commit 140e3026a57ab7d830dab2f2c57796c222db0ea9 upstream.
Commit 9df89d85b407690afa46ddfbccc80bec6869971d "usbcore: set
lpm_capable field for LPM capable root hubs" was created under the
assumption that all USB host controllers should have USB 3.0 Link PM
enabled for all devices under the hosts.
Unfortunately, that's not the case. The xHCI driver relies on knowledge
of the host hardware scheduler to calculate the LPM U1/U2 timeout
values, and it only sets lpm_capable to one for Intel host controllers
(that have the XHCI_LPM_SUPPORT quirk set).
When LPM is enabled for some Fresco Logic hosts, it causes failures with
a AgeStar 3UBT USB 3.0 hard drive dock:
Jan 11 13:59:03 sg-laptop kernel: usb 3-1: new SuperSpeed USB device number 2 using xhci_hcd
Jan 11 13:59:03 sg-laptop kernel: usb 3-1: Set SEL for device-initiated U1 failed.
Jan 11 13:59:08 sg-laptop kernel: usb 3-1: Set SEL for device-initiated U2 failed.
Jan 11 13:59:08 sg-laptop kernel: usb-storage 3-1:1.0: USB Mass Storage device detected
Jan 11 13:59:08 sg-laptop mtp-probe[613]: checking bus 3, device 2: "/sys/devices/pci0000:00/0000:00:1c.3/0000:04:00.0/usb3/3-1"
Jan 11 13:59:08 sg-laptop mtp-probe[613]: bus: 3, device: 2 was not an MTP device
Jan 11 13:59:08 sg-laptop kernel: scsi6 : usb-storage 3-1:1.0
Jan 11 13:59:13 sg-laptop kernel: usb 3-1: Set SEL for device-initiated U1 failed.
Jan 11 13:59:18 sg-laptop kernel: usb 3-1: Set SEL for device-initiated U2 failed.
Jan 11 13:59:18 sg-laptop kernel: usbcore: registered new interface driver usb-storage
Jan 11 13:59:40 sg-laptop kernel: usb 3-1: reset SuperSpeed USB device number 2 using xhci_hcd
Jan 11 13:59:41 sg-laptop kernel: usb 3-1: device descriptor read/8, error -71
Jan 11 13:59:41 sg-laptop kernel: usb 3-1: reset SuperSpeed USB device number 2 using xhci_hcd
Jan 11 13:59:46 sg-laptop kernel: usb 3-1: device descriptor read/8, error -110
Jan 11 13:59:46 sg-laptop kernel: scsi 6:0:0:0: Device offlined - not ready after error recovery
Jan 11 13:59:46 sg-laptop kernel: usb 3-1: USB disconnect, device number 2
lspci for the affected host:
04:00.0 0c03: 1b73:1000 (rev 04) (prog-if 30 [XHCI])
Subsystem: 1043:1039
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 19
Region 0: Memory at dd200000 (32-bit, non-prefetchable) [size=64K]
Capabilities: [50] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold-)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [80] Express (v1) Endpoint, MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <2us, L1 <32us
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Latency L0 unlimited, L1 unlimited
ClockPM- Surprise- LLActRep- BwNot-
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- Retrain- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
Kernel driver in use: xhci_hcd
Kernel modules: xhci_hcd
The commit was backported to stable kernels, and will need to be
reverted there as well.
Signed-off-by: Sarah Sharp <sarah.a.sharp@intel.com>
Reported-by: Sergey Galanov <sergey.e.galanov@gmail.com>
commit 9df89d85b407690afa46ddfbccc80bec6869971d upstream.
This patch sets the lpm_capable field for root hubs with LPM capabilities.
Signed-off-by: Xenia Ragiadakou <burzalodowa@gmail.com>
Reported-by: Martin MOKREJS <mmokrejs@gmail.com>
Suggested-by: Alan Stern <stern@rowland.harvard.edu>
This patch (as1675) removes the CONFIG_USB_SUSPEND option, essentially
replacing it everywhere with CONFIG_PM_RUNTIME (except for one place
in hub.c, where it is replaced with CONFIG_PM because the code needs
to be used in both runtime and system PM). The net result is code
shrinkage and simplification.
There's very little point in keeping CONFIG_USB_SUSPEND because almost
everybody enables it. The few that don't will find that the usbcore
module has gotten somewhat bigger and they will have to take active
measures if they want to prevent hubs from being runtime suspended.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
CC: Peter Chen <peter.chen@freescale.com>
xhci driver divides the root hub into two logical hubs which work
respectively for usb 2.0 and usb 3.0 devices. They are independent
devices in the usb core. But in the ACPI table, it's one device node
and all usb2.0 and usb3.0 ports are under it. Binding usb port with
its acpi node needs the raw port number which is reflected in the xhci
extended capabilities table. This patch is to add find_raw_port_number
callback to struct hc_driver(), fill it with xhci_find_raw_port_number()
which will return raw port number and add a wrap usb_hcd_find_raw_port_number().
Otherwise, refactor xhci_find_real_port_number(). Using
xhci_find_raw_port_number() to get real index in the HW port status
registers instead of scanning through the xHCI roothub port array.
This can help to speed up.
All addresses in xhci->usb2_ports and xhci->usb3_ports array are
kown good ports and don't include following bad ports in the extended
capabilities talbe.
(1) root port that doesn't have an entry
(2) root port with unknown speed
(3) root port that is listed twice and with different speeds.
So xhci_find_raw_port_number() will only return port num of good ones
and never touch bad ports above.
Signed-off-by: Lan Tianyu <tianyu.lan@intel.com>
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
This pulls in a bunch of fixes that are in Linus's tree because we need them
here for testing and development.
This patch (as1649) adds a mechanism for host controller drivers to
inform usbcore when they have begun or ended resume signalling on a
particular root-hub port. The core will then make sure that the root
hub does not get runtime-suspended while the port resume is going on.
Since commit 596d789a211d134dc5f94d1e5957248c204ef850 (USB: set hub's
default autosuspend delay as 0), the system tries to suspend hubs
whenever they aren't in use. While a root-hub port is being resumed,
the root hub does not appear to be in use. Attempted runtime suspends
fail because of the ongoing port resume, but the PM core just keeps on
trying over and over again. We want to prevent this wasteful effort.
Tested-by: Ming Lei <ming.lei@canonical.com>
ACPI provide "_PLD" and "_UPC" aml methods to describe usb port
visibility and connectability. This patch is to add usb_hub_adjust_DeviceRemovable()
to adjust usb hub port's DeviceRemovable according ACPI information and invoke it in
the rh_call_control(). When hub descriptor request is issued at first time,
usb port device isn't created and usb port is not bound with acpi. So first
hub descriptor request is not changed based on ACPI information. After usb
port devices being created, call usb_hub_adjust_DeviceRemovable in the hub_configure()
and then set hub port's DeviceRemovable according ACPI information and this also works
for non-root hub.
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Sarah pointed out that the USB3.0 spec also updates the amount of power
that may be consumed by the device and quoted 9.2.5.1:
|"The amount of current draw for SuperSpeed devices are increased to 150
|mA for low-power devices and 900 mA for high-power"
This patch tries to update all users to use the larger values for
SuperSpeed devices and use the "old" ones for everything else.
While here, two other changes suggested by Alan:
- the comment referering to 7.2.1.1 has been updated to 7.2.1 which is
the correct source of the action.
- the check for hubs with zero ports has been removed.
- compute bus power by full_load * num_ports on root hubs
Acked-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
This resolves a conflict with these files:
drivers/usb/early/ehci-dbgp.c
drivers/usb/host/ehci-ls1x.c
drivers/usb/host/ohci-xls.c
drivers/usb/musb/ux500.c
This reverts commit 73d4066055e0e2830533041f4b91df8e6e5976ff.
Martin Steigerwald reported that this change caused a hard lockup when
using USB if threadirqs are enabled. Thomas pointed out that this patch
is incorrect, and can cause problems. So revert it to get the
previously working functionality back.
Reported-by: Martin Steigerwald <Martin@lichtvoll.de>
Cc: Chuansheng Liu <chuansheng.liu@intel.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
This patch (as1620) speeds up USB root-hub resumes in the common case
where every enabled port has its suspend feature set (which currently
will be true for every runtime resume of the root hub). If all the
enabled ports are suspended then resuming the root hub won't resume
any of the downstream devices. In this case there's no need for a
Resume Recovery delay, because that delay is meant to give devices a
chance to get ready for active use.
To keep track of the port suspend features, the patch adds a
"port_is_suspended" flag to struct usb_device. This has to be tracked
separately from the device's state; it's entirely possible for a USB-2
device to be suspended while the suspend feature on its parent port is
clear. The reason is that devices will go into suspend whenever their
parent hub does.
Reviewed-by: Peter Chen <peter.chen@freescale.com>
Tested-by: Peter Chen <peter.chen@freescale.com>
This patch (as1607) fixes a race that can occur if a USB host
controller is removed while a process is reading the
/sys/kernel/debug/usb/devices file.
The usb_device_read() routine uses the bus->root_hub pointer to
determine whether or not the root hub is registered. The is not a
valid test, because the pointer is set before the root hub gets
registered and remains set even after the root hub is unregistered and
deallocated. As a result, usb_device_read() or usb_device_dump() can
access freed memory, causing an oops.
The patch changes the test to use the hcd->rh_registered flag, which
does get set and cleared at the appropriate times. It also makes sure
to hold the usb_bus_list_lock mutex while setting the flag, so that
usb_device_read() will become aware of new root hubs as soon as they
are registered.
Reported-by: Don Zickus <dzickus@redhat.com>
Cc: stable <stable@vger.kernel.org>
Because the IRQF_DISABLED as the flag is now a NOOP and has been
deprecated and in hardirq context the interrupt is disabled.
so in usb/host code:
Removing the usage of flag IRQF_DISABLED;
Removing the calling local_irq save/restore actions in irq
handler usb_hcd_irq();
Signed-off-by: liu chuansheng <chuansheng.liu@intel.com>
The kernel's version number is used as decimal in the bcdDevice field of
the RH descriptor. For kernel version v3.12 we would see 3.0c in lsusb.
I am not sure how important it is to stick with bcd values since this is
this way since we started git history and nobody complained (however back
then we reported only 2.6).
We don't support sg for isoc transfers, enforce this.
The BOS descriptor is normally fetched and stored in the usb_device->bos
during enumeration. USB 3.0 roothubs don't undergo enumeration, but we
need them to have a BOS descriptor, since each xHCI host has a different
U1 and U2 exit latency. Make sure to fetch the BOS descriptor for USB
3.0 roothubs. It will be freed when the roothub usb_device is released.
Cc: Andiry Xu <andiry.xu@amd.com>
It took me surprisingly long to find the location where the Linux
Foundation vendor id (0x1d6b) is set for the root hubs. A minor update
to three comments makes those locations (trivially) greppable.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
This patch (as1533) fixes a race between root-hub suspend and remote
wakeup. If a wakeup event occurs while a root hub is suspending, it
might not cause the suspend to fail. Although the host controller
drivers check for pending wakeup events at the start of their
bus_suspend routines, they generally do not check for wakeup events
while the routines are running.
In addition, if a wakeup event occurs any time after khubd is frozen
and before the root hub is fully suspended, it might not cause a
system sleep transition to fail. For example, the host controller
drivers do not fail root-hub suspends when a connect-change event is
pending.
To fix both these issues, this patch causes hcd_bus_suspend() to query
the controller driver's hub_status_data method after a root hub is
suspended, if the root hub is enabled for wakeup. Any pending status
changes will count as wakeup events, causing the root hub to be
resumed and the overall suspend to fail with -EBUSY.
A significant point is that not all events are reflected immediately
in the status bits. Both EHCI and UHCI controllers notify the CPU
when remote wakeup begins on a port, but the port's suspend-change
status bit doesn't get set until after the port has completed the
transition out of the suspend state, some 25 milliseconds later.
Consequently, the patch will interpret any nonzero return value from
hub_status_data as indicating a pending event, even if none of the
status bits are set in the data buffer. Follow-up patches make the
necessary changes to ehci-hcd and uhci-hcd.
CC: Sarah Sharp <sarah.a.sharp@linux.intel.com>
CC: Chen Peter-B29397 <B29397@freescale.com>
There's really no point in having hcd->irq as a
signed integer when we consider the fact that
IRQ 0 means NO_IRQ. In order to avoid confusion,
make hcd->irq unsigned and fix users who were
passing -1 as the IRQ number to usb_add_hcd.
Tested-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
Intel has a PCI USB xhci host controller on a new platform. It doesn't
have a line IRQ definition in BIOS. The Linux driver refuses to
initialize this controller, but Windows works well because it only depends
on MSI.
Actually, Linux also can work for MSI. This patch avoids the line IRQ
checking for USB3 HCDs in usb core PCI probe. It allows the xHCI driver
to try to enable MSI or MSI-X first. It will fail the probe if MSI
enabling failed and there's no legacy PCI IRQ.
This patch should be backported to kernels as old as 2.6.32.
Signed-off-by: Alex Shi <alex.shi@intel.com>
Cc: stable@vger.kernel.org
This patch is in succession of previous patch
commit c8421147926fcacf53081a36438a0bed394da9f5
xHCI: Adding #define values used for hub descriptor
Hub descriptors characteristics #defines values are added in
hub_configure() in place of magic numbers as asked by Alan Stern.
And the indentation for switch and case is changed to be same.
Some #defines values are added in ch11.h for defining hub class
protocols and used in hub.c and hcd.c in which magic values were
used for hub class protocols.
Signed-off-by: Aman Deep <amandeep3986@gmail.com>
Add a new field num_mapped_sgs to struct urb so that we have a place to
store the number of mapped entries and can also retain the original
value of entries in num_sgs. Previously, usb_hcd_map_urb_for_dma()
would overwrite this with the number of mapped entries, which would
break dma_unmap_sg() because it requires the original number of entries.
This fixes warnings like the following when using USB storage devices:
WARNING: at lib/dma-debug.c:902 check_unmap+0x4e4/0x695()
ehci_hcd 0000:00:12.2: DMA-API: device driver frees DMA sg list with different entry count [map count=4] [unmap count=1]
Modules linked in: ohci_hcd ehci_hcd
Pid: 0, comm: kworker/0:1 Not tainted 3.2.0-rc2+ #319
Call Trace:
<IRQ> [<ffffffff81036d3b>] warn_slowpath_common+0x80/0x98
[<ffffffff81036de7>] warn_slowpath_fmt+0x41/0x43
[<ffffffff811fa5ae>] check_unmap+0x4e4/0x695
[<ffffffff8105e92c>] ? trace_hardirqs_off+0xd/0xf
[<ffffffff8147208b>] ? _raw_spin_unlock_irqrestore+0x33/0x50
[<ffffffff811fa84a>] debug_dma_unmap_sg+0xeb/0x117
[<ffffffff8137b02f>] usb_hcd_unmap_urb_for_dma+0x71/0x188
[<ffffffff8137b166>] unmap_urb_for_dma+0x20/0x22
[<ffffffff8137b1c5>] usb_hcd_giveback_urb+0x5d/0xc0
[<ffffffffa0000d02>] ehci_urb_done+0xf7/0x10c [ehci_hcd]
[<ffffffffa0001140>] qh_completions+0x429/0x4bd [ehci_hcd]
[<ffffffffa000340a>] ehci_work+0x95/0x9c0 [ehci_hcd]
---[ end trace f29ac88a5a48c580 ]---
Mapped at:
[<ffffffff811faac4>] debug_dma_map_sg+0x45/0x139
[<ffffffff8137bc0b>] usb_hcd_map_urb_for_dma+0x22e/0x478
[<ffffffff8137c494>] usb_hcd_submit_urb+0x63f/0x6fa
[<ffffffff8137d01c>] usb_submit_urb+0x2c7/0x2de
[<ffffffff8137dcd4>] usb_sg_wait+0x55/0x161
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
The HCD_FLAG_SAW_IRQ flag was introduced in order to catch IRQ routing
errors: If an URB was unlinked and the host controller hadn't gotten
any IRQs, it seemed likely that the IRQs were directed to the wrong
vector.
This warning hasn't come up in many years, as far as I know; interrupt
routing now seems to be well under control. Therefore there's no
reason to keep the flag around any more. This patch (as1495) finally
removes it.
* 'pm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (63 commits)
PM / Clocks: Remove redundant NULL checks before kfree()
PM / Documentation: Update docs about suspend and CPU hotplug
ACPI / PM: Add Sony VGN-FW21E to nonvs blacklist.
ARM: mach-shmobile: sh7372 A4R support (v4)
ARM: mach-shmobile: sh7372 A3SP support (v4)
PM / Sleep: Mark devices involved in wakeup signaling during suspend
PM / Hibernate: Improve performance of LZO/plain hibernation, checksum image
PM / Hibernate: Do not initialize static and extern variables to 0
PM / Freezer: Make fake_signal_wake_up() wake TASK_KILLABLE tasks too
PM / Hibernate: Add resumedelay kernel param in addition to resumewait
MAINTAINERS: Update linux-pm list address
PM / ACPI: Blacklist Vaio VGN-FW520F machine known to require acpi_sleep=nonvs
PM / ACPI: Blacklist Sony Vaio known to require acpi_sleep=nonvs
PM / Hibernate: Add resumewait param to support MMC-like devices as resume file
PM / Hibernate: Fix typo in a kerneldoc comment
PM / Hibernate: Freeze kernel threads after preallocating memory
PM: Update the policy on default wakeup settings
PM / VT: Cleanup #if defined uglyness and fix compile error
PM / Suspend: Off by one in pm_suspend()
PM / Hibernate: Include storage keys in hibernation image on s390
To add USB 3.0 link power management (LPM), we need to know what the U1
and U2 exit latencies are for the xHCI host controller. External USB 3.0
hubs report these values through the SuperSpeed Capabilities descriptor in
the BOS descriptor. Make the USB 3.0 roothub for the xHCI host behave
like an external hub and return the BOS descriptors.
The U1 and U2 exit latencies will vary across each host controller, so we
need to dynamically fill those values in by reading the exit latencies out
of the xHC registers. Make the roothub code in the USB core handle
hub_control() returning the length of the data copied.
* pm-runtime:
PM / Tracing: build rpm-traces.c only if CONFIG_PM_RUNTIME is set
PM / Runtime: Replace dev_dbg() with trace_rpm_*()
PM / Runtime: Introduce trace points for tracing rpm_* functions
PM / Runtime: Don't run callbacks under lock for power.irq_safe set
USB: Add wakeup info to debugging messages
PM / Runtime: pm_runtime_idle() can be called in atomic context
PM / Runtime: Add macro to test for runtime PM events
PM / Runtime: Add might_sleep() to runtime PM functions
This patch (as1487) improves the usbcore debugging output for port
suspend and bus suspend, by stating whether or not remote wakeup is
enabled.
This patch (as1486) implements the kernel's new wakeup policy for USB
host controllers. Since they don't generate wakeup requests on their
but merely forward requests from their root hubs toward the CPU, they
should be enabled for wakeup by default.
Also, to be compliant with both the old and new policies, root hubs
should not be enabled for remote wakeup by default. Userspace must
enable it explicitly if it is desired.
This patch (as1482) adds a macro for testing whether or not a
pm_message value represents an autosuspend or autoresume (i.e., a
runtime PM) event. Encapsulating this notion seems preferable to
open-coding the test all over the place.
usb_ifnum_to_if() can return NULL if the USB device does not have a
configuration installed (usb_device->actconfig == NULL), or if we can't
find the interface number in the installed configuration. Return an
error instead of crashing.
The "authorized_default" module parameter of usbcore controls the default
for the authorized_default variable of each USB host controller.
-1 is authorized for all devices except wireless (default, old behaviour)
0 is unauthorized for all devices
Signed-off-by: Carl-Daniel Hailfinger <c-d.hailfinger.devel.2006@gmx.net>
This patch (as1467) removes the last usages of hcd->state from
usbcore. We no longer check to see if an interrupt handler finds that
a controller has died; instead we rely on host controller drivers to
make an explicit call to usb_hc_died().
This fixes a regression introduced by commit
9b37596a2e860404503a3f2a6513db60c296bfdc (USB: move usbcore away from
hcd->state). It used to be that when a controller shared an IRQ with
another device and an interrupt arrived while hcd->state was set to
HC_STATE_HALT, the interrupt handler would be skipped. The commit
removed that test; as a result the current code doesn't skip calling
the handler and ends up believing the controller has died, even though
it's only temporarily stopped. The solution is to ignore HC_STATE_HALT
following the handler's return.
As a consequence of this change, several of the host controller
drivers need to be modified. They can no longer implicitly rely on
usbcore realizing that a controller has died because of hcd->state.
The patch adds calls to usb_hc_died() in the appropriate places.
The patch also changes a few of the interrupt handlers. They don't
expect to be called when hcd->state is equal to HC_STATE_HALT, even if
the controller is still alive. Early returns were added to avoid any
confusion.
Tested-by: Manuel Lauss <manuel.lauss@googlemail.com>
CC: Rodolfo Giometti <giometti@linux.it>
CC: Olav Kongas <ok@artecdesign.ee>
CC: <stable@kernel.org>
If USB type detections fails, we run into default and return 0.
If I unplug a device while the UAS driver is loaded, I get an oops
in usb_free_streams(). This is because usb_unbind_interface() calls
usb_disable_interface() which calls usb_disable_endpoint() which sets
ep_out and ep_in to NULL. Then the UAS driver calls usb_pipe_endpoint()
which returns a NULL pointer and passes an array of NULL pointers to
usb_free_streams().
I think the correct fix for this is to check for the NULL pointer
in usb_free_streams() rather than making the driver check for this
situation. My original patch for this checked for dev->state ==
USB_STATE_NOTATTACHED, but the call to usb_disable_interface() is
conditional, so not all drivers would want this check.
Note from Sarah Sharp: This patch does avoid a potential dereference,
but the real fix (which will be implemented later) is to set the
.soft_unbind flag in the usb_driver structure for the UAS driver, and
all drivers that allocate streams. The driver should free any streams
when it is unbound from the interface. This avoids leaking stream rings
in the xHCI driver when usb_disable_interface() is called.
This should be queued for stable trees back to 2.6.35.
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
Cc: stable@kernel.org
The hcd->flags are in a sorry state. Some of them are clearly specific to
the particular roothub (HCD_POLL_RH, HCD_POLL_PENDING, and
HCD_WAKEUP_PENDING), but some flags are related to PCI device state
(HCD_HW_ACCESSIBLE and HCD_SAW_IRQ). This is an issue when one PCI device
can have two roothubs that share the same IRQ line and hardware.
Make sure to set HCD_FLAG_SAW_IRQ for both roothubs when an interrupt is
serviced, or an URB is unlinked without an interrupt. (We can't tell if
the host actually serviced an interrupt for a particular bus, but we can
tell it serviced some interrupt.)
HCD_HW_ACCESSIBLE is set once by usb_add_hcd(), which is set for both
roothubs as they are added, so it doesn't need to be modified.
HCD_POLL_RH and HCD_POLL_PENDING are only checked by the USB core, and
they are never set by the xHCI driver, since the roothub never needs to be
polled.
The usb_hcd's state field is a similar mess. Sometimes the state applies
to the underlying hardware: HC_STATE_HALT, HC_STATE_RUNNING, and
HC_STATE_QUIESCING. But sometimes the state refers to the roothub state:
HC_STATE_RESUMING and HC_STATE_SUSPENDED.
Alan Stern recently made the USB core not rely on the hcd->state variable.
Internally, the xHCI driver still checks for HC_STATE_SUSPENDED, so leave
that code in. Remove all references to HC_STATE_HALT, since the xHCI
driver only sets and doesn't test those variables. We still have to set
HC_STATE_RUNNING, since Alan's patch has a bug that means the roothub
won't get registered if we don't set that.
Alan's patch made the USB core check a different variable when trying to
determine whether to suspend a roothub. The xHCI host has a split
roothub, where two buses are registered for one PCI device. Each bus in
the xHCI split roothub can be suspended separately, but both buses must be
suspended before the PCI device can be suspended. Therefore, make sure
that the USB core checks HCD_RH_RUNNING() for both roothubs before
suspending the PCI host.
Introduce the notion of a PCI device that may be associated with more than
one USB host controller driver (struct usb_hcd). This patch is the start
of the work to separate the xHCI host controller into two roothubs: a USB
3.0 roothub with SuperSpeed-only ports, and a USB 2.0 roothub with
HS/FS/LS ports.
One usb_hcd structure is designated to be the "primary HCD", and a pointer
is added to the usb_hcd structure to keep track of that. A new function
call, usb_hcd_is_primary_hcd() is added to check whether the USB hcd is
marked as the primary HCD (or if it is not part of a roothub pair). To
allow the USB core and xHCI driver to access either roothub in a pair, a
"shared_hcd" pointer is added to the usb_hcd structure.
Add a new function, usb_create_shared_hcd(), that does roothub allocation
for paired roothubs. It will act just like usb_create_hcd() did if the
primary_hcd pointer argument is NULL. If it is passed a non-NULL
primary_hcd pointer, it sets usb_hcd->shared_hcd and usb_hcd->primary_hcd
fields. It will also skip the bandwidth_mutex allocation, and set the
secondary hcd's bandwidth_mutex pointer to the primary HCD's mutex.
IRQs are only allocated once for the primary roothub.
Introduce a new usb_hcd driver flag that indicates the host controller
driver wants to create two roothubs. If the HCD_SHARED flag is set, then
the USB core PCI probe methods will allocate a second roothub, and make
sure that second roothub gets freed during rmmod and in initialization
error paths.
When usb_hc_died() is called with the primary HCD, make sure that any
roothubs that share that host controller are also marked as being dead.
The xHCI driver essentially has both a USB 2.0 and a USB 3.0 roothub. So
setting the HCD_USB3 bits in the hcd->driver->flags is a bit misleading.
Add a new field to usb_hcd, bcdUSB. Store the result of
hcd->driver->flags & HCD_MASK in it. Later, when we have the xHCI driver
register the two roothubs, we'll set the usb_hcd->bcdUSB field to HCD_USB2
for the USB 2.0 roothub, and HCD_USB3 for the USB 3.0 roothub.
Change the bandwith_mutex in struct usb_hcd to a pointer. This will allow
the pointer to be shared across usb_hcds for the upcoming work to split
the xHCI driver roothub into a USB 2.0/1.1 and a USB 3.0 bus.
Refactor out the code in usb_add_hcd() to request the IRQ line for the
HCD. This will only need to be called once for the two xHCI roothubs, so
it's easier to refactor it into a function, rather than wrapping the long
if-else block into another if statement.
Make the USB 3.0 roothub registered by the USB core have a SuperSpeed
Endpoint Companion Descriptor after the interrupt endpoint. All USB 3.0
devices are required to have this, and the USB 3.0 bus specification
(section 10.13.1) says which values the descriptor should have.
We would like to allow host controller drivers to stop using hcd->state.
Unfortunately, some host controller drivers use hcd->state as an
implicit way of telling the core that a controller has died. The
roothub registration functions must assume the host died if hcd->state
equals HC_STATE_HALT.
To facilitate drivers that don't want to set hcd->state to
HC_STATE_RUNNING in their initialization routines, we set the state to
running before calling the host controller's start function.
The irq enabling code is going to be refactored into a new function, so
clean up some checkpatch errors before moving it.
The hcd->state variable is a disaster. It's not clearly owned by
either usbcore or the host controller drivers, and they both change it
from time to time, potentially stepping on each other's toes. It's
not protected by any locks. And there's no mechanism to prevent it
from going through an invalid transition.
This patch (as1451) takes a first step toward fixing these problems.
As it turns out, usbcore uses hcd->state for essentially only two
things: checking whether the controller's root hub is running and
checking whether the controller has died. Therefore the patch adds
two new atomic bitflags to the hcd structure, to store these pieces of
information. The new flags are used only by usbcore, and a private
spinlock prevents invalid combinations (a dead controller's root hub
cannot be running).
The patch does not change the places where usbcore sets hcd->state,
since HCDs may depend on them. Furthermore, there is one place in
usb_hcd_irq() where usbcore still must use hcd->state: An HCD's
interrupt handler can implicitly indicate that the controller died by
setting hcd->state to HC_STATE_HALT. Nevertheless, the new code is a
big improvement over the current code.
The patch makes one other change. The hcd_bus_suspend() and
hcd_bus_resume() routines now check first whether the host controller
has died; if it has then they return immediately without calling the
HCD's bus_suspend or bus_resume methods.
This fixes the major problem reported in Bugzilla #29902: The system
fails to suspend after a host controller dies during system resume.
Tested-by: Alex Terekhov <a.terekhov@gmail.com>
This is needed to resolve some merge conflicts that were found
in the USB host controller patches, and reported by Stephen Rothwell.
Provide optional hooks for the host controller driver to override the
default DMA mapping and unmapping routines. In general, these shouldn't
be necessary unless the host controller has special DMA requirements,
such as alignment contraints. If these are not specified, the
general usb_hcd_(un)?map_urb_for_dma functions will be used instead.
Also, pass the status to unmap_urb_for_dma so it can know whether the
DMA buffer has been overwritten.
Finally, add a flag to be used by these implementations if they
allocated a temporary buffer so it can be freed properly when unmapping.
Signed-off-by: Robert Morell <rmorell@nvidia.com>
The convention is to prefix symbols exported from the USB HCD core with
"usb_hcd". This change makes unmap_urb_setup_for_dma() and
unmap_urb_for_dma() consistent with that.
The USB core keeps track of pending resume requests for root hubs, in
order to resolve races between wakeup requests and suspends. However
the code that does this is subject to another race (between wakeup
requests and resumes) because the WAKEUP_PENDING flag is cleared
before the resume occurs, leaving a window in which another wakeup
request might arrive.
This patch (as1447) fixes the problem by clearing the WAKEUP_PENDING
flag after the resume instead of before it.
This fixes Bugzilla #24952.
Tested-by: Paul Bender <pebender@san.rr.com>
Tested-by: warpme <warpme@o2.pl>
Cc: stable <stable@kernel.org> [.36+]
* usb-next: (132 commits)
USB: uas: Use GFP_NOIO instead of GFP_KERNEL in I/O submission path
USB: uas: Ensure we only bind to a UAS interface
USB: uas: Rename sense pipe and sense urb to status pipe and status urb
USB: uas: Use kzalloc instead of kmalloc
USB: uas: Fix up the Sense IU
usb: musb: core: kill unneeded #include's
DA8xx: assign name to MUSB IRQ resource
usb: gadget: g_ncm added
usb: gadget: f_ncm.c added
usb: gadget: u_ether: prepare for NCM
usb: pch_udc: Fix setup transfers with data out
usb: pch_udc: Fix compile error, warnings and checkpatch warnings
usb: add ab8500 usb transceiver driver
USB: gadget: Implement runtime PM for MSM bus glue driver
USB: gadget: Implement runtime PM for ci13xxx gadget
USB: gadget: Add USB controller driver for MSM SoC
USB: gadget: Introduce ci13xxx_udc_driver struct
USB: gadget: Initialize ci13xxx gadget device's coherent DMA mask
USB: gadget: Fix "scheduling while atomic" bugs in ci13xxx_udc
USB: gadget: Separate out PCI bus code from ci13xxx_udc
The Inventra DMA engine used with the MUSB controller in many
SoCs cannot use DMA for control transfers on EP0, but can use
DMA for all other transfers.
The USB core maps urbs for DMA if hcd->self.uses_dma is true.
(hcd->self.uses_dma is true for MUSB as well).
Split the uses_dma flag into two - one that says if the
controller needs to use PIO for control transfers, and
another which says if the controller uses DMA (for all
other transfers).
Also, populate this flag for all MUSB by default.
(Tested on OMAP3 and OMAP4 boards, with EHCI and MUSB HCDs
simultaneously in use).
Signed-off-by: Maulik Mankad <x0082077@ti.com>
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Signed-off-by: Anand Gadiyar <gadiyar@ti.com>
Cc: Oliver Neukum <oliver@neukum.org>
Cc: Praveena NADAHALLY <praveen.nadahally@stericsson.com>
Cc: Ajay Kumar Gupta <ajay.gupta@ti.com>
