This driver is not registered by any in-tree user. If needed it the EHCI
driver can be reinstatied using the ehci-platform driver with caps_offset to
0x100.
Signed-off-by: Florian Fainelli <florian@openwrt.org>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
The various devm_ functions allocate memory that is released when a driver
detaches. This patch uses these functions for data that is allocated in
the probe function of a platform device and is only freed in the remove
function.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
This patch (as1564c) converts the EHCI platform drivers to use the
central ehci_setup() routine for generic controller initialization
rather than each having its own idiosyncratic approach.
The major point of difficulty lies in ehci-pci's many vendor- and
device-specific workarounds. Some of them have to be applied before
calling ehci_setup() and some after, which necessitates a fair amount
of code motion. The other platform drivers require much smaller
changes.
One point not addressed by the patch is whether ports should be
powered on or off following initialization. The different drivers
appear to handle this pretty much at random. In fact it shouldn't
matter, because the hub driver turns on power to all ports when it
binds to the root hub. Straightening that out will be left for
another day.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Several fixes as well where the +1 was missing.
Done via coccinelle scripts like:
struct resource *ptr;
- ptr->end - ptr->start + 1
+ resource_size(ptr)
and some grep and typing.
Mostly uncompiled, no cross-compilers.
The two first HC capability registers (CAPLENGTH and HCIVERSION)
are defined as one 8-bit and one 16-bit register. Most HC
implementations have selected to treat these registers as part
of a 32-bit register, giving the same layout for both big and
small endian systems.
This patch adds a new quirk, big_endian_capbase, to support
controllers with big endian register interfaces that treat
HCIVERSION and CAPLENGTH as individual registers.
Signed-off-by: Jan Andersson <jan@gaisler.com>
This patch (as1256) changes ehci-hcd and all the other drivers in the
EHCI family to make use of the new clear_tt_buffer callbacks. When a
Clear-TT-Buffer request is in progress for a QH, the QH is not allowed
to be linked into the async schedule until the request is finished.
At that time, if there are any URBs queued for the QH, it is linked
into the async schedule.
Cc: stable <stable@kernel.org>
This patch (as1245) fixes a bug in ehci-hcd. When an URB is queued
for an endpoint whose QH is already in the LINKED state, the QH
doesn't get refreshed. As a result, if usb_clear_halt() was called
during the time that the QH was linked but idle, the data toggle value
in the QH doesn't get reset.
The symptom is that after a clear_halt, data gets lost and transfers
time out. This problem is starting to show up now because the
"ehci-hcd unlink speedups" patch causes QHs with no queued URBs to
remain linked for a suitable time.
The patch utilizes the new endpoint_reset mechanism to fix the
problem. When an endpoint is reset, the new method forcibly unlinks
the QH (if necessary) and safely updates the toggle value. This
allows qh_update() to be simplified and avoids using usb_device's
toggle bits in a rather unintuitive way.
CC: David Brownell <david-b@pacbell.net>
Tested-by: David <david@unsolicited.net>
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
The bus_id field is going away, use the dev_name() function instead.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
This patch (as1096) fixes an annoying problem: When a full-speed or
low-speed device is plugged into an EHCI controller, it fails to
enumerate at high speed and then is handed over to the companion
controller. But usbcore logs a misleading and unwanted error message
when the high-speed enumeration fails.
The patch adds a new HCD method, port_handed_over, which asks whether
a port has been handed over to a companion controller. If it has, the
error message is suppressed.
This patch (as1095) cleans up the HCD glue and several of the EHCI
bus-glue files. The ehci->is_tdi_rh_tt flag is redundant, since it
means the same thing as the hcd->has_tt flag, so it is removed and the
other flag used in its place.
Some of the bus-glue files didn't get the relinquish_port method added
to their hc_driver structures. Although that routine currently
doesn't do anything for controllers with an integrated TT, in the
future it might. So the patch adds it where it is missing.
Lastly, some of the bus-glue files have erroneous entries for their
hc_driver's suspend and resume methods. These method pointers are
specific to PCI and shouldn't be used otherwise.
(The patch also includes an invisible whitespace fix.)
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
Various minor fixes to some SOC bus glue for EHCI:
- Remove a bogus copyright (by "me"!) which someone added to the FSL
driver, and an irrelevant comment.
- Un-break MODULE_ALIAS() directives after platform_bus hotplugging
acquired a backwards-incompatible change. (Which didn't fix ANY
of the in-tree drivers it prevented from hotplugging -- sigh.)
- Remove some bogus assignments of platform_bus_type; that's done by
the platform_bus code.
- Add some FIXMEs for drivers with that pointless two-level idiom for
probe() and remove() routines. ("Obfuscation" is a non-goal.)
That should help avoid future bus glue which copies that idiom.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
EHCI Glue driver for Intel IXP4XX EHCI USB controller
Signed-off-by: Vladimir Barinov <vbarinov@ru.mvista.com>
