- Add a new compatible string for the Armada 3700 SoCs
- add sbuscfg support for orion usb controller driver. For the SoCs
without hlock, need to program BAWR/BARD/AHBBRST fields in the sbuscfg
register to guarantee the AHB master's burst would not overrun or
underrun the FIFO.
- the sbuscfg register has to be set after the usb controller reset,
otherwise the value would be overridden to 0. In order to do this, the
reset callback is registered.
[gregory.clement@free-electrons.com: - reword commit and comments
- fix error path in ehci_orion_drv_reset()
- fix checkpatch warning]
Signed-off-by: Hua Jing <jinghua@marvell.com>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
Acked-by: Rob Herring <robh@kernel.org>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Commit d445913ce0ab7f ("usb: ehci-orion: add optional PHY support")
added support for optional phys, but devm_phy_optional_get returns
-ENOSYS if GENERIC_PHY is not enabled.
This causes probe failures, even when there are no phys specified:
[ 1.443365] orion-ehci f1058000.usb: init f1058000.usb fail, -38
[ 1.449403] orion-ehci: probe of f1058000.usb failed with error -38
Similar to dwc3, treat -ENOSYS as no phy.
Fixes: d445913ce0ab7f ("usb: ehci-orion: add optional PHY support")
Signed-off-by: Jonas Gorski <jogo@openwrt.org>
This commit adds new register values for the USB_CMD and USB_MODE
registers, which allows to avoid the usage of a number of magic values
in orion_usb_phy_v1_setup().
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core update from Greg KH:
"Here's the set of driver core patches for 3.19-rc1.
They are dominated by the removal of the .owner field in platform
drivers. They touch a lot of files, but they are "simple" changes,
just removing a line in a structure.
Other than that, a few minor driver core and debugfs changes. There
are some ath9k patches coming in through this tree that have been
acked by the wireless maintainers as they relied on the debugfs
changes.
Everything has been in linux-next for a while"
* tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits)
Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries"
fs: debugfs: add forward declaration for struct device type
firmware class: Deletion of an unnecessary check before the function call "vunmap"
firmware loader: fix hung task warning dump
devcoredump: provide a one-way disable function
device: Add dev_<level>_once variants
ath: use seq_file api for ath9k debugfs files
debugfs: add helper function to create device related seq_file
drivers/base: cacheinfo: remove noisy error boot message
Revert "core: platform: add warning if driver has no owner"
drivers: base: support cpu cache information interface to userspace via sysfs
drivers: base: add cpu_device_create to support per-cpu devices
topology: replace custom attribute macros with standard DEVICE_ATTR*
cpumask: factor out show_cpumap into separate helper function
driver core: Fix unbalanced device reference in drivers_probe
driver core: fix race with userland in device_add()
sysfs/kernfs: make read requests on pre-alloc files use the buffer.
sysfs/kernfs: allow attributes to request write buffer be pre-allocated.
fs: sysfs: return EGBIG on write if offset is larger than file size
This commit fixes ehci-orion operation in big-endian mode by enabling byteswap
when accessing registers using 'rdl' and 'wrl' macros.
Signed-off-by: Grzegorz Jaszczyk <jaz@semihalf.com>
Signed-off-by: Marcin Wojtas <mw@semihalf.com>
Reviewed-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Tested-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Sanity check on resource happening with devm_ioremap_resource().
Signed-off-by: Varka Bhadram <varkab@cdac.in>
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
This commit extends the ehci-orion so that it can optionally be passed
a reference to a PHY through the Device Tree. It will be useful for
the Armada 375 SoCs. If no PHY is provided then the behavior of the
driver is unchanged.
[Thomas: use devm_phy_optional_get() so that we handle -EPROBE_DEFER
properly. Also call phy_power_off() when needed, and rename goto
labels.]
In order to disable the clock in the ->remove() function, a call to
devm_clk_get() is being made, which further increases the reference
count of the clock.
In order to clean this up, a private structure holding a pointer to
the clock is added using the override mechanism provided by the ehci
framework. This makes the driver clock handling much more logical.
The bug was introduced in v3.6, however the ehci framework allowing to
use the override mechanism has only been introduced in v3.8, so this
patch won't apply before it.
[Thomas: reword commit log, fix goto label names.]
Fixes: 8c869edaee07c623066266827371235fb9c12e01 ('ARM: Orion: EHCI: Add support for enabling clocks')
Cc: <stable@vger.kernel.org> # v3.8+
In preparation to the introduction of additional initialization steps
in ehci_orion_drv_probe(), we rename the error goto labels from err1,
err2 and err3 names to some more meaningful names.
Commit 77dae54ab385033e488d8b07045bc7f8d931740f ('ARM: Kirkwood:
ehci-orion: Add device tree binding') added the Device Tree binding
for the ehci-orion driver. To achieve that with the irq, it used the
irq_of_parse_and_map() function when probed in DT-mode, and
platform_get_irq() when probed in non-DT mode.
This is not necessary: platform_get_irq() works just as fine in
DT-mode, since the conversion from DT information to 'struct resource'
is done by the generic layers of the kernel.
Therefore, this commit switches back to use just platform_get_irq().
Use devm_*() functions to make cleanup paths simpler.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Acked-by: Jason Cooper <jason@lakedaemon.net>
Use dev_warn() instead of printk() to provide a better message
to userspace.
Individual controller driver has different requirement for wakeup
setting, so move it from core to itself. In order to align with
current etting the default wakeup setting is enabled (except for
chipidea host).
Pass compile test with below commands:
make O=outout/all allmodconfig
make -j$CPU_NUM O=outout/all drivers/usb
Signed-off-by: Peter Chen <peter.chen@freescale.com>
Acked-by: Felipe Balbi <balbi@ti.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
The correct way for a driver to specify the coherent DMA mask is
not to directly access the field in the struct device, but to use
dma_set_coherent_mask(). Only arch and bus code should access this
member directly.
Convert all direct write accesses to using the correct API.
Use the wrapper function for retrieving the platform data instead of
accessing dev->platform_data directly.
We want these fixes.
'ehci_orion_dt_ids' is always compiled in. Hence use of
of_match_ptr is unnecessary.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Cc: Tzachi Perelstein <tzachi@marvell.com>
Many USB host drivers contain code such as:
if (!pdev->dev.dma_mask)
pdev->dev.dma_mask = &tegra_ehci_dma_mask;
... where tegra_ehci_dma_mask is a global. I suspect this code originated
in commit 4a53f4e "USB: ehci-tegra: add probing through device tree" and
was simply copied everywhere else.
This works fine when the code is built-in, but can cause a crash when the
code is in a module. The first module load sets up the dma_mask pointer,
but if the module is removed and re-inserted, the value is now non-NULL,
and hence is not updated to point at the new location, and hence points
at a stale location within the previous module load address, which in
turn causes a crash if the pointer is de-referenced.
The simplest way of solving this seems to be to copy the code from
ehci-platform.c, which uses the coherent_dma_mask as the target for the
dma_mask pointer.
Suggested-by: Arnd Bergmann <arnd@arndb.de>
Acked-by: Tony Prisk <linux@prisktech.co.nz>
Separate the Orion host controller driver from ehci-hcd host
code into its own driver module because of following reason.
With the multiplatform changes in arm-soc tree, it becomes
possible to enable the mvebu platform (which uses
ehci-orion) at the same time as other platforms that require
a conflicting EHCI bus glue. At the moment, this results
in a warning like
drivers/usb/host/ehci-hcd.c:1297:0: warning: "PLATFORM_DRIVER" redefined [enabled by default]
drivers/usb/host/ehci-hcd.c:1277:0: note: this is the location of the previous definition
drivers/usb/host/ehci-orion.c:334:31: warning: 'ehci_orion_driver' defined but not used [-Wunused-variable]
and an ehci driver that only works on one of them.
With the infrastructure added by Alan Stern in patch 3e0232039
"USB: EHCI: prepare to make ehci-hcd a library module", we can
avoid this problem by turning a bus glue into a separate
module, as we do here for the orion bus glue.
An earlier version of this patch was included in 3.9 but caused
a regression there, which has subsequently been fixed.
While we are here, use the opportunity to disabiguate the two
Marvell EHCI controller implementations in Kconfig.
In V4 (arnd):
- Improve Kconfig text
In V3:
- More detail provided in commit message regarding this patch.
- Replaced hcd_name string "ehci-orion" into "orion-ehci".
- MODULE_LICENSE is GPL v2.
- In ehci_init_driver calling second argument passed as NULL instead of
ehci_orion_overrides because ehci_orion_overrides is removed.
In V2:
- Tegra patch related changes removed from this patch.
Signed-off-by: Manjunath Goudar <manjunath.goudar@linaro.org>
Tested-by: Andrew Lunn <andrew@lunn.ch>
Even if bus is not hot-pluggable, the devices can be unbound from the
driver via sysfs, so we should not be using __exit annotations on
remove() methods. The only exception is drivers registered with
platform_driver_probe() which specifically disables sysfs bind/unbind
attributes.
This snuck in from a different tree during the merge and needs to be
removed.
Cc: Alan Stern <stern@rowland.harvard.edu>
Pull ARM SoC device tree conversions and enablement from Olof Johansson:
"Continued device tree conversion and enablement across a number of
platforms; Kirkwood, tegra, i.MX, Exynos, zynq and a couple of other
smaller series as well.
ux500 has seen continued conversion for platforms. Several platforms
have seen pinctrl-via-devicetree conversions for simpler
multiplatform. Tegra is adding data for new devices/drivers, and
Exynos has a bunch of new bindings and devices added as well.
So, pretty much the same progression in the right direction as the
last few releases."
Fix up conflicts as per Olof.
* tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (185 commits)
ARM: ux500: Rename dbx500 cpufreq code to be more generic
ARM: dts: add missing ux500 device trees
ARM: ux500: Stop registering the PCM driver from platform code
ARM: ux500: Move board specific GPIO info out to subordinate DTS files
ARM: ux500: Disable the MMCI gpio-regulator by default
ARM: Kirkwood: remove kirkwood_ehci_init() from new boards
ARM: Kirkwood: Add support LED of OpenBlocks A6
ARM: Kirkwood: Convert to EHCI via DT for OpenBlocks A6
ARM: kirkwood: Add NAND partiton map for OpenBlocks A6
ARM: kirkwood: Add support second I2C bus and RTC on OpenBlocks A6
ARM: kirkwood: Add support DT of second I2C bus
ARM: kirkwood: Convert mplcec4 board to pinctrl
ARM: Kirkwood: Convert km_kirkwood to pinctrl
ARM: Kirkwood: support 98DX412x kirkwoods with pinctrl
ARM: Kirkwood: Convert IX2-200 to pinctrl.
ARM: Kirkwood: Convert lsxl boards to pinctrl.
ARM: Kirkwood: Convert ib62x0 to pinctrl.
ARM: Kirkwood: Convert GoFlex Net to pinctrl.
ARM: Kirkwood: Convert dreamplug to pinctrl.
ARM: Kirkwood: Convert dockstar to pinctrl.
Based on previous work by Michael Walle and Jason Cooper.
Made their work actually work, which required added interrupt from DT
and auxdata, along with setting the dma_mask, which DT does not
currently do.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Cc: Peter Korsgaard <jacmet@sunsite.dk>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Li Yang <leoli@freescale.com>
Cc: Geoff Levand <geoff@infradead.org>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Cc: Olav Kongas <ok@artecdesign.ee>
Cc: Lennert Buytenhek <kernel@wantstofly.org>
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Kukjin Kim <kgene.kim@samsung.com>
This patch (as1623) removes the ehci_port_power() routine and all the
places that call it. There's no reason for ehci-hcd to change the
port power settings; the hub driver takes care of all that stuff.
There is one exception: When the controller is resumed from
hibernation or following a loss of power, the ports that are supposed
to be handed over to a companion controller must be powered on first.
Otherwise the handover won't work. This process is not visible to the
hub driver, so it has to be handled in ehci-hcd.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc into fixes
A collection of warning fixes on non-ARM code from Arnd Bergmann:
* 'testing/driver-warnings' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: s3c: mark s3c2440_clk_add as __init_refok
spi/s3c64xx: use correct dma_transfer_direction type
pcmcia: sharpsl: don't discard sharpsl_pcmcia_ops
USB: EHCI: mark ehci_orion_conf_mbus_windows __devinit
mm/slob: use min_t() to compare ARCH_SLAB_MINALIGN
SCSI: ARM: make fas216_dumpinfo function conditional
SCSI: ARM: ncr5380/oak uses no interrupts
The __devinit section is going away soon, but while it's
still there, we get a correct warning about
ehci_orion_conf_mbus_windows being discarded before
its caller, so it should be marked __devinit rather than
__init.
Without this patch, building dove_defconfig results in:
WARNING: drivers/usb/host/built-in.o(.devinit.text+0x8a4): Section mismatch in reference from the function ehci_orion_drv_probe() to the function .init.text:ehci_orion_conf_mbus_windows()
The function __devinit ehci_orion_drv_probe() references
a function __init ehci_orion_conf_mbus_windows().
If ehci_orion_conf_mbus_windows is only used by ehci_orion_drv_probe then
annotate ehci_orion_conf_mbus_windows with a matching annotation.
Cc: linux-usb@vger.kernel.org
Platform data for device drivers should be defined in
include/linux/platform_data/*.h, not in the architecture
and platform specific directories.
This moves such data out of the orion include directories
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Vinod Koul <vinod.koul@intel.com>
Cc: Dan Williams <djbw@fb.com>
Cc: Bryan Wu <bryan.wu@canonical.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Chris Ball <cjb@laptop.org>
Cc: Liam Girdwood <lrg@ti.com>
Cc: Jaroslav Kysela <perex@perex.cz>
Cc: Takashi Iwai <tiwai@suse.de>
Pull ARM SoC fixes from Olof Johansson:
"A mixed bag of fixes, some for merge window fallout (tegra, MXS), and
a short series of fixes for marvell platforms that didn't make it in
before 3.5."
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: mxs: fix compile error caused by prom_update_property change
ARM: dt: tegra trimslice: enable USB2 port
ARM: dt: tegra trimslice: add vbus-gpio property
ARM: vt8500: Add maintainer for VT8500 architecture
ARM: Kirkwood: Replace mrvl with marvell
ARM: Orion: fix driver probe error handling with respect to clk
ARM: Dove: Fixup ge00 initialisation
ARM: Kirkwood: Fix PHY disable clk problems
ARM: Kirkwood: Ensure runit clock always ticks.
ARM: versatile: Don't use platform clock for Integrator & VE
ARM: tegra: harmony: add regulator supply name and its input supply
The clk patches added code to get and enable clocks in the
respective driver probe functions. If the probe function failed
for some reason after enabling the clock, the clock was not
disabled again in many cases.
Signed-off-by: Simon Baatz <gmbnomis@gmail.com>
Signed-off-by: Andrew Lumm <andrew@lunn.ch>
The ehci_setup() require the pointer of usb_hcd.
Passing the correct pointer in place of ehci_hcd
pointer.
This is side effect of change:
commit 1a49e2ac9651df7349867a5cf44e2c83de1046af
Author: Alan Stern <stern@rowland.harvard.edu>
EHCI: centralize controller initialization
[Although I checked for this specifically, obviously I missed some of
the calls. In addition to the mistake in ehci-tegra.c that Laxman
fixed here, the same thing needs to be fixed in ehci-orion.c and
ehci-xls.c. -- Alan Stern]
This patch (as1564c) converts the EHCI platform drivers to use the
central ehci_setup() routine for generic controller initialization
rather than each having its own idiosyncratic approach.
The major point of difficulty lies in ehci-pci's many vendor- and
device-specific workarounds. Some of them have to be applied before
calling ehci_setup() and some after, which necessitates a fair amount
of code motion. The other platform drivers require much smaller
changes.
One point not addressed by the patch is whether ports should be
powered on or off following initialization. The different drivers
appear to handle this pretty much at random. In fact it shouldn't
matter, because the hub driver turns on power to all ports when it
binds to the root hub. Straightening that out will be left for
another day.
Not all platforms support gating the clock, so it is not an error if
the clock does not exist. However, if it does exist, we should
enable/disable it as appropriate.
Tested-by: Jamie Lentin <jm@lentin.co.uk>
Signed-off-by: Mike Turquette <mturquette@linaro.org>
Use an getter function in plat-orion/addr-map.c to get the address map
structure, rather than pass it to drivers in the platform_data
structures. When the drivers are built for none orion platforms, a
dummy function is provided instead which returns NULL.
Tested-by: Michael Walle <michael@walle.cc>
Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
This flag is a NOOP and can be removed now.
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
The two first HC capability registers (CAPLENGTH and HCIVERSION)
are defined as one 8-bit and one 16-bit register. Most HC
implementations have selected to treat these registers as part
of a 32-bit register, giving the same layout for both big and
small endian systems.
This patch adds a new quirk, big_endian_capbase, to support
controllers with big endian register interfaces that treat
HCIVERSION and CAPLENGTH as individual registers.
Signed-off-by: Jan Andersson <jan@gaisler.com>
TDI driver does the ehci_reset in their reset callback.
Don't reset in ehci_run because configuration settings done in
platform driver will be reset.
This will allow to make msm use ehci_run.
Signed-off-by: Matthieu CASTET <castet.matthieu@parrot.com>
Use resource_size().
Cc: David Brownell <dbrownell@users.sourceforge.net>
I noticed that USB initialization didn't setup correctly on my kirkwood
based board (OpenRD base) if I hadn't initialized USB in U-boot first.
The error message looks like this:
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
orion-ehci orion-ehci.0: Marvell Orion EHCI
orion-ehci orion-ehci.0: new USB bus registered, assigned bus number 1
orion-ehci orion-ehci.0: can't setup
orion-ehci orion-ehci.0: USB bus 1 deregistered
orion-ehci orion-ehci.0: init orion-ehci.0 fail, -110
orion-ehci: probe of orion-ehci.0 failed with error -110
which is caused by ehci_halt() timing out in the handshake() call. I
noticed that U-boot does a reset before calling handshake(), so this
patch does the same thing for Linux. USB now works for me.
Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net>
Acked-by: Nicolas Pitre <nico@marvell.com>
This patch (as1256) changes ehci-hcd and all the other drivers in the
EHCI family to make use of the new clear_tt_buffer callbacks. When a
Clear-TT-Buffer request is in progress for a QH, the QH is not allowed
to be linked into the async schedule until the request is finished.
At that time, if there are any URBs queued for the QH, it is linked
into the async schedule.
Cc: stable <stable@kernel.org>
This patch (as1245) fixes a bug in ehci-hcd. When an URB is queued
for an endpoint whose QH is already in the LINKED state, the QH
doesn't get refreshed. As a result, if usb_clear_halt() was called
during the time that the QH was linked but idle, the data toggle value
in the QH doesn't get reset.
The symptom is that after a clear_halt, data gets lost and transfers
time out. This problem is starting to show up now because the
"ehci-hcd unlink speedups" patch causes QHs with no queued URBs to
remain linked for a suitable time.
The patch utilizes the new endpoint_reset mechanism to fix the
problem. When an endpoint is reset, the new method forcibly unlinks
the QH (if necessary) and safely updates the toggle value. This
allows qh_update() to be simplified and avoids using usb_device's
toggle bits in a rather unintuitive way.
CC: David Brownell <david-b@pacbell.net>
Tested-by: David <david@unsolicited.net>
A pointer to ehci_orion_drv_probe is passed to the core via
platform_driver_register and so the function must not disappear when the
.init sections are discarded. Otherwise (if also having HOTPLUG=y)
unbinding and binding a device to the driver via sysfs will result in an
oops as does a device being registered late.
An alternative to this patch is using platform_driver_probe instead of
platform_driver_register plus removing the pointer to the probe function
from the struct platform_driver.
Cc: Ronen Shitrit <rshitrit@marvell.com>
Cc: Lennert Buytenhek <buytenh@marvell.com>
Cc: David Brownell <david-b@pacbell.net>
Cc: Nicolas Pitre <nico@marvell.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
The Orion ehci driver serves the Orion, kirkwood and DD Soc families.
Since each of those integrate a different USB phy we should have the
ability to use few initialization sequences or to leave the boot loader
phy settings as is.
Signed-off-by: Ronen Shitrit <rshitrit@marvell.com>
This patch performs the equivalent include directory shuffle for
plat-orion, and fixes up all users.
Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
The bus_id field is going away, use the dev_name() function instead.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
This patch (as1096) fixes an annoying problem: When a full-speed or
low-speed device is plugged into an EHCI controller, it fails to
enumerate at high speed and then is handed over to the companion
controller. But usbcore logs a misleading and unwanted error message
when the high-speed enumeration fails.
The patch adds a new HCD method, port_handed_over, which asks whether
a port has been handed over to a companion controller. If it has, the
error message is suppressed.
This patch (as1095) cleans up the HCD glue and several of the EHCI
bus-glue files. The ehci->is_tdi_rh_tt flag is redundant, since it
means the same thing as the hcd->has_tt flag, so it is removed and the
other flag used in its place.
Some of the bus-glue files didn't get the relinquish_port method added
to their hc_driver structures. Although that routine currently
doesn't do anything for controllers with an integrated TT, in the
future it might. So the patch adds it where it is missing.
Lastly, some of the bus-glue files have erroneous entries for their
hc_driver's suspend and resume methods. These method pointers are
specific to PCI and shouldn't be used otherwise.
(The patch also includes an invisible whitespace fix.)
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
Commit 7329e211b987a493cbcfca0e98c60eb108ab42df ("USB: root hubs don't
lie about their number of TTs") requires the various platform EHCI
glue modules to set ->has_tt if the root hub has a Transaction
Translator.
The Orion EHCI root hub does have a Transaction Translator, so set
->has_tt in ehci_orion_setup(). This fixes oopsing on plugging in a
low speed device.
