path: root/drivers/tty/vt
2011-06-04Revert "tty: make receive_buf() return the amout of bytes received"Linus Torvalds
This reverts commit b1c43f82c5aa265442f82dba31ce985ebb7aa71c. It was broken in so many ways, and results in random odd pty issues. It re-introduced the buggy schedule_work() in flush_to_ldisc() that can cause endless work-loops (see commit a5660b41af6a: "tty: fix endless work loop when the buffer fills up"). It also used an "unsigned int" return value fo the ->receive_buf() function, but then made multiple functions return a negative error code, and didn't actually check for the error in the caller. And it didn't actually work at all. BenH bisected down odd tty behavior to it: "It looks like the patch is causing some major malfunctions of the X server for me, possibly related to PTYs. For example, cat'ing a large file in a gnome terminal hangs the kernel for -minutes- in a loop of what looks like flush_to_ldisc/workqueue code, (some ftrace data in the quoted bits further down). ... Some more data: It -looks- like what happens is that the flush_to_ldisc work queue entry constantly re-queues itself (because the PTY is full ?) and the workqueue thread will basically loop forver calling it without ever scheduling, thus starving the consumer process that could have emptied the PTY." which is pretty much exactly the problem we fixed in a5660b41af6a. Milton Miller pointed out the 'unsigned int' issue. Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Reported-by: Milton Miller <miltonm@bga.com> Cc: Stefan Bigler <stefan.bigler@keymile.com> Cc: Toby Gray <toby.gray@realvnc.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-22tty: make receive_buf() return the amout of bytes receivedFelipe Balbi
it makes it simpler to keep track of the amount of bytes received and simplifies how flush_to_ldisc counts the remaining bytes. It also fixes a bug of lost bytes on n_tty when flushing too many bytes via the USB serial gadget driver. Tested-by: Stefan Bigler <stefan.bigler@keymile.com> Tested-by: Toby Gray <toby.gray@realvnc.com> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19tty: Clean console safelyPetr Písař
Traditional \E[2J sequence erases console display but scroll-back buffer and underlying device (frame) buffer keep data that can be accessed by scrolling console back. This patch introduce new \E[J parameter 3 that allows to scramble scroll-back buffer explicitly. Session locking programs (screen, vlock) can use it to prevent attacker to browse locked console history. Signed-off-by: Petr Písař <ppisar@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19tty: remove invalid location line in file headerJovi Zhang
remove invalid location line in each file header after location moved from driver/char to driver/tty Signed-off-by: Jovi Zhang <bookjovi@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19TTY: VT, remove unused variablesJiri Slaby
drivers/tty/vt/vt.c:892:2: warning: Value stored to 'old_screen_size' is never read old_screen_size = vc->vc_screenbuf_size; ^ ~~~~~~~~~~~~~~~~~~~~~ drivers/tty/vt/vt.c:890:2: warning: Value stored to 'old_cols' is never read old_cols = vc->vc_cols; ^ ~~~~~~~~~~~ Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19tty: VT, remove unused variableJiri Slaby
drivers/tty/vt/vt_ioctl.c:1525:2: warning: Value stored to 'kbd' is never read kbd = kbd_table + console; ^ ~~~~~~~~~~~~~~~~~~~ Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19drivers/tty/vt/vt_ioctl.c: repair insane ?: expressionAndrew Morton
Cc: Arthur Taylor <art@ified.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19vt: Add K_OFF return value to vt_ioctl KDGKBMODEArthur Taylor
After adding support for K_OFF in KDSKBMODE, it was forgotten to add support for returning it in KDGKBMODE. Signed-off-by: Arthur Taylor <art@ified.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-24lib, arch: add filter argument to show_mem and fix private implementationsDavid Rientjes
Commit ddd588b5dd55 ("oom: suppress nodes that are not allowed from meminfo on oom kill") moved lib/show_mem.o out of lib/lib.a, which resulted in build warnings on all architectures that implement their own versions of show_mem(): lib/lib.a(show_mem.o): In function `show_mem': show_mem.c:(.text+0x1f4): multiple definition of `show_mem' arch/sparc/mm/built-in.o:(.text+0xd70): first defined here The fix is to remove __show_mem() and add its argument to show_mem() in all implementations to prevent this breakage. Architectures that implement their own show_mem() actually don't do anything with the argument yet, but they could be made to filter nodes that aren't allowed in the current context in the future just like the generic implementation. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Reported-by: James Bottomley <James.Bottomley@hansenpartnership.com> Suggested-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-16Merge branch 'config' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'config' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: BKL: That's all, folks fs/locks.c: Remove stale FIXME left over from BKL conversion ipx: remove the BKL appletalk: remove the BKL x25: remove the BKL ufs: remove the BKL hpfs: remove the BKL drivers: remove extraneous includes of smp_lock.h tracing: don't trace the BKL adfs: remove the big kernel lock
2011-03-02drivers: remove extraneous includes of smp_lock.hArnd Bergmann
These were missed the last time I cleaned this up globally, because of code moving around or new code getting merged. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-02-17tty: now phase out the ioctl file pointer for goodAlan Cox
Only oddities here are a couple of drivers that bogusly called the ldisc helpers instead of returning -ENOIOCTLCMD. Fix the bug and the rest goes away. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17tty,vt: fix VT_SETACTIVATE console switchJiri Olsa
using VT_SETACTIVATE ioctl for console switch did not work, since it put wrong param to the set_console function. Also ioctl returned misleading error, because of the missing break statement. I wonder anyone has ever used this one :). Signed-off-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17tty,vcs removing con_buf/conf_buf_mtxJiri Olsa
seems there's no longer need for using con_buf/conf_buf_mtx as vcs_read/vcs_write buffer for user's data. The do_con_write function, that was the other user of this, is currently using its own kmalloc-ed buffer. Not sure when this got changed, as I was able to find this code in 2.6.9, but it's already gone as far as current git history goes - 2.6.12-rc2. AFAICS there's a behaviour change with the current change. The lseek is not completely mutually exclusive with the vcs_read/vcs_write - the file->f_pos might get updated via lseek callback during the vcs_read/vcs_write processing. I tried to find out if the prefered behaviour is to keep this in sync within read/write/lseek functions, but I did not find any pattern on different places. I guess if user end up calling write/lseek from different threads she should know what she's doing. If needed we could use dedicated fd mutex/buffer. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17tty,vcs: lseek/VC-release race fixJiri Olsa
there's a race between vcs's lseek handler and VC release. The lseek handler does not hold console_lock and touches VC's size info. If during this the VC got released, there's an access violation. Following program triggers the issue for me: [SNIP] #define _BSD_SOURCE #include <stdio.h> #include <sys/types.h> #include <sys/stat.h> #include <fcntl.h> #include <sys/ioctl.h> #include <linux/vt.h> #include <unistd.h> #include <errno.h> static int run_seek(void) { while(1) { int fd; fd = open("./vcs30", O_RDWR); while(lseek(fd, 0, 0) != -1); close(fd); } } static int open_ioctl_tty(void) { return open("/dev/tty1", O_RDWR); } static int do_ioctl(int fd, int req, int i) { return ioctl(fd, req, i); } #define INIT(i) do_ioctl(ioctl_fd, VT_ACTIVATE, i) #define SHUT(i) do_ioctl(ioctl_fd, VT_DISALLOCATE, i) int main(int argc, char **argv) { int ioctl_fd = open_ioctl_tty(); if (ioctl < 0) { perror("open tty1 failed\n"); return -1; } if ((-1 == mknod("vcs30", S_IFCHR|0666, makedev(7, 30))) && (errno != EEXIST)) { printf("errno %d\n", errno); perror("failed to create vcs30"); return -1; } do_ioctl(ioctl_fd, VT_LOCKSWITCH, 0); if (!fork()) run_seek(); while(1) { INIT(30); SHUT(30); } return 0; } [SNIP] Signed-off-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17TTY: use appropriate printk priority levelMandeep Singh Baines
printk()s without a priority level default to KERN_WARNING. To reduce noise at KERN_WARNING, this patch set the priority level appriopriately for unleveled printks()s. This should be useful to folks that look at dmesg warnings closely. Signed-off-by: Mandeep Singh Baines <msb@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17vt: Add virtual console keyboard mode OFFArthur Taylor
virtual console: add keyboard mode OFF Add a new mode for the virtual console keyboard OFF in which all input other than shift keys is ignored. Prevents vt input buffers from overflowing when a program opens but doesn't read from a tty, like X11 using evdev for input. Signed-off-by: Arthur Taylor <art@ified.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-01Merge branch 'tty-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: tty/serial: fix apbuart build n_hdlc: fix read and write locking serial: unbreak billionton CF card tty: use for_each_console() and WARN() on sysfs failures vt: fix issue when fbcon wants to takeover a second time. Fix up trivial conflict in drivers/tty/tty_io.c
2011-01-26console: rename acquire/release_console_sem() to console_lock/unlock()Torben Hohn
The -rt patches change the console_semaphore to console_mutex. As a result, a quite large chunk of the patches changes all acquire/release_console_sem() to acquire/release_console_mutex() This commit makes things use more neutral function names which dont make implications about the underlying lock. The only real change is the return value of console_trylock which is inverted from try_acquire_console_sem() This patch also paves the way to switching console_sem from a semaphore to a mutex. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: make console_trylock return 1 on success, per Geert] Signed-off-by: Torben Hohn <torbenh@gmx.de> Cc: Thomas Gleixner <tglx@tglx.de> Cc: Greg KH <gregkh@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-22tty: use for_each_console() and WARN() on sysfs failuresKay Sievers
This fixes the build warnings in the tty code, and uses the proper function for iterating over the console devices. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-22vt: fix issue when fbcon wants to takeover a second time.Dave Airlie
With framebuffer handover and multiple GPUs, we get into a position where the fbcon unbinds the vesafb framebuffer for GPU 1, but we still have a radeon framebuffer bound from GPU 0, so we don't unregister the console driver. Then when we tried to bind the new radeon framebuffer for GPU1 we never get to the bind call as we fail due to the console being registered already. This changes the return value to -EBUSY when the driver is already registered and continues to bind for -EBUSY. Signed-off-by: Dave Airlie <airlied@redhat.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-07Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (36 commits) serial: apbuart: Fixup apbuart_console_init() TTY: Add tty ioctl to figure device node of the system console. tty: add 'active' sysfs attribute to tty0 and console device drivers: serial: apbuart: Handle OF failures gracefully Serial: Avoid unbalanced IRQ wake disable during resume tty: fix typos/errors in tty_driver.h comments pch_uart : fix warnings for 64bit compile 8250: fix uninitialized FIFOs ip2: fix compiler warning on ip2main_pci_tbl specialix: fix compiler warning on specialix_pci_tbl rocket: fix compiler warning on rocket_pci_ids 8250: add a UPIO_DWAPB32 for 32 bit accesses 8250: use container_of() instead of casting serial: omap-serial: Add support for kernel debugger serial: fix pch_uart kconfig & build drivers: char: hvc: add arm JTAG DCC console support RS485 documentation: add 16C950 UART description serial: ifx6x60: fix memory leak serial: ifx6x60: free IRQ on error Serial: EG20T: add PCH_UART driver ... Fixed up conflicts in drivers/serial/apbuart.c with evil merge that makes the code look fairly sane (unlike either side).
2010-12-16tty: add 'active' sysfs attribute to tty0 and console deviceKay Sievers
tty: add 'active' sysfs attribute to tty0 and console device Userspace can query the actual virtual console, and the configured console devices behind /dev/tt0 and /dev/console. The last entry in the list of devices is the active device, analog to the console= kernel command line option. The attribute supports poll(), which is raised when the virtual console is changed or /dev/console is reconfigured. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> index 0000000..b138b66
2010-11-11vcs: make proper usage of the poll flagsNicolas Pitre
Kay Sievers pointed out that usage of POLLIN is well defined by POSIX, and the current usage here doesn't follow that definition. So let's duplicate the same semantics as implemented by sysfs_poll() instead. Signed-off-by: Nicolas Pitre <nicolas.pitre@canonical.com> Acked-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-05TTY: move .gitignore from drivers/char/ to drivers/tty/vt/Greg Kroah-Hartman
The autogenerated files (consolemap_deftbl.c and defkeymap.c) need to be ignored by git, so move the .gitignore file that was doing it to the properly location now that the files have moved as well. Cc: Arnd Bergmann <arnd@arndb.de> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-05TTY: create drivers/tty/vt and move the vt code thereGreg Kroah-Hartman
The vt and other related code is moved into the drivers/tty/vt directory. Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
