This is the 4.14.159 stable release
arch/arm/Kconfig.debug
arch/arm/boot/dts/imx7s.dtsi
arch/arm/mach-imx/cpuidle-imx6sx.c
drivers/crypto/caam/caamalg.c
drivers/crypto/mxs-dcp.c
drivers/dma/imx-sdma.c
drivers/input/keyboard/imx_keypad.c
drivers/net/can/flexcan.c
drivers/net/can/rx-offload.c
drivers/net/wireless/ath/ath10k/pci.c
drivers/pci/dwc/pci-imx6.c
drivers/spi/spi-fsl-lpspi.c
drivers/usb/dwc3/gadget.c
commit e76b3bf7654c3c94554c24ba15a3d105f4006c80 upstream.
On Dell WD15 dock, sometimes USB ethernet cannot be detected after plugging
cable to the ethernet port, the hub and roothub get runtime resumed and
runtime suspended immediately:
[ 433.315169] xhci_hcd 0000:3a:00.0: hcd_pci_runtime_resume: 0
[ 433.315204] usb usb4: usb auto-resume
[ 433.315226] hub 4-0:1.0: hub_resume
[ 433.315239] xhci_hcd 0000:3a:00.0: Get port status 4-1 read: 0x10202e2, return 0x10343
[ 433.315264] usb usb4-port1: status 0343 change 0001
[ 433.315279] xhci_hcd 0000:3a:00.0: clear port1 connect change, portsc: 0x10002e2
[ 433.315293] xhci_hcd 0000:3a:00.0: Get port status 4-2 read: 0x2a0, return 0x2a0
[ 433.317012] xhci_hcd 0000:3a:00.0: xhci_hub_status_data: stopping port polling.
[ 433.422282] xhci_hcd 0000:3a:00.0: Get port status 4-1 read: 0x10002e2, return 0x343
[ 433.422307] usb usb4-port1: do warm reset
[ 433.422311] usb 4-1: device reset not allowed in state 8
[ 433.422339] hub 4-0:1.0: state 7 ports 2 chg 0002 evt 0000
[ 433.422346] xhci_hcd 0000:3a:00.0: Get port status 4-1 read: 0x10002e2, return 0x343
[ 433.422356] usb usb4-port1: do warm reset
[ 433.422358] usb 4-1: device reset not allowed in state 8
[ 433.422428] xhci_hcd 0000:3a:00.0: set port remote wake mask, actual port 0 status = 0xf0002e2
[ 433.422455] xhci_hcd 0000:3a:00.0: set port remote wake mask, actual port 1 status = 0xe0002a0
[ 433.422465] hub 4-0:1.0: hub_suspend
[ 433.422475] usb usb4: bus auto-suspend, wakeup 1
[ 433.426161] xhci_hcd 0000:3a:00.0: xhci_hub_status_data: stopping port polling.
[ 433.466209] xhci_hcd 0000:3a:00.0: port 0 polling in bus suspend, waiting
[ 433.510204] xhci_hcd 0000:3a:00.0: port 0 polling in bus suspend, waiting
[ 433.554051] xhci_hcd 0000:3a:00.0: port 0 polling in bus suspend, waiting
[ 433.598235] xhci_hcd 0000:3a:00.0: port 0 polling in bus suspend, waiting
[ 433.642154] xhci_hcd 0000:3a:00.0: port 0 polling in bus suspend, waiting
[ 433.686204] xhci_hcd 0000:3a:00.0: port 0 polling in bus suspend, waiting
[ 433.730205] xhci_hcd 0000:3a:00.0: port 0 polling in bus suspend, waiting
[ 433.774203] xhci_hcd 0000:3a:00.0: port 0 polling in bus suspend, waiting
[ 433.818207] xhci_hcd 0000:3a:00.0: port 0 polling in bus suspend, waiting
[ 433.862040] xhci_hcd 0000:3a:00.0: port 0 polling in bus suspend, waiting
[ 433.862053] xhci_hcd 0000:3a:00.0: xhci_hub_status_data: stopping port polling.
[ 433.862077] xhci_hcd 0000:3a:00.0: xhci_suspend: stopping port polling.
[ 433.862096] xhci_hcd 0000:3a:00.0: // Setting command ring address to 0x8578fc001
[ 433.862312] xhci_hcd 0000:3a:00.0: hcd_pci_runtime_suspend: 0
[ 433.862445] xhci_hcd 0000:3a:00.0: PME# enabled
[ 433.902376] xhci_hcd 0000:3a:00.0: restoring config space at offset 0xc (was 0x0, writing 0x20)
[ 433.902395] xhci_hcd 0000:3a:00.0: restoring config space at offset 0x4 (was 0x100000, writing 0x100403)
[ 433.902490] xhci_hcd 0000:3a:00.0: PME# disabled
[ 433.902504] xhci_hcd 0000:3a:00.0: enabling bus mastering
[ 433.902547] xhci_hcd 0000:3a:00.0: // Setting command ring address to 0x8578fc001
[ 433.902649] pcieport 0000:00:1b.0: PME: Spurious native interrupt!
[ 433.902839] xhci_hcd 0000:3a:00.0: Port change event, 4-1, id 3, portsc: 0xb0202e2
[ 433.902842] xhci_hcd 0000:3a:00.0: resume root hub
[ 433.902845] xhci_hcd 0000:3a:00.0: handle_port_status: starting port polling.
[ 433.902877] xhci_hcd 0000:3a:00.0: xhci_resume: starting port polling.
[ 433.902889] xhci_hcd 0000:3a:00.0: xhci_hub_status_data: stopping port polling.
[ 433.902891] xhci_hcd 0000:3a:00.0: hcd_pci_runtime_resume: 0
[ 433.902919] usb usb4: usb wakeup-resume
[ 433.902942] usb usb4: usb auto-resume
[ 433.902966] hub 4-0:1.0: hub_resume
As Mathias pointed out, the hub enters Cold Attach Status state and
requires a warm reset. However usb_reset_device() bails out early when
the device is in suspended state, as its callers port_event() and
hub_event() don't always resume the device.
Since there's nothing wrong to reset a suspended device, allow
usb_reset_device() to do so to solve the issue.
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Cc: stable <stable@vger.kernel.org>
Link: https://lore.kernel.org/r/20191106062710.29880-1-kai.heng.feng@canonical.com
[ Upstream commit 4fdc1790e6a9ef22399c6bc6e63b80f4609f3b7e ]
On plug-in of my USB-C device, its USB_SS_PORT_LS_SS_INACTIVE
link state bit is set. Greping all the kernel for this bit shows
that the port status requests a warm-reset this way.
This just happens, if its the only device on the root hub, the hub
therefore resumes and the HCDs status_urb isn't yet available.
If a warm-reset request is detected, this sets the hubs event_bits,
which will prevent any auto-suspend and allows the hubs workqueue
to warm-reset the port later in port_event.
Signed-off-by: Jan-Marek Glogowski <glogow@fbihome.de>
[ Upstream commit 561759292774707b71ee61aecc07724905bb7ef1 ]
If the device rejects the control transfer to enable device-initiated
U1/U2 entry, then the device will not initiate U1/U2 transition. To
improve the performance, the downstream port should not initate
transition to U1/U2 to avoid the delay from the device link command
response (no packet can be transmitted while waiting for a response from
the device). If the device has some quirks and does not implement U1/U2,
it may reject all the link state change requests, and the downstream
port may resend and flood the bus with more requests. This will affect
the device performance even further. This patch disables the
hub-initated U1/U2 if the device-initiated U1/U2 entry fails.
Reference: USB 3.2 spec 7.2.4.2.3
Signed-off-by: Thinh Nguyen <thinhn@synopsys.com>
commit e244c4699f859cf7149b0781b1894c7996a8a1df upstream.
With Link Power Management (LPM) enabled USB3 links transition to low
power U1/U2 link states from U0 state automatically.
Current hub code detects USB3 remote wakeups by checking if the software
state still shows suspended, but the link has transitioned from suspended
U3 to enabled U0 state.
As it takes some time before the hub thread reads the port link state
after a USB3 wake notification, the link may have transitioned from U0
to U1/U2, and wake is not detected by hub code.
Fix this by handling U1/U2 states in the same way as U0 in USB3 wakeup
handling
This patch should be added to stable kernels since 4.13 where LPM was
kept enabled during suspend/resume
Cc: <stable@vger.kernel.org> # v4.13+
Signed-off-by: Lee, Chiasheng <chiasheng.lee@intel.com>
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
This is the 4.14.126 stable release
drivers/gpio/gpio-vf610.c:
Follow commit 338aa10750ba gpio: vf610: Do not share irq_chip
drivers/gpu/drm/bridge/adv7511/adv7511_drv.c:
Follow commit 67793bd3b394 drm/bridge: adv7511: Fix low refresh rate selection
Use drm_mode_vrefresh(mode) helper
drivers/net/ethernet/freescale/fec_main.c:
Keep downstream file.
drivers/net/wireless/broadcom/brcm80211/brcmfmac/cfg80211.c
Follow commit 46953f97224d brcmfmac: fix missing checks for kmemdup
sound/soc/fsl/Kconfig:
Follow commit ea751227c813 ASoC: imx: fix fiq dependencies
Logical Conflicts:
sound/soc/fsl/fsl_sai.c:
Revert upstream d7325abe29b as downstream fixed it differently
drivers/clk/imx/clk-imx6sl.c
Revert upstream bda9f846ae0 as downstream implemented it differently 68c736e9378
[ Upstream commit 381419fa720060ba48b7bbc483be787d5b1dca6f ]
The SCSI core does not like to have devices or hosts unregistered
while error recovery is in progress. Trying to do so can lead to
self-deadlock: Part of the removal code tries to obtain a lock already
held by the error handler.
This can cause problems for the usb-storage and uas drivers, because
their error handler routines perform a USB reset, and if the reset
fails then the USB core automatically goes on to unbind all drivers
from the device's interfaces -- all while still in the context of the
SCSI error handler.
As it turns out, practically all the scenarios leading to a USB reset
failure end up causing a device disconnect (the main error pathway in
usb_reset_and_verify_device(), at the end of the routine, calls
hub_port_logical_disconnect() before returning). As a result, the
hub_wq thread will soon become aware of the problem and will unbind
all the device's drivers in its own context, not in the
error-handler's context.
This means that usb_reset_device() does not need to call
usb_unbind_and_rebind_marked_interfaces() in cases where
usb_reset_and_verify_device() has returned an error, because hub_wq
will take care of everything anyway.
This particular problem was observed in somewhat artificial
circumstances, by using usbfs to tell a hub to power-down a port
connected to a USB-3 mass storage device using the UAS protocol. With
the port turned off, the currently executing command timed out and the
error handler started running. The USB reset naturally failed,
because the hub port was off, and the error handler deadlocked as
described above. Not carrying out the call to
usb_unbind_and_rebind_marked_interfaces() fixes this issue.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Reported-by: Kento Kobayashi <Kento.A.Kobayashi@sony.com>
Tested-by: Kento Kobayashi <Kento.A.Kobayashi@sony.com>
CC: Bart Van Assche <bvanassche@acm.org>
CC: Martin K. Petersen <martin.petersen@oracle.com>
CC: Jacky Cao <Jacky.Cao@sony.com>
commit d7a6c0ce8d26412903c7981503bad9e1cc7c45d2 upstream.
USB Bluetooth controller QCA ROME (0cf3:e007) sometimes stops working
after S3:
[ 165.110742] Bluetooth: hci0: using NVM file: qca/nvm_usb_00000302.bin
[ 168.432065] Bluetooth: hci0: Failed to send body at 4 of 1953 (-110)
After some experiments, I found that disabling LPM can workaround the
issue.
On some platforms, the USB power is cut during S3, so the driver uses
reset-resume to resume the device. During port resume, LPM gets enabled
twice, by usb_reset_and_verify_device() and usb_port_resume().
Consolidate all checks into new LPM helpers to make sure LPM only gets
enabled once.
Fixes: de68bab4fa96 ("usb: Don't enable USB 2.0 Link PM by default.”)
Cc: stable <stable@vger.kernel.org> # after much soaking
commit 7529b2574a7aaf902f1f8159fbc2a7caa74be559 upstream.
Use new helpers to make LPM enabling/disabling more clear.
This is a preparation to subsequent patch.
[ Upstream commit e86108940e541febf35813402ff29fa6f4a9ac0b ]
When initializing a hub we want to give a USB3 port in link training
the same debounce delay time before autosuspening the hub as already
trained, connected enabled ports.
USB3 ports won't reach the enabled state with "current connect status" and
"connect status change" bits set until the USB3 link training finishes.
Catching the port in link training (polling) and adding the debounce delay
prevents unnecessary failed attempts to autosuspend the hub.
This patch changes bus reset time for B host enumuration, from entering B host
to the time clear USB_PORT_FEAT_C_CONNECTION, a random time after B host detect
port change for A peripheral connection may not work.
Signed-off-by: Li Jun <b47624@freescale.com>
(cherry picked from commit b87d3bb0672ebcfb29c7db8708c586b2d38558d1)
(cherry picked from commit f3ec1858d5293de28476996a59287b7adb8e9cd2)
Use a_set_b_hnp_en to identify if a host can succeed to set b_hnp_enable
for B device, use b_hnp_enable flag to identify if the connected OTG device
is HNP capable. So if the connected otg device is HNP capable but b_hnp_enable
is not set for A host, the host which support HNP polling should continue
enumeration to see if the B device can talk to it later by hnp polling.
(cherry picked from commit b715d0773eea212a25d6b8c5d94530e12935fdaf)
(cherry picked from commit 454369742ce4dec01d89c946a28c3069fc23bbea)
If a HNP capable device STALL b_hnp_enable set feature request, A device
as host should not break otg device enumeration, because this set feature
failure only indicates the B device does not want to be host role for the
moment, A device as host talk to it should be okay.
see charpter 6.2.2.2 of OTG and EH 2.0:
"If the a_hnp_support feature is set, but the b_hnp_enable feature is not set,
then it is likely that b_hnp_enable will be set later when the A-device is
finished using the bus."
(cherry picked from commit 51317577d16034ba151da8d502319f4befb91278)
(cherry picked from commit 3d5d5139b3aef654e8004a2ad9ce757af50aee57)
This is required for USB OTG and EH compliance test 6.7.22(A-UUT “Device No
Response” for connection timeout). When the connected usb device(PET) does
not response to transactions, host will fail to get device descriptor.
Signed-off-by: Li Jun <jun.li@freescale.com>
(cherry picked from commit 86d0bd661ecbbdf97dd9a8ddbaf0d3811de7f39e)
(cherry picked from commit 858af83637291d2ececfc7b2b4b17e3a371b53f3)
commit 704620afc70cf47abb9d6a1a57f3825d2bca49cf upstream.
When reading an extra descriptor, we need to properly check the minimum
and maximum size allowed, to prevent from invalid data being sent by a
device.
Reported-by: Hui Peng <benquike@gmail.com>
Reported-by: Mathias Payer <mathias.payer@nebelwelt.net>
Co-developed-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Hui Peng <benquike@gmail.com>
Signed-off-by: Mathias Payer <mathias.payer@nebelwelt.net>
Cc: stable <stable@kernel.org>
commit 22454b79e6de05fa61a2a72d00d2eed798abbb75 upstream.
This will clear the USB_PORT_FEAT_C_CONNECTION bit in case of a hub port reset
only if a device is was attached to the hub port before resetting the hub port.
Using a Lenovo T480s attached to the ultra dock it was not possible to detect
some usb-c devices at the dock usb-c ports because the hub_port_reset code
will clear the USB_PORT_FEAT_C_CONNECTION bit after the actual hub port reset.
Using this device combo the USB_PORT_FEAT_C_CONNECTION bit was set between the
actual hub port reset and the clear of the USB_PORT_FEAT_C_CONNECTION bit.
This ends up with clearing the USB_PORT_FEAT_C_CONNECTION bit after the
new device was attached such that it was not detected.
This patch will not clear the USB_PORT_FEAT_C_CONNECTION bit if there is
currently no device attached to the port before the hub port reset.
This will avoid clearing the connection bit for new attached devices.
Signed-off-by: Dennis Wassenberg <dennis.wassenberg@secunet.com>
Acked-by: Mathias Nyman <mathias.nyman@linux.intel.com>
[ Upstream commit 5d111f5190848d6fb1c414dc57797efea3526a2f ]
wait_for_connected() wait till a port change status to
USB_PORT_STAT_CONNECTION, but this is not possible if
the port is unpowered. The loop will only exit at timeout.
Such case take place if an over-current incident happen
while system is in S3. Then during resume wait_for_connected()
will wait 2s, which may be noticeable by the user.
Signed-off-by: Dominik Bozek <dominikx.bozek@intel.com>
Signed-off-by: Kuppuswamy Sathyanarayanan <sathyanarayanan.kuppuswamy@linux.intel.com>
commit 249a32b7eeb3edb6897dd38f89651a62163ac4ed upstream.
Based on USB2.0 Spec Section 11.12.5,
"If a hub has per-port power switching and per-port current limiting,
an over-current on one port may still cause the power on another port
to fall below specific minimums. In this case, the affected port is
placed in the Power-Off state and C_PORT_OVER_CURRENT is set for the
port, but PORT_OVER_CURRENT is not set."
so let's check C_PORT_OVER_CURRENT too for over current condition.
Fixes: 08d1dec6f405 ("usb:hub set hub->change_bits when over-current happens")
Tested-by: Alessandro Antenucci <antenucci@korg.it>
Signed-off-by: Bin Liu <b-liu@ti.com>
commit 6e01827ed93947895680fbdad68c072a0f4e2450 upstream.
Some low-speed and full-speed devices (for example, bluetooth)
do not have time to initialize. For them, ETIMEDOUT is a valid error.
We need to give them another try. Otherwise, they will
never be initialized correctly and in dmesg will be messages
"Bluetooth: hci0 command 0x1002 tx timeout" or similars.
Fixes: 264904ccc33c ("usb: retry reset if a device times out")
Signed-off-by: Maxim Moseychuk <franchesko.salias.hudro.pedros@gmail.com>
commit 83a62c51ba7b3c0bf45150c4eac7aefc6c785e94 upstream.
On chromebooks we depend on wakeup count to identify the wakeup source.
But currently USB devices do not increment the wakeup count when they
trigger the remote wake. This patch addresses the same.
Resume condition is reported differently on USB 2.0 and USB 3.0 devices.
On USB 2.0 devices, a wake capable device, if wake enabled, drives
resume signal to indicate a remote wake (USB 2.0 spec section 7.1.7.7).
The upstream facing port then sets C_PORT_SUSPEND bit and reports a
port change event (USB 2.0 spec section 11.24.2.7.2.3). Thus if a port
has resumed before driving the resume signal from the host and
C_PORT_SUSPEND is set, then the device attached to the given port might
be the reason for the last system wakeup. Increment the wakeup count for
the same.
On USB 3.0 devices, a function may signal that it wants to exit from device
suspend by sending a Function Wake Device Notification to the host (USB3.0
spec section 8.5.6.4) Thus on receiving the Function Wake, increment the
wakeup count.
Signed-off-by: Ravi Chandra Sadineni <ravisadineni@chromium.org>
commit 973593a960ddac0f14f0d8877d2d0abe0afda795 upstream.
Sometimes the USB device gets confused about the state of the initialization and
the connection fails. In particular, the device thinks that it's already set up
and running while the host thinks the device still needs to be configured. To
work around this issue, power-cycle the hub's output to issue a sort of "reset"
to the device. This makes the device restart its state machine and then the
initialization succeeds.
This fixes problems where the kernel reports a list of errors like this:
usb 1-1.3: device not accepting address 19, error -71
The end result is a non-functioning device. After this patch, the sequence
becomes like this:
usb 1-1.3: new high-speed USB device number 18 using ci_hdrc
usb 1-1.3: device not accepting address 18, error -71
usb 1-1.3: new high-speed USB device number 19 using ci_hdrc
usb 1-1-port3: attempt power cycle
usb 1-1.3: new high-speed USB device number 21 using ci_hdrc
usb-storage 1-1.3:1.2: USB Mass Storage device detected
Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl>
If the connect status change is set during reset signaling, but
the status remains connected just retry port reset.
This solves an issue with connecting a 90W HP Thunderbolt 3 dock
with a Lenovo Carbon x1 (5th generation) which causes a 30min loop
of a high speed device being re-discovererd before usb ports starts
working.
[ 389.023845] usb 3-1: new high-speed USB device number 55 using xhci_hcd
[ 389.491841] usb 3-1: new high-speed USB device number 56 using xhci_hcd
[ 389.959928] usb 3-1: new high-speed USB device number 57 using xhci_hcd
This is caused by a high speed device that doesn't successfully go to the
enabled state after the second port reset. Instead the connection bounces
(connected, with connect status change), bailing out completely from
enumeration just to restart from scratch.
Link: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1716332
Cc: Stable <stable@vger.kernel.org>
Commit e0429362ab15
("usb: Add device quirk for Logitech HD Pro Webcams C920 and C930e")
introduced quirk to workaround an issue with some Logitech webcams.
The workaround is introducing delay for some USB operations.
According to our testing, delay introduced by original commit
is not long enough and in rare cases we still see issues described
by the aforementioned commit.
This patch increases delays introduced by original commit.
Having this patch applied we do not see those problems anymore.
Signed-off-by: Dmitry Fleytman <dmitry@daynix.com>
Save 80ms device enumeration time by increasing root hub port reset time
The 50ms reset signaling time is not enough for most root hub ports.
Increasing the reset time to 60ms allows host controllers to finish port
reset and removes a retry causing an extra 50ms delay.
The USB 2 specification requires "at least 50ms" for driving root
port reset. The current msleep is exactly 50ms which may not be
enough if there are any delays between writing the reset bit to host
controller portsc register and phy actually driving reset.
On Haswell, Skylake and Kabylake xHC port reset took in average 52-59ms
The 80ms improvement comes from (40ms * 2 port resets) save at enumeration
for each device connected to a root hub port.
more details about root port reset in USB2 section 7.1.7.5:.
"Software must ensure that resets issued to the root ports drive reset
long enough to overwhelm any concurrent resume attempts by downstream
devices. It is required that resets from root ports have a duration of
at least 50 ms (TDRSTR).
This gets the USB fixes in here as well.
Some buggy USB disk adapters disconnect and reconnect multiple times
during the enumeration procedure. This may lead to a device
connecting at full speed instead of high speed, because when the USB
stack sees that a device isn't able to enumerate at high speed, it
tries to hand the connection over to a full-speed companion
controller.
The logic for doing this is careful to check that the device is still
connected. But this check is inadequate if the device disconnects and
reconnects before the check is done. The symptom is that a device
works, but much more slowly than it is capable of operating.
The situation was made worse recently by commit 22547c4cc4fe ("usb:
hub: Wait for connection to be reestablished after port reset"), which
increases the delay following a reset before a disconnect is
recognized, thus giving the device more time to reconnect.
This patch makes the check more robust. If the device was
disconnected at any time during enumeration, we will now skip the
full-speed handover.
Reported-and-tested-by: Zdenek Kabelac <zkabelac@redhat.com>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
The controller driver may be NULL if the controller device
is the middle device between platform device and roothub.
This middle device may not need a device driver due to all
hardware control can be at platform device driver, this
platform device is usually a dual-role USB controller device.
The benefit of using this middle device is we can keep both
controller device's private data (known as struct usb_hcd)
for USB core use, and platform device's private data for
platform driver use.
Signed-off-by: Peter Chen <peter.chen@nxp.com>
Rework smelling code (goto inside compound statement). Perhaps this is
legacy. Anyway such code is not appropriate for Linux kernel.
Signed-off-by: Eugene Korenevsky <ekorenevsky@gmail.com>
The original motivation for disabling/enabling Link PM at device
suspend/resume was to force link state to go via U0 before suspend sets
the link state to U3. Going directly from U2 to U3 is not allowed.
Disabling LPM will forced the link state to U0, but will send a lot of
Set port feature requests for evert suspend and resume.
This is not needed as Hub hardware will take care of going via U0
when a U2 -> U3 transition is requested [1]
[1] USB 3.1 specification section 10.16.2.10 Set Port Feature:
"If the value is 3, then host software wants to selectively suspend the
device connected to this port. The hub shall transition the link to U3
from any of the other U states using allowed link state transitions.
If the port is not already in the U0 state, then it shall transition the
port to the U0 state and then initiate the transition to U3.
While this state is active, the hub does not propagate downstream-directed
traffic to this port, but the hub will respond to resume signaling from the
port"
Add define for the maximum number of ports on a SuperSpeed hub as per
USB 3.1 spec Table 10-5, and use it when verifying the retrieved hub
descriptor.
This specifically avoids benign attempts to update the DeviceRemovable
mask for non-existing ports (should we get that far).
Fixes: dbe79bbe9dcb ("USB 3.0 Hub Changes")
Signed-off-by: Johan Hovold <johan@kernel.org>
Add missing sanity check on the non-SuperSpeed hub-descriptor length in
order to avoid parsing and leaking two bytes of uninitialised slab data
through sysfs removable-attributes (or a compound-device debug
statement).
Note that we only make sure that the DeviceRemovable field is always
present (and specifically ignore the unused PortPwrCtrlMask field) in
order to continue support any hubs with non-compliant descriptors. As a
further safeguard, the descriptor buffer is also cleared.
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Cc: stable <stable@vger.kernel.org> # 2.6.12
A SuperSpeed hub descriptor does not have any variable-length fields so
bail out when reading a short descriptor.
This avoids parsing and leaking two bytes of uninitialised slab data
through sysfs removable-attributes.
Cc: stable <stable@vger.kernel.org> # 2.6.39
Cc: John Youn <John.Youn@synopsys.com>
This resolves a merge issue in the gadget code, and we want the USB
While running a bind/unbind stress test with the dwc3 usb driver on rk3399,
the following crash was observed.
Unable to handle kernel NULL pointer dereference at virtual address 00000218
pgd = ffffffc00165f000
[00000218] *pgd=000000000174f003, *pud=000000000174f003,
*pmd=0000000001750003, *pte=00e8000001751713
Internal error: Oops: 96000005 [#1] PREEMPT SMP
Modules linked in: uinput uvcvideo videobuf2_vmalloc cmac
ipt_MASQUERADE nf_nat_masquerade_ipv4 iptable_nat nf_nat_ipv4 nf_nat rfcomm
xt_mark fuse bridge stp llc zram btusb btrtl btbcm btintel bluetooth
ip6table_filter mwifiex_pcie mwifiex cfg80211 cdc_ether usbnet r8152 mii joydev
snd_seq_midi snd_seq_midi_event snd_rawmidi snd_seq snd_seq_device ppp_async
ppp_generic slhc tun
CPU: 1 PID: 29814 Comm: kworker/1:1 Not tainted 4.4.52 #507
Hardware name: Google Kevin (DT)
Workqueue: pm pm_runtime_work
task: ffffffc0ac540000 ti: ffffffc0af4d4000 task.ti: ffffffc0af4d4000
PC is at autosuspend_check+0x74/0x174
LR is at autosuspend_check+0x70/0x174
Call trace:
[<ffffffc00080dcc0>] autosuspend_check+0x74/0x174
[<ffffffc000810500>] usb_runtime_idle+0x20/0x40
[<ffffffc000785ae0>] __rpm_callback+0x48/0x7c
[<ffffffc000786af0>] rpm_idle+0x1e8/0x498
[<ffffffc000787cdc>] pm_runtime_work+0x88/0xcc
[<ffffffc000249bb8>] process_one_work+0x390/0x6b8
[<ffffffc00024abcc>] worker_thread+0x480/0x610
[<ffffffc000251a80>] kthread+0x164/0x178
[<ffffffc0002045d0>] ret_from_fork+0x10/0x40
Source:
(gdb) l *0xffffffc00080dcc0
0xffffffc00080dcc0 is in autosuspend_check
(drivers/usb/core/driver.c:1778).
1773 /* We don't need to check interfaces that are
1774 * disabled for runtime PM. Either they are unbound
1775 * or else their drivers don't support autosuspend
1776 * and so they are permanently active.
1777 */
1778 if (intf->dev.power.disable_depth)
1779 continue;
1780 if (atomic_read(&intf->dev.power.usage_count) > 0)
1781 return -EBUSY;
1782 w |= intf->needs_remote_wakeup;
Code analysis shows that intf is set to NULL in usb_disable_device() prior
to setting actconfig to NULL. At the same time, usb_runtime_idle() does not
lock the usb device, and neither does any of the functions in the
traceback. This means that there is no protection against a race condition
where usb_disable_device() is removing dev->actconfig->interface[] pointers
while those are being accessed from autosuspend_check().
To solve the problem, synchronize and validate device state between
autosuspend_check() and usb_disconnect().
While stress testing a usb controller using a bind/unbind looop, the
following error loop was observed.
usb 7-1.2: new low-speed USB device number 3 using xhci-hcd
usb 7-1.2: hub failed to enable device, error -108
usb 7-1-port2: cannot disable (err = -22)
usb 7-1-port2: couldn't allocate usb_device
hub 7-1:1.0: hub_ext_port_status failed (err = -22)
hub 7-1:1.0: activate --> -22
** 57 printk messages dropped ** hub 7-1:1.0: activate --> -22
** 82 printk messages dropped ** hub 7-1:1.0: hub_ext_port_status failed (err = -22)
This continues forever. After adding tracebacks into the code,
the call sequence leading to this is found to be as follows.
[<ffffffc0007fc8e0>] hub_activate+0x368/0x7b8
[<ffffffc0007fceb4>] hub_resume+0x2c/0x3c
[<ffffffc00080b3b8>] usb_resume_interface.isra.6+0x128/0x158
[<ffffffc00080b5d0>] usb_suspend_both+0x1e8/0x288
[<ffffffc00080c9c4>] usb_runtime_suspend+0x3c/0x98
[<ffffffc0007820a0>] __rpm_callback+0x48/0x7c
[<ffffffc00078217c>] rpm_callback+0xa8/0xd4
[<ffffffc000786234>] rpm_suspend+0x84/0x758
[<ffffffc000786ca4>] rpm_idle+0x2c8/0x498
[<ffffffc000786ed4>] __pm_runtime_idle+0x60/0xac
[<ffffffc00080eba8>] usb_autopm_put_interface+0x6c/0x7c
[<ffffffc000803798>] hub_event+0x10ac/0x12ac
kick_hub_wq() is called from hub_activate() even after failures to
communicate with the hub. This results in an endless sequence of
hub event -> hub activate -> wq trigger -> hub event -> ...
Provide two solutions for the problem.
- Only trigger the hub event queue if communication with the hub
is successful.
- After a suspend failure, only resume already suspended interfaces
if the communication with the device is still possible.
Each of the changes fixes the observed problem. Use both to improve
robustness.
If usb_get_bos_descriptor() returns an error, usb->bos will be NULL.
Nevertheless, it is dereferenced unconditionally in
hub_set_initial_usb2_lpm_policy() if usb2_hw_lpm_capable is set.
This results in a crash.
usb 5-1: unable to get BOS descriptor
Unable to handle kernel NULL pointer dereference at virtual address 00000008
[00000008] *pgd=000000000174f003, *pud=000000000174f003,
Modules linked in: uinput uvcvideo videobuf2_vmalloc cmac [ ... ]
CPU: 5 PID: 3353 Comm: kworker/5:3 Tainted: G B 4.4.52 #480
Workqueue: events driver_set_config_work
task: ffffffc0c3690000 ti: ffffffc0ae9a8000 task.ti: ffffffc0ae9a8000
PC is at hub_port_init+0xc3c/0xd10
LR is at hub_port_init+0xc3c/0xd10
Call trace:
[<ffffffc0007fbbfc>] hub_port_init+0xc3c/0xd10
[<ffffffc0007fbe2c>] usb_reset_and_verify_device+0x15c/0x82c
[<ffffffc0007fc5e0>] usb_reset_device+0xe4/0x298
[<ffffffbffc0e3fcc>] rtl8152_probe+0x84/0x9b0 [r8152]
[<ffffffc00080ca8c>] usb_probe_interface+0x244/0x2f8
[<ffffffc000774a24>] driver_probe_device+0x180/0x3b4
[<ffffffc000774e48>] __device_attach_driver+0xb4/0xe0
[<ffffffc000772168>] bus_for_each_drv+0xb4/0xe4
[<ffffffc0007747ec>] __device_attach+0xd0/0x158
[<ffffffc000775080>] device_initial_probe+0x24/0x30
[<ffffffc0007739d4>] bus_probe_device+0x50/0xe4
[<ffffffc000770bd0>] device_add+0x414/0x738
[<ffffffc000809fe8>] usb_set_configuration+0x89c/0x914
[<ffffffc00080a120>] driver_set_config_work+0xc0/0xf0
Since we don't know anything about LPM capabilities without BOS descriptor,
don't attempt to enable LPM if it is not available.
Fixes: 890dae886721 ("xhci: Enable LPM support only for hardwired ...")
Cc: Mathias Nyman <mathias.nyman@linux.intel.com>
Update the .c files that depend on these APIs.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
If CONFIG_PM=n:
drivers/usb/core/hub.c:107: warning: ‘hub_usb3_port_prepare_disable’ declared inline after being called
drivers/usb/core/hub.c:107: warning: previous declaration of ‘hub_usb3_port_prepare_disable’ was here
To fix this, move hub_port_disable() after
hub_usb3_port_prepare_disable(), and adjust forward declarations.
Fixes: 37be66767e3cae4f ("usb: hub: Fix auto-remount of safely removed or ejected USB-3 devices")
This was entirely automated, using the script by Al:
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
$(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h)
to do the replacement at the end of the merge window.
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
On a system with a defective USB device connected to an USB hub,
an endless sequence of port connect events was observed. The sequence
of events as observed is as follows:
- Port reports connected event (port status=USB_PORT_STAT_CONNECTION).
- Event handler debounces port and resets it by calling hub_port_reset().
- hub_port_reset() calls hub_port_wait_reset() to wait for the reset
to complete.
- The reset completes, but USB_PORT_STAT_CONNECTION is not immediately
set in the port status register.
- hub_port_wait_reset() returns -ENOTCONN.
- Port initialization sequence is aborted.
- A few milliseconds later, the port again reports a connected event,
and the sequence repeats.
This continues either forever or, randomly, stops if the connection
is already re-established when the port status is read. It results in
a high rate of udev events. This in turn destabilizes userspace since
the above sequence holds the device mutex pretty much continuously
and prevents userspace from actually reading the device status.
To prevent the problem from happening, let's wait for the connection
to be re-established after a port reset. If the device was actually
disconnected, the code will still return an error, but it will do so
only after the long reset timeout.
Cc: Douglas Anderson <dianders@chromium.org>
USB-3 does not have any link state that will avoid negotiating a connection
with a plugged-in cable but will signal the host when the cable is
unplugged.
For USB-3 we used to first set the link to Disabled, then to RxDdetect to
be able to detect cable connects or disconnects. But in RxDetect the
connected device is detected again and eventually enabled.
Instead set the link into U3 and disable remote wakeups for the device.
This is what Windows does, and what Alan Stern suggested.
Cc: stable@vger.kernel.org
Cc: Alan Stern <stern@rowland.harvard.edu>
Some of the USB core files were missing explicit license information.
As all files in the kernel tree are implicitly licensed under the
GPLv2-only, be explicit in case someone get confused looking at
individual files by using the SPDX nomenclature.
In USB20 specification, describes in chapter 9.4.5: The Remote Wakeup
field can be modified by the SetFeature() and ClearFeature() requests
using the DEVICE_REMOTE_WAKEUP feature selector.
In USB30 specification, also describes in chapter 9.4.5: The Function
Remote Wakeup field can be modified by the SetFeature() requests
using the FUNCTION_SUSPEND feature selector. In chapter 9.4.9 Set
Feature reference, it describes Function Remote Wake Enabled/Disabled
at suspend options by SET_FEATURE.
In USB30 specification only mentioned SetFeature(), so we need use
SET_FEATURE replace CLEAR_FEATURE to disable USB30 function remote
wakeup in suspend options.
Signed-off-by: Yonglong Wu <yonglong.wu@mediatek.com>
All kmalloc-based functions print enough information on failures.
Signed-off-by: Wolfram Sang <wsa-dev@sang-engineering.com>
The locking in hub_activate() is not adequate to provide full mutual
exclusion with hub_quiesce(). The subroutine locks the hub's
usb_interface, but the callers of hub_quiesce() (such as
hub_pre_reset() and hub_event()) hold the lock to the hub's
usb_device.
This patch changes hub_activate() to make it acquire the same lock as
those other routines.
CC: <stable@vger.kernel.org> #4.4+
The early-exit pathway in hub_activate, added by commit e50293ef9775
("USB: fix invalid memory access in hub_activate()") needs
improvement. It duplicates code that is already present at the end of
the subroutine, and it neglects to undo the effect of a
usb_autopm_get_interface_no_resume() call.
This patch fixes both problems by making the early-exit pathway jump
directly to the end of the subroutine. It simplifies the code at the
end by merging two conditionals that actually test the same condition
although they appear different: If type < HUB_INIT3 then type must be
either HUB_INIT2 or HUB_INIT, and it can't be HUB_INIT because in that
case the subroutine would have exited earlier.
Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org>
Memory leak and unbalanced reference count:
If the hub gets disconnected while the core is still activating it, this
can result in leaking memory of few USB structures.
This will happen if we have done a kref_get() from hub_activate() and
scheduled a delayed work item for HUB_INIT2/3. Now if hub_disconnect()
gets called before the delayed work expires, then we will cancel the
work from hub_quiesce(), but wouldn't do a kref_put(). And so the
unbalance.
kmemleak reports this as (with the commit e50293ef9775 backported to
3.10 kernel with other changes, though the same is true for mainline as
well):
unreferenced object 0xffffffc08af5b800 (size 1024):
comm "khubd", pid 73, jiffies 4295051211 (age 6482.350s)
hex dump (first 32 bytes):
30 68 f3 8c c0 ff ff ff 00 a0 b2 2e c0 ff ff ff 0h..............
01 00 00 00 00 00 00 00 00 94 7d 40 c0 ff ff ff ..........}@....
backtrace:
[<ffffffc0003079ec>] create_object+0x148/0x2a0
[<ffffffc000cc150c>] kmemleak_alloc+0x80/0xbc
[<ffffffc000303a7c>] kmem_cache_alloc_trace+0x120/0x1ac
[<ffffffc0006fa610>] hub_probe+0x120/0xb84
[<ffffffc000702b20>] usb_probe_interface+0x1ec/0x298
[<ffffffc0005d50cc>] driver_probe_device+0x160/0x374
[<ffffffc0005d5308>] __device_attach+0x28/0x4c
[<ffffffc0005d3164>] bus_for_each_drv+0x78/0xac
[<ffffffc0005d4ee0>] device_attach+0x6c/0x9c
[<ffffffc0005d42b8>] bus_probe_device+0x28/0xa0
[<ffffffc0005d23a4>] device_add+0x324/0x604
[<ffffffc000700fcc>] usb_set_configuration+0x660/0x6cc
[<ffffffc00070a350>] generic_probe+0x44/0x84
[<ffffffc000702914>] usb_probe_device+0x54/0x74
Deadlocks:
If the hub gets disconnected early enough (i.e. before INIT2/INIT3 are
finished and the init_work is still queued), the core may call
hub_quiesce() after acquiring interface device locks and it will wait
for the work to be cancelled synchronously. But if the work handler is
already running in parallel, it may try to acquire the same interface
device lock and this may result in deadlock.
Fix both the issues by removing the call to cancel_delayed_work_sync().
Fixes: e50293ef9775 ("USB: fix invalid memory access in hub_activate()")
Reported-by: Manu Gautam <mgautam@codeaurora.org>
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
The XHCI controller presents two USB buses to the system - one for USB2
and one for USB3. The hub init code (hub_port_init) is reentrant but
only locks one bus per thread, leading to a race condition failure when
two threads attempt to simultaneously initialise a USB2 and USB3 device:
[ 8.034843] xhci_hcd 0000:00:14.0: Timeout while waiting for setup device command
[ 13.183701] usb 3-3: device descriptor read/all, error -110
On a test system this failure occurred on 6% of all boots.
The call traces at the point of failure are:
Call Trace:
[<ffffffff81b9bab7>] schedule+0x37/0x90
[<ffffffff817da7cd>] usb_kill_urb+0x8d/0xd0
[<ffffffff8111e5e0>] ? wake_up_atomic_t+0x30/0x30
[<ffffffff817dafbe>] usb_start_wait_urb+0xbe/0x150
[<ffffffff817db10c>] usb_control_msg+0xbc/0xf0
[<ffffffff817d07de>] hub_port_init+0x51e/0xb70
[<ffffffff817d4697>] hub_event+0x817/0x1570
[<ffffffff810f3e6f>] process_one_work+0x1ff/0x620
[<ffffffff810f3dcf>] ? process_one_work+0x15f/0x620
[<ffffffff810f4684>] worker_thread+0x64/0x4b0
[<ffffffff810f4620>] ? rescuer_thread+0x390/0x390
[<ffffffff810fa7f5>] kthread+0x105/0x120
[<ffffffff810fa6f0>] ? kthread_create_on_node+0x200/0x200
[<ffffffff81ba183f>] ret_from_fork+0x3f/0x70
Call Trace:
[<ffffffff817fd36d>] xhci_setup_device+0x53d/0xa40
[<ffffffff817fd87e>] xhci_address_device+0xe/0x10
[<ffffffff817d047f>] hub_port_init+0x1bf/0xb70
[<ffffffff811247ed>] ? trace_hardirqs_on+0xd/0x10
Which results from the two call chains:
hub_port_init
usb_get_device_descriptor
usb_get_descriptor
usb_control_msg
usb_internal_control_msg
usb_start_wait_urb
usb_submit_urb / wait_for_completion_timeout / usb_kill_urb
hub_port_init
hub_set_address
xhci_address_device
xhci_setup_device
Mathias Nyman explains the current behaviour violates the XHCI spec:
hub_port_reset() will end up moving the corresponding xhci device slot
to default state.
As hub_port_reset() is called several times in hub_port_init() it
sounds reasonable that we could end up with two threads having their
xhci device slots in default state at the same time, which according to
xhci 4.5.3 specs still is a big no no:
"Note: Software shall not transition more than one Device Slot to the
Default State at a time"
So both threads fail at their next task after this.
One fails to read the descriptor, and the other fails addressing the
device.
Fix this in hub_port_init by locking the USB controller (instead of an
individual bus) to prevent simultaneous initialisation of both buses.
Fixes: 638139eb95d2 ("usb: hub: allow to process more usb hub events in parallel")
Link: https://lkml.org/lkml/2016/2/8/312
Link: https://lkml.org/lkml/2016/2/4/748
Signed-off-by: Chris Bainbridge <chris.bainbridge@gmail.com>
If a port can do 10 Gb/s the kernel should say so.
The corresponding check needs to be added.
Signed-off.by: Oliver Neukum <ONeukum@suse.com>>
