This eliminates the last instance of a function's behavior
controlled by a parameter as Linus hates such things.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Move usb_translate_errors from usb core to linux/usb.h as it is meant to
be accessed from drivers.
Signed-off-by: Johan Hovold <jhovold@gmail.com>
If the device pass the USB2 software LPM and the host supports hardware
LPM, enable hardware LPM for the device to let the host decide when to
put the link into lower power state.
If hardware LPM is enabled for a port and driver wants to put it into
suspend, it must first disable hardware LPM, resume the port into U0,
and then suspend the port.
Signed-off-by: Andiry Xu <andiry.xu@amd.com>
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
This commit gets BOS(Binary Device Object Store) descriptor set for Super
Speed devices and High Speed devices which support BOS descriptor.
BOS descriptor is used to report additional USB device-level capabilities
that are not reported via the Device descriptor. By getting BOS descriptor
set, driver can check device's device-level capability such as LPM
capability.
The usb_create_sysfs_intf_files() function always returned zero even
if it failed to create sysfs fails. Since this is a desired behaviour
there is no need to return return code at all. This commit changes
function's return type (form int) to void.
Signed-off-by: Michal Nazarewicz <mina86@mina86.com>
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
USB defines usb_device_type pointing to usb_device_pm_ops that
provides system-wide PM callbacks only and usb_bus_type pointing to
usb_bus_pm_ops that provides runtime PM callbacks only. However,
the USB runtime PM callbacks may be defined in usb_device_pm_ops
which makes it possible to drop usb_bus_pm_ops and will allow us
to consolidate the handling of subsystems by the PM core code.
This converts error codes specific to USB to generic error codes
that can be returned to user space. Tests showed that it is so small
that it is better inlined.
This patch (as1428) converts USB over to the new runtime-PM core
autosuspend framework. One slightly awkward aspect of the conversion
is that USB devices will now have two suspend-delay attributes: the
old power/autosuspend file and the new power/autosuspend_delay_ms
file. One expresses the delay time in seconds and the other in
milliseconds, but otherwise they do the same thing. The old attribute
can be deprecated and then removed eventually.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
This patch (as1329) converts the USB stack over to the PM core's
runtime PM framework. This involves numerous changes throughout
usbcore, especially to hub.c and driver.c. Perhaps the most notable
change is that CONFIG_USB_SUSPEND now depends on CONFIG_PM_RUNTIME
instead of CONFIG_PM.
Several fields in the usb_device and usb_interface structures are no
longer needed. Some code which used to depend on CONFIG_USB_PM now
depends on CONFIG_USB_SUSPEND (requiring some rearrangement of header
files).
The only visible change in behavior should be that following a system
sleep (resume from RAM or resume from hibernation), autosuspended USB
devices will be resumed just like everything else. They won't remain
suspended. But if they aren't in use then they will naturally
autosuspend again in a few seconds.
This patch (as1324) makes a small change to the code used for remote
wakeup of root hubs. hcd_resume_work() now calls the hub driver's
remote-wakeup routine instead of implementing its own version.
The patch is complicated by the need to rename remote_wakeup() to
usb_remote_wakeup(), make it non-static, and declare it in a header
file. There's also the additional complication required to make
everything work when CONFIG_PM isn't set; the do-nothing inline
routine had to be moved into the header file.
This patch (as1297) adds a "remove" attribute to each USB device's
directory in sysfs. Writing to this attribute causes the device to be
deconfigured (the same as writing 0 to the "bConfigurationValue"
attribute) and then tells the hub driver to disable the device's
upstream port. The device remains locked during these activities so
there is no possibility of it getting reconfigured in between. The
port will remain disabled until after the device is unplugged.
The purpose of this is to provide a means for user programs to imitate
the "Safely remove hardware" applet in Windows. Some devices do
expect their ports to be disabled before they are unplugged, and they
provide visual feedback to users indicating when they can safely be
unplugged.
The security implications are minimal. Writing to the "remove"
attribute is no more dangerous than writing to the
"bConfigurationValue" attribute.
Cc: David Zeuthen <davidz@redhat.com>
This patch (as1258) implements a feature that users have been asking
for: It gives programs the ability to "claim" a port on a hub, via a
new usbfs ioctl. A device plugged into a "claimed" port will not be
touched by the kernel beyond the immediate necessities of
initialization and enumeration.
In particular, when a device is plugged into a "claimed" port, the
kernel will not select and install a configuration. And when a config
is installed by usbfs or sysfs, the kernel will not probe any drivers
for any of the interfaces. (However the kernel will fetch various
string descriptors during enumeration. One could argue that this
isn't really necessary, but the strings are exported in sysfs.)
The patch does not guarantee exclusive access to these devices; it is
still possible for more than one program to open the device file
concurrently. Programs are responsible for coordinating access among
themselves.
A demonstration program showing how to use the new interface can be
found in an attachment to
http://marc.info/?l=linux-usb&m=124345857431452&w=2
The patch also makes a small simplification to the hub driver,
replacing a bunch of more-or-less useless variants of "out of memory"
with a single message.
Let attribute group vectors be declared "const". We'd
like to let most attribute metadata live in read-only
sections... this is a start.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
The endpoint devices look like simple attribute groups now, and no longer
like devices with a specific subsystem. They will also no longer emit uevents.
It also removes the device node requests for endpoint devices, which are not
implemented for now.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
The usb_host class isn't used for anything anymore (it was used for
debug files, but they have moved to debugfs a few kernel releases ago),
so let's delete it before someone accidentally puts a file in it.
This patch (as1198) fixes a conceptual bug: Somewhere along the line
we managed to confuse USB class devices with USB char devices. As a
result, the code to send a disconnect signal to userspace would not be
built if both CONFIG_USB_DEVICE_CLASS and CONFIG_USB_DEVICEFS were
disabled.
The usb_fs_classdev_common_remove() routine has been renamed to
usbdev_remove() and it is now called whenever any USB device is
removed, not just when a class device is unregistered. The notifier
registration and unregistration calls are no longer conditionally
compiled. And since the common removal code will always be called as
part of the char device interface, there's no need to call it again as
part of the usbfs interface; thus the invocation of
usb_fs_classdev_common_remove() has been taken out of
usbfs_remove_device().
Reported-by: Alon Bar-Lev <alon.barlev@gmail.com>
Tested-by: Alon Bar-Lev <alon.barlev@gmail.com>
Cc: stable <stable@kernel.org>
This patch (as1200) finishes some fixes that were left incomplete by
an earlier patch.
Although nobody has addressed this issue in the past, it turns out
that we need to distinguish between two different modes of disabling
and enabling endpoints. In one mode only the data structures in
usbcore are affected, and in the other mode the host controller and
device hardware states are affected as well.
The earlier patch added an extra argument to the routines in the
enable_endpoint pathways to reflect this difference. This patch adds
corresponding arguments to the disable_endpoint pathways. Without
this change, the endpoint toggle state can get out of sync between
the host and the device. The exact mechanism depends on the details
of the host controller (whether or not it stores its own copy of the
toggle values).
Reported-by: Dan Streetman <ddstreet@ieee.org>
Tested-by: Dan Streetman <ddstreet@ieee.org>
This patch (as1197) fixes an error introduced recently. Since a
significant number of devices can't handle Set-Interface requests, we
no longer call usb_set_interface() when a driver unbinds from an
interface, provided the interface is already in altsetting 0. However
the interface still does get disabled, and the call to
usb_set_interface() was the only thing re-enabling it. Since the
interface doesn't get re-enabled, further attempts to use it fail.
So the patch adds a call to usb_enable_interface() when a driver
unbinds and the interface is in altsetting 0. For this to work
right, the interface's endpoints have to be re-enabled but their
toggles have to be left alone. Therefore an additional argument is
added to usb_enable_endpoint() and usb_enable_interface(), a flag
indicating whether or not the endpoint toggles should be reset.
This is a forward-ported version of a patch which fixes Bugzilla
#12301.
Reported-by: David Roka <roka@dawid.hu>
Reported-by: Erik Ekman <erik@kryo.se>
Tested-by: Erik Ekman <erik@kryo.se>
This patch (as1185) makes usbcore take advantage of the bus
notifications sent out by the driver core. Now we can create all our
device and interface attribute files before the device or interface
uevent is broadcast.
A side effect is that we no longer create the endpoint "pseudo"
devices at the same time as a device or interface is registered -- it
seems like a bad idea to try registering an endpoint before the
registration of its parent is complete. So the routines for creating
and removing endpoint devices have been split out and renamed, and
they are called explicitly when needed. A new bitflag is used for
keeping track of whether or not the interface's endpoint devices have
been created, since (just as with the interface attributes) they vary
with the altsetting and hence can be changed at random times.
Cc: Kay Sievers <kay.sievers@vrfy.org>
This patch (as1177) modifies the USB core suspend and resume
routines. The resume functions now will take a pm_message_t argument,
so they will know what sort of resume is occurring. The new argument
is also passed to the port suspend/resume and bus suspend/resume
routines (although they don't use it for anything but debugging).
In addition, special pm_message_t values are used for user-initiated,
device-initiated (i.e., remote wakeup), and automatic suspend/resume.
By testing these values, drivers can tell whether or not a particular
suspend was an autosuspend. Unfortunately, they can't do the same for
resumes -- not until the pm_message_t argument is also passed to the
drivers' resume methods. That will require a bigger change.
IMO, the whole Power Management framework should have been set up this
way in the first place.
This patch (as1160b) adds support routines for asynchronous autosuspend
and autoresume, with accompanying documentation updates. There
already are several potential users of this interface, and others are
likely to arise as autosuspend support becomes more widespread.
This patch (as1129) adds support for the new PM callbacks to usbcore.
The new callbacks merely invoke the same old USB power management
routines as the old ones did.
A minor improvement is that the callbacks are present only in the
"USB-device" device_type structure, rather than in the bus_type
structure. This way they will be invoked only for USB devices, not
for USB interfaces. The core USB PM routines automatically handle
suspending and resuming interfaces along with their devices.
USB device files are accessible in two ways: as files in usbfs and as
character device nodes. The two paths are supposed to behave
identically, but they don't. When the underlying USB device is
unplugged, disconnect signals are sent to processes with open usbfs
files (if they requested these signals) but not to processes with open
device node files.
This patch (as1104) fixes the bug by moving the disconnect-signalling
code into a common subroutine which is called from both paths.
Putting this subroutine in devio.c removes the only out-of-file
reference to struct dev_state, and so the structure's declaration can
be moved from usb.h into devio.c.
Finally, the new subroutine performs one extra action: It kills all
the outstanding async URBs. (I'd kill the outstanding synchronous
URBs too, if there was any way to do it.) In the past this hasn't
mattered much, because devices were unregistered from usbfs only
when they were disconnected. But now the unregistration can also
occur whenever devices are unbound from the usb_generic driver. At
any rate, killing URBs when a device is unregistered from usbfs seems
like a good thing to do.
This patch (as1024) takes care of a FIXME issue: Drivers that don't
have the necessary suspend, resume, reset_resume, pre_reset, or
post_reset methods will be unbound and their interface reprobed when
one of the unsupported events occurs.
This is made slightly more difficult by the fact that bind operations
won't work during a system sleep transition. So instead the code has
to defer the operation until the transition ends.
This patch (as1087d) fixes a long-standing problem in usbcore: Device,
interface, and endpoint attributes aren't added until _after_ the
creation uevent has already been broadcast.
Unfortunately there are a few attributes which cannot be created that
early. The "descriptors" attribute is binary and so must be created
separately. The power-management attributes can't be created until
the dev/power/ group exists. And the interface string can vary from
one altsetting to another, so it has to be created dynamically.
power.power_state is scheduled for removal. This patch (as1053)
removes all uses of that field from drivers/usb. Almost all of them
were write-only, the most significant exceptions being sl811-hcd.c and
u132-hcd.c.
Part of this patch was written by Pavel Machek.
Cc: David Brownell <david-b@pacbell.net>
Acked-by: Pavel Machek <pavel@ucw.cz>
Fixes a number of coding style issues in the USB internal header files.
As it is global, give it a usb specific name in the global namespace.
Cc: Inaky Perez-Gonzalez <inaky@linux.intel.com>
These USB API functions will do the full authorization/deauthorization
to be used for a device. When authorized we effectively allow a
configuration to be set. Reverse that when deauthorized.
Effectively this means that we have to clean all the configuration
descriptors on deauthorize and reload them when we authorized. We could
do without throwing them out for wired devices, but for wireless, we can
read them only after authenticating, and thus, when authorizing an
authenticated device we would need to read them. So to simplify, always
release them on deauthorize(), re-read them on authorize().
Also fix leak reported by Ragner Magalhaes; in usb_deauthorize_device(),
bNumConfigurations was being set to zero before the for loop, and thus
the different raw descriptors where never being freed.
Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com>
This patch (as944) adds an explicit "enabled" field to the
usb_host_endpoint structure and uses it in place of the current
mechanism. This is merely a time-space tradeoff; it makes checking
whether URBs may be submitted to an endpoint simpler. The existing
mechanism is efficient when converting urb->pipe to an endpoint
pointer, but it's not so efficient when urb->ep is used instead.
As a side effect, the procedure for enabling an endpoint is now a
little more complicated. The ad-hoc inline code in usb.c and hub.c
for enabling ep0 is now replaced with calls to usb_enable_endpoint,
which is no longer static.
This patch (as919) unifies the code paths used for normal resume and
for reset-resume. Earlier I had failed to note a section in the USB
spec which requires the host to resume a suspended port before
resetting it if the attached device is enabled for remote wakeup.
Since the port has to be resumed anyway, we might as well reuse the
existing code.
The main changes are:
usb_reset_suspended_device() is eliminated.
usb_root_hub_lost_power() is moved down next to the
hub_reset_resume() routine, to which it is logically
related.
finish_port_resume() does a port reset() if the device's
reset_resume flag is set.
usb_port_resume() doesn't check whether the port is initially
enabled if this is a USB-Persist sort of resume.
Code to perform the port reset is added to the resume pathway
for the non-CONFIG_USB_SUSPEND case.
This patch (as915b) combines the public routine usb_port_suspend() and
the private routine __usb_port_suspend() into a single function.
By removing the explicit mention of otg_port in the call to
__usb_port_suspend(), we prevent a possible error in which the system
tries to perform HNP on the wrong port when a non-targeted device is
plugged into a non-OTG port.
This patch (as886) adds the controversial USB-persist facility,
allowing USB devices to persist across a power loss during system
suspend.
The facility is controlled by a new Kconfig option (with appropriate
warnings about the potential dangers); when the option is off the
behavior will remain the same as it is now. But when the option is
on, people will be able to use suspend-to-disk and keep their USB
filesystems intact -- something particularly valuable for small
machines where the root filesystem is on a USB device!
This patch (as880) strives to keep the PM core's idea of a USB
interface's power state in synch with usbcore's own idea. In the end
this doesn't really matter, but it's better to be consistent.
o The "real" usb-devices export now a device node which can
populate /dev/bus/usb.
o The usb_device class is optional now and can be disabled in the
kernel config. Major/minor of the "real" devices and class devices
are the same.
o The environment of the usb-device event contains DEVNUM and BUSNUM to
help udev and get rid of the ugly udev rule we need for the class
devices.
o The usb-devices and usb-interfaces share the same bus, so I used
the new "struct device_type" to let these devices identify
themselves. This also removes the current logic of using a magic
platform-pointer.
The name of the device_type is also added to the environment
which makes it easier to distinguish the different kinds of devices
on the same subsystem.
It looks like this:
add@/devices/pci0000:00/0000:00:1d.1/usb2/2-1
ACTION=add
DEVPATH=/devices/pci0000:00/0000:00:1d.1/usb2/2-1
SUBSYSTEM=usb
SEQNUM=1533
MAJOR=189
MINOR=131
DEVTYPE=usb_device
PRODUCT=46d/c03e/2000
TYPE=0/0/0
BUSNUM=002
DEVNUM=004
This udev rule works as a replacement for usb_device class devices:
SUBSYSTEM=="usb", ACTION=="add", ENV{DEVTYPE}=="usb_device", \
NAME="bus/usb/$env{BUSNUM}/$env{DEVNUM}", MODE="0644"
Updated patch, which needs the device_type patches in Greg's tree.
I also got a bugzilla assigned for this. :)
https://bugzilla.novell.com/show_bug.cgi?id=250659
This patch (as866) adds new entry points for external USB device
suspend and resume requests, as opposed to internally-generated
autosuspend or autoresume. It also changes the existing
remote-wakeup code paths to use the new routines, since remote wakeup
is not the same as autoresume.
As part of the change, it turns out to be necessary to do remote
wakeup of root hubs from a workqueue. We had been using khubd, but it
does autoresume rather than an external resume. Using the
ksuspend_usb_wq workqueue for this purpose seemed a logical choice.
This patch (as864) moves the work routine for USB autosuspend from one
source file to another. This permits the removal of one whole global
symbol (!) and should smooth the way for more changes in the future.
This patch (as861) adds sysfs attributes to expose the autosuspend
delay value for each USB device. If the user changes the delay from 0
(no autosuspend) to a positive value, an autosuspend is attempted.
This patch (as859) makes the default USB autosuspend delay a module
parameter of usbcore. By setting the delay value at boot time, users
will be able to prevent the system from autosuspending devices which
for some reason can't handle it.
The patch also stores the autosuspend delay as a per-device value. A
later patch will allow the user to change the value, tailoring the
delay for each individual device. A delay value of 0 will prevent
autosuspend.
This adds a blacklist to the USB core to handle some autosuspend and
string issues that devices have.
Originally written by Oliver, but hacked up a lot by Greg.
This is needed for the quirk match code.
Cc: Oliver Neukum <oliver@neukum.name>
Thanks to several earlier patches, usb_autosuspend_device() and
usb_autoresume_device() are never called with a second argument other
than 1. This patch (as819) removes the now-redundant argument.
It also consolidates some common code between those two routines,
putting it into a new subroutine called usb_autopm_do_device(). And
it includes a sizable kerneldoc update for the affected functions.
The problem with remembering a user space process by its pid is that it is
possible that the process will exit, pid wrap around will occur.
Converting to a struct pid avoid that problem, and paves the way for
implementing a pid namespace.
Also since usb is the only user of kill_proc_info_as_uid rename
kill_proc_info_as_uid to kill_pid_info_as_uid and have the new version take
a struct pid.
This patch (as791b) fixes things up to avoid compiler warnings or
errors when CONFIG_USB_SUSPEND or CONFIG_PM isn't set.
This patch (as787) creates a new workqueue thread to handle delayed
USB autosuspend requests. Previously the code used keventd. However
it turns out that the hub driver's suspend routine calls
flush_scheduled_work(), making it a poor candidate for running in
keventd (the call immediately deadlocks). The solution is to use a
new thread instead of keventd.
This patch (as740) removes the existing support for autosuspend of
root hubs. That support fit in rather awkwardly with the rest of
usbcore and it was used only by ohci-hcd. It won't be needed any more
since the hub driver will take care of autosuspending all hubs, root
or external.
This patch (as739) adds the basic infrastructure for USB autosuspend
and autoresume. The main features are:
PM usage counters added to struct usb_device and struct
usb_interface, indicating whether it's okay to autosuspend
them or they are currently in use.
Flag added to usb_device indicating whether the current
suspend/resume operation originated from outside or as an
autosuspend/autoresume.
Flag added to usb_driver indicating whether the driver
supports autosuspend. If not, no device bound to the driver
will be autosuspended.
Mutex added to usb_device for protecting PM operations.
Unlike the device semaphore, the locking rule for the pm_mutex
is that you must acquire the locks going _up_ the device tree.
New routines handling autosuspend/autoresume requests for
interfaces and devices.
Suspend and resume requests are propagated up the device tree
(but not outside the USB subsystem).
work_struct added to usb_device, for carrying out delayed
Autoresume added (and autosuspend prevented) during probe and
disconnect.
drivers/usb/core/hub.c: In function `hub_events':
drivers/usb/core/hub.c:2591: warning: statement with no effect
This patch marks some USB core's functions parameters as const. This
improves the design (we're saying to the caller that its parameter is
not going to be modified) and may help in compiler's optimisation work.
Signed-off-by: Luiz Fernando N. Capitulino <lcapitulino@mandriva.com.br>
