path: root/drivers/tty/tty_ldisc.c
2014-11-06tty: Allow safe access to termios for set_ldisc() handlersPeter Hurley
Allow a tty driver to safely access termios settings while handling the set_ldisc() notification. UART drivers use the set_ldisc() notification to check if the N_PPS line discipline is being enabled; if so, modem status interrupts may also need to be enabled. Conversely, modem status interrupts may need to be disabled if switching away from the N_PPS line discipline. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-05tty: Flush ldisc buffer atomically with tty flip buffersPeter Hurley
tty_ldisc_flush() first clears the line discipline input buffer, then clears the tty flip buffers. However, this allows for existing data in the tty flip buffers to be added after the ldisc input buffer has been cleared, but before the flip buffers have been cleared. Add an optional ldisc parameter to tty_buffer_flush() to allow tty_ldisc_flush() to pass the ldisc to clear. NB: Initially, the plan was to do this automatically in tty_buffer_flush(). However, an audit of the behavior of existing line disciplines showed that performing a ldisc buffer flush on ioctl(TCFLSH) was not always the outcome. For example, some line disciplines have flush_buffer() methods but not ioctl() methods, so a ->flush_buffer() command would be unexpected. Reviewed-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-05tty: Fix timeout on pty set ldiscPeter Hurley
When changing the ldisc on one end of a pty pair, there may be waiting readers/writers on the other end which may not exit from the ldisc i/o loop, preventing tty_ldisc_lock_pair_timeout() from acquiring the other side's ldisc lock. Only acquire this side's ldisc lock; although this will no longer prevent the other side from writing new input, that input will not be processed until after the ldisc change completes. This has no effect on normal ttys; new input from the driver was never disabled. Remove tty_ldisc_enable_pair(). Reviewed-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-05tty: Fix hung task on pty hangupPeter Hurley
When hanging up one end of a pty pair, there may be waiting readers/writers on the other end which may not exit, preventing tty_ldisc_lock_pair() from acquiring the other side's ldisc lock. Only acquire this side's ldisc lock; although this will no longer prevent the other side from writing new input, that input will not be processing until after the ldisc hangup is complete. Reported-by: Sasha Levin <sasha.levin@oracle.com> Reviewed-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-05tty: Prefix tty_ldisc_{lock,lock_nested,unlock} functionsPeter Hurley
tty_ldisc_lock(), tty_ldisc_unlock(), and tty_ldisc_lock_nested() are low-level aliases for the underlying lock mechanism. Rename with double underscore to allow for new, higher level functions with those names. Reviewed-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-05tty: Simplify tty_ldisc_release() interfacePeter Hurley
Passing the 'other' tty to tty_ldisc_release() only makes sense for a pty pair; make o_tty function local instead. Reviewed-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-05tty: Remove TTY_HUPPINGPeter Hurley
Now that tty_ldisc_hangup() does not drop the tty lock, it is no longer possible to observe TTY_HUPPING while holding the tty lock on another cpu. Remove TTY_HUPPING bit definition. Reviewed-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-05tty: Invert tty_lock/ldisc_sem lock orderPeter Hurley
Dropping the tty lock to acquire the tty->ldisc_sem allows several race conditions (such as hangup while changing the ldisc) which requires extra states and testing. The ldisc_sem->tty_lock lock order has not been required since tty buffer ownership was moved to tty_port. Reviewed-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-05tty: Don't hold tty_lock for ldisc releasePeter Hurley
The tty->ldisc_sem write lock is sufficient for serializing changes to tty->ldisc; holding the tty lock is not required. Reviewed-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-07tty: delete non-required instances of include <linux/init.h>Paul Gortmaker
None of these files are actually using any __init type directives and hence don't need to include <linux/init.h>. Most are just a left over from __devinit and __cpuinit removal, or simply due to code getting copied from one driver to the next. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-23tty: Convert termios_mutex to termios_rwsemPeter Hurley
termios is commonly accessed unsafely (especially by N_TTY) because the existing mutex forces exclusive access. Convert existing usage. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-23tty: Don't change receive_room for ioctl(TIOCSETD)Peter Hurley
tty_set_ldisc() is guaranteed exclusive use of the line discipline by tty_ldisc_lock_pair_timeout(); shutting off input by resetting receive_room is unnecessary. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-23tty: Clarify multiple-references comment in TIOCSETD ioctlPeter Hurley
2013-07-23tty: Fix hangup race with TIOCSETD ioctlPeter Hurley
The hangup may already have happened; check for that state also. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-23tty: Clarify ldisc variablePeter Hurley
Rename o_ldisc to avoid confusion with the ldisc of the 'other' tty. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-23tty: Replace ldisc locking with ldisc_semPeter Hurley
Line discipline locking was performed with a combination of a mutex, a status bit, a count, and a waitqueue -- basically, a rw semaphore. Replace the existing combination with an ld_semaphore. Fixes: 1) the 'reference acquire after ldisc locked' bug 2) the over-complicated halt mechanism 3) lock order wrt. tty_lock() 4) dropping locks while changing ldisc 5) previously unidentified deadlock while locking ldisc from both linked ttys concurrently 6) previously unidentified recursive deadlocks Adds much-needed lockdep diagnostics. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-23tty: Add lock/unlock ldisc pair functionsPeter Hurley
Just as the tty pair must be locked in a stable sequence (ie, independent of which is consider the 'other' tty), so must the ldisc pair be locked in a stable sequence as well. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-23tty: Fix tty_ldisc_lock name collisionPeter Hurley
The file scope spinlock identifier, tty_ldisc_lock, will collide with the file scope lock function tty_ldisc_lock() so rename it. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-18tty: Remove redundant tty_wait_until_sent()Peter Hurley
tty_ioctl() already waits until sent. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-18tty: Locate get/put ldisc functions togetherPeter Hurley
2013-03-18tty: Fold one-line assign function into callersPeter Hurley
Now that tty_ldisc_assign() is a one-line file-scoped function, remove it and perform the simple assignment at its call sites. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-18tty: Document unsafe ldisc reference acquirePeter Hurley
Merge get_ldisc() into its only call site. Note how, after merging, the unsafe acquire of an ldisc reference is obvious. CPU 0 in tty_ldisc_try() | CPU 1 in tty_ldisc_halt() | test_bit(TTY_LDISC, &tty_flags) | if (true) | clear_bit(TTY_LDISC, &tty_flags) tty->ldisc != 0? | atomic_read(&tty->ldisc->users) if (true) | ret_val == 1? atomic_inc(&tty->ldisc->users) | if (false) | wait | <goes on assuming safe ldisc use> | <doesn't wait - proceeds w/ close> | The spin lock in tty_ldisc_try() does nothing wrt synchronizing the ldisc halt since it's not acquired as part of halting. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-18tty: Separate release semantics of ldisc referencePeter Hurley
tty_ldisc_ref()/tty_ldisc_unref() have usage semantics equivalent to down_read_trylock()/up_read(). Only callers of tty_ldisc_put() are performing the additional operations necessary for proper ldisc teardown, and then only after ensuring no outstanding 'read lock' remains. Thus, tty_ldisc_unref() should never be the last reference; WARN if it is. Conversely, tty_ldisc_put() should never be destructing if the use count != 1. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-18tty: Add ldisc hangup debug messagesPeter Hurley
Expected typical debug log: [ 582.721965] tty_open: opening pts3... [ 582.721970] tty_open: opening pts3... [ 582.721977] tty_release: pts3 (tty count=3)... [ 582.721980] tty_release: ptm3 (tty count=1)... [ 582.722015] pts3 vhangup... [ 582.722020] tty_ldisc_hangup: pts3: closing ldisc: ffff88007a920540 [ 582.724128] tty_release: pts3 (tty count=2)... [ 582.724217] tty_ldisc_hangup: pts3: re-opened ldisc: ffff88007a920580 [ 582.724221] tty_release: ptm3: final close [ 582.724234] tty_ldisc_release: ptm3: closing ldisc: ffff88007a920a80 [ 582.724238] tty_ldisc_release: ptm3: ldisc closed [ 582.724241] tty_release: ptm3: freeing structure... [ 582.724741] tty_open: opening pts3... Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-18tty: Fix 'deferred reopen' ldisc commentPeter Hurley
This comment is a victim of code migration from "tty: Fix the ldisc hangup race"; re-parent it. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-18tty: Make core responsible for synchronizing its workPeter Hurley
The tty core relies on the ldisc layer for synchronizing destruction of the tty. Instead, the final tty release must wait for any pending tty work to complete prior to tty destruction. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-18tty: Complete ownership transfer of flip buffersPeter Hurley
Waiting for buffer work to complete is not required for safely performing changes to the line discipline, once the line discipline is halted. The buffer work routine, flush_to_ldisc(), will be unable to acquire an ldisc ref and all existing references were waited until released (so it can't already have one). Ensure running buffer work which may reference the soon-to-be-gone tty completes and any buffer work running after this point retrieves a NULL tty. Also, ensure all buffer work is cancelled on port destruction. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-18tty: Don't reenable already enabled ldiscPeter Hurley
tty_ldisc_hangup() guarantees the ldisc is enabled (or that there is no ldisc). Since __tty_hangup() was the only user, re-define tty_ldisc_enable() in file-scope. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-18tty: Wait for SAK work before waiting for hangup workPeter Hurley
SAK work may schedule hangup work (if TTY_SOFT_SAK is defined), thus SAK work must be flushed before hangup work. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-18tty: Halt both ldiscs concurrentlyPeter Hurley
The pty driver does not obtain an ldisc reference to the linked tty when writing. When the ldiscs are sequentially halted, it is possible for one ldisc to be halted, and before the second ldisc can be halted, a concurrent write schedules buffer work on the first ldisc. This can lead to an access-after-free error when the scheduled buffer work starts on the closed ldisc. Prevent subsequent use after halt by performing each stage of the halt on both ttys. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-18tty: Strengthen no-subsequent-use guarantee of tty_ldisc_halt()Peter Hurley
In preparation for destructing and freeing the tty, the line discipline must first be brought to an inactive state before it can be destructed. This line discipline shutdown must: - disallow new users of the ldisc - wait for existing ldisc users to finish - only then, cancel/flush their pending/running work Factor tty_ldisc_wait_idle() from tty_set_ldisc() and tty_ldisc_kill() to ensure this shutdown order. Failure to provide this guarantee can result in scheduled work running after the tty has already been freed, as indicated in the following log message: [ 88.331234] WARNING: at drivers/tty/tty_buffer.c:435 flush_to_ldisc+0x194/0x1d0() [ 88.334505] Hardware name: Bochs [ 88.335618] tty is bad=-1 [ 88.335703] Modules linked in: netconsole configfs bnep rfcomm bluetooth ...... [ 88.345272] Pid: 39, comm: kworker/1:1 Tainted: G W 3.7.0-next-20121129+ttydebug-xeon #20121129+ttydebug [ 88.347736] Call Trace: [ 88.349024] [<ffffffff81058aff>] warn_slowpath_common+0x7f/0xc0 [ 88.350383] [<ffffffff81058bf6>] warn_slowpath_fmt+0x46/0x50 [ 88.351745] [<ffffffff81432bd4>] flush_to_ldisc+0x194/0x1d0 [ 88.353047] [<ffffffff816f7fe1>] ? _raw_spin_unlock_irq+0x21/0x50 [ 88.354190] [<ffffffff8108a809>] ? finish_task_switch+0x49/0xe0 [ 88.355436] [<ffffffff81077ad1>] process_one_work+0x121/0x490 [ 88.357674] [<ffffffff81432a40>] ? __tty_buffer_flush+0x90/0x90 [ 88.358954] [<ffffffff81078c84>] worker_thread+0x164/0x3e0 [ 88.360247] [<ffffffff81078b20>] ? manage_workers+0x120/0x120 [ 88.361282] [<ffffffff8107e230>] kthread+0xc0/0xd0 [ 88.362284] [<ffffffff816f0000>] ? cmos_do_probe+0x2eb/0x3bf [ 88.363391] [<ffffffff8107e170>] ? flush_kthread_worker+0xb0/0xb0 [ 88.364797] [<ffffffff816fff6c>] ret_from_fork+0x7c/0xb0 [ 88.366087] [<ffffffff8107e170>] ? flush_kthread_worker+0xb0/0xb0 [ 88.367266] ---[ end trace 453a7c9f38fbfec0 ]--- Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-18tty: Relocate tty_ldisc_halt() to avoid forward declarationPeter Hurley
tty_ldisc_halt() will use the file-scoped function, tty_ldisc_wait_idle(), in the following patch. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-18tty: Fix ldisc halt sequence on hangupPeter Hurley
Flip buffer work cannot be cancelled until all outstanding ldisc references have been released. Convert the ldisc ref wait into a full ldisc halt with buffer work cancellation. Note that the legacy mutex is not held while cancelling. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-18tty: Remove unnecessary re-test of ldisc ref countPeter Hurley
Since the tty->ldisc is prevented from being changed by tty_set_ldisc() when a tty is being hung up, re-testing the ldisc user count is unnecessary -- ie, it cannot be a different ldisc and the user count cannot have increased (assuming the caller meets the precondition that TTY_LDISC flag is cleared) Removal of the 'early-out' locking optimization is necessary for the subsequent patch 'tty: Fix ldisc halt sequence on hangup'. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-18tty: Refactor wait for ldisc refs out of tty_ldisc_hangup()Peter Hurley
Refactor tty_ldisc_hangup() to extract standalone function, tty_ldisc_hangup_wait_idle(), to wait for ldisc references to be released. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-18tty: Add diagnostic for halted line disciplinePeter Hurley
Flip buffer work must not be scheduled by the line discipline after the line discipline has been halted; issue warning. Note: drivers can still schedule flip buffer work. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-15tty: don't deadlock while flushing workqueueSebastian Andrzej Siewior
Since commit 89c8d91e31f2 ("tty: localise the lock") I see a dead lock in one of my dummy_hcd + g_nokia test cases. The first run was usually okay, the second often resulted in a splat by lockdep and the third was usually a dead lock. Lockdep complained about tty->hangup_work and tty->legacy_mutex taken both ways: | ====================================================== | [ INFO: possible circular locking dependency detected ] | 3.7.0-rc6+ #204 Not tainted | ------------------------------------------------------- | kworker/2:1/35 is trying to acquire lock: | (&tty->legacy_mutex){+.+.+.}, at: [<c14051e6>] tty_lock_nested+0x36/0x80 | | but task is already holding lock: | ((&tty->hangup_work)){+.+...}, at: [<c104f6e4>] process_one_work+0x124/0x5e0 | | which lock already depends on the new lock. | | the existing dependency chain (in reverse order) is: | | -> #2 ((&tty->hangup_work)){+.+...}: | [<c107fe74>] lock_acquire+0x84/0x190 | [<c104d82d>] flush_work+0x3d/0x240 | [<c12e6986>] tty_ldisc_flush_works+0x16/0x30 | [<c12e7861>] tty_ldisc_release+0x21/0x70 | [<c12e0dfc>] tty_release+0x35c/0x470 | [<c1105e28>] __fput+0xd8/0x270 | [<c1105fcd>] ____fput+0xd/0x10 | [<c1051dd9>] task_work_run+0xb9/0xf0 | [<c1002a51>] do_notify_resume+0x51/0x80 | [<c140550a>] work_notifysig+0x35/0x3b | | -> #1 (&tty->legacy_mutex/1){+.+...}: | [<c107fe74>] lock_acquire+0x84/0x190 | [<c140276c>] mutex_lock_nested+0x6c/0x2f0 | [<c14051e6>] tty_lock_nested+0x36/0x80 | [<c1405279>] tty_lock_pair+0x29/0x70 | [<c12e0bb8>] tty_release+0x118/0x470 | [<c1105e28>] __fput+0xd8/0x270 | [<c1105fcd>] ____fput+0xd/0x10 | [<c1051dd9>] task_work_run+0xb9/0xf0 | [<c1002a51>] do_notify_resume+0x51/0x80 | [<c140550a>] work_notifysig+0x35/0x3b | | -> #0 (&tty->legacy_mutex){+.+.+.}: | [<c107f3c9>] __lock_acquire+0x1189/0x16a0 | [<c107fe74>] lock_acquire+0x84/0x190 | [<c140276c>] mutex_lock_nested+0x6c/0x2f0 | [<c14051e6>] tty_lock_nested+0x36/0x80 | [<c140523f>] tty_lock+0xf/0x20 | [<c12df8e4>] __tty_hangup+0x54/0x410 | [<c12dfcb2>] do_tty_hangup+0x12/0x20 | [<c104f763>] process_one_work+0x1a3/0x5e0 | [<c104fec9>] worker_thread+0x119/0x3a0 | [<c1055084>] kthread+0x94/0xa0 | [<c140ca37>] ret_from_kernel_thread+0x1b/0x28 | |other info that might help us debug this: | |Chain exists of: | &tty->legacy_mutex --> &tty->legacy_mutex/1 --> (&tty->hangup_work) | | Possible unsafe locking scenario: | | CPU0 CPU1 | ---- ---- | lock((&tty->hangup_work)); | lock(&tty->legacy_mutex/1); | lock((&tty->hangup_work)); | lock(&tty->legacy_mutex); | | *** DEADLOCK *** Before the path mentioned tty_ldisc_release() look like this: | tty_ldisc_halt(tty); | tty_ldisc_flush_works(tty); | tty_lock(); As it can be seen, it first flushes the workqueue and then grabs the tty_lock. Now we grab the lock first: | tty_lock_pair(tty, o_tty); | tty_ldisc_halt(tty); | tty_ldisc_flush_works(tty); so lockdep's complaint seems valid. The earlier version of this patch took the ldisc_mutex since the other user of tty_ldisc_flush_works() (tty_set_ldisc()) did this. Peter Hurley then said that it is should not be requried. Since it wasn't done earlier, I dropped this part. The code under tty_ldisc_kill() was executed earlier with the tty lock taken so it is taken again. I was able to reproduce the deadlock on v3.8-rc1, this patch fixes the problem in my testcase. I didn't notice any problems so far. Cc: Alan Cox <alan@linux.intel.com> Cc: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-15tty: Only wakeup the line discipline idle queue when queue is activeIvo Sieben
Before waking up the tty line discipline idle queue first check if the queue is active (non empty). This prevents unnecessary entering the critical section in the wake_up() function and therefore avoid needless scheduling overhead on a PREEMPT_RT system caused by two processes being in the same critical section. Signed-off-by: Ivo Sieben <meltedpianoman@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-24tty: Use raw spin lock to protect TTY ldisc administrationIvo Sieben
The global "normal" spin lock that guards the line discipline administration is replaced by a raw spin lock. On a PREEMPT_RT system this prevents unwanted scheduling overhead around the line discipline administration. On a 200 MHz AT91SAM9261 processor setup this fixes about 100us of scheduling overhead on a TTY read or write call. Signed-off-by: Ivo Sieben <meltedpianoman@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22TTY: move tty buffers to tty_portJiri Slaby
So this is it. The big step why we did all the work over the past kernel releases. Now everything is prepared, so nothing protects us from doing that big step. | | \ \ nnnn/^l | | | | \ / / | | | '-,.__ => \/ ,-` => | '-,.__ | O __.´´) ( .` | O __.´´) ~~~ ~~ `` ~~~ ~~ The buffers are now in the tty_port structure and we can start teaching the buffer helpers (insert char/string, flip etc.) to use tty_port instead of tty_struct all around. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22TTY: ldisc, wait for idle ldisc in releaseJiri Slaby
We reintroduced tty_ldisc_wait_idle in 100eeae2c5c (TTY: restore tty_ldisc_wait_idle) and used in set_ldisc. Then we added it also to the hangup path in 92f6fa09bd453 (TTY: ldisc, do not close until there are readers). And we noted that there is one more path: ~ Before 65b770468e98 tty_ldisc_wait_idle was called also from ~ tty_ldisc_release. It is called from tty_release, so I don't think ~ we need to restore that one. Well, I was wrong. There might still be holders of an ldisc reference. Not from userspace, but drivers. If they take a reference and a user closes the device immediately after that, we have a problem. ldisc is halted and closed by TTY, but the driver still may call some ldisc's operation and cause a crash. So restore the tty_ldisc_wait_idle call also to the third location where it was before 65b770468e98 (tty-ldisc: turn ldisc user count into a proper refcount). Now we should be safe with respect to the ldisc reference counting as all* tty_ldisc_close paths are safely called with reference count of one. * Not the one in tty_ldisc_setup's fail path. But that is called before the first open finishes. So userspace does not see it yet. Even thought the driver is given the TTY already via ->install, it should not take a reference to the ldisc yet. If some driver is to do this, we should put one tty_ldisc_wait_idle also in the setup. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02Merge branch 'for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
Pull workqueue changes from Tejun Heo: "This is workqueue updates for v3.7-rc1. A lot of activities this round including considerable API and behavior cleanups. * delayed_work combines a timer and a work item. The handling of the timer part has always been a bit clunky leading to confusing cancelation API with weird corner-case behaviors. delayed_work is updated to use new IRQ safe timer and cancelation now works as expected. * Another deficiency of delayed_work was lack of the counterpart of mod_timer() which led to cancel+queue combinations or open-coded timer+work usages. mod_delayed_work[_on]() are added. These two delayed_work changes make delayed_work provide interface and behave like timer which is executed with process context. * A work item could be executed concurrently on multiple CPUs, which is rather unintuitive and made flush_work() behavior confusing and half-broken under certain circumstances. This problem doesn't exist for non-reentrant workqueues. While non-reentrancy check isn't free, the overhead is incurred only when a work item bounces across different CPUs and even in simulated pathological scenario the overhead isn't too high. All workqueues are made non-reentrant. This removes the distinction between flush_[delayed_]work() and flush_[delayed_]_work_sync(). The former is now as strong as the latter and the specified work item is guaranteed to have finished execution of any previous queueing on return. * In addition to the various bug fixes, Lai redid and simplified CPU hotplug handling significantly. * Joonsoo introduced system_highpri_wq and used it during CPU hotplug. There are two merge commits - one to pull in IRQ safe timer from tip/timers/core and the other to pull in CPU hotplug fixes from wq/for-3.6-fixes as Lai's hotplug restructuring depended on them." Fixed a number of trivial conflicts, but the more interesting conflicts were silent ones where the deprecated interfaces had been used by new code in the merge window, and thus didn't cause any real data conflicts. Tejun pointed out a few of them, I fixed a couple more. * 'for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (46 commits) workqueue: remove spurious WARN_ON_ONCE(in_irq()) from try_to_grab_pending() workqueue: use cwq_set_max_active() helper for workqueue_set_max_active() workqueue: introduce cwq_set_max_active() helper for thaw_workqueues() workqueue: remove @delayed from cwq_dec_nr_in_flight() workqueue: fix possible stall on try_to_grab_pending() of a delayed work item workqueue: use hotcpu_notifier() for workqueue_cpu_down_callback() workqueue: use __cpuinit instead of __devinit for cpu callbacks workqueue: rename manager_mutex to assoc_mutex workqueue: WORKER_REBIND is no longer necessary for idle rebinding workqueue: WORKER_REBIND is no longer necessary for busy rebinding workqueue: reimplement idle worker rebinding workqueue: deprecate __cancel_delayed_work() workqueue: reimplement cancel_delayed_work() using try_to_grab_pending() workqueue: use mod_delayed_work() instead of __cancel + queue workqueue: use irqsafe timer for delayed_work workqueue: clean up delayed_work initializers and add missing one workqueue: make deferrable delayed_work initializer names consistent workqueue: cosmetic whitespace updates for macro definitions workqueue: deprecate system_nrt[_freezable]_wq workqueue: deprecate flush[_delayed]_work_sync() ...
2012-08-20workqueue: deprecate flush[_delayed]_work_sync()Tejun Heo
flush[_delayed]_work_sync() are now spurious. Mark them deprecated and convert all users to flush[_delayed]_work(). If you're cc'd and wondering what's going on: Now all workqueues are non-reentrant and the regular flushes guarantee that the work item is not pending or running on any CPU on return, so there's no reason to use the sync flushes at all and they're going away. This patch doesn't make any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Ian Campbell <ian.campbell@citrix.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Mattia Dongili <malattia@linux.it> Cc: Kent Yoder <key@linux.vnet.ibm.com> Cc: David Airlie <airlied@linux.ie> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Karsten Keil <isdn@linux-pingi.de> Cc: Bryan Wu <bryan.wu@canonical.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Alasdair Kergon <agk@redhat.com> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: David Woodhouse <dwmw2@infradead.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: linux-wireless@vger.kernel.org Cc: Anton Vorontsov <cbou@mail.ru> Cc: Sangbeom Kim <sbkim73@samsung.com> Cc: "James E.J. Bottomley" <James.Bottomley@HansenPartnership.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Takashi Iwai <tiwai@suse.de> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Petr Vandrovec <petr@vandrovec.name> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Avi Kivity <avi@redhat.com>
2012-08-10tty: localise the lockAlan Cox
The termios and other changes mean the other protections needed on the driver tty arrays should be adequate. Turn it all back on. This contains pieces folded in from the fixes made to the original patches | From: Geert Uytterhoeven <geert@linux-m68k.org> (fix m68k) | From: Paul Gortmaker <paul.gortmaker@windriver.com> (fix cris) | From: Jiri Kosina <jkosina@suze.cz> (lockdep) | From: Eric Dumazet <eric.dumazet@gmail.com> (lockdep) Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-27tty: Fix race in tty releaseAlan Cox
Ian Abbott found that the tty layer would explode with the right set of parallel open and close operations. This is because we race in the handling of tty->drivers->termios[]. Correct this by Making tty_ldisc_release behave like nromal code (takes the lock, does stuff, drops the lock) Drop the tty lock earlier in tty_ldisc_release Taking the tty mutex around the driver->termios update in all cases Adding a WARN_ON to catch future screwups. I also forgot to clean up the pty resources properly. With a pty pair we need to pull both halves out of the tables. Signed-off-by: Alan Cox <alan@linux.intel.com> Tested-by: Ian Abbott <abbotti@mev.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-26tty ldisc: Close/Reopen race prevention should check the proper flagShachar Shemesh
Commit acfa747b introduced the TTY_HUPPING flag to distinguish closed TTY from currently closing ones. The test in tty_set_ldisc still remained pointing at the old flag. This causes pppd to sometimes lapse into uninterruptible sleep when killed and restarted. Signed-off-by: Shachar Shemesh <shachar@liveu.tv> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16tty: move the termios object into the ttyAlan Cox
This will let us sort out a whole pile of tty related races. The alternative would be to keep points and refcount the termios objects. However 1. They are tiny anyway 2. Many devices don't use the stored copies 3. We can remove a pty special case Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16tty: revert incorrectly applied lock patchAlan Cox
I sent GregKH this after the pre-requisites. He dropped the pre-requesites for good reason and unfortunately then applied this patch. Without this reverted you get random kernel memory corruption which will make bisecting anything between it and the properly applied patches a complete sod. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-12tty ldisc: Close/Reopen race prevention should check the proper flagShachar Shemesh
2012-07-06tty: localise the lockAlan Cox
