path: root/drivers/usb/host/ehci-hcd.c
2006-01-04[PATCH] USB: hcd uses EXTRA_CFLAGS for -DDEBUGDavid Brownell
This modifies the HCD builds to automatically "-DDEBUG" if CONFIG_USB_DEBUG is selected. It's just a minor source code cleanup, guaranteeing consistency. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: ehci fix driver model wakeup flagsDavid Brownell
On some systems, EHCI seems to be getting IRQs too early during driver setup ... before the root hub is allocated, in particular, making trouble for any code chasing down root hub pointers! In this case, it seems to be safe to just ignore the root hub setting. Thanks to Rafael J. Wysocki for getting this properly tested. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: EHCI updates (4/4) driver model wakeup flagsDavid Brownell
This teaches the EHCI driver to use the new driver model wakeup flags, replacing the similar ones in the HCD glue. It also adds a workaround for the current glitch whereby PCI init doesn't init the wakeup flags from the PCI PM capabilities. (EHCI controllers don't worry about legacy mode; the PCI PM capability would always do the job.) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-23[PATCH] USB: EHCI updates split init/reinit logic for resumeDavid Brownell
Moving the PCI-specific parts of the EHCI driver into their own file created a few issues ... notably on resume paths which (like swsusp) require re-initializing the controller. This patch: - Splits the EHCI startup code into run-once HCD setup code and separate "init the hardware" reinit code. (That reinit code is a superset of the "early usb handoff" code.) - Then it makes the PCI init code run both, and the resume code only run the reinit code. - It also removes needless pci wrappers around EHCI start/stop methods. - Removes a byteswap issue that would be seen on big-endian hardware. The HCD glue still doesn't actually provide a good way to do all this run-one init stuff in one place though. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-23[PATCH] USB: EHCI updatesDavid Brownell
This fixes some bugs in EHCI suspend/resume that joined us over the past few releases (as usbcore, PCI, pmcore, and other components evolved): - Removes suspend and resume recursion from the EHCI driver, getting rid of the USB_SUSPEND special casing. - Updates the wakeup mechanism to work again; there's a newish usbcore call it needs to use. - Provide simpler tests for "do we need to restart from scratch", to address another case where PCI Vaux was lost. (In this case it was restoring a swsusp snapshot, but there could be others.) Un-exports a symbol that was temporarily exported. A notable change from previous version is that this doesn't move the spinlock init, so there's still a resume/reinit path bug. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] EHCI, split out PCI glueMatt Porter
This splits BIOS and PCI specific support out of ehci-hcd.c into ehci-pci.c. It follows the model already used in the OHCI driver so support for non-PCI EHCI controllers can be more easily added. Signed-off-by: Matt Porter <mporter@kernel.crashing.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> drivers/usb/host/ehci-hcd.c | 543 ++++++-------------------------------------- drivers/usb/host/ehci-pci.c | 414 +++++++++++++++++++++++++++++++++ drivers/usb/host/ehci.h | 1 3 files changed, 492 insertions(+), 466 deletions(-)
2005-10-28[PATCH] remove usb_suspend_device() parameterDavid Brownell
This patch removes the extra usb_suspend_device() parameter. The original reason to pass that parameter was so that this routine could suspend any active children. A previous patch removed that functionality ... leaving no reason to pass the parameter. A close analogy is pci_set_power_state, which doesn't need a pm_message_t either. On the internal code path that comes through the driver model, the parameter is now used to distinguish cases where USB devices need to "freeze" but not suspend. It also checks for an error case that's accessible through sysfs: attempting to suspend a device before its interfaces (or for hubs, ports). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> drivers/usb/core/hub.c | 34 +++++++++++++++++++++------------- drivers/usb/core/usb.c | 23 +++++++++++++++++++++-- drivers/usb/host/ehci-hcd.c | 2 +- drivers/usb/host/isp116x-hcd.c | 2 +- drivers/usb/host/ohci-pci.c | 2 +- include/linux/usb.h | 2 +- 6 files changed, 46 insertions(+), 19 deletions(-)
2005-10-28[PATCH] USB: ehci.patch (earlier irq disable)David Brownell
This tweaks the EHCI reboot notifier to also halt the EHCI controller, and makes that halt code force IRQs off. Both should always have been done. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> drivers/usb/host/ehci-hcd.c | 8 ++++++++ 1 file changed, 8 insertions(+)
2005-10-28[PATCH] gfp_t: drivers/usbAl Viro
2005-09-12[PATCH] drivers/usb: fix-up schedule_timeout() usageNishanth Aravamudan
Description: Use schedule_timeout_{,un}interruptible() instead of set_current_state()/schedule_timeout() to reduce kernel size. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-12[PATCH] USB: EHCI workaround for NForce and mem > 2GBDavid Brownell
NVidia reports (via Mark Overby) that some of their EHCI controllers don't like certain data structure addresses beyond the 2GB mark. He provided an earlier version of this patch. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-12[PATCH] USB: EHCI port tweaksDavid Brownell
One change may improve some S1 or S3 resume cases, and the other seems mostly to explain some strange state "lsusb" would show. Two fixes: - On resume, don't think about resuming any unpowered port, or resetting any port with OWNER set to the OHCI/UHCI companion. This will make some S1 and S3 resume scenarios work better. - PORT_CSC was not being cleared correctly in ehci_hub_status_data. This was visible at least through current versions of "lsusb", and might have caused some other hub related strangeness. The fix addresses all three write-to-clear bits, using the same approach that UHCI happens to use: a mask of bits that are cleared in most writes to that port status register. Original patch seems to have been from from William.Morrow@amd.com and this version (from David) finishes the write-to-clear changes. Signed-off-by: Jordan Crouse <jordan.crouse@amd.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-08[PATCH] PCI: start paying attention to a lot of pci function return valuesGreg Kroah-Hartman
2005-07-12[PATCH] USB: Fix kmalloc's flags type in USBOlav Kongas
Greg, This patch fixes the kmalloc() flags argument type in USB subsystem; hopefully all of its occurences. The patch was made against patch-2.6.12-git2 from Jun 20. Cleanup of flags for kmalloc() in USB subsystem. Signed-off-by: Olav Kongas <ok@artecdesign.ee> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-27[PATCH] USB: misc ehci updatesDavid Brownell
Various minor EHCI updates * Dump some more info in the debug dumps, notably the product description (e.g. chip vendor), BIOS handhake flags, and debug port status (when it's not managed by the HCD). * Minor updates to the BIOS handoff code: always flag the HCD as owned by Linux (in case BIOS doesn't grab it "early"), and on the buggy-BIOS path always match the "early handoff" code and forcibly disable SMI IRQs. * For the disabled 64bit DMA support, there's now a constant to use for the mask; use it. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-27[PATCH] USB HCDs: no longer need to register root hubAlan Stern
This patch changes the host controller drivers; they no longer need to register their root hubs because usbcore will take care of it for them. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-05-03[PATCH] USB: ehci power fixesDavid Brownell
Miscellaneous updates for EHCI. - Mostly updates the power switching on EHCI controllers. One routine centralizes the "power on/off all ports" logic, and the capability to do that is reported more correctly. - Courtesy Colin Leroy, a patch to always power up ports after resumes which didn't keep a USB device suspended. The reset-everything logic powers down those ports (on some hardware) so something needs to turn them back on. - Minor tweaks/bugfixes for the debug port support. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-04-18[PATCH] USB: hcd suspend uses pm_message_tDavid Brownell
This patch includes minor "sparse -Wbitwise" updates for the PCI based HCDs. Almost all of them involve just changing the second parameter of the suspend() method to a pm_message_t ... the others relate to how the EHCI code walks in-memory data structures. (There's a minor bug fixed there too ... affecting the big-endian sysfs async schedule dump.) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Index: gregkh-2.6/drivers/usb/core/hcd.h ===================================================================
