Without it udev won't be able to load the driver once it notices the
device unbound.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Felipe Balbi <balbi@ti.com>
peripheral drivers are using usb_add_gadget()/usb_del_gadget() to
register/unregister to the udc-core.
The udc-core will take the first available gadget driver and attach
function driver which is calling usb_gadget_register_driver(). This is
the same behaviour we have right now.
Only dummy_hcd was tested, the others were compiled tested.
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Anton Tikhomirov <av.tikhomirov@samsung.com>
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Dan Carpenter <error27@gmail.com>
Cc: Darius Augulis <augulis.darius@gmail.com>
Cc: Eric Miao <eric.y.miao@gmail.com>
Cc: Jingoo Han <jg1.han@samsung.com>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Cc: Li Yang <leoli@freescale.com>
Cc: Michael Hennerich <michael.hennerich@analog.com>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Pavankumar Kondeti <pkondeti@codeaurora.org>
Cc: Roy Huang <roy.huang@analog.com>
Cc: Toshiharu Okada <toshiharu-linux@dsn.okisemi.com>
Cc: Xiaochen Shen <xiaochen.shen@intel.com>
Cc: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com>
Cc: Yuan-Hsin Chen <yhchen@faraday-tech.com>
Cc: cxie4 <cxie4@marvell.com>
Cc: linux-geode@lists.infradead.org
|drivers/usb/gadget/mv_udc_core.c:2108: error: label `error' used but not defined
This seems to be broken since the initial commit. I changed this to a
simple return. The other user is the probe code which lets ->probe()
fail on error here.
|drivers/usb/gadget/mv_udc_core.c:2107: warning: passing argument 1 of `dev_err' from incompatible pointer type
|drivers/usb/gadget/mv_udc_core.c:2118: warning: initialization from incompatible pointer type
|drivers/usb/gadget/mv_udc_core.c:2119: warning: initialization from incompatible pointer type
|drivers/usb/gadget/mv_udc_core.c:2130: error: initializer element is not constant
|drivers/usb/gadget/mv_udc_core.c:2130: error: (near initialization for `udc_driver.driver.pm')
Cc: Chao Xie <chao.xie@marvell.com>
This patch add USB client support Marvell PXA9xx/PXA168 chips. The USB
controller in PXA9xx/PXA168 is a High-Speed OTG controller. The available
endpoints is different between PXA9xx and PXA168.
NOTE:
It is the first version of Marvell PXA9xx/PXA168 USB controller driver.
The support for OTG mode will be added in later patch.
PXA9xx and PXA168 has integrated UTMI PHY in the chips. The initialization
for the PHY is a little different between PXA9xx and PXA168.
Signed-off-by: Chao Xie <chao.xie@marvell.com>
