path: root/drivers/usb/host/ehci-ppc-of.c
2012-08-10drivers/usb/host/ehci-ppc-of.c: use devm_ functionsJulia Lawall
The various devm_ functions allocate memory that is released when a driver detaches. This patch uses these functions for data that is allocated in the probe function of a platform device and is only freed in the remove function. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-09EHCI: centralize controller initializationAlan Stern
This patch (as1564c) converts the EHCI platform drivers to use the central ehci_setup() routine for generic controller initialization rather than each having its own idiosyncratic approach. The major point of difficulty lies in ehci-pci's many vendor- and device-specific workarounds. Some of them have to be applied before calling ehci_setup() and some after, which necessitates a fair amount of code motion. The other platform drivers require much smaller changes. One point not addressed by the patch is whether ports should be powered on or off following initialization. The different drivers appear to handle this pretty much at random. In fact it shouldn't matter, because the hub driver turns on power to all ports when it binds to the root hub. Straightening that out will be left for another day. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-03USB: EHCI: Support controllers with big endian capability regsJan Andersson
The two first HC capability registers (CAPLENGTH and HCIVERSION) are defined as one 8-bit and one 16-bit register. Most HC implementations have selected to treat these registers as part of a 32-bit register, giving the same layout for both big and small endian systems. This patch adds a new quirk, big_endian_capbase, to support controllers with big endian register interfaces that treat HCIVERSION and CAPLENGTH as individual registers. Signed-off-by: Jan Andersson <jan@gaisler.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-28dt/usb: Eliminate users of of_platform_{,un}register_driverGrant Likely
Get rid of users of of_platform_driver in drivers/usb. The of_platform_{,un}register_driver functions are going away, so the users need to be converted to using the platform_bus_type directly. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-09-03USB: ehci-ppc-of: problems in unwindDan Carpenter
The iounmap(ehci->ohci_hcctrl_reg); should be the first thing we do because the ioremap() was the last thing we did. Also if we hit any of the goto statements in the original code then it would have led to a NULL dereference of "ehci". This bug was introduced in: 796bcae7361c "USB: powerpc: Workaround for the PPC440EPX USBH_23 errata [take 3]" I modified the few lines in front a little so that my code didn't obscure the return success code path. Signed-off-by: Dan Carpenter <error27@gmail.com> Reviewed-by: Grant Likely <grant.likely@secretlab.ca> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-06of/device: Replace struct of_device with struct platform_deviceGrant Likely
of_device is just an alias for platform_device, so remove it entirely. Also replace to_of_device() with to_platform_device() and update comment blocks. This patch was initially generated from the following semantic patch, and then edited by hand to pick up the bits that coccinelle didn't catch. @@ @@ -struct of_device +struct platform_device Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: David S. Miller <davem@davemloft.net>
2010-05-22of: Remove duplicate fields from of_platform_driverGrant Likely
.name, .match_table and .owner are duplicated in both of_platform_driver and device_driver. This patch is a removes the extra copies from struct of_platform_driver and converts all users to the device_driver members. This patch is a pretty mechanical change. The usage model doesn't change and if any drivers have been missed, or if anything has been fixed up incorrectly, then it will fail with a compile time error, and the fixup will be trivial. This patch looks big and scary because it touches so many files, but it should be pretty safe. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Sean MacLennan <smaclennan@pikatech.com>
2010-05-18of: Always use 'struct device.of_node' to get device node pointer.Grant Likely
The following structure elements duplicate the information in 'struct device.of_node' and so are being eliminated. This patch makes all readers of these elements use device.of_node instead. (struct of_device *)->node (struct dev_archdata *)->prom_node (sparc) (struct dev_archdata *)->of_node (powerpc & microblaze) Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-03-02USB: Convert concatenated __FILE__ to %s, __FILE__Joe Perches
Reduces string space a bit Neaten a macro redefine of dbg Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02USB host: make Open Firmware device id constantNémeth Márton
The match_table field of the struct of_device_id is constant in <linux/of_platform.h> so it is worth to make the initialization data also constant. The semantic match that finds this kind of pattern is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ disable decl_init,const_decl_init; identifier I1, I2, x; @@ struct I1 { ... const struct I2 *x; ... }; @s@ identifier r.I1, y; identifier r.x, E; @@ struct I1 y = { .x = E, }; @c@ identifier r.I2; identifier s.E; @@ const struct I2 E[] = ... ; @depends on !c@ identifier r.I2; identifier s.E; @@ + const struct I2 E[] = ...; // </smpl> Signed-off-by: Németh Márton <nm127@freemail.hu> Cc: Julia Lawall <julia@diku.dk> Cc: cocci@diku.dk Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-12USB: EHCI: use the new clear_tt_buffer interfaceAlan Stern
This patch (as1256) changes ehci-hcd and all the other drivers in the EHCI family to make use of the new clear_tt_buffer callbacks. When a Clear-TT-Buffer request is in progress for a QH, the QH is not allowed to be linked into the async schedule until the request is finished. At that time, if there are any URBs queued for the QH, it is linked into the async schedule. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15USB: EHCI: update toggle state for linked QHsAlan Stern
This patch (as1245) fixes a bug in ehci-hcd. When an URB is queued for an endpoint whose QH is already in the LINKED state, the QH doesn't get refreshed. As a result, if usb_clear_halt() was called during the time that the QH was linked but idle, the data toggle value in the QH doesn't get reset. The symptom is that after a clear_halt, data gets lost and transfers time out. This problem is starting to show up now because the "ehci-hcd unlink speedups" patch causes QHs with no queued URBs to remain linked for a suitable time. The patch utilizes the new endpoint_reset mechanism to fix the problem. When an endpoint is reset, the new method forcibly unlinks the QH (if necessary) and safely updates the toggle value. This allows qh_update() to be simplified and avoids using usb_device's toggle bits in a rather unintuitive way. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: David Brownell <david-b@pacbell.net> Tested-by: David <david@unsolicited.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-07USB: powerpc: Workaround for the PPC440EPX USBH_23 errata [take 3]Vitaly Bordug
A published errata for ppc440epx states, that when running Linux with both EHCI and OHCI modules loaded, the EHCI module experiences a fatal error when a high-speed device is connected to the USB2.0, and functions normally if OHCI module is not loaded. There used to be recommendation to use only hi-speed or full-speed devices with specific conditions, when respective module was unloaded. Later, it was observed that ohci suspend is enough to keep things going, and it was turned into workaround, as explained below. Quote from original descriprion: The 440EPx USB 2.0 Host controller is an EHCI compliant controller. In USB 2.0 Host controllers, each EHCI controller has one or more companion controllers, which may be OHCI or UHCI. An USB 2.0 Host controller will contain one or more ports. For each port, only one of the controllers is connected at any one time. In the 440EPx, there is only one OHCI companion controller, and only one USB 2.0 Host port. All ports on an USB 2.0 controller default to the companion controller. If you load only an ohci driver, it will have control of the ports and any deviceplugged in will operate, although high speed devices will be forced to operate at full speed. When an ehci driver is loaded, it explicitly takes control of the ports. If there is a device connected, and / or every time there is a new device connected, the ehci driver determines if the device is high speed or not. If it is high speed, the driver retains control of the port. If it is not, the driver explicitly gives the companion controller control of the port. The is a software workaround that uses Initial version of the software workaround was posted to linux-usb-devel: http://www.mail-archive.com/linux-usb-devel@lists.sourceforge.net/msg54019.html and later available from amcc.com: http://www.amcc.com/Embedded/Downloads/download.html?cat=1&family=15&ins=2 The patch below is generally based on the latter, but reworked to powerpc/of_device USB drivers, and uses a few devicetree inquiries to get rid of (some) hardcoded defines. Signed-off-by: Vitaly Bordug <vitb@kernel.crashing.org> Signed-off-by: Stefan Roese <sr@denx.de> Cc: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-29USB: EHCI: suppress unwanted error messagesAlan Stern
This patch (as1096) fixes an annoying problem: When a full-speed or low-speed device is plugged into an EHCI controller, it fails to enumerate at high speed and then is handed over to the companion controller. But usbcore logs a misleading and unwanted error message when the high-speed enumeration fails. The patch adds a new HCD method, port_handed_over, which asks whether a port has been handed over to a companion controller. If it has, the error message is suppressed. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: David Brownell <david-b@pacbell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-29USB: EHCI: fix up root-hub TT messAlan Stern
This patch (as1095) cleans up the HCD glue and several of the EHCI bus-glue files. The ehci->is_tdi_rh_tt flag is redundant, since it means the same thing as the hcd->has_tt flag, so it is removed and the other flag used in its place. Some of the bus-glue files didn't get the relinquish_port method added to their hc_driver structures. Although that routine currently doesn't do anything for controllers with an integrated TT, in the future it might. So the patch adds it where it is missing. Lastly, some of the bus-glue files have erroneous entries for their hc_driver's suspend and resume methods. These method pointers are specific to PCI and shouldn't be used otherwise. (The patch also includes an invisible whitespace fix.) Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: David Brownell <dbrownell@users.sourceforge.net>
2008-02-01USB: add ehci-ppc-of bus glue (device-tree aware)Valentine Barshak
This adds device-tree-aware ehci-ppc-of driver. The code is based on the ehci-ppc-soc driver by Stefan Roese <sr@denx.de>. Signed-off-by: Valentine Barshak <vbarshak@ru.mvista.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
