path: root/drivers/usb/host/ohci-pnx4008.c
2010-08-11i2c: Add support for custom probe functionJean Delvare
The probe method used by i2c_new_probed_device() may not be suitable for all cases. Let the caller provide its own, optional probe function. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-03-02USB: fix I2C API usage in ohci-pnx4008.Luotao Fu
i2c_board_info doesn't contain a member called name. i2c_register_client call does not exist. Signed-off-by: Luotao Fu <l.fu@pengutronix.de> Acked-by: Jean Delvare <khali@linux-fr.org> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11USB: Add missing static markers to ohci-pnx4008Jean Delvare
I can't see any reason why these would not be static. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-07USB: Convert ohci-pnx4008 to a new-style i2c driverJean Delvare
The legacy i2c binding model will go away soon, convert ohci-pnx4008 to use the new binding model instead. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17USB: EHCI, OHCI, UHCI: remove version numbersAlan Stern
This patch (as1145) removes the essentially useless driver-version strings from ehci-hcd, ohci-hcd, and uhci-hcd. It also unifies the form of the banner lines they display upon loading and adds a missing test for usb_disabled() to ehci-hcd. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-21USB: automatically enable RHSC interruptsAlan Stern
This patch (as1069c) changes the way OHCI root-hub status-change interrupts are enabled. Currently a special HCD method, hub_irq_enable(), is called when the hub driver is finished using a root hub. This approach turns out to be subject to races, resulting in unnecessary polling. The patch does away with the method entirely. Instead, the driver automatically enables the RHSC interrupt when no more status changes are present. This scheme is safe with controllers using level-triggered semantics for their interrupt flags. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Eliminate useless includes of asm/mach-types.hRussell King
There are 43 includes of asm/mach-types.h by files that don't reference anything from that file. Remove these unnecessary includes. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-21USB: ohci-pnx4008: I2C cleanups and fixesJean Delvare
Various cleanups and fixes to the i2c code in ohci-pnx4008: * Delete empty isp1301_command. The i2c driver command implementation is optional, so there's no point in providing an empty implementation. * Give a name to isp1301_driver. I'm surprised that i2c-core accepted to register this driver at all. I've chosen "isp1301_pnx" as the name, because it's not a generic ISP1301 driver (much like the isp1301_omap driver.) We might want to make the name even more specific (but "isp1301_ohci_pnx4008" doesn't fit.) * The ISP1301 is definitely not a hardware monitoring device. * Fix a memory leak on failure in isp1301_attach. If i2c_attach_client fails, the client is not registered so isp1301_detach is never called and the i2c_client memory is lost. * Use strlcpy instead of strcpy. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Vitaly Wool <vitalywool@gmail.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21USB: usb dev_name() instead of dev->bus_idKay Sievers
The bus_id field is going away, use the dev_name() function instead. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-06Revert "USB: don't explicitly reenable root-hub status interrupts"Linus Torvalds
This reverts commit e872154921a6b5256a3c412dd69158ac0b135176. Andrey Borzenkov reports that it resulted in a totally hung machine for him when loading the OHCI driver. Extensive netconsole capture with SysRq output shows that modprobe gets stuck in ohci_hub_status_data() when probing and enabling the OHCI controller, see for example http://lkml.org/lkml/2008/7/5/236 for an analysis. The problem appears to be an interrupt flood triggered by the commit that gets reverted, and Andrey confirmed that the revert makes things work for him again. Reported-and-tested-by: Andrey Borzenkov <arvidjaar@mail.ru> Acked-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: David Brownell <david-b@pacbell.net> Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-24USB: don't explicitly reenable root-hub status interruptsAlan Stern
This patch (as1069b) changes the way OHCI root-hub status-change interrupts are enabled. Currently a special HCD method, hub_irq_enable(), is called when the hub driver is finished using a root hub. This approach turns out to be subject to races, resulting in unnecessary polling. The patch does away with the method entirely. Instead, the driver automatically enables the RHSC interrupt when no more status changes are present. This scheme is safe with controllers using level-triggered semantics for their interrupt flags. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-11usb host: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable USB HCDs, to allow re-enable auto loading. [dbrownell@users.sourceforge.net: more drivers; registration fixes] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-27i2c: Kill rogue driver IDsJean Delvare
I2C driver IDs are optional, so if you don't need one, just omit it. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-01-27i2c: normal_i2c can be made const (remaining drivers)Jean Delvare
2007-07-12USB: ohci-pnx4008: Remove unnecessary cast of return value of kzallocSuresh Jayaraman
Remove unnecessary cast of return value of kzalloc() in usb/host/ohci-pnx4008.c Signed-off-by: Suresh Jayaraman <sjayaraman@novell.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-14[PATCH] Scheduled removal of SA_xxx interrupt flags fixupsThomas Gleixner
The obsolete SA_xxx interrupt flags have been used despite the scheduled removal. Fixup the remaining users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Roland Dreier <rolandd@cisco.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Cc: Dave Airlie <airlied@linux.ie> Cc: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-07ohci: Rework bus glue integration to allow several at onceSylvain Munaut
The previous model had the module_init & module_exit function in the bus glue .c files themselves. That's a problem if several glues need to be selected at once and the driver is built has module. This case is quite common in embedded system where you want to handle both the integrated ohci controller and some extra controller on PCI. The ohci-hcd.c file now provide the module_init & module_exit and appropriate driver registering/unregistering is done conditionally, using #ifdefs. Signed-off-by: Sylvain Munaut <tnt@246tNt.com> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-20USB: ohci whitespace/comment fixupsDavid Brownell
This is an OHCI cleanup patch ... it removes a lot of erroneous whitespace (space before tab, at end of line) as well as the obsolete inline changelog. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-17USB: ohci-pnx4008 build fixesDavid Brownell
The OHCI bus glue for the Philips PNX chips is missing a few calls. - Bus suspend/resume were wrongly omitted in the original submission. - Two new calls were added since that glue was submitted: * Root hub irq enable call * Shutdown hook for usbcore Plus usb_bus.hcpriv has now been removed from usbcore. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-27USB OHCI controller support for PNX4008Vitaly Wool
inlined is the patch that adds basic support for USB OHCI controller support for PNX4008 Philips PNX4008 ARM board. Due to HW design, it depends on I2C driver for PNX4008 which I've recetnly posted to LKML and i2c at lm-sensors. Signed-off-by: Vitaly Wool <vitalywool@gmail.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
