commit 303911cfc5b95d33687d9046133ff184cf5043ff upstream.
The syzbot fuzzer has found two (!) races in the USB character device
registration and deregistration routines. This patch fixes the races.
The first race results from the fact that usb_deregister_dev() sets
usb_minors[intf->minor] to NULL before calling device_destroy() on the
class device. This leaves a window during which another thread can
allocate the same minor number but will encounter a duplicate name
error when it tries to register its own class device. A typical error
message in the system log would look like:
sysfs: cannot create duplicate filename '/class/usbmisc/ldusb0'
The patch fixes this race by destroying the class device first.
The second race is in usb_register_dev(). When that routine runs, it
first allocates a minor number, then drops minor_rwsem, and then
creates the class device. If the device creation fails, the minor
number is deallocated and the whole routine returns an error. But
during the time while minor_rwsem was dropped, there is a window in
which the minor number is allocated and so another thread can
successfully open the device file. Typically this results in
use-after-free errors or invalid accesses when the other thread closes
its open file reference, because the kernel then tries to release
resources that were already deallocated when usb_register_dev()
failed. The patch fixes this race by keeping minor_rwsem locked
throughout the entire routine.
Reported-and-tested-by: syzbot+30cf45ebfe0b0c4847a1@syzkaller.appspotmail.com
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
CC: <stable@vger.kernel.org>
Link: https://lore.kernel.org/r/Pine.LNX.4.44L0.1908121607590.1659-100000@iolanthe.rowland.org
call init_usb_class simultaneously
There is race condition when two USB class drivers try to call
init_usb_class at the same time and leads to crash.
code path: probe->usb_register_dev->init_usb_class
To solve this, mutex locking has been added in init_usb_class() and
destroy_usb_class().
As pointed by Alan, removed "if (usb_class)" test from destroy_usb_class()
because usb_class can never be NULL there.
Signed-off-by: Ajay Kaher <ajay.kaher@samsung.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Cc: stable <stable@vger.kernel.org>
Some of the USB core files were missing explicit license information.
As all files in the kernel tree are implicitly licensed under the
GPLv2-only, be explicit in case someone get confused looking at
individual files by using the SPDX nomenclature.
kbasename() helper is dedicated to find a last part of the filename or
pathname. USB core uses open-coded variant of that helper.
Replace some lines of code by kbasename() call.
The current users do not have trailing slash and we are on the safe side to
make such change. I dig a history of the code under question up and found the
patch [1] that brought it along with the same to tty layer. The check for
trailing slash looks like copy'n'paste thing and I consider it as redundant.
[1] http://www.kernel.org/pub/linux/kernel//people/akpm/patches/2.5/2.5.69/2.5.69-mm3/broken-out/linus.patch
Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Pull vfs updates from Al Viro:
"All kinds of stuff this time around; some more notable parts:
- RCU'd vfsmounts handling
- new primitives for coredump handling
- files_lock is gone
- Bruce's delegations handling series
- exportfs fixes
plus misc stuff all over the place"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (101 commits)
ecryptfs: ->f_op is never NULL
locks: break delegations on any attribute modification
locks: break delegations on link
locks: break delegations on rename
locks: helper functions for delegation breaking
locks: break delegations on unlink
namei: minor vfs_unlink cleanup
locks: implement delegations
locks: introduce new FL_DELEG lock flag
vfs: take i_mutex on renamed file
vfs: rename I_MUTEX_QUOTA now that it's not used for quotas
vfs: don't use PARENT/CHILD lock classes for non-directories
vfs: pull ext4's double-i_mutex-locking into common code
exportfs: fix quadratic behavior in filehandle lookup
exportfs: better variable name
exportfs: move most of reconnect_path to helper function
exportfs: eliminate unused "noprogress" counter
exportfs: stop retrying once we race with rename/remove
exportfs: clear DISCONNECTED on all parents sooner
exportfs: more detailed comment for path_reconnect
Signed-off-by: Matthias Beyer <mail@beyermatthias.de>
including:
- removing of trailing whitespace
- removing spaces before array indexing (foo [] to foo[])
- reindention of a switch-case block
- spaces to tabs
When building the htmldocs (in verbose mode), scripts/kernel-doc reports the
following type of warnings:
Warning(drivers/usb/core/usb.c:76): No description found for return value of
'usb_find_alt_setting'
Fix them by:
- adding some missing descriptions of return values
- using "Return" sections for those descriptions
Signed-off-by: Yacine Belkadi <yacine.belkadi.1@gmail.com>
There is a misprint in init_usb_class():
IS_ERR is used to get error code instead of PTR_ERR.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
This class was not named properly years ago, and it turns out that tools
like udev can't properly see the devices in this class after booting due
to the fact that there is a bus with the same name in the system.
Changing this to "usbmisc" fixes this problem, and it solves the problem
for the future when we want to unify classes and busses.
Reported-by: Kay Sievers <kay@vrfy.org>
dbg() was a very old USB-specific macro that should no longer
be used. This patch removes it from being used in the driver
and uses dev_dbg() instead.
CC: Al Viro <viro@zeniv.linux.org.uk>
both callers of device_get_devnode() are only interested in lower 16bits
and nobody tries to return anything wider than 16bit anyway.
The `name' variable is unused in usb_deregister_dev() since commit d6e5bcf
(devfs: Remove the mode field from usb_class_driver as it's no longer needed).
Signed-off-by: Libor Pechacek <lpechacek@suse.cz>
The big kernel lock has been removed from all these files at some point,
leaving only the #include.
Remove this too as a cleanup.
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
vfs: make no_llseek the default
vfs: don't use BKL in default_llseek
llseek: automatically add .llseek fop
libfs: use generic_file_llseek for simple_attr
mac80211: disallow seeks in minstrel debug code
lirc: make chardev nonseekable
viotape: use noop_llseek
raw: use explicit llseek file operations
ibmasmfs: use generic_file_llseek
spufs: use llseek in all file operations
arm/omap: use generic_file_llseek in iommu_debug
lkdtm: use generic_file_llseek in debugfs
net/wireless: use generic_file_llseek in debugfs
drm: use noop_llseek
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
Recent changes in the usbhid layer exposed a bug in usbcore. If
CONFIG_USB_DYNAMIC_MINORS is enabled then an interface may be assigned
a minor number of 0. However interfaces that aren't registered as USB
class devices also have their minor number set to 0, during
initialization. As a result usb_find_interface() may return the
wrong interface, leading to a crash.
This patch (as1418) fixes the problem by initializing every
interface's minor number to -1. It also cleans up the
usb_register_dev() function, which besides being somewhat awkwardly
written, does not unwind completely on all its error paths.
Tested-by: Philip J. Turmel <philip@turmel.org>
Tested-by: Gabriel Craciunescu <nix.or.die@googlemail.com>
Tested-by: Alex Riesen <raa.lkml@gmail.com>
Tested-by: Matthias Bayer <jackdachef@gmail.com>
CC: Jiri Kosina <jkosina@suse.cz>
Cc: stable <stable@kernel.org>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Straightforward push into the drivers to allow
auditing individual drivers separately
Signed-off-by: Oliver Neukum <oliver@neukum.org>
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Add a missing goto. We dereference usb_class on the next line.
Found by smatch static checker.
This allows subsytems to provide devtmpfs with non-default permissions
for the device node. Instead of the default mode of 0600, null, zero,
random, urandom, full, tty, ptmx now have a mode of 0666, which allows
non-privileged processes to access standard device nodes in case no
other userspace process applies the expected permissions.
This also fixes a wrong assignment in pktcdvd and a checkpatch.pl complain.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
This adds support for USB drivers to report their requested nodename to
userspace. It also updates a number of USB drivers to provide the
needed subdirectory and device name to be used for them.
Signed-off-by: Jan Blunck <jblunck@suse.de>
USB should not be having it's own printk macros, so remove err() and
use the system-wide standard of dev_err() wherever possible. In the
few places that will not work out, use a basic printk().
Now that device_create() has been audited, rename things back to the
original call to be sane.
device_create() is race-prone, so use the race-free
device_create_drvdata() instead as device_create() is going away.
The bus_id field is going away, use the dev_name() function instead.
usb_open() is protected by a down_read(&minor_rwsem), but I'm not sure I
trust it to protect everything including subsidiary open() functions.
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
Over two years ago, the Linux USB developers stated that they believed
there was no way to create a USB kernel driver that was not under the
GPL. This patch moves the USB apis to enforce that decision.
There are no known closed source USB drivers in the wild, so this patch
should cause no problems.
This patch (as908) adds central protection in usbcore for the
prototypical race between opening and unregistering a char device.
The spinlock used to protect the minor-numbers array is replaced with
an rwsem, which can remain locked across a call to a driver's open()
method. This guarantees that open() and deregister() will be mutually
exclusive.
The private locks currently used in several individual drivers for
this purpose are no longer necessary, and the patch removes them. The
following USB drivers are affected: usblcd, idmouse, auerswald,
legousbtower, sisusbvga/sisusb, ldusb, adutux, iowarrior, and
usb-skeleton.
As a side effect of this change, usb_deregister_dev() must not be
called while holding a lock that is acquired by open(). Unfortunately
a number of drivers do this, but luckily the solution is simple: call
usb_deregister_dev() before acquiring the lock.
In addition to these changes (and their consequent code
simplifications), the patch fixes a use-after-free bug in adutux and a
race between open() and release() in iowarrior.
Many files include the filename at the beginning, serveral used a wrong one.
Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com>
Making structs const prevents accidental bugs and with the proper debug
options they're protected against corruption.
Signed-off-by: Luiz Fernando N. Capitulino <lcapitulino@mandriva.com.br>
This reverts bd00949647ddcea47ce4ea8bb2cfcfc98ebf9f2a commit because it
required a newer version of udev to work properly than what is currently
documented in Documentation/Changes.
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Now /sys/class/usb is dynamically created when we have something to put
in it, and removed when all devices go away.
Just trying to cut down on the clutter in sysfs...
Mark the f_ops members of inodes as const, as well as fix the
ripple-through this causes by places that copy this f_ops and then "do
stuff" with it.
Signed-off-by: Arjan van de Ven <arjan@infradead.org>
This lets us remove a lot of code in the drivers that were all checking
the same thing. It also found some bugs in a few of the drivers, which
has been fixed up.
needed
Also fixes all drivers that set this field, and removes some other devfs
specfic USB logic.
drivers/usb/class/usblp.c | 3 +--
drivers/usb/core/file.c | 19 ++++---------------
drivers/usb/image/mdc800.c | 3 +--
drivers/usb/input/aiptek.c | 2 +-
drivers/usb/input/hiddev.c | 3 +--
drivers/usb/media/dabusb.c | 3 +--
drivers/usb/misc/auerswald.c | 3 +--
drivers/usb/misc/idmouse.c | 5 ++---
drivers/usb/misc/legousbtower.c | 5 ++---
drivers/usb/misc/rio500.c | 3 +--
drivers/usb/misc/sisusbvga/sisusb.c | 5 -----
drivers/usb/misc/usblcd.c | 9 ++++-----
drivers/usb/usb-skeleton.c | 3 +--
include/linux/usb.h | 7 ++-----
14 files changed, 22 insertions(+), 51 deletions(-)
The previous patch adding the ability to nest struct class_device
changed the paramaters to the call class_device_create(). This patch
fixes up all in-kernel users of the function.
Trivial fix to USB class-creation error path; please apply.
Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
class_simple
static.
Index: gregkh-2.6/drivers/usb/core/usb.h
infrastructure for it.
Let it rip!
