In function udc_probe() call put_device() when device_register() fails.
Signed-off-by: Rahul Ruikar <rahul.ruikar@gmail.com>
Acked-by: Thomas Dahlmann <dahlmann.thomas@arcor.de>
Cc: David Brownell <david-b@pacbell.net>
The same expression is tested twice and the result is the same each time.
Instead test for use_dma_ppb as in the test above.
The sematic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@expression@
expression E;
* E
|| ... || E
* E
&& ... && E
// </smpl>
To accomplish this the function to register a gadget driver takes the bind
function as a second argument. To make things clearer rename the function
to resemble platform_driver_probe.
This fixes many section mismatches like
WARNING: drivers/usb/gadget/g_printer.o(.data+0xc): Section mismatch in
reference from the variable printer_driver to the function
.init.text:printer_bind()
The variable printer_driver references
the function __init printer_bind()
All callers are fixed.
[m.nazarewicz@samsung.com: added dbgp]
Signed-off-by: Michał Nazarewicz <m.nazarewicz@samsung.com>
- fixed shared interrupt bug reported by Vadim Lobanov
- fixed possible warning oops on driver unload when connected
- prevent interrupt flood in PIO mode ("modprobe amd5536udc use_dma=0")
when using gadget ether
Signed-off-by: Thomas Dahlmann <dahlmann.thomas@arcor.de>
Cc: Robert Richter <robert.richter@amd.com>
Cc: stable <stable@kernel.org>
list_entry, which is an alias for container_of, cannot return NULL, as
there is no way to add a NULL value to a doubly linked list.
A simplified version of the semantic match that findds this problem is as
follows:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
@r@
expression x,E;
statement S1,S2;
position p,p1;
*x = list_entry@p(...)
... when != x = E
*if@p1 (x == NULL) S1 else S2
// </smpl>
* Remove smp_lock.h from files which don't need it (including some headers!)
* Add smp_lock.h to files which do need it
* Make smp_lock.h include conditional in hardirq.h
It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT
This will make hardirq.h inclusion cheaper for every PREEMPT=n config
(which includes allmodconfig/allyesconfig, BTW)
The base versions handle constant folding now.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
This patch lets the files using linux/version.h match the files that
#include it.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
The bus_id field is going away, use the dev_set_name() function
to set it properly.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
drivers/usb/host/ohci-sm501.c:93:24: warning: Using plain integer as NULL pointer
drivers/usb/gadget/amd5536udc.c:3254:9: warning: Using plain integer as NULL pointer
drivers/usb/gadget/amd5536udc.c:3267:9: warning: Using plain integer as NULL pointer
drivers/usb/gadget/amd5536udc.c:3277:9: warning: Using plain integer as NULL pointer
drivers/usb/gadget/amd5536udc.c:3285:9: warning: Using plain integer as NULL pointer
drivers/usb/gadget/amd5536udc.c:3293:9: warning: Using plain integer as NULL pointer
* endianness annotations
* endianness fixes
* missing get_unaligned/put_unaligned
It's pretty much all over the place, changes to different files are independent.
Serial-parts-Acked-by: Alan Cox <alan@redhat.com>
driver
In drivers/usb/gadget/amd5536udc.c::udc_pci_probe(), sizeof(struct udc)
storage is allocated for 'dev'.
There are many exit points from the function where 'dev' is not free'd but has
also not yet been used for anything. The following patch free's 'dev' at the
return points where it has not yet been used.
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Cc: David Brownell <dbrownell@users.sourceforge.net>
I'm having problem with oopses when rebooting, if I modprobe g_serial
and rmmod g_serial and do a reboot I get an oops in device_shutdown().
The reason seems to be that usb_gadget_unregister_driver() doesn't do
enough cleanup. With this at91_udc patch I don't get the oops.
Signed-off-by: Patrik Sevallius <patrik.sevallius@enea.com>
[ Same bug was in other peripheral controller drivers; fixed ]
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Acked-by: David Brownell <david-b@pacbell.net>
Get rid of pointless pci_set_mwi() compiler warning.
Move <linux/usb_gadget.h> to <linux/usb/gadget.h>, reducing
some of the clutter in the main include directory.
Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
Cc: Thomas Dahlmann <thomas.dahlmann@amd.com>
Remove redundant memset() call from udc_pci_probe(). No functional change.
Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl>
Driver for the AMD5536 UDC, as found in the AMD Geode CS5536 (southbridge).
This is a high speed DMA-capable controller, which can also be used in
OTG configurations (which are not supported by this patch).
Acked-by: Jordan Crouse <jordan.crouse@amd.com>
