path: root/drivers/tty
2011-05-23Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (48 commits) serial: 8250_pci: add support for Cronyx Omega PCI multiserial board. tty/serial: Fix break handling for PORT_TEGRA tty/serial: Add explicit PORT_TEGRA type n_tracerouter and n_tracesink ldisc additions. Intel PTI implementaiton of MIPI 1149.7. Kernel documentation for the PTI feature. export kernel call get_task_comm(). tty: Remove to support serial for S5P6442 pch_phub: Support new device ML7223 8250_pci: Add support for the Digi/IBM PCIe 2-port Adapter ASoC: Update cx20442 for TTY API change pch_uart: Support new device ML7223 IOH parport: Use request_muxed_region for IT87 probe and lock tty/serial: add support for Xilinx PS UART n_gsm: Use print_hex_dump_bytes drivers/tty/moxa.c: Put correct tty value TTY: tty_io, annotate locking functions TTY: serial_core, remove superfluous set_task_state TTY: serial_core, remove invalid test Char: moxa, fix locking in moxa_write ... Fix up trivial conflicts in drivers/bluetooth/hci_ldisc.c and drivers/tty/serial/Makefile. I did the hci_ldisc thing as an evil merge, cleaning things up.
2011-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) b43: fix comment typo reqest -> request Haavard Skinnemoen has left Atmel cris: typo in mach-fs Makefile Kconfig: fix copy/paste-ism for dell-wmi-aio driver doc: timers-howto: fix a typo ("unsgined") perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course'). treewide: fix a few typos in comments regulator: change debug statement be consistent with the style of the rest Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations" audit: acquire creds selectively to reduce atomic op overhead rtlwifi: don't touch with treewide double semicolon removal treewide: cleanup continuations and remove logging message whitespace ath9k_hw: don't touch with treewide double semicolon removal include/linux/leds-regulator.h: fix syntax in example code tty: fix typo in descripton of tty_termios_encode_baud_rate xtensa: remove obsolete BKL kernel option from defconfig m68k: fix comment typo 'occcured' arch:Kconfig.locks Remove unused config option. treewide: remove extra semicolons ...
2011-05-19serial: 8250_pci: add support for Cronyx Omega PCI multiserial board.Antony Pavlov
This patch adds support for the Omega-PCI, an 8-port asynchronous multiport adapter for computers with PCI bus [1]. [1] http://www.cronyx.ru/hardware/ompci.html Signed-off-by: Antony Pavlov <antony@niisi.msk.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-19tty/serial: Fix break handling for PORT_TEGRAStephen Warren
When a break is received, Tegra's UART apparently fills the FIFO with 0 bytes. These must be drained so that they aren't interpreted as actual data received. This allows e.g. MAGIC_SYSRQ to work on Tegra's UARTs. v2: Added FIXME comment to clear_rx_fifo Originally-by: Laxman Dewangan <ldewangan@nvidia.com> Cc: Laxman Dewangan <ldewangan@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-19tty/serial: Add explicit PORT_TEGRA typeStephen Warren
Tegra's UART is currently auto-detected as PORT_XSCALE due to register bit UART_IER.UUE being writable. However, the Tegra documentation states that this register bit is reserved. Hence, we should not program it. Instead, the documentation specifies that the UART is 16550 compatible. However, Tegra does need register bit UART_IER.RTOIE set, which is not enabled by any 16550 port type. This was not noticed before, since PORT_XSCALE enables CAP_UUE, which conflates both UUE and RTOIE bit programming. This change defines PORT_TEGRA that doesn't set UART_CAP_UUE, but does set UART_CAP_RTOIE, which is a new capability indicating that the RTOIE bit needs to be enabled. Based-on-code-by: Laxman Dewangan <ldewangan@nvidia.com> Cc: Laxman Dewangan <ldewangan@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-19SERIAL: Lantiq: Add driver for MIPS Lantiq SOCs.John Crispin
Signed-off-by: John Crispin <blogic@openwrt.org> Signed-off-by: Ralph Hempel <ralph.hempel@lantiq.com> Signed-off-by: Felix Fietkau <nbd@openwrt.org> Cc: alan@lxorguk.ukuu.org.uk Cc: linux-mips@linux-mips.org Cc: linux-serial@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/2269/ Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-18drivercore: revert addition of of_match to struct deviceGrant Likely
Commit b826291c, "drivercore/dt: add a match table pointer to struct device" added an of_match pointer to struct device to cache the of_match_table entry discovered at driver match time. This was unsafe because matching is not an atomic operation with probing a driver. If two or more drivers are attempted to be matched to a driver at the same time, then the cached matching entry pointer could get overwritten. This patch reverts the of_match cache pointer and reworks all users to call of_match_device() directly instead. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-13n_tracerouter and n_tracesink ldisc additions.J Freyensee
The n_tracerouter and n_tracesink line discpline drivers use the Linux tty line discpline framework to route trace data coming from a tty port (say UART for example) to the trace sink line discipline driver and to another tty port(say USB). Those these two line discipline drivers can be used together, independently from pti.c, they are part of the original implementation solution of the MIPI P1149.7, compact JTAG, PTI solution for Intel mobile platforms starting with the Medfield platform. Signed-off-by: J Freyensee <james_p_freyensee@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-12tty: Remove to support serial for S5P6442Kukjin Kim
According to removing ARCH_S5P6442, we don't need to support serial for S5P6442. Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-118250_pci: Add support for the Digi/IBM PCIe 2-port AdapterScott Kilau
Add support to the 8250 PCI serial driver for the Digi/IBM PCIe 2-port Async EIA-232 Adapter. Oxford Semiconductor produces a 2/4/8 port UART (OXPCIe952/OXPCIe954/OXPCIe958) chip called the Tornado, that can be used to create a very simple serial board product. The kernel sources currently have just 2 vendors using this chip, which is Oxford and Mainpipe. This new Digi/IBM serial product now uses it as well. Rather than create a long running comment of vendors using the chip, the one changed comment in the patch below now just lists "For Oxford Semiconductor Tornado based devices" to be a more generic comment for all vendors that end up using the Oxford Tornado chip. Cc: Michael Reed <mreed10@us.ibm.com> Signed-off-by: Scott Kilau <scottk@digi.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-10pch_uart: Support new device ML7223 IOHTomoya MORINAGA
Support new device OKI SEMICONDUCTOR ML7223 IOH(Input/Output Hub). The ML7223 IOH is for MP(Media Phone) use. The ML7223 is companion chip for Intel Atom E6xx series. The ML7223 is completely compatible for Intel EG20T PCH. Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.okisemi.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-10treewide: fix a few typos in commentsJustin P. Mattock
- kenrel -> kernel - whetehr -> whether - ttt -> tt - sss -> ss Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-03tty/serial: add support for Xilinx PS UARTJohn Linn
The Xilinx PS Uart is used on the new ARM based SoC. This UART is not compatible with others such that a seperate driver is required. Signed-off-by: John Linn <john.linn@xilinx.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-29n_gsm: Use print_hex_dump_bytesJoe Perches
Use the standard mechanism to print a hex buffer to eliminate empty printf warning. A couple % smaller text and data too. $ size drivers/tty/n_gsm.o* text data bss dec hex filename 23543 312 6376 30231 7617 drivers/tty/n_gsm.o.new 24051 408 6496 30955 78eb drivers/tty/n_gsm.o.old Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-29drivers/tty/moxa.c: Put correct tty valueJulia Lawall
The tty value that should be put is the one that was just gotten by tty_port_tty_get, not the one that is the argument to the enclosing function. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @exists@ local idexpression struct tty_struct *x; expression ra,rr; statement S1,S2; @@ x = tty_port_tty_get(...) ... when != x = rr when any when != tty_kref_put(x,...) when != if (...) { ... tty_kref_put(x,...) ...} ( if(<+...x...+>) S1 else S2 | if(...) { ... when != x = ra when forall when != tty_kref_put(x,...) *return...; } ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-26treewide: cleanup continuations and remove logging message whitespaceJoe Perches
Using C line continuation inside format strings is error prone. Clean up the unintended whitespace introduced by misuse of \. Neaten correctly used line continations as well for consistency. drivers/scsi/arcmsr/arcmsr_hba.c has these errors as well, but arcmsr needs a lot more work and the driver should likely be moved to staging instead. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-04-26Merge branch 'master' into for-nextJiri Kosina
Fast-forwarded to current state of Linus' tree as there are patches to be applied for files that didn't exist on the old branch.
2011-04-25TTY: tty_io, annotate locking functionsJiri Slaby
tty_write_lock and tty_write_unlock contain imbalanced locking. But this is intentional, so mark them appropriately by __acquires/__releases. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-25TTY: serial_core, remove superfluous set_task_stateJiri Slaby
msleep* is guaranteed to return with TASK_RUNNING task state. And since there is no other set_task_state in the paths of uart_wait_until_sent, we need not to set_task_state to TASK_RUNNING. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-25TTY: serial_core, remove invalid testJiri Slaby
tty->index (named here as line) is set up in initialize_tty_struct. The value is checked in get_tty_driver for the found driver as: if (device < base || device >= base + p->num) continue; *index = device - base; So index/line can never be more than driver->num. Hence remove this test from uart_open. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-25Char: moxa, fix locking in moxa_writeJiri Slaby
moxa_write can be called from atomic context with irqs disabled (from ppp_async_push). Don't enable interrupts by spin_unlock_bh as this might cause deadlocks in the ppp layer. Instead, use irqsave/irqrestore spin_lock functions. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-25Char: nozomi, remove useless tty_semJiri Slaby
tty_sem used to protect tty open count. This was removed in 33dd474a but the lock remained in place. So remove it completely as it protects nothing now. Also this solves Mac's problem with inatomic operation called from atomic context (ppp): BUG: scheduling while atomic: firefox-bin/1992/0x10000800 Modules linked in: ... Pid: 1992, comm: firefox-bin Not tainted 2.6.38 #1 Call Trace: ... [] ? mutex_lock+0xe/0x21 [] ? ntty_write+0x5d/0x192 [nozomi] [] ? __mod_timer.clone.30+0xbe/0xcc [] ? check_preempt_curr+0x60/0x6d [] ? __nf_ct_refresh_acct+0x75/0xbe [] ? ppp_async_push+0xa9/0x3bd [ppp_async] [] ? ppp_async_send+0x34/0x40 [ppp_async] [] ? ppp_push+0x6c/0x4f9 [ppp_generic] ... Signed-off-by: Jiri Slaby <jslaby@suse.cz> Reported-by: Mac <kmac@poczta.fm> Tested-by: Gerald Pfeifer <gerald@pfeifer.com> Reviewed-by: Jack Stone <jwjstone@fastmail.fm> Cc: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-25Char: nozomi, remove port.count checksJiri Slaby
Before 33dd474a, these were some kind of protection against race with HUP. They were protected with port->tty_sem at the same time. By that commit, the counting was switched to tty_port's one, but the locking remained the old one. So the count was not protected by any lock anymore. The driver should not test whether it raced with HUP or not anyways. With the new refcounted tty model, it just should proceed as nothing happened because all needed info is still there. In respect to this, let's drop the useless and unprotected tests (tty_port->count is protected by tty_port->lock). Signed-off-by: Jiri Slaby <jslaby@suse.cz> Tested-by: Gerald Pfeifer <gerald@pfeifer.com> Cc: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-25Char: nozomi, use GFP_KERNEL for kfifo allocationJiri Slaby
The allocation was moved to probe function in 9842c38e9176. And we can sleep there. So allocate the 4*8192 bytes as GFP_KERNEL to mitigate the allocation failure. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Tested-by: Gerald Pfeifer <gerald@pfeifer.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-22tty: make receive_buf() return the amout of bytes receivedFelipe Balbi
it makes it simpler to keep track of the amount of bytes received and simplifies how flush_to_ldisc counts the remaining bytes. It also fixes a bug of lost bytes on n_tty when flushing too many bytes via the USB serial gadget driver. Tested-by: Stefan Bigler <stefan.bigler@keymile.com> Tested-by: Toby Gray <toby.gray@realvnc.com> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19tty/n_gsm: fix bug in CRC calculation for gsm1 modeMikhail Kshevetskiy
Problem description: gsm_queue() calculate a CRC for arrived frames. As a last step of CRC calculation it call gsm->fcs = gsm_fcs_add(gsm->fcs, gsm->received_fcs); This work perfectly for the case of GSM0 mode as gsm->received_fcs contain the last piece of data required to generate final CRC. gsm->received_fcs is not used for GSM1 mode. Thus we put an additional byte to CRC calculation. As result we get a wrong CRC and reject incoming frame. Signed-off-by: Mikhail Kshevetskiy <mikhail.kshevetskiy@gmail.com> Acked-by: Alan Cox <alan@linux.intel.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19serial/imx: read cts state only after acking cts change irqUwe Kleine-König
If cts changes between reading the level at the cts input (USR1_RTSS) and acking the irq (USR1_RTSD) the last edge doesn't generate an irq and uart_handle_cts_change is called with a outdated value for cts. The race was introduced by commit ceca629 ([ARM] 2971/1: i.MX uart handle rts irq) Reported-by: Arwed Springer <Arwed.Springer@de.trumpf.com> Tested-by: Arwed Springer <Arwed.Springer@de.trumpf.com> Cc: stable@kernel.org # 2.6.14+ Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19Serial: Remove unused code.Govindraj.R
Remove stale code in serial_core layer. Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Govindraj.R <govindraj.raja@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19tty: Clean console safelyPetr Písař
Traditional \E[2J sequence erases console display but scroll-back buffer and underlying device (frame) buffer keep data that can be accessed by scrolling console back. This patch introduce new \E[J parameter 3 that allows to scramble scroll-back buffer explicitly. Session locking programs (screen, vlock) can use it to prevent attacker to browse locked console history. Signed-off-by: Petr Písař <ppisar@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19Serial: ifx6x60c: Remove duplicate includes of linux/tty.hJesper Juhl
Including linux/tty.h 3 times is a little over the top - once will do. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19tty: remove invalid location line in file headerJovi Zhang
remove invalid location line in each file header after location moved from driver/char to driver/tty Signed-off-by: Jovi Zhang <bookjovi@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19serial: core, remove uart_update_termiosJiri Slaby
Now, uart_update_termios is empty, so it's time to remove it. We no longer need a live tty in .dtr_rts. So this should prune all the bugs where tty is zeroed in port->tty during tty_port_block_til_ready. There is one thing to note. We don't set ASYNC_NORMAL_ACTIVE now. It's because this is done already in tty_port_block_til_ready. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19serial: core, do not set DTR/RTS twice on startupJiri Slaby
In .dtr_rts we do: uart_set_mctrl(uport, TIOCM_DTR | TIOCM_RTS) and call uart_update_termios. It does: uart_set_mctrl(port, TIOCM_DTR | TIOCM_RTS) once again. As the only callsite of uart_update_termios is .dtr_rts, remove the uart_set_mctrl from uart_update_termios to not set it twice. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19serial: core, move termios handling to uart_startupJiri Slaby
We should not fiddle with speed and cflags in .dtr_rts hook. Actually we might not have tty at that moment already. So move the console cflag copy and speed setup into uart_startup. Actually the speed setup is already there, but we need to call it unconditionally (uart_startup is called from uart_open with hw_init = 0). This means we move uart_change_speed before dtr/rts setup in .dtr_rts. But this should not matter as the setup should be called after uart_change_speed anyway. Before: After: dtr/rts setup (dtr_rts) uart_change_speed (startup) uart_change_speed (update_termios) dtr/rts setup (dtr_rts) dtr/rts setup (update_termios) dtr/rts setup (update_termios) The second setup will dismiss with the next patch. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19Char: moxa, do not touch NORMAL_ACTIVE bitJiri Slaby
The bit is set in tty_port_block_til_ready (via moxa_open) and unset in tty_port_close (via moxa_close). No need to pin it in the driver. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19serial: altera_uart: Scan for a free port if platform device id is -1Tobias Klauser
Devices extracted from device tree all seem to have pdev->id set to -1. Up until now we mapped all devices with id -1 to the first device. This behaviour could lead to problems when using more than one Altera UART in a system. This patch changes the behaviour of the driver to scan for the next free id in case the id is -1. Because we cannot refer back to the assigned id in altera_uart_remove, the port instance needs to be stored in device drvdata. Reported-by: David Smoot <davidsmoot@gmail.com> Cc: Anton Vorontsov <cbouatmailru@gmail.com> Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19TTY: fix fail path in tty_openJiri Slaby
When tty_add_file fails we omit to clean up. Fix that by calling tty_release appropriatelly. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19TTY: plug in deinitialize_tty_structJiri Slaby
Used the newly introduced deinitialize_tty_struct to properly shut down ldisc. It is intended to fix the Julian's reported problem. He reports that kmemleak checker warns about memory leak: unreferenced object 0xc0e19860 (size 8): comm cat, pid 1226, jiffies 4294919464 (age 287.476s) hex dump (first 8 bytes): 44 de 2d c1 01 00 00 00 D.-..... backtrace: [<c1065a74>] create_object+0x109/0x1ad [<c1063d2b>] kmem_cache_alloc+0x60/0x68 [<c113505c>] tty_ldisc_get+0x54/0x76 [<c11358c9>] tty_ldisc_init+0xa/0x20 [<c1130ab4>] initialize_tty_struct+0x2d/0x1ac [<c1130c8c>] tty_init_dev+0x59/0x10d [<c113136d>] tty_open+0x24a/0x3a2 ... Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Reported-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19TTY: introduce deinit helpers for proper ldisc shutdownJiri Slaby
Introduce deinitialize_tty_struct which should be called after initialize_tty_struct and before successfull tty_ldisc_setup. It calls tty_ldisc_deinit which is opposite of tty_ldisc_init. It only puts a reference to ldisc and assigns NULL to tty->ldisc. It will be used to shut down ldisc when tty_release cannot be called yet. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Julian Anastasov <ja@ssi.bg> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19TTY: unify pty_unix98_install fail path handlingJiri Slaby
Change it so that we call the deinit functions at one place at the end of the function (by gotos). And while at it use some sane label names. This is a preparation for the deinitialization of tty in the next patch. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Julian Anastasov <ja@ssi.bg> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19TTY: unify pty_install fail path handlingJiri Slaby
2011-04-19TTY: unify tty_init_dev fail path handlingJiri Slaby
2011-04-19TTY: rocket, remove unused variablesJiri Slaby
drivers/tty/rocket.c:1393:2: warning: Value stored to 'cp' is never read cp = &info->channel; ^ ~~~~~~~~~~~~~~ drivers/tty/rocket.c:1412:2: warning: Value stored to 'cp' is never read cp = &info->channel; ^ ~~~~~~~~~~~~~~ drivers/tty/rocket.c:1730:2: warning: Value stored to 'cp' is never read cp = &info->channel; ^ ~~~~~~~~~~~~~~ drivers/tty/rocket.c:1825:3: warning: Value stored to 'str' is never read str = "8"; ^ ~~~ [many 'str' warnings stripped] drivers/tty/rocket.c:2037:3: warning: Value stored to 'board_type' is never read board_type = "RocketModem"; ^ ~~~~~~~~~~~~~ [some 'board_type' warnings stripped] Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19Char: moxa, remove unused variablesJiri Slaby
drivers/tty/moxa.c:1287:2: warning: Value stored to 'port' is never read port = tty->index; ^ ~~~~~~~~~~ drivers/tty/moxa.c:1763:2: warning: Value stored to 'cflag' is never read cflag = termio->c_cflag; /* termio->c_cflag */ ^ ~~~~~~~~~~~~~~~ Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19TTY: VT, remove unused variablesJiri Slaby
drivers/tty/vt/vt.c:892:2: warning: Value stored to 'old_screen_size' is never read old_screen_size = vc->vc_screenbuf_size; ^ ~~~~~~~~~~~~~~~~~~~~~ drivers/tty/vt/vt.c:890:2: warning: Value stored to 'old_cols' is never read old_cols = vc->vc_cols; ^ ~~~~~~~~~~~ Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19Char: cyclades, fix unused variableJiri Slaby
drivers/tty/cyclades.c:1454:2: warning: Value stored to 'channel' is never read channel = info->line - card->first_line; ^ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Fix it by moving it to the appropriate debug section where it is used. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19TTY: serial_core, remove unused variableJiri Slaby
drivers/tty/serial/serial_core.c:1980:2: warning: Value stored to 'tty' is never read tty = port->tty; ^ ~~~~~~~~~ Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Govindraj.R <govindraj.raja@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19tty: VT, remove unused variableJiri Slaby
drivers/tty/vt/vt_ioctl.c:1525:2: warning: Value stored to 'kbd' is never read kbd = kbd_table + console; ^ ~~~~~~~~~~~~~~~~~~~ Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19drivers/tty/vt/vt_ioctl.c: repair insane ?: expressionAndrew Morton
Cc: Arthur Taylor <art@ified.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19vt: Add K_OFF return value to vt_ioctl KDGKBMODEArthur Taylor
After adding support for K_OFF in KDSKBMODE, it was forgotten to add support for returning it in KDGKBMODE. Signed-off-by: Arthur Taylor <art@ified.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
