This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6
* 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (26 commits)
amba pl011: workaround for uart registers lockup
n_gsm: fix the wrong FCS handling
pch_uart: add missing comment about OKI ML7223
pch_uart: Add MSI support
tty: fix "IRQ45: nobody cared"
PTI feature to allow user to name and mark masterchannel request.
0 for o PTI Makefile bug.
tty: serial: samsung.c remove legacy PM code.
SERIAL: SC26xx: Fix link error.
serial: mrst_max3110: initialize waitqueue earlier
mrst_max3110: Change max missing message priority.
tty: s5pv210: Add delay loop on fifo reset function for UART
tty/serial: Fix XSCALE serial ports, e.g. ce4100
serial: bfin_5xx: fix off-by-one with resource size
drivers/tty: use printk_ratelimited() instead of printk_ratelimit()
tty: n_gsm: Added refcount usage to gsm_mux and gsm_dlci structs
tty: n_gsm: Add raw-ip support
tty: n_gsm: expose gsmtty device nodes at ldisc open time
pch_phub: Fix register miss-setting issue
serial: 8250, increase PASS_LIMIT
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
fs: Merge split strings
treewide: fix potentially dangerous trailing ';' in #defined values/expressions
uwb: Fix misspelling of neighbourhood in comment
net, netfilter: Remove redundant goto in ebt_ulog_packet
trivial: don't touch files that are removed in the staging tree
lib/vsprintf: replace link to Draft by final RFC number
doc: Kconfig: `to be' -> `be'
doc: Kconfig: Typo: square -> squared
doc: Konfig: Documentation/power/{pm => apm-acpi}.txt
drivers/net: static should be at beginning of declaration
drivers/media: static should be at beginning of declaration
drivers/i2c: static should be at beginning of declaration
XTENSA: static should be at beginning of declaration
SH: static should be at beginning of declaration
MIPS: static should be at beginning of declaration
ARM: static should be at beginning of declaration
rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check
Update my e-mail address
PCIe ASPM: forcedly -> forcibly
gma500: push through device driver tree
Fix up trivial conflicts:
- arch/arm/mach-ep93xx/dma-m2p.c (deleted)
- drivers/gpio/gpio-ep93xx.c (renamed and context nearby)
- drivers/net/r8169.c (just context changes)
git+ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc
* 'next/deletion' of git+ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc:
ARM: mach-loki: delete
ARM: mach-s3c2400: delete
ARM: mach-s3c24a0: delete
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc
* 'next/cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (133 commits)
ARM: EXYNOS4: Change devname for FIMD clkdev
ARM: S3C64XX: Cleanup mach/regs-fb.h from mach-s3c64xx
ARM: S5PV210: Cleanup mach/regs-fb.h from mach-s5pv210
ARM: S5PC100: Cleanup mach/regs-fb.h from mach-s5pc100
ARM: S3C24XX: Use generic s3c_set_platdata for devices
ARM: S3C64XX: Use generic s3c_set_platdata for OneNAND
ARM: SAMSUNG: Use generic s3c_set_platdata for NAND
ARM: SAMSUNG: Use generic s3c_set_platdata for USB OHCI
ARM: SAMSUNG: Use generic s3c_set_platdata for HWMON
ARM: SAMSUNG: Use generic s3c_set_platdata for FB
ARM: SAMSUNG: Use generic s3c_set_platdata for TS
ARM: S3C64XX: Add PWM backlight support on SMDK6410
ARM: S5P64X0: Add PWM backlight support on SMDK6450
ARM: S5P64X0: Add PWM backlight support on SMDK6440
ARM: S5PC100: Add PWM backlight support on SMDKC100
ARM: S5PV210: Add PWM backlight support on SMDKV210
ARM: EXYNOS4: Add PWM backlight support on SMDKC210
ARM: EXYNOS4: Add PWM backlight support on SMDKV310
ARM: SAMSUNG: Create a common infrastructure for PWM backlight support
clocksource: convert 32-bit down counting clocksource on S5PV210/S5P64X0
Fix up trivial conflict in arch/arm/mach-imx/mach-scb9328.c
* 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6:
dt: include linux/errno.h in linux/of_address.h
of/address: Add of_find_matching_node_by_address helper
dt: remove extra xsysace platform_driver registration
tty/serial: Add devicetree support for nVidia Tegra serial ports
dt: add empty of_property_read_u32[_array] for non-dt
dt: bindings: move SEC node under new crypto/
dt: add helper function to read u32 arrays
tty/serial: change of_serial to use new of_property_read_u32() api
dt: add 'const' for of_property_read_string parameter **out_string
dt: add helper functions to read u32 and string property values
tty: of_serial: support for 32 bit accesses
dt: document the of_serial bindings
dt/platform: allow device name to be overridden
drivers/amba: create devices from device tree
dt: add of_platform_populate() for creating device from the device tree
dt: Add default match table for bus ids
Uart port is registered as a console during the driver's probe.
So explict registration of console with console_initcall is
removed.
Signed-off-by: Thomas Abraham <thomas.ab@samsung.com>
[kgene.kim@samsung.com: removed changes of s3c2400 and s3c24a0]
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
On Tue, 28 Jun 2011, Ben Dooks wrote:
> On Tue, Jun 28, 2011 at 11:22:57PM +0200, Arnd Bergmann wrote:
> > On a related note, what about mach-s3c2400? It seems to be even more
> > incomplete.
> Probably the same fate awaits that. It is so old that there's little
> incentive to do anything with it.
So out it goes as well.
The PORT_S3C2400 definition in include/linux/serial_core.h is left there
to prevent a reuse of the same number for another port type.
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Commit bcae8aeb32 "[ARM] S3C24A0: Initial architecture support files"
brought in a bunch of files while explicitly leaving out the corresponding
Kconfig entry, stating that the series is not complete.
More than 2.5 years later, the support for this has not seen any progress.
This is therefore dead code. If someone wants to revive this code, it is
always possible to retrieve it from the Git repository.
Acked-by: Ben Dooks <ben-linux@fluff.org>
net/bluetooth/l2cap_core.c
Sync with Linus' tree to be able to apply pending patches that
are based on newer code already present upstream.
This workaround aims to break the deadlock situation
which raises during continuous transfer of data for long
duration over uart with hardware flow control. It is
observed that CTS interrupt cannot be cleared in uart
interrupt register (ICR). Hence further transfer over
uart gets blocked.
It is seen that during such deadlock condition ICR
don't get cleared even on multiple write. This leads
pass_counter to decrease and finally reach zero. This
can be taken as trigger point to run this UART_BT_WA.
Workaround backups the register configuration, does soft
reset of UART using BIT-0 of PRCC_K_SOFTRST_SET/CLEAR
registers and restores the registers.
This patch also provides support for uart init and exit
function calls if present.
Signed-off-by: Shreshtha Kumar Sahu <shreshthakumar.sahu@stericsson.com>
Signed-off-by: Alexander Stein <alexander.stein@systec-electronic.com>
Reviewed-by: Jesper Juhl <jj@chaosbits.net>
In s3c24xx_serial_console_setup function, if the uart port that is
being setup as a console has not been initialized, an error can be
returned instead of using uart port 0 as the default console port.
The uart port that was intended to be used as a console could be
initialized at a later point during boot and then registered as a
console. This will avoid using uart port 0 as a unintended console
port.
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-2.6-arm-soc
* 'at91/fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-2.6-arm-soc:
AT91: Change nand buswidth logic to match hardware default configuration
at91: Use "pclk" as con_id on at91cap9 and at91rm9200
at91: fix udc, ehci and mmc clock device name for cap9/9g45/9rl
atmel_serial: fix internal port num
at91: fix at91_set_serial_console: use platform device id
Simplifies the code a bit and drops a few lines.
This patch "modernize" tty/serial/samsung.c to use non-legacy code for
suspend/resume.
Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com>
Signed-off-by: KyungMin Park <kyungmin.park@samsung.com>
Kconfig allows enabling console support for the SC26xx driver even when
it's configured as a module resulting in a:
ERROR: "uart_console_device" [drivers/tty/serial/sc26xx.ko] undefined!
modpost error since the driver was merged in
eea63e0e8a60d00485b47fb6e75d9aa2566b989b [SC26XX: New serial driver for
SC2681 uarts] in 2.6.25. Fixed by only allowing console support to be
enabled if the driver is builtin.
Cc: linux-serial@vger.kernel.org
Cc: linux-mips@linux-mips.org
Cc: stable <stable@kernel.org>
Acked-by: Alan Cox <alan@linux.intel.com>
The driver went to initialize its waitqueue at the start of the main processing
thread. However, it is possible that this thread is not scheduled on a CPU
before the write function is called which leads to a following error:
BUG: spinlock bad magic on CPU#1, swapper/1
lock: f5f3ebdc, .magic: 00000000, .owner: <none>/-1, .owner_cpu: 0
Pid: 1, comm: swapper Not tainted 3.0.0-rc2+ #67
Call Trace:
[<c1289663>] spin_bug+0xa3/0xf0
[<c12897ad>] do_raw_spin_lock+0x7d/0x150
[<c1490006>] ? init_idle+0x8d/0x20c
[<c14963de>] _raw_spin_lock_irqsave+0x4e/0x60
[<c102f2bb>] ? __wake_up+0x1b/0x50
[<c102f2bb>] __wake_up+0x1b/0x50
[<c12d03bc>] ? uart_console_write+0x4c/0x60
[<c12d36c0>] ? serial_m3110_enable_ms+0x10/0x10
[<c12d3715>] serial_m3110_con_write+0x55/0x60
[<c1041575>] __call_console_drivers+0x75/0x90
[<c10415d9>] _call_console_drivers+0x49/0x80
[<c1041baa>] console_unlock+0xca/0x1f0
[<c10420ef>] vprintk+0x18f/0x4f0
[<c10787cb>] ? trace_hardirqs_on+0xb/0x10
[<c14928a3>] printk+0x18/0x1a
[<c1042730>] register_console+0x2e0/0x350
[<c12d098e>] uart_add_one_port+0x33e/0x3d0
[<c103e10b>] ? try_to_wake_up+0x18b/0x250
[<c1485ba6>] serial_m3110_probe+0x1c2/0x1df
[<c12d3d20>] ? serial_m3110_suspend+0x40/0x40
[<c1303db7>] spi_drv_probe+0x17/0x20
We fix this by initializing the waitqueue before the main thread is created.
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Signed-off-by: Alan Cox <alan@linux.intel.com>
Change print message to notice instead of error to clean up
non critcal messages showing on startup. The MAX3111 not being present
is a normal path for end user systems.
Signed-off-by: William Douglas <william.douglas@intel.com>
[rebased on 3.0, switched to dev_dbg()]
This patch addes delay loop on fifo reset function for UART.
On high speed freq, it needs delay function when fifo reset.
If not, system will hang by this uart reset problem when resuming
from suspend mode.
Signed-off-by: Jongpill Lee <boyko.lee@samsung.com>
Signed-off-by: Jaecheol Lee <jc.lee@samsung.com>
Commit 4539c24fe4f92c09ee668ef959d3e8180df619b9 "tty/serial: Add
explicit PORT_TEGRA type" introduced separate flags describing the need
for IER bits UUE and RTOIE. Both bits are required for the XSCALE port
type. While that patch updated uart_config[] as required, the auto-probing
code wasn't updated to set the RTOIE flag when an XSCALE port type was
detected. This caused such ports to stop working. This patch rectifies
that.
Reported-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Tested-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: stable <stable@kernel.org> [3.0]
This doesn't cause any real bugs, but it should still be fixed.
Some platforms e.g. TI Davinci require 32-bit accesses to the UARTs.
The of_serial driver currently registers all UARTs as UPIO_MEM. Add a
new attribute "reg-io-width" to allow the port to be registered with
different IO width requirements.
Signed-off-by: Jamie Iles <jamie@jamieiles.com>
* 'tty-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6:
serial: bcm63xx_uart: fix irq storm after rx fifo overrun.
amba pl011: platform data for reg lockup and glitch v2
tty: n_gsm: improper skb_pull() use was leaking framed data
tty: n_gsm: Fixed logic to decode break signal from modem status
TTY: ntty, add one more sanity check
TTY: ldisc, do not close until there are readers
8250: Fix capabilities when changing the port type
8250_pci: Fix missing const from merges
ARM: SAMSUNG: serial: Fix on handling of one clock source for UART
serial: ioremap warning fix for jsm driver.
8250_pci: add -ENODEV code for Intel EG20T PCH
Fis the warning
drivers/tty/serial/8250_pci.c:1457: warning: initialization from incompatible pointer type
Cc: Greg KH <greg@kroah.com>
the atmel_ports is link to the console number and not the device id
this was not detected on at91 as we always register the dbgu on the console
as ttyS0
tested on at91sam9263 by setting the dbgu as ttyS1 and use as console
diff --git a/arch/arm/mach-at91/board-sam9263ek.c b/arch/arm/mach-at91/board-sam9263ek.c
index 70e5646..9b8a14f 100644
- a/arch/arm/mach-at91/board-sam9263ek.c
+ b/arch/arm/mach-at91/board-sam9263ek.c
@@ -58,14 +58,14 @@ static void __init ek_init_early(void)
/* Initialize processor: 16.367 MHz crystal */
at91_initialize(16367660);
- /* DBGU on ttyS0. (Rx & Tx only) */
- at91_register_uart(0, 0, 0);
+ /* DBGU on ttyS1. (Rx & Tx only) */
+ at91_register_uart(0, 1, 0);
- /* USART0 on ttyS1. (Rx, Tx, RTS, CTS) */
- at91_register_uart(AT91SAM9263_ID_US0, 1, ATMEL_UART_CTS | ATMEL_UART_RTS);
+ /* USART0 on ttyS0. (Rx, Tx, RTS, CTS) */
+ at91_register_uart(AT91SAM9263_ID_US0, 0, ATMEL_UART_CTS | ATMEL_UART_RTS);
- /* set serial console to ttyS0 (ie, DBGU) */
- at91_set_serial_console(0);
+ /* set serial console to ttyS1 (ie, DBGU) */
+ at91_set_serial_console(1);
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Alan Cox <alan@linux.intel.com>
Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Just tyops.
processing thread. However, it is possible that this thread is not
scheduled on a CPU before the write function is called which leads to a
following error:
Call Trace:
Fix this by initializing the waitqueue before the main thread is
created.
Change print message to notice instead of error to clean up non critical
messages showing on startup. The MAX3111 not being present is a normal
Remove linux/mm.h inclusion from netdevice.h -- it's unused (I've checked manually).
To prevent mm.h inclusion via other channels also extract "enum dma_data_direction"
definition into separate header. This tiny piece is what gluing netdevice.h with mm.h
via "netdevice.h => dmaengine.h => dma-mapping.h => scatterlist.h => mm.h".
Removal of mm.h from scatterlist.h was tried and was found not feasible
on most archs, so the link was cutoff earlier.
Hope people are OK with tiny include file.
Note, that mm_types.h is still dragged in, but it is a separate story.
RX fifo reset is required to clear irq.
Signed-off-by: Maxime Bizon <mbizon@freebox.fr>
uart gets blocked.
If dmi_get_system_info() returns NULL, pch_uart_init_port() will
dereferencea a zero pointer.
This oops was observed on an Atom based board which has no BIOS, but
a bootloder which doesn't provide DMI data.
Cc: Greg KH <gregkh@suse.de>
Cc: <stable@kernel.org>
Several fixes as well where the +1 was missing.
Done via coccinelle scripts like:
struct resource *ptr;
- ptr->end - ptr->start + 1
+ resource_size(ptr)
and some grep and typing.
Mostly uncompiled, no cross-compilers.
With virtual machines like qemu, it's pretty common to see "too much
work for irq4" messages nowadays. This happens when a bunch of output
is printed on the emulated serial console. This is caused by too low
PASS_LIMIT. When ISR loops more than the limit, it spits the message.
I've been using a kernel with doubled the limit and I couldn't see no
problems. Maybe it's time to get rid of the message now?
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
The purpose of the patch is to add EEH support to the 8250_PCI driver
for the IBM/Digi PCIE 2port Async EIA-232 Adapter that uses a PLX
chipset on the PPC platforrm. Basic support for this adapter was
recently added https://lkml.org/lkml/2011/5/11/341
This patch was created against the linux-next kernel
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Breno Leitao <leitao@linux.vnet.ibm.com>
Cc: Scott Kilau <scottk@digi.com>
Signed-off-by: Michael Reed <mreed@linux.vnet.ibm.com>
Timedia/SUNIX PCI cards with both serial and parallel ports are
currently supported by 8250_pci and parport_pc individually. Moving
that support into parport_serial allows using both types of ports at the
same time.
This was successfully tested with a SUNIX 4079T.
Signed-off-by: Frédéric Brière <fbriere@fbriere.net>
Cc: linux-parport@lists.infradead.org
This function, if present, is called early on by the 8250_pci probe; it
can be used to reject devices meant for parport_serial. (The .init
function cannot be used for this purpose, as it is also called by
parport_serial.)
Add I/O based support for serial and parallel ports of the following
chips:
Vendor: Moschip (0x9710)
Parts (device IDs)
* 9900 (0x9900)
* 9904 (0x9904
* 9901 (0x9912, also sold as 9912)
* 9922 (0x9922)
On all chips but the 9900, a single port is provided per PCI subdevice
(subvendor-ID 0xA000, subdevice-IDs 0x1000 for serial, 0x2000 for
parallel with proper class codes). In cascading configurations, the
9900 provides two devices per subdevice, with subvendor-ID 0xA000 and
subdevice-IDs 0x30ps where p is the number of parallel ports and s the
number of serial ports.
Basic testing was only done on the serial part of a 9912 to the point
where it can be used for a serial kernel console, and advanced features
are completely untested. It is possible to reduce functionality of the
chips by adding a configuration EEPROM, and the datasheet [1] is
inconsistent w.r.t subdevices in the 4s+2s1p and 2s1p+4s
configurations. The subdevice-ID 0x3012 should likely read 0x3011 with
a serial port in function 3, which would be consistent with the BAR
layouts. For now, the drivers ignore subdevices with ID 0x1000 and no
class code.
The parallel ports are integrated in parport_serial even for purely
parallel parts to reduce the footprint of the patch.
[1] http://www.moschip.com/data/products/MCS9900/MCS9900_Datasheet.pdf
Signed-off-by: Nicos Gollan <gtdev@spearhead.de>
When changing the port type, the capabilities flags should be changed
also, otherwise the capabilities will not correspond to the port type,
which make set_sleep() crash on rmmod.
This patch just assign the correct capabilites when the port changes.
Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com>
CC: Michael Reed <mreed@linux.vnet.ibm.com>
Signed-off-by: Antony Pavlov <antony@niisi.msk.ru>
Signed-off-by: Borislav Petkov <bp@alien8.de>
Signed-off-by: Vasily Averin <vvs@sw.ru>
This patch fixes the way of comparison for handling of two or more
clock sources for UART.
For example, if just only one clock source is defined even though
there are two clock sources for UART, the serial driver does not
set proper clock up. Of course, it is problem.
So this patch changes the condition of comparison to avoid useless
setup clock and adds a flag 'NO_NEED_CHECK_CLKSRC' which means
selection of source clock is not required.
In addition, since the Exynos4210 has only one clock source for UART
this patch adds the flag into its common_init_uarts().
Signed-off-by: Boojin Kim <boojin.kim@samsung.com>
I saw a warning about ioremap from the jsm driver on a system which
looked like this:
resource map sanity check conflict: 0xe0200800 0xe02017ff 0xe0200800 0xe0200fff 0000:01:08.0
Turns out the warning is valid. The jsm driver has been asking to ioremap
0x1000 forever, but in fact only 8 port chips have 0x1000 bytes of memory.
4 port chips have 0x800 and 2 port chips have 0x400 according to the
data sheet. It makes more sense to map the size of the region rather
than a hard coded value. If you happen to have the region legitimately
mapped to a base address that is not 4K aligned, ioremap complains
otherwise.
Signed-off-by: Len Sorensen <lsorense@csclub.uwaterloo.ca>
