commit 5b24c28cfe136597dc3913e1c00b119307a20c7e upstream.
Currently ncm->notify_req is used to flag when a request is in-flight.
ncm->notify_req is set to NULL and when a request completes it is
subsequently reset.
This is fundamentally buggy in that the unbind logic of the NCM driver will
unconditionally free ncm->notify_req leading to a NULL pointer dereference.
Fixes: 40d133d7f542 ("usb: gadget: f_ncm: convert to new function interface with backward compatibility")
Cc: stable <stable@vger.kernel.org>
Signed-off-by: Bryan O'Donoghue <bryan.odonoghue@linaro.org>
Signed-off-by: Felipe Balbi <balbi@kernel.org>
This patch adds to support no_skb_reserve function to improve
performance for some platforms. About the detail, please refer to
the commit log of "quirk_avoids_skb_reserve" in
include/linux/usb/gadget.h.
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
Patch enables SuperSpeed for NCM gadget.
Tested with USB3380 and measured TCP throughput with two Intel PCs:
udc to host: 920 Mbit/s
host to udc: 550 Mbit/s
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@haltian.com>
Add the 'ssp_descriptors' parameter to the usb_assign_descriptors()
function. This allows a function driver to add descriptors for
SuperSpeedPlus speeds if it supports it.
Also update all uses of this function in the gadget subsystem so that
they pass NULL for the ssp_descriptors parameters.
Signed-off-by: John Youn <johnyoun@synopsys.com>
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
Pull SCSI target updates from Nicholas Bellinger:
"This series contains HCH's changes to absorb configfs attribute
->show() + ->store() function pointer usage from it's original
tree-wide consumers, into common configfs code.
It includes usb-gadget, target w/ drivers, netconsole and ocfs2
changes to realize the improved simplicity, that now renders the
original include/target/configfs_macros.h CPP magic for fabric drivers
and others, unnecessary and obsolete.
And with common code in place, new configfs attributes can be added
easier than ever before.
Note, there are further improvements in-flight from other folks for
v4.5 code in configfs land, plus number of target fixes for post -rc1
code"
In the meantime, a new user of the now-removed old configfs API came in
through the char/misc tree in commit 7bd1d4093c2f ("stm class: Introduce
an abstraction for System Trace Module devices").
This merge resolution comes from Alexander Shishkin, who updated his stm
class tracing abstraction to account for the removal of the old
show_attribute and store_attribute methods in commit 517982229f78
("configfs: remove old API") from this pull. As Alexander says about
that patch:
"There's no need to keep an extra wrapper structure per item and the
awkward show_attribute/store_attribute item ops are no longer needed.
This patch converts policy code to the new api, all the while making
the code quite a bit smaller and easier on the eyes.
Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com>"
That patch was folded into the merge so that the tree should be fully
bisectable.
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (23 commits)
ocfs2/cluster: use per-attribute show and store methods
ocfs2/cluster: move locking into attribute store methods
netconsole: use per-attribute show and store methods
target: use per-attribute show and store methods
spear13xx_pcie_gadget: use per-attribute show and store methods
dlm: use per-attribute show and store methods
usb-gadget/f_serial: use per-attribute show and store methods
usb-gadget/f_phonet: use per-attribute show and store methods
usb-gadget/f_obex: use per-attribute show and store methods
usb-gadget/f_uac2: use per-attribute show and store methods
usb-gadget/f_uac1: use per-attribute show and store methods
usb-gadget/f_mass_storage: use per-attribute show and store methods
usb-gadget/f_sourcesink: use per-attribute show and store methods
usb-gadget/f_printer: use per-attribute show and store methods
usb-gadget/f_midi: use per-attribute show and store methods
usb-gadget/f_loopback: use per-attribute show and store methods
usb-gadget/ether: use per-attribute show and store methods
usb-gadget/f_acm: use per-attribute show and store methods
usb-gadget/f_hid: use per-attribute show and store methods
To simplify the configfs interface and remove boilerplate code that also
causes binary bloat.
Reviewed-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com>
Acked-by: Felipe Balbi <balbi@ti.com>
Since ep->driver_data is not used for endpoint claiming, neither for
enabled/disabled state storing, we can reduce number of places where
we read or modify it's value, as now it has no particular meaning for
function or framework logic.
In case of f_ncm, ep->driver_data was used only for endpoint claiming
and marking endpoints as enabled, so we can simplify code by reducing
it.
Signed-off-by: Robert Baldyga <r.baldyga@samsung.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
The 'driver_data' field in ep0 is never set to pointer to cdev, so we
have to obtain it from another source as in this context ep->driver_data
contains invalid data.
Use generic mechanism to check if UDC controller supports zlp.
Added failure check for usb_assign_descriptors call in bind function.
Acked-By: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Pavitrakumar Managutte <pavitra1729@gmail.com>
Removed usb_free_all_descriptors in the bind functions, which
results in double-free corruption of the descriptors on error path.
The usb descriptors are allocated by usb_assign_descriptors.
Reviewed-by: Robert Baldyga <r.baldyga@samsung.com>
Reviewed-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Unfortunately, the USB gadget layer has this weird things where NULL
skbs are passed into ops->ndo_start_xmit() in order to trigger the
dev->wrap() calls to build packets.
This is completely outside of the allowable range of sane arguments
for the ndo_start_xmit method. All invocations of ndo_start_xmit()
should be with non-NULL SKB arguments.
Put back the direct call, but with a comment explaining how this
is not acceptable in the long term.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
The drivers/usb/gadget directory contains many files.
Files which are related can be distributed into separate directories.
This patch moves the USB functions implementations into a separate directory.
Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com>
