None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
There is no need to skip querying the config and string descriptors for
unauthorized WUSB devices when usb_new_device is called. It is allowed
by WUSB spec. The only action that needs to be delayed until
authorization time is the set config. This change allows user mode
tools to see the config and string descriptors earlier in enumeration
which is needed for some WUSB devices to function properly on Android
systems. It also reduces the amount of divergent code paths needed
for WUSB devices.
Signed-off-by: Thomas Pugliese <thomas.pugliese@gmail.com>
While reading the config parsing code I noticed this check is missing, without
this check config->desc.wTotalLength can end up with a value larger then the
dev->rawdescriptors length for the config, and when userspace then tries to
get the rawdescriptors bad things may happen.
Cc: stable <stable@vger.kernel.org>
Alan Stern pointed out that a USB port could potentially get powered off
when the attached USB device is in the middle of enumerating, due to
race conditions:
http://marc.info/?l=linux-usb&m=134130616707548&w=2
If that happens, we need to ensure the enumeration fails. If a call to
usb_get_descriptor() fails for a reason other than a Stall, return an
error. That should handle the case where the port is powered off.
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Lan Tianyu <tianyu.lan@intel.com>
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
This commit gets BOS(Binary Device Object Store) descriptor set for Super
Speed devices and High Speed devices which support BOS descriptor.
BOS descriptor is used to report additional USB device-level capabilities
that are not reported via the Device descriptor. By getting BOS descriptor
set, driver can check device's device-level capability such as LPM
capability.
Signed-off-by: Andiry Xu <andiry.xu@amd.com>
Now ${LINUX}/drivers/usb/* can use usb_endpoint_maxp(desc) to get maximum packet size
instead of le16_to_cpu(desc->wMaxPacketSize).
This patch fix it up
Cc: Armin Fuerst <fuerst@in.tum.de>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Johannes Erdfelt <johannes@erdfelt.com>
Cc: Vojtech Pavlik <vojtech@suse.cz>
Cc: Oliver Neukum <oliver@neukum.name>
Cc: David Kubicek <dave@awk.cz>
Cc: Johan Hovold <jhovold@gmail.com>
Cc: Brad Hards <bhards@bigpond.net.au>
Acked-by: Felipe Balbi <balbi@ti.com>
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: Thomas Dahlmann <dahlmann.thomas@arcor.de>
Cc: David Brownell <david-b@pacbell.net>
Cc: David Lopo <dlopo@chipidea.mips.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Michal Nazarewicz <m.nazarewicz@samsung.com>
Cc: Xie Xiaobo <X.Xie@freescale.com>
Cc: Li Yang <leoli@freescale.com>
Cc: Jiang Bo <tanya.jiang@freescale.com>
Cc: Yuan-hsin Chen <yhchen@faraday-tech.com>
Cc: Darius Augulis <augulis.darius@gmail.com>
Cc: Xiaochen Shen <xiaochen.shen@intel.com>
Cc: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Cc: OKI SEMICONDUCTOR, <toshiharu-linux@dsn.okisemi.com>
Cc: Robert Jarzmik <robert.jarzmik@free.fr>
Cc: Ben Dooks <ben@simtec.co.uk>
Cc: Thomas Abraham <thomas.ab@samsung.com>
Cc: Herbert Pötzl <herbert@13thfloor.at>
Cc: Arnaud Patard <arnaud.patard@rtp-net.org>
Cc: Roman Weissgaerber <weissg@vienna.at>
Acked-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Cc: Tony Olech <tony.olech@elandigitalsystems.com>
Cc: Florian Floe Echtler <echtler@fs.tum.de>
Cc: Christian Lucht <lucht@codemercs.com>
Cc: Juergen Stuber <starblue@sourceforge.net>
Cc: Georges Toth <g.toth@e-biz.lu>
Cc: Bill Ryder <bryder@sgi.com>
Cc: Kuba Ober <kuba@mareimbrium.org>
Cc: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com>
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
wMaxPacketSize is __le16 and should be accessed as such. Also fix the
wBytesPerInterval assignment while here.
v2: also fix the wBytesPerInterval assigment, noticed by Matt Evans
This patch should be backported to the 3.0 kernel.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Acked-by: Matt Evans <matt@ozlabs.org>
Cc: stable@kernel.org
while going through Tatyana's changes for the gadget framework I noticed
that this type is not defined as __le16.
This patch (as1375) eliminates the usb_host_ss_ep_comp structure used
for storing a dynamically-allocated copy of the SuperSpeed endpoint
companion descriptor. The SuperSpeed descriptor is placed directly in
the usb_host_endpoint structure, alongside the standard endpoint
descriptor.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
usb_gat_configuratio() used two pointers to point to the same
memory. Code simplified, by removing one of them.
Signed-off-by: Michal Nazarewicz <mina86@mina86.com>
Add a new quirk USB_QUIRK_HONOR_BNUMINTERFACES, when this quirk is
set and a device has more interface descriptors in a configuration
then it claims to have in config->bNumInterfaces, ignore all additional
interfaces.
This is needed for devices which try to hide unused interfaces by only
lowering config->bNumInterfaces, and which can't handle if you try to talk
to the "hidden" interfaces.
The usbcore headers: hcd.h and hub.h are shared between usbcore,
HCDs and a couple of other drivers (e.g. USBIP modules).
So, it makes sense to move them into a more public location and
to cleanup dependency of those modules on kernel internal headers.
This patch moves hcd.h from drivers/usb/core into include/linux/usb/
Signed-of-by: Eric Lescouet <eric@lescouet.org>
When there's a descriptor after the SuperSpeed endpoint companion
descriptor, the previous code would have skipped over twice the length it
was supposed to. This code fixes crashes seen with UASP devices (which
have a UASP descriptor after the SS endpoint companion descriptor).
Cc: stable <stable@kernel.org>
usb_parse_ss_endpoint_companion() was supposed to allocate a structure to
hold the SuperSpeed Endpoint Companion descriptor, and either copy the
values the device returned, or fill in default values if the device
descriptor did not include the companion descriptor.
However, the previous code would miss the last endpoint in a configuration
with no descriptors after it. Make usb_parse_endpoint() allocate the SS
endpoint companion descriptor and fill it with default values, even if
we've run out of buffer space in this configuration descriptor.
Differentiate between SuperSpeed endpoint companion descriptor and the
wireless USB endpoint companion descriptor. Make all structure names for
this descriptor have "ss" (SuperSpeed) in them. David Vrabel asked for
this change in http://marc.info/?l=linux-usb&m=124091465109367&w=2
Reported-by: David Vrabel <david.vrabel@csr.com>
The USB 3.0 bus specification added an "Endpoint Companion" descriptor that is
supposed to follow all SuperSpeed Endpoint descriptors. This descriptor is used
to extend the bus protocol to allow more packets to be sent to an endpoint per
"microframe". The word microframe was removed from the USB 3.0 specification
because the host controller does not send Start Of Frame (SOF) symbols down the
USB 3.0 wires.
The descriptor defines a bMaxBurst field, which indicates the number of packets
of wMaxPacketSize that a SuperSpeed device can send or recieve in a service
interval. All non-control endpoints may set this value as high as 16 packets
(bMaxBurst = 15).
The descriptor also allows isochronous endpoints to further specify that they
can send and receive multiple bursts per service interval. The bmAttributes
allows them to specify a "Mult" of up to 3 (bmAttributes = 2).
Bulk endpoints use bmAttributes to report the number of "Streams" they support.
This was an extension of the endpoint pipe concept to allow multiple mass
storage device commands to be outstanding for one bulk endpoint at a time. This
should allow USB 3.0 mass storage devices to support SCSI command queueing.
Bulk endpoints can say they support up to 2^16 (65,536) streams.
The information in the endpoint companion descriptor must be stored with the
other device, config, interface, and endpoint descriptors because the host
controller needs to access them quickly, and we need to install some default
values if a SuperSpeed device doesn't provide an endpoint companion descriptor.
Modify the USB core to handle the new USB 3.0 speed, "SuperSpeed". This
is 5.0 Gbps (wire speed). There are probably more places that check for
speed that I've missed.
SuperSpeed devices have a 512 byte endpoint 0 max packet size. This shows
up as a bMaxPacketSize0 set to 0x09 (see table 9-8 of the USB 3.0 bus
spec).
xHCI spec says that the xHC can handle intervals up to 2^15 microframes. That
might change when real silicon becomes available.
Add FIXME note for SuperSpeed isochronous endpoints. They can transmit up
to 16 packets in one "burst" before they wait for an acknowledgment of the
packets. They can do up to 3 bursts per microframe (determined by the
mult value in the endpoint companion descriptor). The xHCI driver doesn't
have support for isoc yet, so fix this later.
This teaches EHCI how to to work around bugs in certain high speed
devices, by accomodating "bulk" packets that exceed the 512 byte
constant value required by the USB 2.0 specification. (Have a
look at section 5.8.3, paragraphs 1 and 3.)
It also makes the descriptor parsing code warn when it encounters
such bugs. (We've had reports of maybe two or three such devices,
all pretty recent.)
Such devices are nonconformant. The proper fix is have the vendors
of those devices do the simple, obvious, and correct thing ... which
will let them be used with USB hosts that don't have workarounds for
this particular vendor bug. But unless/until they do, we can at least
have one of the high speed HCDs work with such buggy devices.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Fixes a number of coding style issues in the remaining .c files in
drivers/usb/core/
If called and the device is not authorized to be used, then we don't
allow reading the configurations.
Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com>
USB_IAD: Adds support for USB Interface Association Descriptors.
This patch adds support to the USB host stack for parsing, storing, and
displaying Interface Association Descriptors. In /proc/bus/usb/devices
lines starting with A: show the fields in an IAD. In sysfs if an
interface on a USB device is referenced by an IAD the following files
will be added to the sysfs directory for that interface:
iad_bFirstInterface, iad_bInterfaceCount, iad_bFunctionClass, and
iad_bFunctionSubClass, iad_bFunctionProtocol
Signed-off-by: Craig W. Nadler <craig@nadler.us>
Many device manufacturers are using full-speed bInterval values in high-speed
interrupt endpoint descriptors. If the bInterval value is greater than 16,
assume the device uses full-speed descriptors and fix the value accordingly.
Signed-off-by: Laurent Pinchart <laurent.pinchart@skynet.be>
A noticeable number of low-speed devices mistakenly include
descriptors for Bulk endpoints, which is forbidden by the USB spec.
In an attempt to make such devices more usable, this patch (as924)
converts the descriptors to Interrupt with an interval of 1 ms.
This patch (as904) adds code to check for endpoint descriptor bInterval
values outside the legal limits. Illegal values are set to 32 ms, which
seems like a reasonable default.
This fixes Bugzilla #8432.
This patch (as907) prevents us from trying to allocate 0 bytes
when an interface has no endpoint descriptors.
Change usb_get_configuration() so that it is more tolerant to devices
with bad configuration descriptors (it'll make it ignore
configurations that fail to load).
Signed-off-by: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
This lets us remove a lot of code in the drivers that were all checking
the same thing. It also found some bugs in a few of the drivers, which
has been fixed up.
This patch (as592) makes a few small improvements to the way device
strings are handled, and it fixes some bugs in a couple of other sysfs
attribute routines. (Look at show_configuration_string() to see what I
mean.)
This patch (as590) fixes up all the remaining places where usbcore can
use kzalloc rather than kmalloc/memset.
static.
Index: gregkh-2.6/drivers/usb/core/usb.h
infrastructure for it.
Let it rip!
