Now that this is DRD, it doesn't make sense to keep it under
drivers/usb/host.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
Configuring the mode of operation of port 1 doesn't belong to the HCD
code, as it's related to the soon to come UDC support. Move the
configuration to core code.
Although the corresponding register is part of the HCD register space,
processor bus initialization is not specific to the HCD. To prepare for
device controller support, move bus interface initialization to core
code.
Reviewed-by: Felipe Balbi <balbi@ti.com>
Move core device initialization to a central location in order to share
it with the device mode implementation.
The isp1760-rhcd.h header contains PTD constants and structures only
useful for the HCD implementation. It also contains register definitions
that will be needed by common code when implementing support for the
ISP1761 device controller, but doesn't contain the isp1760_hcd structure
definition that will also be used by common code.
Move definitions to the right location and create an isp1760-regs.h to
store register definitions. No change other than moving definitions and
modifying indentation is performed.
The slotinfo and memory_chunk structures are specific to the driver and
defined in a header file. Prefix them with isp1760_ to avoid namespace
clashes.
Allocate the driver private data structure manually instead of using the
usb_hcd private space. This will allow skipping hcd registration for the
isp1761 when used in device mode only.
This simplifies error and remove code paths.
The function takes quite a few arguments, passing the resource pointer
instead of the start address and length simplifies it a bit.
The argument is unused, remove it.
The two functions are specific to the driver but have very generic
names, subject to collisions. Rename them.
The glue code probe functions don't need to access the hcd structure
anymore. Modify isp1760_register to return an integer error code instead
of the hcd pointer.
Don't duplicate *_set_drvdata calls in glue code.
The removal cleanup code is duplicated between the different bus glues.
Move it to a central location.
Switching to the managed gpio descriptor API simplifies both error and
cleanup code paths (by removing the need to free the gpio) and runtime
code (by removing manual handling of the active low flag). It also
permits handling the reset gpio entirely from within the HCD code,
sharing it between the different glue layers.
Having switched over all of the users of CONFIG_PM_RUNTIME to use
CONFIG_PM directly, turn the latter into a user-selectable option
and drop the former entirely from the tree.
Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org>
Acked-by: Kevin Hilman <khilman@linaro.org>
USB hub has started to use a workqueue instead of kthread. Let's update
the documentation and comments here and there.
This patch mostly just replaces "khubd" with "hub_wq". There are only few
exceptions where the whole sentence was updated. These more complicated
changes can be found in the following files:
Documentation/usb/hotplug.txt
drivers/net/usb/usbnet.c
drivers/usb/core/hcd.c
drivers/usb/host/ohci-hcd.c
drivers/usb/host/xhci.c
Signed-off-by: Petr Mladek <pmladek@suse.cz>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Individual controller driver has different requirement for wakeup
setting, so move it from core to itself. In order to align with
current etting the default wakeup setting is enabled (except for
chipidea host).
Pass compile test with below commands:
make O=outout/all allmodconfig
make -j$CPU_NUM O=outout/all drivers/usb
Signed-off-by: Peter Chen <peter.chen@freescale.com>
Commit 84ebc10294a3d7be4c66f51070b7aedbaa24de9b (USB: remove
CONFIG_USB_SUSPEND option) failed to remove all of the usages of
USB_SUSPEND throughout the kernel. This patch (as1677) removes the
remaining instances of that symbol.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Fix two problems detected by the sparse code analyser:
|drivers/usb/host/isp1760-hcd.c:935:6: warning: symbol 'schedule_ptds' was not declared. Should it be static?
|drivers/usb/host/isp1760-hcd.c:1288:6: warning: symbol 'errata2_function' was not declared. Should it be static?
Signed-off-by: Arvid Brodin <arvid.brodin@xdin.com>
Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
After packetize_urb was called, we could still run into an error path
and will not hand over the prepared qtd to the qtd_list. Make sure to
free the prepared qtd in that case to avoid memory leaks.
Signed-off-by: Michael Grzeschik <m.grzeschik@pengutronix.de>
Make sure that dequeued urbs get handled first
by collect_qtds. To achieve that we better move them
up to the head in the qh list.
This for instance fixes hanging serial devices, which wait
for dequeued urbs to properly close their device node.
If DEBUG is defined, the kmem_cache_create call a
WARN_ON if the name of the cache uses a space.
This fixes a memory leak reported by Catalin Marinas:
schedule_ptds() is called from isp1760_irq() and removes the qh from the
controlqhs queue but ep->hcpriv still points to the qh and therefore it is not
freed.
Shortly after this, the isp1760_endpoint_disable() function sets ep->hcpriv to
NULL and calls schedule_ptds() but since the corresponding qh is no longer in
the queue, it is simply forgotten and reported by kmemleak.
With this patch, the qh is always freed at endpoint_disable, instead, and the
corresponding entry removed from the queue head list.
While I was at it, I also replaced the lines in isp1760_endpoint_disable()
that removed remaining qtds from the qh with a WARN_ON check for non-empty qh,
in line with earlier comments from Alan Stern (linux-usb list, 2011-07-20).
Signed-off-by: Arvid Brodin <arvid.brodin@enea.com>
Tested-by: Catalin Marinas <catalin.marinas@arm.com>
Small code refactoring to ease the real fix in patch #2.
Properly triggering the reset wire is necessary with the ISP1761 used
on Terasic DE4 Altera-FPGA boards using a NIOS2 processor, for example.
This is an optional implementation for the OF binding only. The other
bindings just pass an invalid GPIO to the isp1760_register() routine.
Example, usage in DTS:
gpios = <&pio_isp1761rst_0 0 1>;
to point to a GPIO controller from within the ISP1761 node: GPIO 0, active low.
Signed-off-by: Joachim Foerster <joachim.foerster@missinglinkelectronics.com>
When a low or full speed urb in progress is unlinked (or some other error
occurs), the buffer in the transaction translator (part of the hub) might end
up in an inconsistent state. This can make all further low and full speed
transactions fail, unless the buffer is cleared.
The bug can be seen when running the usbtest unlink tests as "set altsetting
to 0 failed, -110", and gets fixed by this patch.
1) A bug in the usage of time_after() in errata2_function().
2) Clear done_maps just prior to starting a new transfer in
start_bus_transfer(), instead of just after, when done_map bits might have
been validly set by the started transfer.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
... and some small code style fixes.
Errata 2 for the isp1760 explains that the chip sometimes does not issue
interrupts when an ATL (bulk or control) transfer is completed. There are
several issues with the current work-around (SOF interrupts) for this:
1) It seems the chip sometimes does not even set the done bit for a
completed transfer, in which case SOF interrupts does not solve
the problem since we still check the done map to find out which
transfer descriptors to handle.
2) The above point seems to happen only when ATL and SOF interrupts
are enabled at the same time. However, disabling ATL interrupts
increases the latency between transfer completion and handling.
This is very noticeable in the testusb suite, which take several
minutes more to run with ATL interrupts disabled.
This patch removes the code to switch on SOF interrupts, and instead
use a kernel timer to periodically check for "old" descriptors that
have their VALID and ACTIVE flags unset, indicating completion, thus
avoiding the dependency on the chip's done map (and SOF interrupts)
to find transfers affected by this HW bug.
[bigeasy@linutronix: 80 lines limit]
Like the previous patch, this patch has been split from the next one
for clarity.
Move the few lines of code in isp1760_enable_interrupts() and
isp1760_init_maps() into isp1760_run(). This makes the following patch
easier.
Both control and bulk transfers use isp1760 slots of type ATL, but the
driver unlink code for ATL slots only acts on urbs describing a bulk
transfer, letting the code for INT slots take care of the unlink instead,
which often ended up removing the interrupt transfer for root hub events
instead. That's not good, and gets fixed by this patch.
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Use skip map to avoid spurious interrupts from unlinked transfers.
Also changes to urb_dequeue() and endpoint_disable() to avoid
release of spinlock in uncertain state.
Preparation for patch #2. The function isp1760_endpoint_disable() does almost
the same thing as urb_dequeue(). In patch #2 I change these to use a common
helper function instead of calling each other - for clarity but also to
avoid releasing the spinlock while in a "questionable" state. It seemed
proper to have these functions close to each other in the code.
This patch replaces the code that handles qtds. Intead of directly allocating
chip mem and chip slot, enqueue the transfer in a list of queue heads. Use
a centralized function enqueue_qtds() to prioritize and enqueue transfers.
This removes all of the interrupt context BUG() calls when out of chip
mem or transfer slots. It also makes it possible to efficiently use the
dual-port mem on the chip for double-buffered transfers, which improve
transfer times to/from/between usb sticks by about 40 % on my HW.
With this patch it should also be possible to handle qtd scheduling outside
of the interrupt handler, for significantly improved kernel latency. I have
not implemented this since there are some locking issues which I haven't
had time to look at.
This fixes a bug in my previous (2.6.38) patch series which caused
urb->status value to be wrong after unlink (broke usbtest 11, 12).
Since we always set the OR flag for each transfer, we can just as well set all
these bits to 1 at init and be done with it. Also, HcBufferStatus can be set
at init as per the ISP1761 datasheet page 47 with no loss of performance.
This collects urb enqueue code that was spread out all over the place
into a couple of more readable functions.
This removes the "qh is 0" printout. qh == NULL if the urb has
been unlinked, so this condition is normal.
This reverts commit 5808544690300071f09eef9ab83a0fb1f60cf1cd.
To quote Richard:
I don't think this should be mainlined. It was a
misunderstanding on my part. If you see all the other hdc
drivers in the same location, they all do the same thing (i.e.
clear the interrupt status first, then do the work) that
"glitch" I think I saw was actually two back-to-back
interrupts.
Sebastian (the original author of isp1760) explained it to me a
few days after my submission.
sorry for the confusion
Cc: Richard Retanubun <RichardRetanubun@ruggedcom.com>
This patch moves the HcInterrupt register write to clear the
pending interrupt to after the isr work is done, doing this removes
glitches in the irq line.
Signed-off-by: Richard Retanubun <richardretanubun@ruggedcom.com>
Fix printk format build warning and grammar typo on same line.
drivers/usb/host/isp1760-hcd.c:300: warning: format '%lu' expects type 'long unsigned int', but argument 4 has type 'size_t'
Update the USB core to deal with USB 3.0 hubs. These hubs have a slightly
different hub descriptor than USB 2.0 hubs, with a fixed (rather than
variable length) size. Change the USB core's hub descriptor to have a
union for the last fields that differ. Change the host controller drivers
that access those last fields (DeviceRemovable and PortPowerCtrlMask) to
use the union.
Translate the new version of the hub port status field into the old
version that khubd understands. (Note: we need to fix it to translate the
roothub's port status once we stop converting it to USB 2.0 hub status
internally.)
Add new code to handle link state change status. Send out new control
messages that are needed for USB 3.0 hubs, like Set Hub Depth.
This patch is a modified version of the original patch submitted by John
Youn. It's updated to reflect the removal of the "bitmap" #define, and
change the hub descriptor accesses of a couple new host controller
drivers.
Signed-off-by: John Youn <johnyoun@synopsys.com>
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Cc: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com>
Cc: Tony Olech <tony.olech@elandigitalsystems.com>
Cc: "Robert P. J. Day" <rpjday@crashcourse.ca>
Cc: Max Vozeler <mvz@vozeler.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Cc: Rodolfo Giometti <giometti@linux.it>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Anton Vorontsov <avorontsov@mvista.com>
Cc: Sebastian Siewior <bigeasy@linutronix.de>
Cc: Lothar Wassmann <LW@KARO-electronics.de>
Cc: Olav Kongas <ok@artecdesign.ee>
Cc: Martin Fuzzey <mfuzzey@gmail.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: David Brownell <dbrownell@users.sourceforge.net>
Using a #define to redefine a common variable name is a bad thing,
especially when the #define is in a header. include/linux/usb/hcd.h
redefined bitmap to DeviceRemovable to avoid typing a long field in the
hub descriptor. This has unintended side effects for files like
drivers/usb/core/devio.c that include that file, since another header
included after hcd.h has different variables named bitmap.
Remove the bitmap #define and replace instances of it in the host
controller code. Cleanup the spaces around function calls and square
brackets while we're at it.
This fixes a problem with my previous patch series where there's a great
risk that the kernel will crash when unplugging interrupt devices from
the USB port. These lines must have got missing when I rebased the
patches from the older kernel I was working with to 2.6.37 and 2.6-next:
This fixes a bug where the kernel may crash if you unplug a USB device
that has active interrupt transfers.
Remove redundant "toggle" member from struct isp1760_qtd, and store toggle
status in struct isp1760_qh only.
Replace the period calculation for INT packets with something readable. Seems
to fix a rare bug with quickly repeated insertion/removal of several USB
devices simultaneously (hub control INT packets).
