt@linux.vnet.ibm.com>
Cc: Daniel Walker <dwalker@fifo99.com>
Cc: Bryan Huntsman <bryanh@codeaurora.org>
Cc: Peter Korsgaard <jacmet@sunsite.dk>
Cc: Tony Prisk <linux@prisktech.co.nz>
Acked-by: David Brown <davidb@codeaurora.org>
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
